13.06.2022., 00:20 | #1 |
Datum registracije: Jun 2022
Postovi: 25
Mikrotik i MaxTV - problemi
Imam Mikrotik 2011UiAS-2HnD i optiku od HTa. Danas sam dobio STB i nikako to natjerati da radi, pročitao sam valjda sve i jednu temu ovdje i na redditu što sam našao. Ovisno o tome u kojem je bridgeu port ether5 gdje je spojen STB, dobijem ili ekran za unos korisničkog ID i PINa (a to ne prolazi, kaže "Dogodila se pogreška") ili kad je u bridge-iptv gdje i mora biti, prvo dobijem x396 pa x397 greške. Gdje sam zeznuo? U prilogu počišćena konfa. Net radi, ONT je spojen na ether1, STB na ether5. Svi ostali portovi osim 9 su za net, na 9 bi trebao doći VoIP.... Tnx! Code:
# jun/13/2022 00:14:49 by RouterOS 7.2.3 # software id = PGV3-3UNL # # model = 2011UiAS-2HnD /interface bridge add admin-mac=4C:5E:0C:XX:XX:XX auto-mac=no comment=defconf mtu=1498 name=bridge add mtu=1500 name=bridge-iptv /interface vlan add interface=ether1 mtu=1492 name=vlan100-internet vlan-id=100 add interface=ether1 name=vlan1500-iptv vlan-id=1500 /interface pppoe-client add add-default-route=yes disabled=no interface=vlan100-internet keepalive-timeout=60 max-mru=1500 max-mtu=1500 \ name=pppoe-out1 service-name=HT user=xxxx@htnet-dsl /interface list add comment=defconf name=WAN add comment=defconf name=LAN /interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 add bridge=bridge-iptv comment=defconf ingress-filtering=no interface=ether5 add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 add bridge=bridge ingress-filtering=no interface=wlan2 add bridge=bridge interface=ether9 add bridge=bridge-iptv interface=vlan1500-iptv /interface bridge settings set use-ip-firewall=yes /ip neighbor discovery-settings set discover-interface-list=LAN /ip settings set max-neighbor-entries=8192 /ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192 /interface list member add comment=defconf interface=bridge list=LAN add comment=defconf interface=ether1 list=WAN add interface=pppoe-out1 list=WAN /ip firewall filter add action=accept chain=input comment=maxTV protocol=igmp Code:
/interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 add bridge=bridge-iptv comment=defconf interface=ether5 pvid=1500 add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 add bridge=bridge ingress-filtering=no interface=wlan2 add bridge=bridge interface=ether9 add bridge=bridge-iptv interface=vlan1500-iptv pvid=1500 Code:
add mtu=1500 name=bridge-iptv pvid=1500 vlan-filtering=yes
My name is Legion... For we are many! Zadnje izmijenjeno od: mrGood238. 13.06.2022. u 00:27. Razlog: dodantne info |
13.06.2022., 08:03 | #2 |
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,405
Moraš dodati VLAN ID 1500 i priority 2 za taj LAN port također RTSP i IGMP Snooping mora biti uključen. Inače sve postavke. http://forum.pcekspert.com/showpost....57&postcount=1 Sent from my Nexus 6P using Tapatalk |
13.06.2022., 08:30 | #3 | |
Postovi: 25
Code:
/interface bridge add igmp-snooping=yes name=bridge-iptv pvid=1500 vlan-filtering=yes /interface bridge port add bridge=bridge-iptv comment=defconf interface=ether5 pvid=1500 add bridge=bridge-iptv interface=vlan1500-iptv pvid=1500 /interface vlan add interface=ether1 mtu=1492 name=vlan100-internet vlan-id=100 add interface=ether1 name=vlan1500-iptv vlan-id=1500 Našao nešto, to je to? Code:
/ip firewall mangle add action=set-priority chain=output new-priority=2 out-interface=bridge-iptv
My name is Legion... For we are many! Zadnje izmijenjeno od: mrGood238. 13.06.2022. u 08:35. Razlog: dodane info |
