Povratak   PC Ekspert Forum > Računala > Audio, Video, DVD
Staro 19.01.2019., 04:42   #121
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 131
Xiaomi Mi Airdots Pro Earbuds - Improved Edition of Mi AirDots
Easily listen to and control your music while on the move with the Xiaomi Mi AirDots Pro. Featuring a wireless design, these in-ear headphones come with convenient touch controls, making it easy to control music and calls. Likewise, you can use the touch controls to activate voice assistants. In addition, they are compatible with both Android and iOS devices. Designed to function independently, you can even use just one of the earbuds. Moreover, the AirDots Pro last for up to ten hours on a full charge, they also take just under one hour to charge completely. Complete with noise cancelation, the earbuds allow you to make clear calls on the go. To ensure a comfortable fit, the earbuds provide silicone tips.
Product Features:
● Adopting the left and right split true wireless design, bid farewell to the wire binding, achieve true wireless.
● 7mm neodymium iron boron magnetic + titanium-plated diaphragm dynamic ring speaker unit, tri-band balance.
● ANC active noise reduction, the sound is purer and the feeling is more real.
● HD sound quality, support AAC advanced audio coding technology, more complete preservation of the original sound.
● Control music, calls, and voice assistant with a simple touch.
● Both the left and right earphones have a built-in high-sensitivity microphone for binaural call, beamforming and ENC noise reduction technology, bringing HD call quality.
● Automatic pairing, wearing the sensor, taking off the earphones will automatically pause the music.
● Magnetic contact charging, Hall magnetic switch and USB Type-C interface, faster charging.
● IPX4 waterproof so that the sweat and rain are not terrible.
● Paired with iOS and Android devices, including tablets laptops, and mobile phones.
These new wireless earphones offer a music-listening experience that is synchronized with the stereophonic, they are small and smart, the music experience is beyond imagined: https://gearvita.com/xiaomi-mi-airdo...earphones.html
Related products:
xiaomi airdots headset
qcy t1c mini wireless earphones
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 21.01.2019., 08:21   #122
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom BX10 Clip Earphones Provides All-day Comfort
Langsdom BX10 earphones connected to a mini remote control with a 3.5mm plug, the control panel allows you to adjust the volume and control the microphone. The device adopts noise reduction technology, reproduces high-quality stereo sound and powerful bass, supports voice control, gives comfortable wearing.
Product Features:
● 2-in-1 Micro USB Interface
The USB interface can be both used for battery charging and earphone connection, convenient to use.
● Magnetic Metal Earphones
With the magnet attraction design, like a necklace, you can wear it around your neck when you don't use them.
● Strong Magnetic Silicone Clip
Innovative magnetic design with silicone, which can absorb on clothing freely, easy for sporting and relaxation.
● Multifunction Buttons
All the control in your hands, 3 buttons for volume control, answer call and skip song, compatible for iPhone, iPad, Android, etc.
● Easy to Pair
Bluetooth v4.1 technology allows you to connect quickly to any smart device or PC.
● Excellent Battery Life
Charging about 2 hours, talking time up to 5 hours, standby time about 120 hours.
● Battery Capacity Display
Supports iOS phone for capacity display, to know your battery status timely.
● High Sound Quality
Low sound quality loss will be prevented and high sound resolution will be warranted by the micro USB connection.
● Wear Comfortable
With human body engineering design, comfortable fit the ear canal, more effective sound insulation to prevent leak.
The unique color and fashionable metal materials, suitable for any combination, give you a different look and possibilities: https://gearvita.com/langsdom-bx10-c...-earphone.html
You may also like:
xiaomi minimalist portable flashlight
raspberry pi 3 model a+ motherboard
Staro 22.01.2019., 05:49   #123
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Edifier M100 Wireless Bluetooth Speaker - Designed for Outdoor Use
The Edifier MP100 speaker is a fully featured ultra portable Bluetooth speaker, compatible with Bluetooth 4.0 technology and microSD functionality, gives you multiple ways to play your favourite tracks. The battery offers up to 20 hours of use, take the MP100 anywhere with its dust proof and splash proof exterior. This small but powerful speaker also acts as a speakerphone for answering calls.
Product Features:
● Portable with Clip
Made for the adventurous type, it is ultra-portable and rugged, the clip at the top is made to clip onto your belt or backpack.
● Amazing Low-frequency
Built-in proprietary skin cavity suspension technology, smaller vibration damping, brings an amazing amount of low-frequency sense.
