Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 16.04.2008., 23:53   #1
wlcasemodding
wlcasemodding's Avatar
Postovi: 355
Problem sa php-om
Ovo je kod:
....<body>
<table width="361" height="79" border="1" cellpadding="0" cellspacing="0" bordercolor="#999999">
<tr>
<td width="297"><span class="style1">Evidencija</span></td>
<td width="64">&nbsp;</td>
<td width="70">UKUPNO:</td>
</tr>
<tr>
<td bgcolor="#CCCCCC"><span class="style1">polje1</span></td>
<td align="center" valign="middle" bgcolor="#CCCCCC">
<form id="form2" name="form2" method="post" action="">
<label>
<input name="button1" type="submit" id="Spremi1" value="Dodaj" />
</label>
</form>
if (!empty($_POST['button1'])) {
mysql_connect("localhost", "wlcasemodding", "mk123");
mysql_select_db("baza");
$a= "SELECT polje1 FROM tablica";
$b= $a+1;
"UPDATE tablica SET polje1=$b";
</td>
</table>
</body>
/html>
greška koja mi se javlja nakon uploada je:
Parse error: syntax error, unexpected $end in /home/elprohr/public_html/evidencija.php on line 41
Nikako da skužim di je greška, može ko pomoći. Tek ucim php pa sorry na mom neznanju Ono sto bi trebala ova forma raditi je da iscita vrijednost polje1 iz baze, poveca ga za 1 i ponovo spremi u bazu.
wlcasemodding je offline   Reply With Quote
Staro 17.04.2008., 21:14   #2
ejSid
Lunatic
ejSid's Avatar
Postovi: 213
koja je linija 41?
ejSid je offline   Reply With Quote
Staro 20.04.2008., 16:27   #3
immortal
Kernel panic
Postovi: 522
Mislim da bi umjesto ovoga:
Code:
$b= $a+1;
trebalo staviti ovo:
Code:
$a= mysql_query("SELECT polje1 FROM tablica");
$b= $a+1;
mysql_query("UPDATE tablica SET polje1=$b");
Uglavnom, ne možeš samo staviti mysql naredbe u php, moraš imati ovaj mysql_query.
Keyboard error or no keyboard present
Press F1 to continue, DEL to enter SETUP
immortal je offline   Reply With Quote
Staro 22.04.2008., 12:53   #4
wlcasemodding
Postovi: 355
ovo je izmjenjeni kod:
<input name="button1" type="submit" id="button1" value="Dodaj" />
$b= $a+1;
print ("$b");
kod ispiše polje1 u stranici, ali nikako da uspijem podesiti da ga updatea kada pritisnem gumb.
Staro 22.04.2008., 22:49   #5
ejSid
Lunatic
ejSid's Avatar
Postovi: 213
Za updejtanje mu trebaš reći što želiš updejtati, jer sad o nezna što da updejta.
zanči ovako:
$query = "UPDATE tablica SET
polje1 = {$b}
WHERE nešto = {nešto}";
mysql_query($query);