13.06.2022., 22:24 | #4 |
Postovi: 25
Riješeno... Neki tikvan zaboravio propustiti MaxTV na ONTu, tj. provision/bundle nije bio dobar. Export relevantnih dijelova konfe, koga zanima. Idući problem/meta, VoIP. Code:
/interface bridge add admin-mac=4C:5E:0C:XX:XX:XX auto-mac=no comment=defconf mtu=1498 name=bridge add igmp-snooping=yes name=bridge-iptv pvid=1500 vlan-filtering=yes add name=bridge-voip pvid=101 vlan-filtering=yes /interface vlan add interface=ether1 mtu=1492 name=vlan100-internet vlan-id=100 add interface=ether1 name=vlan101-voip vlan-id=101 add interface=ether1 name=vlan1500-iptv vlan-id=1500 /interface pppoe-client add add-default-route=yes disabled=no interface=vlan100-internet \ keepalive-timeout=60 max-mru=1500 max-mtu=1500 name=pppoe-out1 service-name=\ HT user=xxxxx@htnet-dsl /interface list add comment=defconf name=WAN add comment=defconf name=LAN /interface bridge filter add action=drop chain=forward in-interface=wlan2 add action=drop chain=forward out-interface=wlan2 /interface bridge port add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 add bridge=bridge-iptv comment=defconf interface=ether5 pvid=1500 add bridge=bridge comment=defconf ingress-filtering=no interface=ether6 add bridge=bridge comment=defconf ingress-filtering=no interface=ether7 add bridge=bridge comment=defconf ingress-filtering=no interface=ether8 add bridge=bridge comment=defconf ingress-filtering=no interface=ether10 add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1 add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1 add bridge=bridge ingress-filtering=no interface=wlan2 add bridge=bridge-voip interface=ether9 pvid=101 add bridge=bridge-iptv interface=vlan1500-iptv pvid=1500 add bridge=bridge-voip interface=vlan101-voip pvid=101 /interface bridge settings set use-ip-firewall=yes /ip neighbor discovery-settings set discover-interface-list=LAN /ip settings set max-neighbor-entries=8192 /ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192 /interface list member add comment=defconf interface=bridge list=LAN add comment=defconf interface=ether1 list=WAN add interface=pppoe-out1 list=WAN /ip firewall mangle add action=set-priority chain=output new-priority=2 out-interface=bridge-iptv \ passthrough=yes add action=set-priority chain=output new-priority=5 out-interface=bridge-voip \ passthrough=yes /ip firewall service-port set sip disabled=yes
My name is Legion... For we are many! Zadnje izmijenjeno od: mrGood238. 13.06.2022. u 22:26. Razlog: obrisan višak |
24.03.2024., 10:27 | #5 |
Postovi: 10
Malo dižem temu iz mrtvih, ali, malo sam zapeo Ukratko, nakon više od jednog desetljeća na A1, prešao sam na T-Com optiku (500/250), uspio dobiti ONT, Speedport u bridge modu, itd... Ali hoću se riješiti Speedporta, kao glavni router za Internet koristim Mikrotik RB2011. ONT spojen na Ether1, bridge-internet su portovi 2,3, 4 i 5, bridge-iptv su portovi 6 i 7, za voip me trenutno nije briga. Odrađeno sve kako treba iz gorenavedenih postova, ali pojavio se problem. Sve je lijepo proradilo iz prve, ali tijekom downloada, MaxTV - umre. Slika zamrzne i ostane takva sve dok download traje. S obzirom da je RB2011 dosta star router i da mu je 500Mbps internet popriličan zalogaj za njegov single core CPU, zanima me, da li je vrijeme za bolji Mikrotik (i da li bi to riješilo problem) ili mi je promaklo nešto u postavkama? Čudi me to malo jer tijekom downloada CPU nikad ne ide iznad 60%? |
24.03.2024., 11:40 | #6 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,077
