Povratak   PC Ekspert Forum > Internet > ISP
Staro 20.04.2009., 13:00   #181
Postovi: 15,115
Alternativni fw i kako osposobit MaxTv
Ako ste poslušali savjet i spremili T-Com postavke ovo vam nije potrebno,
međutim ako ste bili brzopleti pa niste evo kako osposobiti MaxTv na alternativnom fw a bez T-Com postavki (tnx. T0mB1ll).
Kao i u prethodnim "rješenjima" koristite CLI preko Telnet - a
(za one koji neznaju o ćemu se radi: Telnet commands, start->run->cmd pa unutra tipkati)
Code:
(All commands entered are after the prompt “{admin}=>:” )
Log into the CLI interface – telnet 192.168.1.1
Username : administrator
Password : !M1PhoIAD2
2) List the atm interfaces.
{admin}=>:atm iflist
atm_Internet: dest : pvc_Internet
Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : mac
Connection State : connected
3) Add a new ATM interface called TCOM_IPTV
{admin}=>:atm ifadd intf = TCOM_IPTV
4) Verify that the new ATM interface is added
TCOM_IPTV : dest : (none)
Retry : 10 QoS : default Encaps : llc Fcs : disabled Ulp : ip
Connection State : not-connected
5) Add a new phonebook entry for VPI=0 VCI=40
{admin}=>:atm phonebook add name=atm_pvc_0_40 addr=0.40
6) Verify that the new phonebook entry is added
{admin}=>:atm phonebook list
Name Use Address
pvc_Internet 1 0.33
atm_pvc_0_40 0 0.40
7) Configure the TCOM_IPTV ATM interface
{admin}=>:atm ifconfig intf=TCOM_IPTV dest=atm_pvc_0_40 encaps=llc ulp=mac
8) Attach and connect the ATM interface
{admin}=>:atm ifattach intf=TCOM_IPTV
9) Create a new bridge interface
{admin}=>:eth bridge ifadd intf=IPTV
10) Configure the bridge to TCOM_IPTV ensure multicast filter is disabled.
{admin}=>:eth bridge ifconfig intf=IPTV dest=TCOM_IPTV mcastfilter=disabled
11) Attach the bridge connection
{admin}=>:eth bridge ifattach intf=IPTV
12) Save the configuration to flash (default filename= user.ini)
{admin}=>:config save
filename = user.ini
{admin}=>
Moguće da IPTV tj. MaxTv odmah proradi ali bi bilo pametno napravit jedan Reboot uređaja.
Staro 24.04.2009., 18:34   #182
ShAd0w_dAnCeR
ShAd0w_dAnCeR's Avatar
Lokacija: BJ/ZG
Postovi: 526
a ako ne koristim maxtv, a ocu thomsona preflashat na sluzbeni firmware, el mogu normalno ga konfigurirat preko njegovog sucelja?
takoder da li je istina da se thomsona moze preflashat tako da radi na optimu? [narucio sam wlan router+wlan stick od optime, ali za slucaj da dobijem nekog telseya il kaj ja znam kaj]
ShAd0w_dAnCeR je offline   Reply With Quote
Staro 24.04.2009., 20:07   #183
thopok
Lokacija: Splity
Postovi: 3,004
Thomson + optima???
A bar onoliko koliko to dopušta to sučelje.
Staro 12.07.2009., 21:49   #184
opasnibilly
Postovi: 3
zna li netko kako se ovom uređaju može pristupiti udaljeno?
npr kad sam imao Dlink onda sam upisao u browser ip od rutera... sad to ne pali. Tako sam mogao mjenjati postavke uređaja koji se nalazio kod mene u stanu gdje god ja bio. To mi je služilo da brzo forwardam port za remote desktop ili takve stvari...
Mora postojat način. malo je preglupo ako ovaj uređaj nema tu mogućnost..
Btw znam za Remote assistance ali to nije to. Remote assistance kad ukljucim onda se sam zgasi nakon nekog vremena.
opasnibilly je offline   Reply With Quote
Staro 12.07.2009., 22:02   #185
msvrtan
Datum registracije: Oct 2001
Postovi: 2,735
uf jesi siguran da bi to zelio?
mislim da se nemoze kod njega to nikako... naime to je zastita .. zamisli da se moze i da ti ljudi pokusavaju uci u ruter ... mislim da bi ih brzo prokleo..
stavi iza njega neki komp i spoji se na njega remote desktopom i tamo otvori browser i to napravi..
blog u beta testu
msvrtan je offline   Reply With Quote
Staro 12.07.2009., 22:06   #186
opasnibilly
Postovi: 3
pa da to bih zelio... ionako postoji šifra.
na dlinku sam mogao i to sam obilato koristio
Staro 12.07.2009., 23:20   #187
thopok
Lokacija: Splity
Postovi: 3,004
Pa ionako mu ISP pristupa.
