Staro 11.04.2017., 14:55   #1
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,059
Nvidia Quadro P400
Samo kratak info, prije izvjesnog vremena ubacio sam dva fantasticna nVidia produkta, low-end Quadroice bazirane na Pascalu, P400 (najslabija) verzija, puta dva. Cijenom su mi bile i vise nego pogodne, ne trose skoro nista, i ne cuju se kada ne treba. 3x mini DP, gutaju i DP, i DVI (pa samim time i HDMI), i VGA.
Samo malo podataka, fotki i slicno.
Code:
hashcat (v3.40) starting in benchmark mode...
* Device #1: Not a native Intel OpenCL runtime, expect massive speed loss
             You can use --force to override this but do not post error reports if you do so
* Device #2: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
             See the wiki on how to disable it: https://hashcat.net/wiki/doku.php?id=timeout_patch
* Device #3: WARNING! Kernel exec timeout is not disabled, it might cause you errors of code CL_OUT_OF_RESOURCES
nvmlDeviceGetPowerManagementLimit(): Not Supported
OpenCL Platform #1: Advanced Micro Devices, Inc.
* Device #1: Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz, skipped
OpenCL Platform #2: NVIDIA Corporation
* Device #2: Quadro P400, 512/2048 MB allocatable, 2MCU
* Device #3: Quadro P400, 512/2048 MB allocatable, 2MCU
Hashtype: MD4
Speed.Dev.#2.....:  2477.6 MH/s (54.07ms)
Speed.Dev.#3.....:  2537.5 MH/s (52.73ms)
Speed.Dev.#*.....:  5015.2 MH/s
Hashtype: MD5
Speed.Dev.#2.....:  1448.5 MH/s (92.54ms)
Speed.Dev.#3.....:  1484.5 MH/s (90.22ms)
Speed.Dev.#*.....:  2933.0 MH/s
Hashtype: Half MD5
Speed.Dev.#2.....:   958.8 MH/s (69.91ms)
Speed.Dev.#3.....:   979.8 MH/s (68.32ms)
Speed.Dev.#*.....:  1938.6 MH/s
Hashtype: SHA1
Speed.Dev.#2.....:   531.1 MH/s (63.08ms)
Speed.Dev.#3.....:   545.0 MH/s (61.40ms)
Speed.Dev.#*.....:  1076.1 MH/s
Hashtype: SHA256
Speed.Dev.#2.....:   206.2 MH/s (80.94ms)
Speed.Dev.#3.....:   211.6 MH/s (78.76ms)
Speed.Dev.#*.....:   417.8 MH/s
Hashtype: SHA384
Speed.Dev.#2.....: 69899.6 kH/s (59.85ms)
Speed.Dev.#3.....: 71274.8 kH/s (58.65ms)
Speed.Dev.#*.....:   141.2 MH/s
Hashtype: SHA512
Speed.Dev.#2.....: 70650.4 kH/s (59.15ms)
Speed.Dev.#3.....: 73033.5 kH/s (57.21ms)
Speed.Dev.#*.....:   143.7 MH/s
Hashtype: SHA-3(Keccak)
Speed.Dev.#2.....: 57256.0 kH/s (73.06ms)
Speed.Dev.#3.....: 58897.1 kH/s (70.92ms)
Speed.Dev.#*.....:   116.2 MH/s
Hashtype: SipHash
Speed.Dev.#2.....:  1896.7 MH/s (70.62ms)
Speed.Dev.#3.....:  1951.1 MH/s (68.53ms)
Speed.Dev.#*.....:  3847.9 MH/s
Hashtype: Skip32
Speed.Dev.#2.....:   396.0 MH/s (42.16ms)
Speed.Dev.#3.....:   421.0 MH/s (39.66ms)
Speed.Dev.#*.....:   816.9 MH/s
Hashtype: RipeMD160
Speed.Dev.#2.....:   315.9 MH/s (52.82ms)
Speed.Dev.#3.....:   320.7 MH/s (51.32ms)
Speed.Dev.#*.....:   636.5 MH/s
Hashtype: Whirlpool
Speed.Dev.#2.....: 16698.8 kH/s (125.49ms)
Speed.Dev.#3.....: 17245.2 kH/s (121.42ms)
Speed.Dev.#*.....: 33944.0 kH/s
Hashtype: GOST R 34.11-94
Speed.Dev.#2.....: 15845.2 kH/s (132.27ms)
Speed.Dev.#3.....: 16316.1 kH/s (128.31ms)
