02.08.2016., 22:51 | #151 |
Datum registracije: Aug 2014
Lokacija: vukovar
Postovi: 107
Opet corak odgovor, ali ipak sam nasao dalje ono sto me zanimalo. Covjek se isto pita sto i ja: The limited writings and capacity\price of the SSD are known drawbacks as the sensitivity to shocks of the HDD. The hybrid SSHD (standard HDD+SSD cache) have a classic HD combined with a small SSD used as cache and managed by the firmware of the SSHD. Now I want to know what happens when the SSD cache reaches the writing limit quote for all the cells, the two possible alternatives are: a) simply the firmware stop to use the SSD caching and the SSHD becomes a standard HDD b) the SSHD becomes unusable What is the right answer? (The b alternative would make the SSHD choice, the less durable alternative and the worst choice ever for a server.) I have searched reliable sources about this, but I haven't found anything. The mechanical problems of HDD are very rare if they they are not subjected to shocks during the read\write operations, in standard condition the MTF range between 1 million to 1.5 million hours for a modern HDD. In the SSD, particularly SSD TLC, wearing is a problem, MLC typical maximum PE-cycle-per-block numbers range from 1500 to 10,000 (5000 mostly). Reach 5000 cycles is relatively easy if the storage is used intensively (especially in server use). So It's really important the SSD cache durability, and in addition must be considered also that cache-SSD sectors in SSHD are used even most intensively of a standard SSD that can distribute the wearing on a larger space. --------------- Odgovor slijedi: For SSHD users, we do worry about what happen when the SSD Cache wear out. Toshiba does provide official information on their SSHD FAQ. I have heard that NAND flash can wear out over time. What happens if the NAND component in the Toshiba SSHD reaches its endurance limit? Will data be lost?But I cannot find any similar information from Seagate, I have no proof to know it’s the same to Seagate SSHD. SSD cache in SSHD compromises the lifecycle compared to standard HDD? on superuser provides a good discussion on this topic. My conclusion: before the SSD cache wear out, there will be more and more damaged chips in SSD which means the available SSD cache is becoming smaller and smaller. User shall notice that the performance is decline slowly without any warning from S.M.A.R.T. . Linkovi na clanke: http://superuser.com/questions/58116...o-standard-hdd https://amigotechnotes.wordpress.com...ache-wear-out/ |
02.08.2016., 23:07 | #152 |
Lokacija: Petrinja
Postovi: 1,604
Gle stvar je jednostavna: Ako koristiš bilo koji disk u serverskom okruženju mejnjat ćeš ga dok je još debelo ispod bilo kojeg thresholda odnosno MTB.a. S druge strane u kućnom okruženju opet vrijedi ista stvar - ako ti je stalo do podataka pratit ćeš smart i sukladno tome mjenjat diskove preventivno. Sad možemo razgovarati o isplativosti ali .... kako god okrenuo pitanje je samo kako ćeš koristiti disk. Ako razmišljaš što će duže trajat razmišljaš krivo - jer disk se svakom minutom rada troši bilo mehanički bilo SSD tako da.... |
02.08.2016., 23:29 | #153 | |
Lokacija: vukovar
Postovi: 107
02.08.2016., 23:57 | #154 |
Lokacija: Petrinja
Postovi: 1,604
Pa problem sa novom tehnologijom je što imaš samo teoriju ali ne i praktiččne sksperimentalne podatke. Logično je da će se prije potrošiti tih 8 mb cachea, ali opet s druge strane ovisi i o algoritmu proizvođača diska kako je pisao da se to ubrzanje koristi. I sam si vidjeo kako toshiba finp piše što će bito kada se istroši, mo,že ti se desit da će za godinu dana izbacit firmware koji će ti točno očitavat koliko je života ostalo ... ne moš znat ovisi o tržištu i proizvođačima. Po meni su ti hibridi ni vrit ni mimo, niti su cijenom nešto niti performansama ili uzmeš mehaniku ili ssd. To me podsjeća malo na ono ubrzanje šta je sedmica mislim donijela kad uštekaš običan stick i onda ti se ubrzaju windowsi ....al ne mogu reć da sam baš vidjeo da to ljudi masovno koriste..... |
03.08.2016., 01:23 | #155 |
Lokacija: vukovar
Postovi: 107
Inace, za one koji imaju dosta RAM-a, a nemaju SSD/SSHD (ili neki drugi razlog), mozda moze posluziti programcic ImDisk Virtual Disk Driver pomocu kojeg od dijela RAM-a po zelji i mogucnostima radite virtualni disk te na njega mozete kopirati fajlove/programe koje zelite da se pokrecu jako brzo. Na neki nacin je to slicno kao SSHD, samo korisnik bira sto ce prekopirati na takav disk (za razliku od SSHD-a gdje to radi software) i nema ogranicenja ciklusa pisanja/brisanja. Mana ovoga je ocigledna i proizilazi iz samog nacina rada - u slucaju naglog gasenja racunala, sadrzaj virtualnog diska se brise. U nekom drugom slucaju ovo moze biti i prednost - na ovakav disk mozete staviti programe ili fajlove za koje zelite da se gasenjem racunala trajno izbrisu; npr. browser s historyjem itd. Zadnje izmijenjeno od: stribor919. 03.08.2016. u 01:46. Razlog: dopuna |
26.08.2016., 10:49 | #156 |
Lokacija: vukovar
Postovi: 107
Zanima me nesto u vezi SSHD: Jel on kesira podatke neovisno s bilo kojeg prikljucenog HDD-a na PC-u ovisno o tome koliko cesto pristupamo necemu ili samo s onog na kojem je SSD dio? Ili u prijevodu: ako stavim na dodatni HDD (ne na SSHD) portabilni preglednik slika i cesto ga otvaram - hoce li ga SSHD kesirati u SSD dio? Hvala |
26.08.2016., 11:39 | #157 | |
Postovi: 4,888
Igor Batinic |
15.11.2016., 13:47 | #158 |
Protupožarac
Lokacija: Tamo gdje sunce vječno sja
Nego kacmo kod Seagatea, meni je za oko zapeo Firecuda 1TB ST1000DX002 SSHD da njega akviziram i zamjenim za WD 640GB black koji ima već 7 godina i malo manje od 7 godina radnih sati. Jel ima netko iskustva sa SSHD diskovima. Vidim da nije skup. Jeftiniji je od WD blacka a isto ima 5 godina gare, a osjetno brži. Zadnje izmijenjeno od: domy_os. 02.01.2020. u 01:11. Razlog: obrisan višak |
15.11.2016., 20:25 | #161 | |
Lokacija: Zg/Zd
Postovi: 674
Sada kad su 120/128GB SSD za OS i aplikacije relativno pristupačni, ne vidim potrebu za tim, posebno ako ti treba za gaming jer su danas igre puno veće od tih 8GB cachea (SSD dijela) pa se gubi smisao, jednostavno, preveliki je protok različitih podataka sa diska da bi se zadržali u cacheu i drugi put brže učitavali. Za male uredske makine gdje se svaki dan ponavlja manje-više isti scenarij, nešto OS-a, neka Office/poslovna aplikacija je još uvijek ok jer se sve skupa vrti u okviru tih 8GB. Lijepo je što su im povećali garanciju na 5 god. ali za nešto manje dobiješ duplo veći obični disk tako da ako već imaš SSD za OS, sry Fato Zadnje izmijenjeno od: domy_os. 02.01.2020. u 01:14. Razlog: obrisan višak |
