09.10.2003., 21:51 | #1 |
Postovi: 537
**Abit NF7-S Beep Codes
++++++++++++++++++++++++++++++++++++++++++++++ **Abit NF7-S Beep Codes Basic Beep Codes for ABIT AWARD BIOS Motherboards No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board One beep - board is working fine One long beep then machine shuts down - faulty, improperly installed or missing CPU 1 short(Beep) System booting is normally 2 short(Beep) CMOS setting error 1 long - 1 short(Beep) DRAM ERROR 1 long - 2 short(Beep) Display card or monitor connected error 1 long - 3 short(Beep) Keyboard Error 1 long - 9 short(Beep) ROM Error Long(Beep) continuous DRAM isn't inserted correctly Short(Beep) continuous POWER supply has a problem A two-tone siren, generally caused by overheating or out of specification voltages ++++++++++++++++++++++++++++++++++++++++++++++ Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking). Ovo je sa abitovog foruma.Znam da je netko pitao da li abit ima neki dijagnostički sustav.Neda mi se ovo prevest jer već jednom jesam ali je pukla veza sa internetom i cijeli se post izbrisao. |
09.10.2003., 23:26 | #2 |
Administrator
Lokacija: Sesvete
Postovi: 15,944
Eto vidiš a ljudi se bune da ABIT nema dijagnostiku. Ima, ima ali moraš slušati da bi čuo, kao curu |
10.10.2003., 01:31 | #3 |
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,372
Taj netko sam bio ja.Pa dobro to mi je dovoljno doduše bio bi mi draži MSI ev sistem al i ovo je OK!Sam je malo zajebano onih 9 kratkih beepova!
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder! Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! Alfisti site, Alfisti forum |
10.10.2003., 16:39 | #4 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,469
Moja se glasa ko" hitna A imam i "dijagnostičke" ledice Piše na kutiji, a bogme su i na ploči, čist fino svijetle u mraku... Ni ja, ni priručnik,ni proizvođač neznamo zakaj to služi. Testovi na netu su otprilike rekli sljedeće: Postoje ledice za dijagnostiku što je pohvalno-ali proizvođač nije za to isporučio nikakvu dokumentaciju Nije ni dan danas |