Speed.Dev.#*.....: 32161.3 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 256-bit
Speed.Dev.#2.....:  3311.2 kH/s (312.83ms)
Speed.Dev.#3.....:  3416.5 kH/s (303.09ms)
Speed.Dev.#*.....:  6727.6 kH/s
Hashtype: GOST R 34.11-2012 (Streebog) 512-bit
Speed.Dev.#2.....:  3314.6 kH/s (312.51ms)
Speed.Dev.#3.....:  3419.2 kH/s (302.86ms)
Speed.Dev.#*.....:  6733.7 kH/s
Hashtype: DES (PT = $salt, key = $pass)
Speed.Dev.#2.....:  1322.2 MH/s (50.44ms)
Speed.Dev.#3.....:  1362.6 MH/s (48.95ms)
Speed.Dev.#*.....:  2684.8 MH/s
Hashtype: 3DES (PT = $salt, key = $pass)
Speed.Dev.#2.....: 38603.4 kH/s (54.24ms)
Speed.Dev.#3.....: 39880.5 kH/s (52.38ms)
Speed.Dev.#*.....: 78483.9 kH/s
Hashtype: phpass, MD5(Wordpress), MD5(phpBB3), MD5(Joomla)
Speed.Dev.#2.....:   454.7 kH/s (70.54ms)
Speed.Dev.#3.....:   475.2 kH/s (67.92ms)
Speed.Dev.#*.....:   929.9 kH/s
Hashtype: scrypt
Speed.Dev.#2.....:    57169 H/s (17.23ms)
Speed.Dev.#3.....:    58609 H/s (16.67ms)
Speed.Dev.#*.....:   115.8 kH/s
Hashtype: PBKDF2-HMAC-MD5
Speed.Dev.#2.....:   503.0 kH/s (63.43ms)
Speed.Dev.#3.....:   518.9 kH/s (61.71ms)
Speed.Dev.#*.....:  1021.9 kH/s
Hashtype: PBKDF2-HMAC-SHA1
Speed.Dev.#2.....:   222.5 kH/s (60.58ms)
Speed.Dev.#3.....:   228.4 kH/s (58.87ms)
Speed.Dev.#*.....:   450.9 kH/s
Hashtype: PBKDF2-HMAC-SHA256
Speed.Dev.#2.....:    81696 H/s (45.39ms)
Speed.Dev.#3.....:    84643 H/s (83.97ms)
Speed.Dev.#*.....:   166.3 kH/s
Hashtype: PBKDF2-HMAC-SHA512
Speed.Dev.#2.....:    30476 H/s (62.56ms)
Speed.Dev.#3.....:    31386 H/s (60.69ms)
Speed.Dev.#*.....:    61861 H/s
Hashtype: Skype
Speed.Dev.#2.....:   851.0 MH/s (78.77ms)
Speed.Dev.#3.....:   874.4 MH/s (76.56ms)
Speed.Dev.#*.....:  1725.3 MH/s
Hashtype: WPA/WPA2
Speed.Dev.#2.....:    27359 H/s (74.44ms)
Speed.Dev.#3.....:    28183 H/s (72.29ms)
Speed.Dev.#*.....:    55542 H/s
Hashtype: IKE-PSK MD5
Speed.Dev.#2.....:   114.4 MH/s (73.16ms)
Speed.Dev.#3.....:   119.7 MH/s (69.99ms)
Speed.Dev.#*.....:   234.0 MH/s
Hashtype: IKE-PSK SHA1
Speed.Dev.#2.....: 52769.0 kH/s (78.94ms)
Speed.Dev.#3.....: 54724.6 kH/s (76.38ms)
Speed.Dev.#*.....:   107.5 MH/s
Hashtype: NetNTLMv1-VANILLA / NetNTLMv1+ESS
Speed.Dev.#2.....:  1433.4 MH/s (93.54ms)
Speed.Dev.#3.....:  1476.4 MH/s (90.77ms)
Speed.Dev.#*.....:  2909.7 MH/s
Hashtype: NetNTLMv2
Speed.Dev.#2.....:   107.6 MH/s (77.82ms)
Speed.Dev.#3.....:   110.7 MH/s (75.56ms)
Speed.Dev.#*.....:   218.4 MH/s
Hashtype: IPMI2 RAKP HMAC-SHA1
Speed.Dev.#2.....:   114.3 MH/s (73.29ms)
Speed.Dev.#3.....:   117.1 MH/s (71.48ms)
Speed.Dev.#*.....:   231.4 MH/s
Hashtype: Kerberos 5 AS-REQ Pre-Auth etype 23
Speed.Dev.#2.....: 19158.7 kH/s (54.47ms)
Speed.Dev.#3.....: 20104.2 kH/s (104.11ms)
Speed.Dev.#*.....: 39262.8 kH/s
Hashtype: Kerberos 5 TGS-REP etype 23
Speed.Dev.#2.....: 19133.2 kH/s (54.55ms)
Speed.Dev.#3.....: 20077.4 kH/s (104.26ms)
Speed.Dev.#*.....: 39210.5 kH/s
Hashtype: DNSSEC (NSEC3)
Speed.Dev.#2.....:   223.0 MH/s (74.84ms)
