Staro 08.05.2011., 15:41   #1
vip-terminator
Postovi: 191
Firefox 4 problem
Pozzzz...
Instaliro sam firefox 4 i desava mi se nes cudo. Imam otvoren firefox na ekranu. I da npr otvorim Win explorer, posle 2,3 sekunde ničim izazvan, firefox ce mi se podizat i spustat preko Win explorera non stop i nemmrem napravit. Stvar je ok kad firefox minimiziram, onda se ne podize. Ali kad je maximiziran i bilo sta oda otvorim, bilo koji program, firefox mi se digne i zajebe stvar...
hlp
vip
vip-terminator je offline   Reply With Quote
Staro 08.05.2011., 15:44   #2
Protupožarac
Lokacija: Tamo gdje sunce vječno sja
skini ekstenziju "Minimize to tray revived" i poštelaj da ti se FF minimizira u tray i nećeš imati tih problema.
Staro 08.05.2011., 16:49   #3
vip-terminator
Postovi: 191
ne al ne zelim svaki put minimizirat firefox. Zelim da on bude na ekranu al da mi se ne pojavljuje preko drugih programa..
mozda nisam dobro objasnio...naso sam da jos jedan tip ima isti problem...mozda ovak se boje pojasni
Firefox keeps taking over my screen!
I have been having a very annoying issue with Firefox since downloading Firefox 4. Frequently when I switch from Firefox to another application, after a few seconds the Firefox screen will "take over," even though it does not show up as the selected program in the taskbar. Basically it's just the image of the Firefox window that takes over my screen, not the application (I can't, for example, click on anything that appears), and I have to toggle back and forth between programs in the takbar to get back to the window of the application that I was using. I never had this problem before, but it happens very often now. Is this happening to anyone else?
vip
Staro 08.05.2011., 18:57   #4
KorisNick
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Imaš još jednu opciju, vrati se na 3.6. To sam ja napravio, jer mi se ne sviđa 4orka.
KorisNick je offline   Reply With Quote
Staro 08.05.2011., 22:26   #5
borny
Too much busy
borny's Avatar
Postovi: 1,536
Kako obrnuti postupak da se vrati na staro?
Bez reinstalacije i skidanja 3.6...
Staro 10.05.2011., 19:29   #6
zgmmax
zgmmax's Avatar
Postovi: 1,617
Autor borny Pregled postova
ja sam jucer skinuo FF 3.6.17 i instalirao preko FF 4 bez pol frke, restarto komp i sve super sljaka
Staro 10.05.2011., 22:04   #7
tripl3
1337
tripl3's Avatar
Postovi: 42
Imas u about:config dosta opcija za Window Focus. Sigurno se da nešto sredit da ne iskače, downgrade nije način riješavanja problema.
tripl3 je offline   Reply With Quote
Staro 20.05.2011., 14:31   #8
goc_mails
low_rider
goc_mails's Avatar
Postovi: 471
Pozdrav..evo da se i ja nadvežem na još jedan bug u ff4 a da ne otvaram novi thread. Ne znam dali je već negdje to spomenuto ali nakon određenog vremena surfajući u firefoxu 4, strelica miša doslovno popi.di! Poćne blinkat, nestajat i slićne gluposti. Moram ga zatvorit i ponovno pokrenut. Ni u jednom drugm programu nemam ovakih manifestacija pa pretpostavljam da je do nove quattro verzije. Ima li netko slićnih problema?
A bu bu....
goc_mails je offline   Reply With Quote
