Staro 06.04.2024., 20:13   #72721
lowrider
lowrider's Avatar
Lokacija: KR
Postovi: 1,109
Taj kojeg sam vidio bio je u Vž s ČK tablama
Lowrider
lowrider je online   Reply With Quote
Staro 06.04.2024., 20:26   #72722
Wolverine
Wolverine's Avatar
Postovi: 12,413
Imam negdi na mobu fotku nekog sa ZG tablicama.
Evo ga
20240309-131259
_____________
A kad smo kod toga kaj se vidi po cestama, fakat mi fale ovakvi prizori dok se šećeš gradom
20220930-162907 20220930-162919 20220930-184257 20220930-184338
20221001-162144 20221001-162151 20221001-162210 20221005-200217
20221005-200238 20221005-200510 20221005-205019 20221005-205147
20221005-205517 20221005-210241 20221005-210254 20221007-212646
20221007-212656 20221007-212706 20221008-183958 20221015-201108
20221015-201139 20221016-201119 20221016-201125 20221028-184137
20221028-184158 20221028-193404 20221028-193418 20221028-204323
20221028-204336 20221028-204347 20221028-204359 20221028-204411
Prebroj Tesle u samo jednom bloku
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 06.04.2024., 21:58   #72723
murina
murina's Avatar
Postovi: 443
napokon car day
2 Vitare otpada na reciklažu
Zasluzila je usisavanje i pranje
Jadni Spider
10km đir, voda, spužva, punjač na akumulator
Good day
Staro 06.04.2024., 22:07   #72724
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 8,660
Iz kategorije što se ne viđa svaki dan… 575 Superamerica
Taj V12 je i u leru divota za uši
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 06.04.2024., 23:26   #72725
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,105
Aha, nisam te dobro citao. Mislio sam da mislis na ZG crnog, jer to je jedini crni kojeg sam vidio u HR. Vecinom su crveni ili polarno bijeli.
Vezano za LC500, da predobro izgleda autić, preko bare ih ima ko pljeve. A i tu u ZG se zna zalomit koji.
Mogao bi jedino bez kicastih surikan/suza na farovima. Ali onda se sjetim kad je 90-tih Lexus uveo transparentna straznja svjetla, pa su svi odjednom morali imati ista.
Bila je neka peticija za RCV8 i LCV8, da dobije rucne mijenjace koju su pokrenula dva velika auto portala s vlasnicima modela, ali su dobili ala Toyota pricu o manualcu virtualcu.
Staro 06.04.2024., 23:35   #72726
Wolverine
Wolverine's Avatar
Postovi: 12,413
Dobro se drzi Alfa
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 07.04.2024., 07:56   #72727
Postovi: 33,365
Ima jedan LC500 RI rege koji se zna dokotrljati do mene. Prekrasan auto - širok, nizak, sav uglato agresivan.
btw, evo popisa lokacija novih kamera
https://autonet.bug.hr/propisi/odzvo...a-nadzor-39823
Staro 07.04.2024., 10:36   #72728
Tumor
prof.dr. gospodar svemira
Tumor's Avatar
Postovi: 382
Autor aski Pregled postova
Jasno je meni to, samo sam mislio na neke pizdarije koja ja mogu napraviti sam ili nađeš auto na parkingu udaren dok si npr. otišao kupiti hranu ili cipele.
Pa si ne želim priuštiti sex bez užitka s osiguranjem, nego da se to relativno brzo i lako riješi ako već plaćam dosta veliku premiju kaska 😬
Allianz - mozda jesu skuplji, ali s njima za sada samo dobra iskustva.
Zena nasla na parkingu ogreban cosak prednjeg branika i malo blatobrana. Odvezla u Mazdu (u pitanju je ona njihova crvena boja), servis popravi i nikakvih problema sa naplatom osiguranja. Zapravo, servis direktno s osiguranjem rijesi.
Mali na istom autu ogrebao zadnji branik (pocetnik vozac), isto kao gore - u servis i sve rijeseno bez ikakvih problema sa osiguranjem. Auto ima kasko.
Kuca isto osigurana kod njih. Ja sam zatvarao ventil za vodu u kupaoni jer sam mijenjao mijesalicu u tusu. Kada sam ga odvrnuo nazad ocito sam nesto sje... jer je laganini slinio, ali kako je kapao ispod plocica nisam odmah primjetio. Zbog toga nastala na zidu vlazna fleka nekih 30cm x 30cm. Prijavio na Allianz, bez ikakve primjedbe uredno isplatili nekih 1700kn, to je bilo prije nekih 5-6 godina.
Dakle, za sada sa Allianzom samo pozitivna iskustva.
If you are not paranoid you don't have enough information
Tumor je offline   Reply With Quote
Staro 07.04.2024., 11:09   #72729
medo
#erase startup-config
medo's Avatar
Postovi: 2,980
Alianz imam već dugo. Također nemam zamjerki. Čini se da je Alianz kao Croatia nekada.