Nije li upravo zato otvoren jedan?
I ne samo to. Također postoji više vrsta korisnika, itd....
Daljnje podešavanje je vjerojatno moguće jedino CLI-om.
Zadnje izmijenjeno od: thopok. 12.07.2009. u 23:37.
Staro 13.07.2009., 00:12   #188
opasnibilly
Postovi: 3
sumnjam da mu T-com pristupa... danas sam ga upogonio a imam ga vec par mjeseci.
intalirao sam novi firmware. neznam čemu bi oni pristupali mojem ruteru. šta imaju prckat po nejmu? firmware se ioanko nije mjenjao od 2007.
no to nije bilo moje pitanje.. nastranu ISP i sigurnost i štajaznam šta. briga me za sigurnost jer šta mi ko može? ko prvo da me neko ide zajebavat treba saznat moj ip... onda mora nekak probit sifru od rutera i sta onda? moze mi se igrat s ruterom? lol. ak je nekom tak dosadno da mu se da tak nes radit i ako to ima nekog smisla dam mu i ip i sifru i nek odere!! :P
dakle. jel se može kako? mene zanima kak da ja to napravim...
mene čudi da to nisam našao, to više manje svi ruteri imaju
Staro 13.07.2009., 23:47   #189
thopok
Lokacija: Splity
Postovi: 3,004
O tome bi se dalo raspravljat. Možda su ga prilagodili novom nijansom ljubičaste?
To bi ih moglo spriječit…
Pa očito se može kad mu i oni pristupaju…Samo ga je sad teže podesit onako kako su ga i sami podesili…Tako da bi bilo dobro proučit njihove postavke…
Pa valjda je ovaj poseban…
Staro 21.08.2009., 00:37   #190
RedScorpio
Datum registracije: Aug 2009
Lokacija: zagorje...
Postovi: 1
ovaj router sam dobil s max tv-om(onaj probni rok od 3mj), i nakon kaj smo ga odjavili, nismo vrnuli router(a i nije ko da su ga trazili )
e sad, net je normalno prek njega delal par dana i onda iz cista mira krepal(dok sam bil na moru... to mi starci rekli) i sad sam isel glet u cem je problem, i ispada da mi dns-i ne delaju (isel sam na onaj connectivity check) i to sljedeca dva: 195.29.149.197, 195.29.166.117
sad sam spojen prek drugog routera(koji nije wlan, i to je glavni prob) i nemrem pingati ove servere, ke to onda nikome ne delaju? jer sam bil i nasel gde je neko pital za nje i kao reklo se da su dobri
onda sam mislil promijeniti dns na opendns servere i to kak je ovde opisano(jer nisam nasel nigde na stranice od routera kak tam zmeniti dns-e....): http://forums.opendns.com/comments.p...&page=1#Item_2
i prvo mi se htel spojiti prek telneta, i sve sam to napravil, al kad sam se spojil na net, mi je uzel defaultne dns-e... i nakon toga se vise nisam mogel spojiti prek telneta (dal moram neke iskljuciti/ukljuciti da se mogu spojiti?)
pokusaval prek onog setup wizarda, al isto nije pomoglo, jer tam nemres upisivati dns adrese, i samo su dvije opcije, nakon cega se ni spajati na net vise nije htelo koristim isti username i pass, al mi je hitalo ili auth. failed ili disconected by the user, mislim wtf? a da mi bar nije 5min ranije to isto delalo
onda sam mislil promijeniti firmware, al to trebas cijeli net pretraziti da najdes linkove i to sam jos nasel neke UK operatore, pa nisam ni pokusaval.. e ima neko od vas link na firmware koji bi delal i kojeg bi se moglo podesiti da dela na t-comu? ili kak da podesim nove dns-e?
ponorel bum s ovim routerom... >_>
RedScorpio je offline   Reply With Quote
Staro 21.08.2009., 01:42   #191
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,598
Mislim da sam na jednoj temi, možda čak i ovoj dao linkove kako stavit novi firmware, pa malo prosurfaj
Staro 21.08.2009., 10:25   #192
Postovi: 15,115
Manualni unos DNS servera
Poznato je da automatikom dodjeljeni / prepoznati DNS - ovi kod T-Coma ne rade uvjek i najbolje. Rješenje je odabrati korištenje manualno unesenih. Također je poznato da takva podešavanja (ako su i podržana) kroz web konfig ne rade zbog ogranićenja u T-Com custom fw za ovaj uređaj. Koje DNS servere ćete koristit ovisi o vama, u ovom vodiču ću koristit stari (koji još radi) od T-Coma i OpenDNS. Više DNS by ISP.