Speed.Dev.#3.....:   230.4 MH/s (72.31ms)
Speed.Dev.#*.....:   453.5 MH/s
Hashtype: PostgreSQL Challenge-Response Authentication (MD5)
Speed.Dev.#2.....:   389.0 MH/s (86.08ms)
Speed.Dev.#3.....:   401.2 MH/s (83.43ms)
Speed.Dev.#*.....:   790.2 MH/s
Hashtype: MySQL Challenge-Response Authentication (SHA1)
Speed.Dev.#2.....:   155.0 MH/s (53.97ms)
Speed.Dev.#3.....:   160.1 MH/s (52.12ms)
Speed.Dev.#*.....:   315.2 MH/s
Hashtype: SIP digest authentication (MD5)
Speed.Dev.#2.....:   130.1 MH/s (64.38ms)
Speed.Dev.#3.....:   134.0 MH/s (62.40ms)
Speed.Dev.#*.....:   264.1 MH/s
Hashtype: SMF > v1.1
Speed.Dev.#2.....:   453.1 MH/s (73.95ms)
Speed.Dev.#3.....:   465.4 MH/s (71.88ms)
Speed.Dev.#*.....:   918.5 MH/s
Hashtype: vBulletin < v3.8.5
Speed.Dev.#2.....:   456.2 MH/s (73.46ms)
Speed.Dev.#3.....:   469.5 MH/s (71.26ms)
Speed.Dev.#*.....:   925.7 MH/s
Hashtype: vBulletin > v3.8.5
Speed.Dev.#2.....:   316.3 MH/s (52.74ms)
Speed.Dev.#3.....:   325.3 MH/s (51.20ms)
Speed.Dev.#*.....:   641.6 MH/s
Hashtype: IPB2+, MyBB1.2+
Speed.Dev.#2.....:   327.7 MH/s (50.90ms)
Speed.Dev.#3.....:   336.2 MH/s (49.50ms)
Speed.Dev.#*.....:   663.9 MH/s
Hashtype: WBB3, Woltlab Burning Board 3
Speed.Dev.#2.....: 89235.4 kH/s (93.83ms)
Speed.Dev.#3.....: 91825.6 kH/s (91.09ms)
Speed.Dev.#*.....:   181.1 MH/s
Hashtype: OpenCart
Speed.Dev.#2.....:   140.3 MH/s (59.70ms)
Speed.Dev.#3.....:   144.1 MH/s (58.03ms)
Speed.Dev.#*.....:   284.4 MH/s
Hashtype: Joomla < 2.5.18
Speed.Dev.#2.....:  1446.5 MH/s (92.68ms)
Speed.Dev.#3.....:  1489.0 MH/s (89.97ms)
Speed.Dev.#*.....:  2935.5 MH/s
Hashtype: PHPS
Speed.Dev.#2.....:   456.7 MH/s (73.37ms)
Speed.Dev.#3.....:   470.0 MH/s (71.21ms)
Speed.Dev.#*.....:   926.7 MH/s
Hashtype: Drupal7
Speed.Dev.#2.....:     3739 H/s (67.66ms)
Speed.Dev.#3.....:     3856 H/s (65.61ms)
Speed.Dev.#*.....:     7594 H/s
Hashtype: osCommerce, xt:Commerce
Speed.Dev.#2.....:   849.4 MH/s (78.84ms)
Speed.Dev.#3.....:   873.5 MH/s (76.62ms)
Speed.Dev.#*.....:  1722.9 MH/s
Hashtype: PrestaShop
Speed.Dev.#2.....:   565.2 MH/s (59.29ms)
Speed.Dev.#3.....:   580.4 MH/s (57.65ms)
Speed.Dev.#*.....:  1145.5 MH/s
Hashtype: Django (SHA-1)
Speed.Dev.#2.....:   452.9 MH/s (73.95ms)
Speed.Dev.#3.....:   465.7 MH/s (71.85ms)
Speed.Dev.#*.....:   918.6 MH/s
Hashtype: Django (PBKDF2-SHA256)
Speed.Dev.#2.....:     4100 H/s (50.60ms)
Speed.Dev.#3.....:     4237 H/s (49.05ms)
Speed.Dev.#*.....:     8337 H/s
Hashtype: Mediawiki B type
Speed.Dev.#2.....:   421.9 MH/s (79.44ms)
Speed.Dev.#3.....:   434.3 MH/s (77.13ms)
Speed.Dev.#*.....:   856.2 MH/s
Hashtype: Redmine Project Management Web App
Speed.Dev.#2.....:   183.1 MH/s (91.14ms)
Speed.Dev.#3.....:   188.6 MH/s (88.38ms)
Speed.Dev.#*.....:   371.8 MH/s
Hashtype: PunBB
Speed.Dev.#2.....:   183.1 MH/s (91.16ms)
Speed.Dev.#3.....:   188.6 MH/s (88.43ms)
Speed.Dev.#*.....:   371.7 MH/s
Speed.Dev.#2.....:  1447.3 MH/s (92.62ms)
Speed.Dev.#3.....:  1487.0 MH/s (89.98ms)
Speed.Dev.#*.....:  2934.3 MH/s
Hashtype: MSSQL(2000)
