14.06.2009., 21:21 | #93 | |
Postovi: 1,679
Dal je netko probal samsunga j700 odkodirati da bude za sve mreže. Ak ima neki link kak da se to sredi besplatno Citiraj:
1. First do a CUSTOM reset: *2767*2878# 2. Take a wrong network SIM and insert a half of it, so when you turn on the phone it don't detect the SIM. Very important so it won't ask for network password and shows "Insert SIM" message. 3. Now take out the battery a little so you can insert fully the SIM without turnig off the phone, at this stage the phone is still asking to "Insert SIM" with the WRONG SIM inside. 4. Make a FULL reset: *2767*3855# 5. The phone should reboot working with "wrong" sim inside. 6. Change the NCK password to 8 zeros: *7465625*638*00000000*00000000# 7. Disable network lock: #7465625*638*00000000# Zadnje izmijenjeno od: Router. 14.06.2009. u 22:47. |
15.06.2009., 16:59 | #95 |
Postovi: 1,679
21.07.2009., 16:28 | #97 |
Lokacija: Munich
Postovi: 2,203
ajde vi maheri mi recite jednu stvar.moze li se ikako maknuti onaj logo (tj natpis) operatera T mobile,tele i tako dalje na sony ericsson w880 ? fala nervira me |
21.07.2009., 16:39 | #98 | |
Lokacija: /
Postovi: 2,053
ali s tim "modom" bi se nakon 3 dana uredno zblokal tj. trebalo bi mu pol minute da ude u Menu itd. - čim sam ga maknul, sve radi ko podmazano. al eto, možda sam ja naletil na tu neefikasnu verziju |
22.07.2009., 08:10 | #99 |
MIUI HR Translator
Lokacija: Krapina
Postovi: 630
MIUI HR Translator |
22.07.2009., 12:00 | #102 |
Lokacija: Munich
Postovi: 2,203
22.07.2009., 12:27 | #103 |
Postovi: 8,918
Tu ti je objasnjen postupak rada sa XS-om > http://forum.pcekspert.com/showthread.php?t=71405
___________ HTPC: Intel Core2Duo E8500 × ATI Sapphire HD4670 HDMI × 2x 1GB DDR2 × Samsung 160GB × Lenovo Key+Mouse × Philips 49PFS5501 LED TV × Technics SA-EH780 5.1 × Windows 10 Laptop1: Lenovo x100e w/Windows 10 |
22.07.2009., 12:49 | #104 | |
Lokacija: Munich
Postovi: 2,203
24.07.2009., 22:32 | #105 |
Postovi: 161
dal se moze otkljucati (od doma) Nokia 3110 classic od t-coma. i ako moze sa kojim programom. |