Code:
Prvo moramo saznati ime Interface - a:
Code:
{Administrator} :dns server route list
Dobit ćete slično ovom:
Code:
DNS Server       Source            Domain            Metric       Intf     State
195.109.122.104   *                                    10       Internet     UP
195.109.61.66     *                                    10       Internet     UP
U ovom primjeru ime koje tražimo je Internet. Slijedi niz komandi kojima ćemo brisati postojeće, unjeti nove:
Code:
dns server route flush
dns server debug clear
dns server route add dns=195.29.150.3 metric=1 intf=Internet
dns server route add dns=208.67.222.222 metric=1 intf=Internet
Za provjeru dali ste dobro unjeli:
Code:
Rezultat bi trebao biti:
Code:
195.29.150.3       *                                    1       Internet     UP
208.67.222.222     *                                    1       Internet     UP
Preostaje vam snimanje postavki i izlaz iz Telnet programa:
Code:
saveall
exit
Sada slijedi test otvaranjem raznih web stranica kombinirajući one koje rade i one koje su vam prije pravile "probleme".
Staro 02.09.2009., 11:19   #193
skare
skare's Avatar
Postovi: 137
imam thomsona 780 I WL. koristim carnet duo uslugu. je li se može postaviti u router mode. može li mi netko dati link sa objašnjenjem. pročitao sam ovih 7 stranica, ali ima raznih providera. nisam našao nikog sa carnet duo. ja se spajam preko PPPOE konkecije koju sam kreirao u network connections.
uopće ne mogu ući u postavke routera sa 192.168.1.X. je li to zato što je u bridge modeu?
i7 3520M, 2.9GHz @0.841v
1x4GB Micron ddr3,12 GB Hynix ddr3 1600 MHz,
Samsung SSD 840 Pro 256 Gb, nVIDIA Quadro K1000M 2048MB, 15,6"[/QUOTE]
skare je offline   Reply With Quote
Staro 02.09.2009., 12:22   #194
Postovi: 27,876
Baci oko na temu o Iskon.Duo usluzi. Tamo se i o tome raspravljalo. btw, u Iskonove uređaje se ulazi sa 192.168.100.1
Staro 02.09.2009., 16:18   #195
skare
skare's Avatar
Postovi: 137
hvala! stalno zaboravim, ali ne mogu ući svejedno.
Staro 03.09.2009., 11:32   #196
Postovi: 15,115
Autor skare Pregled postova
Ne, zato jer mu je vjerojatno druga IP adresa. Postavi mrežne postavke na Automatic, sačekaj malo, otvori CMD, upiši ipconfig /all, pronađi mrežnu u izlistanom i pod Gateway je IP adresa routera.
Autor coconut Pregled postova
Iskon je imao neke serije routera i na 192.168.5.1 koliko se sjećam.
Staro 03.09.2009., 13:20   #197
Postovi: 27,876
Sam sam se sjetio da se i taj IP koristi. Imam stari (skoro 3g.) Thompson i otvaram ga sa 192.168.100.1.
Staro 03.09.2009., 15:22   #198
skare
skare's Avatar
Postovi: 137
Autor Nikky Pregled postova
da u pravu si, ide sa 5. ali svejedno ne mogu ništa napraviti jer carnet ne omogućava postavke u router mode-u. tako da sam osuđen na PPPOE konekciju.
hvala na odgovoru!
Staro 03.09.2009., 16:54   #199
thopok
Lokacija: Splity
Postovi: 3,004
Pa nije se ništa novo otkrilo.
Autor vinja Pregled postova
Bubba, vidis, problem je kad sa Iskon.DUO predjes na DUO.Carnet. Tada gubis router mod, ostaje ti bridge, i moras ostvarivat pppoe konekciju - to je jedini nacin. I to, iako iskon tvrdi drukcije, mozes istovremeno ostvarit samo jednu konekciju. I u mene je Thompson 780 - i sad sam uzeo wireless router (158kn u kvarka TP Link WR340G - radi savrseno) - da mi se radi pppoe i da se moja 3 kompa mogu spajati na net (bez da jedan glumi server).