Speed.Dev.#2.....:   546.9 MH/s (61.24ms)
Speed.Dev.#3.....:   562.4 MH/s (59.50ms)
Speed.Dev.#*.....:  1109.3 MH/s
Hashtype: MSSQL(2005)
Speed.Dev.#2.....:   546.5 MH/s (61.31ms)
Speed.Dev.#3.....:   562.5 MH/s (59.49ms)
Speed.Dev.#*.....:  1109.0 MH/s
Hashtype: MSSQL(2012)
Speed.Dev.#2.....: 67866.2 kH/s (61.64ms)
Speed.Dev.#3.....: 69676.9 kH/s (59.98ms)
Speed.Dev.#*.....:   137.5 MH/s
Hashtype: MySQL323
Speed.Dev.#2.....:  3165.3 MH/s (84.71ms)
Speed.Dev.#3.....:  3262.1 MH/s (82.08ms)
Speed.Dev.#*.....:  6427.4 MH/s
Hashtype: MySQL4.1/MySQL5
Speed.Dev.#2.....:   248.0 MH/s (67.27ms)
Speed.Dev.#3.....:   254.8 MH/s (65.43ms)
Speed.Dev.#*.....:   502.8 MH/s
Hashtype: Oracle H: Type (Oracle 7+)
Speed.Dev.#2.....: 67205.6 kH/s (62.06ms)
Speed.Dev.#3.....: 68921.7 kH/s (60.41ms)
Speed.Dev.#*.....:   136.1 MH/s
Hashtype: Oracle S: Type (Oracle 11+)
Speed.Dev.#2.....:   529.6 MH/s (63.26ms)
Speed.Dev.#3.....:   546.2 MH/s (61.26ms)
Speed.Dev.#*.....:  1075.8 MH/s
Hashtype: Oracle T: Type (Oracle 12+)
Speed.Dev.#2.....:     7506 H/s (67.94ms)
Speed.Dev.#3.....:     7707 H/s (66.18ms)
Speed.Dev.#*.....:    15212 H/s
Hashtype: Sybase ASE
Speed.Dev.#2.....: 19181.3 kH/s (53.92ms)
Speed.Dev.#3.....: 19626.6 kH/s (52.67ms)
Speed.Dev.#*.....: 38807.9 kH/s
Hashtype: EPiServer 6.x < v4
Speed.Dev.#2.....:   457.9 MH/s (73.19ms)
Speed.Dev.#3.....:   465.8 MH/s (71.86ms)
Speed.Dev.#*.....:   923.8 MH/s
Hashtype: EPiServer 6.x > v4
Speed.Dev.#2.....:   185.9 MH/s (89.79ms)
Speed.Dev.#3.....:   189.3 MH/s (88.13ms)
Speed.Dev.#*.....:   375.2 MH/s
Hashtype: md5apr1, MD5(APR), Apache MD5
Speed.Dev.#2.....:   684.8 kH/s (94.01ms)
Speed.Dev.#3.....:   697.8 kH/s (92.17ms)
Speed.Dev.#*.....:  1382.7 kH/s
Hashtype: ColdFusion 10+
Speed.Dev.#2.....:   121.1 MH/s (69.21ms)
Speed.Dev.#3.....:   122.6 MH/s (68.29ms)
Speed.Dev.#*.....:   243.6 MH/s
Hashtype: hMailServer
Speed.Dev.#3.....:   189.3 MH/s (88.11ms)
Hashtype: SHA-1(Base64), nsldap, Netscape LDAP SHA
Speed.Dev.#2.....:   535.7 MH/s (62.48ms)
Speed.Dev.#3.....:   546.3 MH/s (61.24ms)
Speed.Dev.#*.....:  1082.1 MH/s
Hashtype: SSHA-1(Base64), nsldaps, Netscape LDAP SSHA
Speed.Dev.#2.....:   535.6 MH/s (62.49ms)
Speed.Dev.#3.....:   545.6 MH/s (61.22ms)
Speed.Dev.#*.....:  1081.2 MH/s
Hashtype: SSHA-256(Base64), LDAP {SSHA256}
Speed.Dev.#2.....:   208.0 MH/s (80.21ms)
Speed.Dev.#3.....:   212.0 MH/s (78.58ms)
Speed.Dev.#*.....:   420.0 MH/s
Hashtype: SSHA-512(Base64), LDAP {SSHA512}
Speed.Dev.#2.....: 71706.9 kH/s (58.33ms)
Speed.Dev.#3.....: 73173.3 kH/s (57.08ms)
Speed.Dev.#*.....:   144.9 MH/s
Hashtype: LM
Speed.Dev.#2.....:  1331.4 MH/s (50.10ms)
Speed.Dev.#3.....:  1358.9 MH/s (48.99ms)
Speed.Dev.#*.....:  2690.3 MH/s
Hashtype: NTLM
Speed.Dev.#2.....:  2492.5 MH/s (53.74ms)
Speed.Dev.#3.....:  2540.2 MH/s (52.67ms)
Speed.Dev.#*.....:  5032.6 MH/s
Hashtype: Domain Cached Credentials (DCC), MS Cache
Speed.Dev.#2.....:   724.5 MH/s (92.52ms)
Speed.Dev.#3.....:   737.1 MH/s (90.77ms)