● 4.5W Power
Uses class D amplifier, which is very efficient and has a palm-sized sound system, it has a 4.5W non-distortion power.
● Good Quality
● Silicone jacket, symbolic button, crystal texture packaging, full of quality taste.
● Bluetooth 4.0
Adopts Bluetooth 4.0 technology, which can transmit farther, connect faster, and consume less power.
● Long Lasting Battery Life
Powered by a high-quality lithium battery, fully charged and played at medium volume for up to 10 hours.
● IPX5 Waterproof
Small three defensed - waterproof, dustproof and shockproof, small wind and rain or splash of water can still make it sing loudly without any worry.
● Wide Compatiblility
Compatible with many devices such as smartphones and laptops. Using Bluetooth 4.0, connecting it to your smartphone, whether it is an iPhone, Android, or Windows phone you can use the MP100 as a speakerphone so you can take calls hands free.
M100 is specially designed to be used outside, with the small body and convenient clip, you can take it with you all the time and go wherever you want: https://gearvita.com/edifier-m100-wi...h-speaker.html
Hot sale products:
cheap xiaomi poco f1 lte 128gb
cheap xiaomi redmi note 5 64gb global version
Staro 23.01.2019., 05:35   #124
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
VITOG T12 Wireless Bluetooth Earphones with Charging Box
VITOG T12 wireless earphones features dual ear stereo design, left and right ear channel separation. You can use the headset solely, or used them in pairs of stereo mode. They weight of only 4g, mini size and 3 sizes of earcaps provide you long time wearing comfort, and guarantees stability when walking, running and more. Built-in high-sensitivity microphone, reduces ambient noises and grasps the detail of voice, ideal for in-car calling or working use. 40mAh rechargeable battery in each earphones ensures 2 hours of working time. Coming with a 280mAh charging box, which enables the earphones charging for about 3 times. The earphones are charged automatically in the charging box and stop automatically after fully charged.
Product Features:
● Comfortable and Soft Eartips
Adopt soft and environmental silicone ear caps, wearing comfortable.
● Excellent Craft
Use special technology to cover the appearance, to protect the earphones well from damage.
● Bluetooth 4.1
Bluetooth version 4.1 technology, adjusted the influence of old profile, improved compatability and stability.
● Innovative Charging Case
Equipped with a mini charging dock, convenient for personal carry, supplier the electricity with a long time when outdoor travel.
● 4g Lightweight
Mini design and light weight, no any pain and uncomfortable feeling in ear.
● Automatical Charging
Magnetic charging method of earphones automatically charging until full power, protects from over charging.
● Charging Indicator
Charger of 5V 1A or USB port both can be charged, red light will be showed during harging, blue light will be showed once full charged.
● Super Mini and Invisible
Small and exquisite shape satisfies the diversified demand.
● Noise Canceling
With the CVC6.0 noise canceling technology, you can enjoy the clear music and calls.
● Wide Compatability
The Bluetooth earphones are compatable with all kinds of Bluetooth devices such as mobile phone, ipad and so on.
VITOG T12 come with two color options, black and silver. You can wear them to do your favorite exercise without worry about them falling out: https://gearvita.com/vitog-t12-stere...earphones.html
Related products:
cheap xiaomi airdots headset
cheap lenovo air tws bluetooth earphones
Staro 24.01.2019., 07:14   #125
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
OnePlus Bullets 2T Type-C Earphones - Better Audio with a Built-in DAC
OnePlus Bullets 2T earphones continues the design adopted by the first generation of bullets earphones. The main body of the earphone is made of metal and is sprayed with 205 zircon sand. It is anodized twice to make sure that the earphones have a better texture. The wire makes less easy to knot and wrap and has a wire control function. Aramid fiber is also added to the wire to make it more durable. OnePlus Bullets 2T Earphones has a built-in independent DAC digital decoder, which supports 96KHz/24Bit high-definition audio format, can provide better quality sound from its aluminum alloy sound cavity. The most important thing is that a OnePlus Bullets 2T uses a Type-C interface instead of the traditional 3.5mm headphone jack.
Product Features:
● Crafted a listening experience that's immersive, vibrant, and extraordinarily detailed, thanks to an advanced internal DAC with high-res audio support.
● Fitted with a high-quality film diaphragm that makes voices sound more realistic and immediate.
● The flat-wire cables are tangle-free and threaded with tough Karbon fiber.
● No need to take out your phone every time you want to pause a song or answer a call, that's what the three-button in-line remote control is for.
