Staro 15.08.2018., 09:42   #1651
zvonac
zvonac's Avatar
Lokacija: okolica Samobora
Postovi: 4,361
Autor darkijas Pregled postova
Kak ti se čini dot pitch u usporedbi sa dell-om
Mogu samo usporedit sa U2412M..
Defintivno je razlika vidljiva, oštrija u korist naravno Filipsa..
Gledam s iste daljine ko i prethodni 2412M, možda je sitnije, al očito me još vid dobro služi
Al pomak je očigledan, kako kod surfanja, desktop radnji, tako i u igrama.
Staro 15.08.2018., 13:07   #1652
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 9,309
A malo ti je i gpu pružila noge...
Staro 15.08.2018., 14:55   #1653
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
ako je 12ms input lag onda je ovaj monitor odlican. Jedino jos sacekati taj najavljeni 31,5" IPS AOC
dmr je offline   Reply With Quote
Staro 15.08.2018., 16:04   #1654
Drug Brko
Retired S.T.A.L.K.E.R.
Drug Brko's Avatar
Lokacija: Chernobyl Exclusion Zone, Kiev Oblast, Ukraine
Postovi: 18,062
Autor dmr Pregled postova
Još nisi nabavio 1440P monitor :D ?
Sent from Usreo Mobara
CPU: AMD Ryzen R5 2600 B2 Pinnacle Ridge 3400MHz @ 4200MHz (100x42 @ 1,373V) SMT enabled
CLR: THERMALRIGHT Venomous X Black w/ NOCTUA NF-F12 PWM chromax.black.swap 120mm Fan
MBO: ASUS ROG Crosshair VI Hero
RAM: G.SKILL Trident Z RGB DDR4-3200 2x8GB (16GB) @ 3466MHz -- 14-14-14-30 1T @ 1,40V
VGA: EVGA GeForce GTX 1080 FTW Gaming 8192MB
HDD: SAMSUNG 960 EVO 250GB SSD M.2 ++ SAMSUNG 860 EVO 500GB SSD SATA3 ++ WD Black 500GB WD5001AALS ++ WD Red 2000GB WD20EFRX ++ WD Red 3000GB WD30EFRX
OPT: LG GH24NS90
PSU: SEASONIC X-750 (SS-750KM3) 750W 80+Gold Modular
BOX: FRACTAL DESIGN Define R5 Blackout Edition Midi Tower w/ window panel
LCD: DELL UltraSharp U2715H 27" LCD @ 2560x1440
OS1: MICROSOFT Windows 10 Pro x64
CPU: INTEL Xeon X5450 E0 Harpertown 3000MHz @ 3000MHz (333x9 @ 1,200V)
CLR: INTEL FOXCONN Stock HSF
MBO: FOXCONN G31MX
RAM: BUFFALO Firestix DDR2-1066 1x1GB ++ KINGSTON ValueRAM DDR2-800 1x2GB (3GB) @ 800MHz -- 6-6-6-18 @ 1,8V
VGA: INTEL G31 OnBoard
HDD: SEAGATE Barracuda 7200.10 160GB ST3160815AS ++ SEAGATE Enterprise ES.2 500GB ST3500320NS
OPT: TSST SH-S223
PSU: FORTRON 250W w/ Active PFC
BOX: MS Apollo Midi Tower
OS1: MICROSOFT Windows XP Professional w/ SP3
OS2: MICROSOFT Windows 7 Professional N 32bit w/ SP1
OS3: MICROSOFT Windows 8.1 Professional N 32bit
OS4: MICROSOFT Windows 10 Professional N 32bit
GSM: SAMSUNG Galaxy S7 SM-G930F Black Onyx
ROM: Android Oreo v8.0.0 BTU
MSD: SANDISK 64GB Extreme MicroSDXC Class 10 U3
Reputacija: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37
Drug Brko je offline   Reply With Quote
Staro 15.08.2018., 16:06   #1655
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
Nisam, kako najavise ovaj 31.5" IPS tu sam stao Ipak mi je 1440p na 27" presitno.
Staro 15.08.2018., 16:27   #1656
zvonac
zvonac's Avatar
Postovi: 4,361
Bome da. Sad ne stoji neiskoristena, a i opcenito graficki puno lijepse izgleda na 2k neg na FHD..
Dok je razlika manja izmedju 2k i 4k, prakticki zanemariva, a izmedju fhd i 2k je zamjetna razlika i to je bio jedan od razloga prelazak na 2k rezu..