Speed.Dev.#*.....:  1461.6 MH/s
Hashtype: Domain Cached Credentials 2 (DCC2), MS Cache 2
Speed.Dev.#2.....:    22367 H/s (71.31ms)
Speed.Dev.#3.....:    22907 H/s (69.84ms)
Speed.Dev.#*.....:    45274 H/s
Hashtype: MS-AzureSync PBKDF2-HMAC-SHA256
Speed.Dev.#2.....:   783.8 kH/s (69.42ms)
Speed.Dev.#3.....:   803.7 kH/s (67.87ms)
Speed.Dev.#*.....:  1587.6 kH/s
Hashtype: descrypt, DES(Unix), Traditional DES
Speed.Dev.#2.....: 65275.8 kH/s (63.99ms)
Speed.Dev.#3.....: 66420.0 kH/s (62.63ms)
Speed.Dev.#*.....:   131.7 MH/s
Hashtype: BSDiCrypt, Extended DES
Speed.Dev.#2.....:   102.4 kH/s (105.83ms)
Speed.Dev.#3.....:   104.4 kH/s (103.91ms)
Speed.Dev.#*.....:   206.8 kH/s
Hashtype: md5crypt, MD5(Unix), FreeBSD MD5, Cisco-IOS MD5
Speed.Dev.#2.....:   685.9 kH/s (93.95ms)
Speed.Dev.#3.....:   697.9 kH/s (92.23ms)
Speed.Dev.#*.....:  1383.7 kH/s
Hashtype: bcrypt, Blowfish(OpenBSD)
Speed.Dev.#2.....:     1030 H/s (30.14ms)
Speed.Dev.#3.....:     1053 H/s (29.46ms)
Speed.Dev.#*.....:     2083 H/s
Hashtype: sha256crypt, SHA256(Unix)
Speed.Dev.#2.....:    25854 H/s (62.61ms)
Speed.Dev.#3.....:    26386 H/s (61.36ms)
Speed.Dev.#*.....:    52239 H/s
Hashtype: sha512crypt, SHA512(Unix)
Speed.Dev.#2.....:    11094 H/s (74.29ms)
Speed.Dev.#3.....:    11329 H/s (72.76ms)
Speed.Dev.#*.....:    22423 H/s
Hashtype: OSX v10.4, v10.5, v10.6
Speed.Dev.#2.....:   456.5 MH/s (73.42ms)
Speed.Dev.#3.....:   466.3 MH/s (71.80ms)
Speed.Dev.#*.....:   922.8 MH/s
Hashtype: OSX v10.7
Speed.Dev.#2.....: 63220.5 kH/s (66.20ms)
Speed.Dev.#3.....: 64304.7 kH/s (64.92ms)
Speed.Dev.#*.....:   127.5 MH/s
Hashtype: OSX v10.8+
Speed.Dev.#2.....:      873 H/s (67.77ms)
Speed.Dev.#3.....:      898 H/s (66.31ms)
Speed.Dev.#*.....:     1771 H/s
Hashtype: AIX {smd5}
Speed.Dev.#2.....:   685.1 kH/s (93.94ms)
Speed.Dev.#3.....:   697.6 kH/s (92.12ms)
Hashtype: AIX {ssha1}
Speed.Dev.#2.....:  3177.0 kH/s (72.84ms)
Speed.Dev.#3.....:  3239.7 kH/s (71.40ms)
Speed.Dev.#*.....:  6416.7 kH/s
Hashtype: AIX {ssha256}
Speed.Dev.#2.....:  1143.5 kH/s (53.71ms)
Speed.Dev.#3.....:  1168.1 kH/s (52.58ms)
Speed.Dev.#*.....:  2311.6 kH/s
Hashtype: AIX {ssha512}
Speed.Dev.#2.....:   460.3 kH/s (67.42ms)
Speed.Dev.#3.....:   469.1 kH/s (65.92ms)
Speed.Dev.#*.....:   929.4 kH/s
Hashtype: Cisco-PIX MD5
Speed.Dev.#2.....:  1070.5 MH/s (62.58ms)
Speed.Dev.#3.....:  1091.9 MH/s (61.35ms)
Speed.Dev.#*.....:  2162.4 MH/s
Hashtype: Cisco-ASA MD5
Speed.Dev.#2.....:  1091.0 MH/s (61.43ms)
Speed.Dev.#3.....:  1111.0 MH/s (60.25ms)
Speed.Dev.#*.....:  2202.0 MH/s
Hashtype: Cisco-IOS SHA256
Speed.Dev.#2.....:   208.2 MH/s (80.17ms)
Speed.Dev.#3.....:   212.2 MH/s (78.57ms)
Speed.Dev.#*.....:   420.4 MH/s
Hashtype: Cisco $8$
Speed.Dev.#2.....:     4156 H/s (50.04ms)
Speed.Dev.#3.....:     4218 H/s (49.06ms)
Speed.Dev.#*.....:     8374 H/s
Hashtype: Cisco $9$
Speed.Dev.#2.....:      886 H/s (576.93ms)
Speed.Dev.#3.....:      905 H/s (565.10ms)
Speed.Dev.#*.....:     1791 H/s
Hashtype: Juniper Netscreen/SSG (ScreenOS)