● The left and right channels reproduce sound independently, reducing noise and capturing each note perfectly.
● By removing the MIC signal from the channels, the quality of your phone calls is significantly improved.
● Traits like temperature resistance and plug durability are all put to the test, and only the earbuds that emerge from the tests in pristine condition are good enough for your ears.
● Perfectly compatible with OnePlus 6T.
The Bullets 2T are extra-lightweight at just 1.8 grams, they're made with an aluminum alloy sound chamber, which does not have any negative sides while greatly reducing cavity resonance which causes distortion of sound: https://gearvita.com/oneplus-bullets...earphones.html
You may also like:
cheap qcy t1c mini wireless earphones
cheap huawei CP60 wireless charger
Staro 25.01.2019., 07:57   #126
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Edifier W2 Wireless Stereo Earphones with Charging Box
Edifier W2 wireless earphones use true wireless technology, wireless interconnection of left and right ears. A new generation of true wireless stereo, binaural calls, left and right ear split design, also can be used alone, easy and convenient.
Product Features:
● Mini But Strong
The shape is smaller and more comfortable than most TWS headphones.
● One-button Operation
Both sides of the headset have multi-function buttons for call and music operation. Both sides of the headset have a omnidirectional microphone port to support noise reduction in the voice call environment, and the call is convenient and clear.
● Special Design
When the earphone is taken out from the charging box, the power is turned on, the left and right earphones are interconnected, and the connected device is automatically connected back, which saves time and worry.
● Bluetooth 5.0
Bluetooth technology upgrade, faster transmission speed, lower power consumption, more than 10 meters of barrier-free transmission distance.
● 12 Hours of Battery Life
The texture charging box, the magnetic card slot, absorbs the stability. The headset lasts for 3 hours, the charging box can be recharged 3 times, that is, an additional 9 hours of battery life, to ensure that every trip is uninterrupted.
● IPX4 Waterproof
Effectively prevent rain and sweat from damaging components.
Edifier W2 is suitable for users who need quality and freedom of movement while listening to their favorite songs: https://gearvita.com/edifier-w2-wire...earphones.html
You may also like:
cheap xiaomi mi mix 3 128gb
cheap xiaomi mi band 3 smart bracelet
Staro 26.01.2019., 08:06   #127
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom BT20 Bluetooth Headset - Both Wireless And Wired Modes
Langsdom BT20 headset is foldable, with an attached audio cable, you can still enjoy favorite music when the battery is flat. Also you can share music with your best friend through line-out audio. The adjustable headset rests gently on your head and rotated ear cups which can rotate more than 180° for a personalized fit. Soft cushions cradle your ears, and all materials are lightweight and built to last. With Bluetooth 4.1, even the maximum volume will not breaking the sound quality, super bass HiFi stereo sound quality output. Built in concealed HD microphone, which is noise canceling, delivers more clear and nature sound. One-Key button to answer or reject the incoming phone calls, free your both hands, safety driving.
Product Features:
● Bluetooth 4.1 technology, super bass HiFi stereo sound quality output.
● Built-in amplifier active automatically improving the sounds details in Bluetooth mode.
● The improved neodymium driver brings high-fidelity stereo sound quality.
● Easy one touch pairing with NFC technology.
● Additional audio line input, for use when battery is low.
● Support both wireless mode and wired mode.
● Built-in microphone enables hands-free calling.
● One-key button to answer or reject the incoming phone calls, free your both hands.
● Leatherette earpad fully isolate external noise.
● Soft earmuffs and adjustable headband for comfort fit and long time wearing.
● Built-in 550mAh rechargeable battery, 120 hours long standby time.
● Foldable design, space-saving, convenient carrying.
After several tune tests, just to better represent the natural soundtrack, so you feel comparable to the quality of wired headphones: https://gearvita.com/langsdom-bt20-w...h-headset.html
Hot sale products:
cheap xiaomi mi pad 4 wifi tablet 64gb
cheap xiaomi minimalist portable flashlight
Staro 28.01.2019., 08:36   #128
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom L9 Neckband Earphones - Magnetic Design, Voice Prompt, 10 Hours Music Time
With light and comfortable fit and performance offering about 10 hours music playback time, the Langsdom L9 neckband earphones are simply mind blowing, perfect for the work environment and for exercise routines. The neckband is made of flexible material, capable of twisting without breakage or split. The magnetic design keeps the earbuds in place when not in use. It is compatible with all Bluetooth devices, support vibration and voice prompt, you will never miss any call.