Ako te udari netko osiguran kod Euroherca, savjet je zovi muriju i ne pristaj na nikakve dogovore. Još nisam čuo lijepe riječi za njih.
Staro 07.04.2024., 12:49   #72730
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,105
Every Car With a Manual Transmission in 2024
Autor medo Pregled postova
Nema vise zlatnog pravila, svi mogu raditi u nekom trenutku probleme. HR je zagusena kucama, s toliko prodanih polica, za sve i svasta.
To su posebno dozivljeli ljudi koji su imali osiguranje nekretnina, nakon zemljotresa, neki se i danas jos spore. Sigurno da noble imena daju osjecaj sigurnosti, ali po onome sto mi Blazun govori, a sto i sam svjedocim, bas svi se mogu izmotavati, od prilike do prilike.
Staro 07.04.2024., 15:58   #72731
medo
medo's Avatar
Postovi: 2,980
Osobno ne bi imao problem s automaticima kada:
1.) kada bi trajali kao manualci
2.) kada bi ih se lakše dalo tweakati (najviše da ne drže auto u preniskim okretajima)
Staro 07.04.2024., 16:06   #72732
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 8,660
Imaš dvije opcije ovdje:
Gledati višu klasu auta (konkretno, BMW već po defaultu ima odlično podešen automatik)
Drugo je prebaciti u drugi način rada (sport)
Jel uopće postoji trenutno moderni auto s automatskim mjenjačem koji nema mode selector?
Veći problem je što neki imaju programiranu amneziju pa kod novog paljenja auta vrate na defaultne postavke iako su korisničke postavke skroz drugačije. Opet, konkretno BMW.
Da, može se kroz bimmercode to postaviti, ali nije za svakog.
Na Audiju imam sad individual postavke s mjenjačem u sport modu i srećom ostaju aktivne i kod novog pokretanja, tako da nemam zamjerki.
S druge strane, Opel mi je (Astra K ) imao katastrofalni automatik bez mogućnosti sport moda, a CVT u Japancima je kategorija za sebe
Možda su noviji modeli nešto bolji, ali eto, to mi je ostalo u pamćenju.
Ne vjerujem da je nešto na što se čovjek ne navikne nakon par tjedana.
LCD: BENQ PD3200Q
Staro 07.04.2024., 16:08   #72733
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,499
Nisam siguran što ti smeta na automatiku, ali trenutni auto mi je prvi s automatikom i ne bi se vratio na manual.
Staro 07.04.2024., 17:24   #72734
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,177
Nemam puno iskustva s automaticima, ali vozio sam ZF 8hp u BMWu 116d f20 i f10 520d, to je perfekcij, draži su mi od DSGa. Iduća obnova vozilice bude automatik.
Staro 07.04.2024., 18:14   #72735
medo
medo's Avatar
Postovi: 2,980
Autor 1v@n Pregled postova
Ovo bi mi bilo sasvim dovoljno
To ti je onaj novi službeni Audi? Čuo sam da na najnovijim DSG-ovima više ne moraš biti na kočnici ili u neutralu da stoje na semaforu. Je li tako i kod tebe? Gledam si novog T-Crossa benzinca s DSG-om ali stari DQ200 se nisu baš pokazali trajnima...
Inače da, stari DSGovi drže okretaje preprenisko. U Sportu drže previsoko i uz to je previše živčan i osjetljiv.
Staro 07.04.2024., 18:32   #72736
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 8,660
Da, A3 40TFSIe (obožavam ove njihove oznake, srećom su odustali sad od njih)
Uključiš auto hold i ne moraš biti na kočnici. Samo kad se zaustaviš, stisneš još jednom malo jače kočnicu i stoji dok ponovno ne dodaš gas.
Nije samo do VAG, svi imaju tu opciju, samo je stvar je li serijska ili dodatna oprema.
BMW je imao paljenje tog na fizičku tipku, kod Audija je zakopano u menijima.
LCD: BENQ PD3200Q
Staro 07.04.2024., 18:51   #72737
Postovi: 16,120
Neki dan vidio LC 500 crni.
Prekrasan stroj uživo
Vozi se svaki dan na relaciji Tehnobeton - ČK, ČK rege.
Već ga viđam jedno 10 dana skoro svaki dan. I neki dan sam ga pratio prema ČK, bogami se vozi, ne zajebava se. Mojih 240ks ni blizu mu ne mogu, mislio da sam da će nekako penzionerski, ali stišće ga dobrano.
Upravo pred Angelusom u VŽ vidio McLaren P1, trula višnja, ZG rege. Bogami, pojava od auta.
Zadnje izmijenjeno od: Mommistake. 07.04.2024. u 19:45.