Staro Jučer, 02:03   #1657
Manuel Calavera
Postovi: 9,309
Autor zvonac Pregled postova
To ljudi često zanemaruju i gledaju na 1440p kao nešto što će im samo fps pojesti...
Staro Jučer, 03:19   #1658
warlock25
Ares
Postovi: 1,516
Mogu samo rec da prijelaz sa 1080p na 4k u witcheru 3 izgleda prepredobro.Probao sam prije dsr na 4k ali ogromna je razlika kad je nativno 4k reza.Nisam mislio da ce toliko poboljsanje bit.Na youtubeu nemres skuzit razliku bas u 1080p i 4k ali je ogromna.
Staro Jučer, 12:49   #1659
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
Meni recimo nista posebno u igrama nije bilo 1440p na 27" vs 1200p na 24", ali je zato performanse sjebalo samo tako
Staro Jučer, 13:25   #1660
zvonac
zvonac's Avatar
Postovi: 4,361
Zanimljivo, kod mene je razlika znacajna izmedju 1200 24" i 1440p 27", razlika je vidljiiva..
Za performanse me ni malo ne dira, mogu mirno spavat
Ne znam, al gejmanje na FHD rezi je za mene stvar proslosti, jednom dok se proba 2k ili 4k, to je to..
Staro Jučer, 13:31   #1661
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
nije 1200p fHD, it's beyond
Staro Jučer, 13:51   #1662
Drug Brko
Drug Brko's Avatar
Postovi: 18,062
Za performanse me ni malo ne dira, mogu mirno spavat:D
Vidiš, recimo ja nisam primjetio razliku veliku u gamingu. Ok, veći je FOV zbog veće reze... i to je to. Više sam primjetio u produktivnosti (AutoCAD / Office) i tu mi to dođe puuuno bolje i korisnije nego u gamingu. A ironija je što sam kupovao monitor za "gaming" na većoj rezi :D
Definitivno je 1440P u svemu bolje od 1080P. Sad su mi 23" 1080P monitori mali :D
OPT: LG GH24NS90
MBO: FOXCONN G31MX
OPT: TSST SH-S223
Staro Jučer, 14:24   #1663
zvonac
zvonac's Avatar
Postovi: 4,361
Meni je veca razlika u gejmingu izmedju FHD i 2k, nego izmedju 2k i 4k..
Cak mi razlika u velicini ekrana nije nesto, da je mozda veci jos malo, mozda bi bilo bolje, ovak 27", nis nekaj ekstra..
Mozda zbog tog sto sam povremeno igral na 55" telki, pa mi je sve ispod tog malo
Staro Jučer, 15:12   #1664
darkijas
darkijas's Avatar
Postovi: 1,346
Puno ovisi o tome kakav panel se potrefi. Karikiram, ukoliko npr taj philips ima kontrast oko 1100;1 a dell mozda oko 800:1 ta razlika se itekako primjeti pa odmah sve djeluje bolje, uključujući i dot pitch
darkijas je offline   Reply With Quote
Staro Jučer, 15:26   #1665
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
Pa i ne bas. Ja imam ovaj stari hp lp2475w kojem je kontrast opao na 600 i nešto, a probao sam dell u2713h kojem je kontrast oko 1000 i nije me impresionirao.
Staro Jučer, 15:34   #1666
Drug Brko
Drug Brko's Avatar
Postovi: 18,062
Opet, ovisi i o očima, o očekivanjima i onome što nekoga veseli ili ne :D
OPT: LG GH24NS90
MBO: FOXCONN G31MX
OPT: TSST SH-S223
Staro Jučer, 15:39   #1667
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
Pa najviše me nije veselilo sto je presitno sve na desktopu i sto su mi performanse u igrama zeznute podobro, a vizuelno u igrama gotovo da ne primjetim boost. Da je bar manji PPI možda bi i lego nekako, jer ipak nudi vise prostora na desktopu, al za to treba bar 30"
Staro Jučer, 16:06   #1668
darkijas
darkijas's Avatar
Postovi: 1,346
Meni je konkretno dell u2515h puno bolje sjeo od u2715h modela bas zbog kontrasta. Npr filmovi u mracnim scenama i igra koju sam tada igrao (rise of the tomb raider) sve to je značajno bolje izgledalo na manjem monitoru. Takodjer slika je djelovala ostrije.
Sliku sam bio klonirao na oba monitora. Pokusavao sam korigiranjem opcija postavki na monitoru i kompu popraviti stanje, ali bez uspjeha.