Product Features:
● Vibration and Voice Prompt
When there's coming call, it will remind you with vibration, you will never miss any phone call when you are doing exercise or even in a noisy place.
● Bluetooth 4.1 Technology
More energy-efficient, stable, and faster transmission speed. Very low standby power consumption and quick pairing.
● Long Distance Transmission
Maximum pairing range can be 33ft, offering you impressive dynamic sound even you are 10 meters away from your device.
● Lightweight Neckband and Magnetic Design
Weighs only 0.25Ib in flexible and durable silicone neckband, allows for a more snug and comfortable fit around your neck, magnetic design can prevent tangles in the cords.
● High Call Resolution
DSP noise canceling technology reduces noise and increases call resolution by 30%, which provides you high-quality sound and clearer voice for calls.
● IPX4 Waterproof
Never worry about accidental water leakage when put it in the bag with improved durability withstanding all sweat, wet weather conditions.
● Ultra Long Battery Life
135mAh battery provides 320 hours standby time, 10 hours playback time and up to 11 hours talk time, charging duration is 30-75 mins.
Top quality material TPU unique around the neck design brings flexible twisting ways, comfortable for all day use: https://gearvita.com/langsdom-l9-nec...earphones.html
Hot sale products:
cheap xiaomi redmi 6a global version
cheap xiaomi mi mix 2s smartphone 128gb
Staro 29.01.2019., 08:45   #129
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom T6 Wireless Bluetooth Earphones with Charging Box
Langsdom T6 wireless Bluetooth earphones design in pumps out the bass and ultra-clear midrange earphones provide a super comfortable noise reducing fit for a fully balanced and ultra-realistic soundstage.
Product Features:
● Lightweight Design
5.2g for single earbud, super light and comfortble fit your ears even after longtime.
● Comfortable And Stable
With silicone earplugs, the earbuds can be firmly secured to your ears and do not easily fall off during work or running.
● Stereo And Monaural Modes
Can be used alone, which is equivalent to two independent Bluetooth headsets, you can share music to someone within 10 meters, or you can enjoy the stereo sound of two headphones.
● Sweat Resistant
IPX4 sweatproof keeps it stay in place during sweaty workouts.
● DSP Digital Noise Reduction Call
Chip built-in DSP, effectively eliminate regular noise, professional EQ adjustment, delivers pure and good sound quality.
● Pairing Faster
Bluetooth V4.2 and EDR technology ensure easy to pair and connect, click the button to get ready for connection.
● One Button Control
One button design, press easily and operate conveniently, easily to answer/hang up calls, play/pause/switch music.
● Portable Charging Box
Charge for one hour provides up to three hours of music time, the charging box can charge the headsets four times and power off when fully charged.
● Automatically Paring And Charging
Turn on and automatically connect to smart devices when removed from the case, turn off and charge when put back in.
This real wireless headset lets you share music or video sounds with someone. No more worries, rebounds, framed or kneaded things. Most importantly, it ensures your safety when driving a car: https://gearvita.com/langsdom-t6-min...rging-box.html
Top sellers on our website:
best lenovo air tws bluetooth earphones
best q50 kids gps smartwatch
Staro 30.01.2019., 07:34   #130
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom L5 Pro Bluetooth Earphone - Up to 10 Hours Playtime
The Langsdom L5 Pro Bluetooth earphone is the update version of L5, it has two shells to balance the weight on both sides, separate Bluetooth module and battery to improve Bluetooth stabilityh. You can use the silicone eartips for more comfortable wearing and anti-fall out. Weight of only 16g, you won't feel its existence when exercise. Built-in magnet, the earbuds will attach each other when not in use. The improved battery ensures up to 10 hours music time, you can get a long music trip.
Product Features:
● Strong Bass
The latest decoding technology and the latest 10M NdFeB unit provide a pure high quality sound similar to a CD.
Bluetooth transmission range up to 33 feet and high compatibility for most devices, such as iPhone, iPad android smartphones, tablets and other bluetooth music devices.
● Powerful Sound
Produces an incredible HiFi stereo sound, frequency of up to 20-20000Hz, can reach high pitch and pick up deep bass easily, suitable for most musical style.
● Secure Fit
Equipped with soft silicone eartips, can not only fit your ears comfortably, also hold the earphones in place during rigorous workouts.
● Lightweight and IPX4 Waterproof
Only weighs 13g, you can not even feel its existence. Ergonomic design for a good fit for the ears, can reduce the effect of the culture effectively. IPX4 waterproof range for water splash and sweat, you can run without any pressure.