Staro 07.04.2024., 19:39   #72738
Postovi: 33,365
Kod Yarissa Cross i Captura imaš autohold tipku na centralnom tunelu. Svaki put kada staneš možeš dignuti nogu s kočnice i nećeš krenuti. Tek kada dodaš gas, on krene. Idealno za gradske vožnje pune semafora.
Staro 07.04.2024., 21:47   #72739
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,320
Ne radi se o auto holdu, nego baš o tome da auto ne ide naprijed dok je u D sve dok ne stisneš gas. Meni se to baš i ne sviđa jer u gužvi dobro dođe da ne moraš pimplati po gasu da bi se pomaknuo metar dva.
žmnpp
Staro 07.04.2024., 22:12   #72740
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 8,660
Prvi put čujem da tako nešto postoji a nije auto hold (ne hill assist, nego auto hold)
LCD: BENQ PD3200Q
Staro 07.04.2024., 22:26   #72741
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,499
To ima (auto hold) i moj skoro desetljeće stari Audi, i pali se na tipku.
Staro 08.04.2024., 01:25   #72742
GreenLife
Čika Zeljeni
GreenLife's Avatar
Datum registracije: Sep 2013
Lokacija: München
Postovi: 410
Autor buljo Pregled postova
Imam auto hold koji jako rijetko uključujem.
Ali kod mene npr. radi i na način ako je uključen adaptivni tempomat , i ako imam auto ispred sebe - moj sam koči i staje, a kad ga želim ponovno pokrenut samo malo stisnem gas ili ručicu tempomata i on ide dalje. Milina za kolone ili gradsku vožnju.
Staro 08.04.2024., 01:47   #72743
GreenLife
Čika Zeljeni
GreenLife's Avatar
Lokacija: München
Postovi: 410
Autor X-Plosiv Pregled postova
Ima netko možda iskustva sa Continental Sportcontact 7?
Gledam za ljetne dimenzije 235/35/19 i razbijam glavu da li da idem na provjereno Michelin Pilot Sport 4S, ili da probam ove, pa ako ih je imao netko.
Pirelli Pzero napokon otišle u smeće, najgore gume ikada nakon Assymetric 2
@X-plosiv - samo da javim da sam uzeo ove, trenutno samo dvije jer su mi druge dvije (Continental ContiSportContact 5P ) još ok za ovu sezonu.
Inače ove nove sam si stavio otraga, i prošli vikend malo bacio žešći đir po zavojima. Ja sam i više nego zadovoljan s držanjem.
Staro 08.04.2024., 07:21   #72744
Postovi: 33,365
Objavljen je natječaj za sufinanciranje EV. Počinje 22.04.
Lista vozila
Staro 08.04.2024., 08:04   #72745
njOob
njOob's Avatar
Lokacija: Jug
Postovi: 440
Je li postoji zabrana prodaje auta ako ga uzmem? Nemogu nac to.
Sent from my SM-G996B using Tapatalk
njOob je offline   Reply With Quote
Staro 08.04.2024., 08:20   #72746
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 574
pročitao sam negdje da je 2 godine.
Staro 08.04.2024., 09:14   #72747
Postovi: 33,365
Točno, zabrana prodaje je 2g. od registracije. Tako je bilo i prije.
https://www.index.hr/auto/clanak/poz...a/2554382.aspx
Staro 08.04.2024., 09:28   #72748
Postovi: 16,120
Ima netko iskustva s Twingom električnim?
Gledam ženi da uzmemo nešto za po gradu, imam osjećaj da mi se ovaj moj Škodilak dizel baš uništava u gradu, svaki put kad dođe doma s posla, a ima nekih 4km do posla, pogotovo zimi, da auto umire.
Njena prosječna potrošnja je 15-20l/100km (uzme prosjek tih 4km zadnjih).
Ona to kresne, gas doma i u garažu, auto ne stigne ni zraka uzeti niti se zagrijati.
E sad, sestra vozi službeni HP-ov Twingo, kaže da zimi nije prošla ni 80km s punom baterijom? Sestra se vozi u Novom Zagrebu između 10-tak poštanskih ureda na dnevnoj bazi, ako joj se zadesi da slučajno vanredno mora u Dubravu ili negdje van Novog Zagreba, uvijek je knap s baterijom na kraju dana.
Moguće da od deklariranih 300-400, ustvari realno po gradu zimi ispadne manje od 100km?
Staro 08.04.2024., 10:25   #72749
tomokt
Datum registracije: Jun 2010
Postovi: 29
Imamo ga 2.5 godine, super je Twingo za grad. Po zimi je domet oko 100-120 km po gradu. Držimo ga u grijanoj garaži u kući gdje se i puni.
tomokt je offline   Reply With Quote
Staro 08.04.2024., 10:41   #72750
Postovi: 16,120
Autor tomokt Pregled postova
Znači ako će mi biti kroz zimu vani, mogu stvarno računati na 60-80km dometa?
Ako je tako, otpada.