Speed.Dev.#2.....:   842.4 MH/s (79.56ms)
Speed.Dev.#3.....:   859.7 MH/s (77.86ms)
Speed.Dev.#*.....:  1702.1 MH/s
Hashtype: Juniper IVE
Speed.Dev.#2.....:   684.8 kH/s (93.98ms)
Speed.Dev.#3.....:   698.0 kH/s (92.07ms)
Speed.Dev.#*.....:  1382.8 kH/s
Hashtype: Android PIN
Speed.Dev.#2.....:   370.4 kH/s (87.33ms)
Speed.Dev.#3.....:   378.0 kH/s (85.47ms)
Speed.Dev.#*.....:   748.5 kH/s
Hashtype: Citrix NetScaler
Speed.Dev.#2.....:   495.5 MH/s (67.61ms)
Speed.Dev.#3.....:   505.5 MH/s (66.28ms)
Speed.Dev.#*.....:  1001.0 MH/s
Hashtype: RACF
Speed.Dev.#2.....:   179.6 MH/s (93.32ms)
Speed.Dev.#3.....:   184.5 MH/s (90.73ms)
Speed.Dev.#*.....:   364.1 MH/s
Hashtype: GRUB 2
Speed.Dev.#2.....:     3058 H/s (67.66ms)
Speed.Dev.#3.....:     3132 H/s (66.32ms)
Speed.Dev.#*.....:     6191 H/s
Hashtype: Radmin2
Speed.Dev.#2.....:   534.4 MH/s (62.71ms)
Speed.Dev.#3.....:   546.4 MH/s (61.22ms)
Speed.Dev.#*.....:  1080.8 MH/s
Hashtype: SAP CODVN B (BCODE)
Speed.Dev.#2.....:   175.7 MH/s (94.96ms)
Speed.Dev.#3.....:   178.8 MH/s (93.23ms)
Speed.Dev.#*.....:   354.5 MH/s
Hashtype: SAP CODVN F/G (PASSCODE)
Speed.Dev.#2.....: 76288.3 kH/s (109.84ms)
Speed.Dev.#3.....: 77884.3 kH/s (107.55ms)
Speed.Dev.#*.....:   154.2 MH/s
Hashtype: SAP CODVN H (PWDSALTEDHASH) iSSHA-1
Speed.Dev.#2.....:   415.4 kH/s (77.83ms)
Speed.Dev.#3.....:   423.5 kH/s (76.26ms)
Speed.Dev.#*.....:   838.9 kH/s
Hashtype: Lotus Notes/Domino 5
Speed.Dev.#2.....: 14385.8 kH/s (143.79ms)
Speed.Dev.#3.....: 14503.5 kH/s (144.50ms)
Speed.Dev.#*.....: 28889.4 kH/s
Hashtype: Lotus Notes/Domino 6
Speed.Dev.#2.....:  4764.0 kH/s (109.91ms)
Speed.Dev.#3.....:  4861.6 kH/s (107.62ms)
Speed.Dev.#*.....:  9625.6 kH/s
Hashtype: Lotus Notes/Domino 8
Speed.Dev.#2.....:    45594 H/s (71.07ms)
Speed.Dev.#3.....:    46485 H/s (69.70ms)
Speed.Dev.#*.....:    92080 H/s
Hashtype: PeopleSoft
Speed.Dev.#2.....:   552.0 MH/s (60.69ms)
Speed.Dev.#3.....:   562.5 MH/s (59.47ms)
Speed.Dev.#*.....:  1114.5 MH/s
Hashtype: PeopleSoft PS_TOKEN
Speed.Dev.#2.....:   217.4 MH/s (76.78ms)
Speed.Dev.#3.....:   221.4 MH/s (75.29ms)
Speed.Dev.#*.....:   438.8 MH/s
Hashtype: 7-Zip
Speed.Dev.#2.....:      625 H/s (49.15ms)
Speed.Dev.#3.....:      653 H/s (95.37ms)
Speed.Dev.#*.....:     1278 H/s
Hashtype: WinZip
Speed.Dev.#2.....:    75944 H/s (49.01ms)
Speed.Dev.#3.....:    77390 H/s (48.06ms)
Speed.Dev.#*.....:   153.3 kH/s
Hashtype: RAR3-hp
Speed.Dev.#2.....:     2487 H/s (51.21ms)
Speed.Dev.#3.....:     2578 H/s (49.33ms)
Speed.Dev.#*.....:     5065 H/s
Hashtype: RAR5
Speed.Dev.#2.....:     2512 H/s (50.04ms)
Speed.Dev.#3.....:     2570 H/s (48.98ms)
Speed.Dev.#*.....:     5082 H/s
Hashtype: AxCrypt
Speed.Dev.#2.....:     7716 H/s (215.85ms)
Speed.Dev.#3.....:     7903 H/s (211.04ms)
Speed.Dev.#*.....:    15620 H/s
Hashtype: AxCrypt in memory SHA1
Speed.Dev.#2.....:   514.1 MH/s (65.13ms)
Speed.Dev.#3.....:   524.9 MH/s (63.80ms)
Speed.Dev.#*.....:  1039.0 MH/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....:    18724 H/s (51.93ms)