@Gabre - evo kako vidis, mozes...samo ti treba wireless router (ja kupio ovaj gore u Kvarka, i sve radi glatko)
ali su neki isto tako prijavili da takvo ograničenje ne postoji kod SX763.
Staro 11.09.2009., 14:19   #200
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 3,438
zna netko dal se moze kako podesit ovog thomsona da se sam automatski reboot-a svaki dan u neko odredeno vrijeme?
ta opcija dolazi sa novim simensovim ruterima pa reko ako netko zna caku za ovog nebi bilo na odmet
Staro 13.09.2009., 21:58   #201
vranjba
vranjba's Avatar
Postovi: 564
Autor mali david Pregled postova
Ima nekoliko rješenja, a najjednostavnije je ako se max-tv ne koristi, onda se može ići na ponovnu konfiguraciju (setup) i odabrati nešto kao single pay (ima još onaj duo i triple - tako nešto)
Nakon te konfiguracije trebala bi sva 4 porta biti za lan.
Drugo rješenje, koje ni sam nisam probao, je preko telneta. Skine se neki telnet program, recimo Putty i mora se imati administratorski account (user name i password) Uđe se u router sa tim accountom, ukuca menu i dalje se snalazite. Tu ima SVE opcije koje postoje na tom routeru, a kojih nema u 99% firmware-a...
Dakle, onako jednostavno kao na D-linku nema, ali je moguće...
jel može netko pojasnit malo ovo za korištenje 3 ili 4 ulaza na net bez flashanja, kako se dolazi do toga, dali se ulazi sa asministrator ili user
vranjba je offline   Reply With Quote
Staro 24.09.2009., 13:00   #202
zoxter
Lokacija: Pazin
Postovi: 1
pozdrav....imam problema sa konekcijom na net prek dotičnog routera. Komp mi se uspije spojit na sam router, međutim ne može se spojit na njega, kaže mi da da je "limited or no conectivity". Koristim d-linkov usb adapter za spajanje na router, i on ima neki wizard da se spojim na router, pita me wep zaštitu, ukucam je i kaže da mi bim sad trebao bit spojen na router..međutim nije :/ takodjer ne mogu se spojit na sam router prek njegove ip adrese prek ie!
ima li tko ideju kaj krvio radim i šta da napravim?!!
zoxter je offline   Reply With Quote
Staro 24.09.2009., 14:20   #203
Postovi: 15,115
Prvo pretresi komp da nema virusa/ crviiju i ine gamadi jer se oni vole igrati mrežnim postavkama,
pročitaj smjernice i preporuke u ADSL Bibliji,
prvo osposobi mrežnu konekciju (Lan) PC <> Router,
a onda pređi na bežičnu,
koristi fiksne IP adrese.
Staro 24.09.2009., 16:46   #204
DraŽ
DraŽ's Avatar
Lokacija: Okolica Petrinje
Postovi: 886
ja sam sve iz prve uspio.
U IE upišeš 192.168.1.1. i dođeš u postavke routera, sve sam postavio, conectao se na net i dobio sam vezu na lapu tj. mogu ići na net preko wlan-a, a onaj cd/dvd od d-linka mi je nešto srao kod instaliranja, pa sam to riješio tako da windowsi sami nađu drivere na tom dvd-u. I čim se instaliralo dobio sam vezu na net.
Prema ispisu spajanja vidim da mi se barem 1-2 puta na dan disconecta s interneta tj. pukne veza, a upload je mizerno mali.
Nokia XM5800 nekada zna kada se poveže na router, resetirat ga.Vidim da i drugi imaju problema s tim routerom + nokia xm5800, ali meni se tek jedanput dogodilo.
Onaj cd od t-coma nisam ni dobio, samo neki od routera od kojeg ništ koristi.