● Magnet Design
Aluminum design built with magnet, join the two parts as a necklace when not in use, it is a practical way to carry them.
● 10 Hours Playtime
Fully charged within 1.5 hours, the powerful rechargeable battery provides up to 10 hours playtime, the remaining battery power of the earphones will be displayed on the iOS phone screen.
● HD Calls
CVC 6.0 noise cancellation technology reduces the noise around and offers you a clear conversation experience in HD.
● Multifunctional Button
Easy control for handling phone calls, song change and volume control, you will not miss any phone call and massage.
It is easy to setup and pair, only two steps needed and it is available with two color options: https://gearvita.com/langsdom-l5pro-...-earphone.html
Related products:
best xiaomi airdots headset
best xiaomi lyej05lm mini earphone
Staro 14.02.2019., 11:23   #131
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Meizu Flow Three-driver Hybrid Earphones - Feel Nothing, Hear Everything
Meizu Flow earphones are made in the form factor of internal gagging for good sound insulation, and together with the hybrid design of the Meizu Flow emitters, reproduce sound with a sensitivity of 105dB at 1KHz. The curved shape of the Meizu Flow is made with regard to the anatomical shape of the ear canal, fits perfectly to your ear, which allows you to stay in the headphones for a long time without discomfort.
Product Features:
● Flowing Aesthetic
Producing a texture through wiredrawing, gloss using powder metallurgy, high precision CNC line dissection, creating a liquid aesthetic of light and shadow.
● Three Hybrid Drivers
A high-fidelity dynamic driver to enhance the depth of the bass and two highly sensitive balanced armature drivers to enhance the resolution and layering in mid and high frequencies, accopanied by a specialized frequency dividing circuit, producing balanced multiband audio performance.
● Bass Venting System (BVS)
Customized conduit extends the low frequency response time, utilizing a dynamic driver with improved space, paired with an ingenious curved microfilter to further increased the clarity and dynamic range of the sound.
● Comfort Wearing
Adopting ergonomic design, through countless adjustments, making the curved surface fit perfectly to the ear. The curved arc design ensures stability and comfort so that you can immerse yourself in music and forget that you are even wearing earphones.
● Quality Wire
Quality silver-coated copper wire to ensure a low resistance and high conduction rate across the entire wire. The selected quality MEMS microphone enables outstanding call quality. Using separate microphone and audio wires, to further electrical interference from the wire, guaranteeing authentic sound restoration.
Silicone earplugs, dual layer earplugs, and inert earplugs, the customized airplane jack and portable silica gel case are provided to satisfy your requirements: https://gearvita.com/meizu-flow-hifi...-with-mic.html
Hot sale products:
best xiaomi mi box s tv box global version
best xiaomi mi mix 3 128gb global version
Staro Jučer, 09:00   #132
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 131
Langsdom BX9 Bluetooth Sports Earphone with Magnetic Suction Design
Langsdom BX9 earphone is light to 24g, with skin friendly coatings, comfortable to use. Adopt oblique ear design, eliminated the trouble of falling. Imported Bluetooth chip CSR4.2 keeps the volume at a safe level, and ensures stable connection in all directions within 10 meters. It is equipped with CVC6.0 noise reduction function, provides a perfect shocking sound quality. Adopt IPX5 waterproof design, you do not need to worry about rain and sweat when doing outdoor sports. 150mAh battery capacity provides standby time up to 200 hours to meet your needs.
Product Features:
● 45° Centrifugal Shaft Design
Ergonomic design, 45° will be more fit ears and no easy to fall off.
● Large Capacity Battery
Built-in 150mAh large capacity lithium battery, 10 hours music play time and up to 200 hours super long standby time.
● Natural Sound
Uses 14.2mm composite diaphragm sound unit that the voice will be more pure and better sound quality.
● IPX5 Waterproof
IPX5 water resistance and sweatproof ensure flawless performance when you doing exercise.
● HD Calls
The HD microphone guarantees HD calls when you are in noisy environments.
● Comfortable to Wear
Adaptive soft round neckline, no sense of wearing a full day.
● Voice Command
Answer/reject calls, control music and calls from the headset, easy to operate.
● Automatic Fit
Memory wire automatically maintained in the U-shape.
It is available in three optional colors: black, blue and red: https://gearvita.com/langsdom-bx9-sp...-earphone.html
You may like:
best xiaomi mi pad 4 wifi tablet 64gb
best xiaomi mi pad 4 lte tablet 64gb international version