Speed.Dev.#3.....:    19111 H/s (50.90ms)
Speed.Dev.#*.....:    37834 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....:    28810 H/s (61.42ms)
Speed.Dev.#3.....:    29390 H/s (60.22ms)
Speed.Dev.#*.....:    58199 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....:     2382 H/s (211.55ms)
Speed.Dev.#3.....:     2441 H/s (206.38ms)
Speed.Dev.#*.....:     4823 H/s
Hashtype: TrueCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:    35678 H/s (48.85ms)
Speed.Dev.#3.....:    36387 H/s (47.91ms)
Speed.Dev.#*.....:    72064 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit
Speed.Dev.#2.....:       31 H/s (53.17ms)
Speed.Dev.#3.....:       31 H/s (52.12ms)
Speed.Dev.#*.....:       62 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA512 + XTS 512 bit
Speed.Dev.#2.....:       31 H/s (67.16ms)
Speed.Dev.#3.....:       62 H/s (65.82ms)
Speed.Dev.#*.....:       93 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-Whirlpool + XTS 512 bit
Speed.Dev.#2.....:        0 H/s (213.33ms)
Speed.Dev.#3.....:        0 H/s (208.71ms)
Speed.Dev.#*.....:        0 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-RipeMD160 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:       93 H/s (53.19ms)
Speed.Dev.#3.....:       93 H/s (52.15ms)
Speed.Dev.#*.....:      186 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit
Speed.Dev.#2.....:       62 H/s (53.25ms)
Speed.Dev.#3.....:       62 H/s (52.14ms)
Speed.Dev.#*.....:      124 H/s
Hashtype: VeraCrypt PBKDF2-HMAC-SHA256 + XTS 512 bit + boot-mode
Speed.Dev.#2.....:      186 H/s (53.24ms)
Speed.Dev.#3.....:      186 H/s (52.09ms)
Speed.Dev.#*.....:      372 H/s
Hashtype: Android FDE <= 4.3
Speed.Dev.#2.....:    56209 H/s (71.96ms)
Speed.Dev.#3.....:    57411 H/s (70.51ms)
Speed.Dev.#*.....:   113.6 kH/s
Hashtype: Android FDE (Samsung DEK)
Speed.Dev.#2.....:    20298 H/s (49.02ms)
Speed.Dev.#3.....:    20761 H/s (47.94ms)
Speed.Dev.#*.....:    41060 H/s
Hashtype: eCryptfs
Speed.Dev.#2.....:      928 H/s (66.52ms)
Speed.Dev.#3.....:      962 H/s (65.21ms)
Speed.Dev.#*.....:     1890 H/s
Hashtype: MS Office <= 2003 MD5 + RC4, oldoffice$0, oldoffice$1
Speed.Dev.#2.....: 15138.0 kH/s (69.09ms)
Speed.Dev.#3.....: 15438.3 kH/s (67.63ms)
Speed.Dev.#*.....: 30576.4 kH/s
Hashtype: MS Office <= 2003 MD5 + RC4, collision-mode #1
Speed.Dev.#2.....: 21390.5 kH/s (97.77ms)
Speed.Dev.#3.....: 22107.0 kH/s (94.63ms)
Speed.Dev.#*.....: 43497.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, oldoffice$3, oldoffice$4
Speed.Dev.#2.....: 20085.4 kH/s (104.20ms)
Speed.Dev.#3.....: 20547.2 kH/s (101.77ms)
Speed.Dev.#*.....: 40632.5 kH/s
Hashtype: MS Office <= 2003 SHA1 + RC4, collision-mode #1
Speed.Dev.#2.....: 22165.4 kH/s (94.51ms)
Speed.Dev.#3.....: 22632.7 kH/s (92.42ms)
Speed.Dev.#*.....: 44798.2 kH/s
Hashtype: Office 2007
Speed.Dev.#2.....:     8994 H/s (74.23ms)
Speed.Dev.#3.....:     9153 H/s (72.81ms)
Speed.Dev.#*.....:    18147 H/s