ima nešto oko verzije ros-a i igmp-a. nisam pratio puno teme ali spominjalo se. nemam maxtv pa me to nije zanimalo. i da uzmi jači. 2011 je zastario uređaj i za ove brzine ti treba nešto jače. ovo si pusti kao switch. po pitanju performansi, ništa jače od ac2 ti nije potrebno. ja imam stari hex 750gr3 i on uredno gura 500/250, i ne kanim ić na jače, ali ti bi mogao. sad je tik izbacio neke nove modele za ne previše para, ili ostani na ac2. |
24.03.2024., 12:22 | #7 |
Postovi: 10
Ako se moram riješiti routera, OK, ići će hap ax2, sa ugašenim WiFijem, jer za taj dio posla zadužen je UniFi Četvrojezgreni procesor i hrpa RAM-a, čini mi se ovako na papiru da je dobar. Samo prije nego što iskeširam zanima me postoji li možda nekakvo rješenje, jer trzanje slike iritira. Sad sam vratio Speedporta natrag, bilo bi mi drago imati u ormaru jedan uređaj manje. |
24.03.2024., 13:28 | #8 |
Lokacija: istra
Postovi: 3,077
par forumaša je složilo cijeli HT triple play na mikrotiku, moguće puppo i karlo ali da sad ne kažem pizdariju, idi kopaj stare topike. ja imam samo internet i to , za sada, sa technicolorom u bridge-u. prelistaj malo mikrotikov forum o ax2... nije se baš proslavio, ali se ne sjećam zašto nije. mislim da je kriv wifi, a sve ostalo je OK. imaš i: https://mikrotik.com/product/l009uigs_rm možda kao jedini bonus je 2.5G wan port, future proofing. mada ne vidim da će ikad ikome za home use 1gbit biti malo. |
24.03.2024., 14:11 | #9 | |
Postovi: 1,405
Konekcija mora biti Bridgeana sa prioritetom 2. Također moraš imati na konekciji upaljen IGMP (po mogućnosti V3). Primjer kod mene https://ibb.co/x1TG7XP https://ibb.co/0ZXB5Y9 Ako i ovo nerješi problem onda je problem sa samim ONT ONUom(nedavni slučaj). Traži novi ili kupi svoj. Sent from my Pixel 7 Pro using Tapatalk |
24.03.2024., 18:47 | #10 |
Postovi: 4,534
kupi 4011 rb i drbaj |
24.03.2024., 21:50 | #11 | |
Postovi: 10
Trza jedino kada je aktivan download, inače radi kako treba. Bridge postavljen identično prema uputama iz prethodnih postova. Nekako imam dojam da bi mi RB4011 (ili 5009) bio overkill. |
24.03.2024., 23:16 | #12 | ||
Postovi: 1,405
Meni doma na Asusu nema šanse da bilo kakvi Torrent ili Download ičega da mi ubije IPTV (MaxTV). Na MikroTik forumu govore da je to više do slabog CPUa,vrlo moguće je da ti Download zakuca CPU na 100%. Ako imaš QoS na MikroTiku pokušaj rezervirati 15MBit za IPTV(MaxTV) pa testiraj. Napravi test tako što ideš skinuti neki veliki file i prati CPU usage na MikroTiku. Ja i dalje stojim pri svome da je vjerovatno problem u konfiguraciji dok se nedokaže obrnuto jer ako TPLink VR2100v na A1 FTTHu sa 1GBit ždere Net+IPTV+VoIP i nema problema bez obzira na load. Citiraj:
Jedan ili više LANova taggiraš za VoIP i tu nakačiš ISP router ili vlastiti VoIP uređaj npr. nedavno je ekipa spajala VoIP Gatewaye Gigasete i YeaLinkove. Zadnje izmijenjeno od: Karlo666. 24.03.2024. u 23:23. |
26.03.2024., 10:52 | #13 |
Postovi: 10
OK, čini mi se da sam uspio! RB2011 je definitivno preslab, valjda mu je problem bio što nema hardware offloading za VLAN - mislio sam da je OK staviti MaxTV u drugu switch grupu (prva je gigabit, portovi od 1-5, a druga je 100mbps, portovi 6-10). Odlučio sam ponoviti eksperiment koristeći jedan drugi Mikrotik kojeg sam našao doma, u pitanju je Hex Poe RB960PGS, također single-core CPU ali jedna switch grupa. I sve radi kako treba, identična konfiguracija. Nagarim download, MaxTV ne trza. Sada je iduće - složiti VoIP, imam telefon Siemens Gigaset A540IP, ali tu sam totalni dummie, pa ako ima tko kakav savjet? |