Skylake PCIvy bridge NotebookBay Trail Tablet
CPU: Intel Core i7 6700k @ 4.5GHz, 1.27V Adaptive, LLC 5, under Scythe Mugen Max
MBO: ASUS Z170 Pro Gaming
RAM: Kingston HyperX Savage DDR4 16GB (2x8GB) 2666MHz CL13 @ 3000Mhz 14-16-16-39
GPU: Gainward Phoenix GS Nvidia GeForce GTX 1060 @ stock
SSD1: Samsung Evo 850, 250GB
SSD2: Samsung Evo 850, 250GB
HDD1: WD Blue 1TB, WD10JPVX
HDD2: WD Green 2TB, WD20EARS-
HDD3: WD Green 3TB, WD30EZRX
OPTICAL DRIVE: LG CH10LS20, Blu Ray
PSU: EVGA Supernova G2, 550W
CASE: Fractal Arc XL
VENTS: 3x Fractal 140mm, 3x Arctic Cooling F14, 140mm
OS: Win 10 Pro, 64-bit
MONITOR: DELL U2412M - 24 inch, IPS, 1920x1200
TV: Panasonic P47AS650 - 47 inch, IPS, 1920x1080, 3D + DIY Ambilight
MOUSE: FUNC MS-3 r2
KEYBOARD: Logitech G110
GAMEPAD: XBOX 360, wired
HEADPHONES: Sennheiser HD598 SE
SPEAKERS: Logitech X-530
DELL Inspiron 15R, 5520
Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
AMD Radeon 7670 + Intel HD4000
OCZ Agility 3, 120GB
15,6 inch LCD, 1366x768
6-cell baterry, 48Whr
Optical drive, 5 in 1 card reader, Bluetooth, Wifi, HDMI + VGA...
Win 10 Pro, 64-bit
ASUS Transformer T100TA
Intel Atom Z3775, 1.46GHz, Turbo 2.39GHz
Intel HD Graphics
LPDDR3, 2GB, 1066MHz
64GB eMMC
10.1 inch IPS LCD, 1366x768
2-cell, 31Whr, 9-11hr battery life
Win 10 Home, 32-bit
DraŽ je offline   Reply With Quote
Staro 15.10.2009., 14:41   #205
Medek
Lokacija: varaždin
Postovi: 2
Pozdrav,
nadam se da sam našao pravo mjesto za sljedeće pitanje:
Imam Thomson st780i od t-coma koji mi već jedno vrijeme ne radi, naime, svijetli mi power lampica konstantno crveno, te se baš ništa drugo ne dešava što god uključio otraga. Probao i reset, ali niš se ne događa.
Jel to znak da se skroz pokvario ili neka software grška?? KAko da ispitam radi li uopće ?
Medek je offline   Reply With Quote
Staro 15.10.2009., 15:34   #206
Postovi: 27,876
Zovi službu za korisnike i objasni im prroblem. Oni ga daljinski mogu iskontrolirati i resetirati. Moja pretpostavka je da je riknuo.
Staro 15.10.2009., 16:12   #207
thopok
Lokacija: Splity
Postovi: 3,004
S takvim uređajem ne mogu oni išta učinit…
Staro 15.10.2009., 16:19   #208
Medek
Lokacija: varaždin
Postovi: 2
Ma problemi s ovim uređajem od samog početka. Sad nakon neznam kojeg pokušaja resetiranja svijetli mi power narančasto i žmirka ethernet zeleno. Uglavnom, komp ga nikako ne prepoznaje.
Staro 28.10.2009., 22:38   #209
DudeQ
DudeQ's Avatar
Lokacija: The Netherlands
Postovi: 3
Pozdrav, Postoji li mogucnost da netko zna za administratorski username & pass koji je u ST780WL eventualno mozda ujezdio novim remote updatom od strane t-com? Posto ovaj --> administrator / !M1PhoIAD2, ocito ne radi, a samo obicnim 'user'-skim se naravno nemre nis zeljeno i potrebno napraviti. Unaprijed zahvaljujem na trudu a akoBogda i trazenom odgovoru.
DudeQ je offline   Reply With Quote
Staro 03.12.2009., 10:04   #210
Renci
Renci's Avatar
Lokacija: Križevci
Postovi: 837
Autor Jole911 Pregled postova
Evo kome treba FW od T-coma 3Play IPTV radi
FW-Thomson byT-COM
Sretno
Molio bih ponovni upload GK firmwarea ili link gdje da ga skinem...
Nemogu ga nigdje naci, hvala.
Intel C2D E6750 @ 3400MHz (AC Freezer 7 Pro)
Asus P5K Premium
2 x 1GB OCZ Platinum XTC @ 1100MHz
XFX 8800GT Alpha Dog Edition 512DDR3
2 x WD 1GB
Enermax Liberty 400W (modular)
Cooler Master Centurion 5 (Black Edition)
Zalman Fan Controller ZM-MFC1 Plus
DVD-RW, CardReader
Samsung SyncMaster 2032BW
Logitech G9 + G11
Renci je offline   Reply With Quote