Hashtype: Office 2010
Speed.Dev.#2.....:     4483 H/s (74.27ms)
Speed.Dev.#3.....:     4553 H/s (72.80ms)
Speed.Dev.#*.....:     9035 H/s
Hashtype: Office 2013
Speed.Dev.#2.....:      622 H/s (66.16ms)
Speed.Dev.#3.....:      625 H/s (64.81ms)
Speed.Dev.#*.....:     1247 H/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4)
Speed.Dev.#2.....: 22742.7 kH/s (91.99ms)
Speed.Dev.#3.....: 23266.0 kH/s (89.89ms)
Speed.Dev.#*.....: 46008.7 kH/s
Hashtype: PDF 1.1 - 1.3 (Acrobat 2 - 4) + collider-mode #1
Speed.Dev.#2.....: 24669.3 kH/s (84.89ms)
Speed.Dev.#3.....: 25201.8 kH/s (82.99ms)
Speed.Dev.#*.....: 49871.1 kH/s
Hashtype: PDF 1.4 - 1.6 (Acrobat 5 - 8)
Speed.Dev.#2.....:  1111.7 kH/s (57.00ms)
Speed.Dev.#3.....:  1134.8 kH/s (55.71ms)
Speed.Dev.#*.....:  2246.4 kH/s
Hashtype: PDF 1.7 Level 3 (Acrobat 9)
Speed.Dev.#2.....:   207.7 MH/s (80.32ms)
Speed.Dev.#3.....:   212.1 MH/s (78.57ms)
Speed.Dev.#*.....:   419.8 MH/s
Hashtype: PDF 1.7 Level 8 (Acrobat 10 - 11)
Speed.Dev.#2.....:     2390 H/s (356.64ms)
Speed.Dev.#3.....:     2480 H/s (343.69ms)
Speed.Dev.#*.....:     4870 H/s
Hashtype: Password Safe v2
Speed.Dev.#2.....:    20188 H/s (24.34ms)
Speed.Dev.#3.....:    19148 H/s (25.96ms)
Speed.Dev.#*.....:    39336 H/s
Hashtype: Password Safe v3
Speed.Dev.#2.....:    81584 H/s (49.86ms)
Speed.Dev.#3.....:    83242 H/s (48.85ms)
Speed.Dev.#*.....:   164.8 kH/s
Hashtype: Lastpass
Speed.Dev.#2.....:   157.5 kH/s (51.02ms)
Speed.Dev.#3.....:   159.4 kH/s (50.38ms)
Speed.Dev.#*.....:   316.9 kH/s
Hashtype: 1Password, agilekeychain
Speed.Dev.#2.....:   223.8 kH/s (71.42ms)
Speed.Dev.#3.....:   229.8 kH/s (69.70ms)
Speed.Dev.#*.....:   453.6 kH/s
Hashtype: 1Password, cloudkeychain
Speed.Dev.#2.....:      742 H/s (67.54ms)
Speed.Dev.#3.....:      777 H/s (66.16ms)
Speed.Dev.#*.....:     1519 H/s
Hashtype: Bitcoin/Litecoin wallet.dat
Speed.Dev.#2.....:      309 H/s (66.54ms)
Speed.Dev.#3.....:      311 H/s (65.21ms)
Speed.Dev.#*.....:      620 H/s
Hashtype: Blockchain, My Wallet
Speed.Dev.#2.....:  5500.4 kH/s (23.63ms)
Speed.Dev.#3.....:  5639.9 kH/s (23.20ms)
Speed.Dev.#*.....: 11140.3 kH/s
Hashtype: Keepass 1 (AES/Twofish) and Keepass 2 (AES)
Speed.Dev.#2.....:     9148 H/s (152.05ms)
Speed.Dev.#3.....:     9353 H/s (148.80ms)
Speed.Dev.#*.....:    18500 H/s
Hashtype: ArubaOS
Speed.Dev.#2.....:   457.6 MH/s (73.23ms)
Speed.Dev.#3.....:   465.9 MH/s (71.77ms)
Speed.Dev.#*.....:   923.5 MH/s
Started: Fri Mar 24 15:59:50 2017
Stopped: Fri Mar 24 16:15:15 2017
Programer
PCI-Z - PCI-Z is a freeware lightweight system utility designed to provide information about (unknown) PCI (PCI-E, PCI-X...) devices and helps you find appropriate device drivers.
1time.link - Generate encrypted one-time links or share encrypted one-time downloadable files.
Staro 11.04.2017., 15:18   #2
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 1,402
To je uvod u review ili ... ?
ThinkPad T440p: [ i5 4300M | 16 GB DDR3 | 2x240 Intel 1500 Pro | 1920x1080 IPS ]