Steta jer 27" diagonala mi se vise dopala od 25" ali sam ipak zbog svega radije morao ostaviit manji monitor
Staro Jučer, 17:29   #1669
Drug Brko
Drug Brko's Avatar
Postovi: 18,062
Ako si imao samo jedan U2715H i jedan U2515H, onda je vjerojatno moguće da si imao dosta bolji panel na 25-ici.
Ne znam, vidim da se bolje kužiš i bolje vidiš od mene, no meni je 27" prvih tjedan dva bilo sitno sve i stavljao sam na 110-120% web stranice i lagano to spuštao i sad sam na 100% i sve OK.
Ali ovako mislim da bi na 25" mi sve bilo presitno. Nisam ga vidio ali imam takav osjećaj.
Što se boje tiče i tih crnih, ovo ono, to me ne tangira. Postavil sam ga prema TFT Cetralovim uputama sa onim tcc fajlom (valjda sam dobro rekao :) ) drugi ili treći dan i tako stoji od onda. Slika mi je dobra i po danu i po noći i pod rasvjetom sobe za bilo koji scenarij.
Na kraju najviše rada na monitoru ode na Office i CAD, a najmanje na igre. Nevjerovatno ali istinito. Evo sad igram Doom jer sam narajcan na ovaj trailer od Eternala. Mjesec dana nisam igrao ništa, a mjesec dva prije toga casual CSGO i Pes 2017 protiv AI-a. Ali mi nije žao upgradea. Bilo bi mi žao da mi je ostao onaj viewsonic :)
OPT: LG GH24NS90
MBO: FOXCONN G31MX
OPT: TSST SH-S223
Staro Jučer, 21:17   #1670
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 5,241
Koja je prva rezolucija nakon 1920x1080 koja bi išla na 27"?
Ag008 je online   Reply With Quote
Staro Jučer, 21:23   #1671
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
2240x1260 bi dobio 95 PPI sto je isto ko 23" 1080p monitor. Ako si to mislio Ako mislis od onih koje postoje to je 2560x1440
Zadnje izmijenjeno od: dmr. Jučer u 21:44.
Staro Jučer, 22:02   #1672
Drug Brko
Drug Brko's Avatar
Postovi: 18,062
Autor Ag008 Pregled postova
Pa 2560x1440, koja bi mogla biti? Imaš i 27" 16:10 2560x1600 ali košta jedno 5x više od prosjećnog 16:9.
OPT: LG GH24NS90
MBO: FOXCONN G31MX
OPT: TSST SH-S223
Staro Jučer, 22:16   #1673
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 553
zar ima 27" 16:10 2560x1600 monitor?
Staro Jučer, 22:20   #1674
Drug Brko
Drug Brko's Avatar
Postovi: 18,062
Zezno sam se, mislio sam na 30 colera onog Della mrcinu UP3017.
OPT: LG GH24NS90
MBO: FOXCONN G31MX
OPT: TSST SH-S223
Staro Danas, 00:27   #1675
darkijas
darkijas's Avatar
Postovi: 1,346
Nedavno sam taj svoj dell u2515h udruzio sa tv tunerom i rekoh da usporedimo sa panasonicovim led televizorom opremljenim ips alpha panasonic matricom koji mi se u tom trenutku nasao pri ruci.
U usporedbi se monitor kod mracnijih scena drzao jako dobro i boje su takodjer na monitoru izgledale ljepse. Telka je pak odnjela pobjedu kada su se prikazivale nijanse u svjetlijim scenama kao npr oblaci na nebu i sve te nijanse. Tad sam skuzio da te grdacije monitor pomalo guta. E sad,jel to imalo veze sa tv tunerom koji je inferioran onom na televizoru ili samo tako stoje stvari,nisam uspio dokuciti
Staro Danas, 02:23   #1676
flyer1
flyer1's Avatar
Lokacija: home
Postovi: 404
kakav source si ti koristia za tu komparaciju? zanima me jer je 2515 true 8-bitna matrica, pa nema ditheringa koji spacial resolution zrtvuje u korist trika s chroma subsamplingom, racunajuci na sklonost dobrog dijela korisnickog populacije za ''zivim'' bojama.
btw nabaci i info neki o toj matrici u panasonicu.
flyer1 je offline   Reply With Quote
Staro Danas, 07:30   #1677
darkijas
darkijas's Avatar
Postovi: 1,346
Uglavnom slovenske zemaljske hd programe. Tv je bio panasonic 42d25e dakle model iz 2010 godine
