Staro 22.05.2012., 15:53   #1
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,107
Nvidia GeForce v301.42 WHQL driveri
NVIDIA GeForce 301.42 WinVista 7 64-bit
NVIDIA GeForce 301.42 WinVista 7 32-bit
NVIDIA GeForce 301.42 WinXP 64-bit
NVIDIA GeForce 301.42 WinXP 32-bit
This is the first WHQL-certified unified driver from the R300 family of drivers (versions 300.00 to 301.99).
GeForce R300 drivers are packed with new industry-leading, GeForce-exclusive features as well as some really nice performance increases in top games.
New in R300 Drivers:
New GPU Support:
GeForce GTX 690
GeForce GTX 680
GeForce GTX 670
GeForce GT 600-series GPUs
Performance Boost – Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. GeForce 296.10 WHQL-certified drivers. Results will vary depending on your GPU and system configuration:
GeForce GTX 570/580:
Up to 23% in Just Cause 2 with SLI
Up to 21% in The Elder Scrolls V: Skyrim
Up to 17% in StarCraft II with SLI
Up to 14% in Far Cry 2 with SLI
Up to 9% in Bulletstorm
Up to 7% in Civilization V
Up to 6% in Deus Ex: Human Revolution with SLI
Up to 6% in Dragon Age 2 with SLI
Up to 5% in Metro 2033 with SLI
Up to 5% in Total War: Shogun 2
GeForce GTX 560/560 Ti:
Up to 20% in The Elder Scrolls V: Skyrim
Up to 15% in Just Cause 2 with SLI
Up to 13% in Far Cry 2 with SLI
Up to 12% in Bulletstorm
Up to 11% in Civilization V
Up to 10% in StarCraft II with SLI
Up to 9% in Batman: Arkham City
Up to 4% in Deus Ex: Human Revolution with SLI
Up to 4% in Dragon Age 2 with SLI
Up to 4% in Metro 2033 with SLI
Up to 4% in Total War: Shogun 2
NVIDIA FXAA Technology – shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. FXAA is supported on all GeForce 8-series and later GPUs. Note: This feature is disabled for games that already have built-in support for FXAA. Visit GeForce.com to learn more.
NVIDIA Adaptive Vertical Sync – dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. Adaptive VSync is supported on all GeForce 8-series and later GPUs. Visit GeForce.com to learn more.
NVIDIA Frame Rate Target – dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI. Visit GeForce.com to learn more.
NVIDIA Surround Technology – Adds the following new Surround capabilities.Visit GeForce.com to learn more.
Add in a fourth accessory display with GeForce GTX 600-series to get access to your email, web, or other applications while you game.
Maximize an application to a single physical display when in Surround mode (enabled by default).
Confine the Windows Taskbar to the center display (enabled by default).
Enable bezel peeking – a feature which enables users to temporarily peek behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions.
Add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications).
Full center display acceleration for single wide display modes (center display must be connected to the master GPU).
NVIDIA SLI Technology – Adds or updates the following SLI profiles:
Alan Wake
Call of Juarez: The Cartel
Counter-Strike: Global Offensive
Deus Ex: Human Revolution - The Missing Link
Left 4 Dead
Orcs Must Die!
Portal 2
Resident Evil: Operation Raccoon City
Risen 2: Dark Waters
The Darkness II
Battlefield: Bad Company 2
Crusader Kings II
Max Payne 3
Sniper Elite V2
Street Fighter X Tekken
NVIDIA 3D Vision – Adds or updates the following 3D Vision profiles:
All Zombies Must Die! – rated Fair
Ghosts 'n Goblins Online – rated Good
Oil Rush – rated 3D Vision Ready
Postal III – rated Good
Rayman Origins – rated Good
SevenCore – rated Fair
Stacking – rated Good
Unigine Heaven Benchmark v3.0 – rated 3D Vision Ready
Wargame: European Escalation – rated Good
Warp – rated Good
Wings of Prey – rated Fair
Krater – rated Poor
Adam's Venture Episode 1- rated Poor
Blacklight: Retribution – rated Poor
The Darkness II – updated in-game recommended settings
Depth Hunter – updated profile
Dirt: Showdown – rated Good
Passion Leads Army Benchmark – rated 3D Vision Ready
Resident Evil: Operating Raccoon City – Rated Fair
rFactor 2 – changed rating to 3D Vision Ready
Trackmania 2: Canyon – rated Fair
Unigine 3.0 Heaven Benchmark – updated profile
World of Tanks – changed rating to Excellent.
Other Details
Installs PhysX System Software v9.12.0213.
Installs HD Audio v1.3.16.0.
Supports OpenGL 4.2
Supports DisplayPort 1.2 for GeForce GTX 600-series.
Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
GeForce 600 series:
GTX 690, GTX 680, GTX 670, GT 645, GT 640, GT 630, GT 620, GT 610, 605
GeForce 500 series:
GTX 590, GTX 580, GTX 570, GTX 560 Ti, GTX 560 SE, GTX 560, GTX 555, GTX 550 Ti, GT 545, GT 530, GT 520, 510
GeForce 400 series:
GTX 480, GTX 470, GTX 465, GTX 460 v2, GTX 460 SE v2, GTX 460 SE, GTX 460, GTS 450, GT 440, GT 430, GT 420, 405
GeForce 300 series:
GT 340, GT 330, GT 320, 315, 310
GeForce 200 series:
GTX 295, GTX 285, GTX 280, GTX 275, GTX 260, GTS 250, GTS 240, GT 240, GT 230, GT 220, G210, 210, 205
GeForce 100 series:
GT 140, GT 130, GT 120, G 100
GeForce 9 series:
9800 GX2, 9800 GTX/GTX+, 9800 GT, 9600 GT, 9600 GSO, 9600 GS, 9500 GT, 9500 GS, 9400 GT, 9400, 9300 GS, 9300 GE, 9300, 9200, 9100
GeForce 8 series:
8800 Ultra, 8800 GTX, 8800 GTS 512, 8800 GTS, 8800 GT, 8800 GS, 8600 GTS, 8600 GT, 8600 GS, 8500 GT, 8400 SE, 8400 GS, 8400, 8300 GS, 8300, 8200 / nForce 730a, 8200, 8100 / nForce 720a
GeForce 7 series:
7950 GX2, 7950 GT, 7900 GTX, 7900 GT/GTO, 7900 GS, 7800 SLI, 7800 GTX, 7800 GT, 7800 GS, 7650 GS, 7600 LE, 7600 GT, 7600 GS, 7550 LE, 7500 LE, 7350 LE, 7300 SE / 7200 GS, 7300 LE, 7300 GT, 7300 GS, 7150 / NVIDIA nForce 630i, 7100 GS, 7100 / NVIDIA nForce 630i, 7100 / NVIDIA nForce 620i, 7050 PV / NVIDIA nForce 630a, 7050 / NVIDIA nForce 630i, 7050 / NVIDIA nForce 610i, 7025 / NVIDIA nForce 630a
GeForce 6 series:
6800 XT, 6800 XE, 6800 Ultra, 6800 Series GPU, 6800 LE, 6800 GT, 6800 GS/XT, 6800 GS, 6800, 6700 XL, 6610 XL, 6600 VE, 6600 LE, 6600 GT, 6600, 6500, 6250, 6200 TurboCache, 6200SE TurboCache, 6200 LE, 6200 A-LE, 6200, 6150SE nForce 430, 6150LE / Quadro NVS 210S, 6150 LE, 6150, 6100 nForce 420, 6100 nForce 405, 6100 nForce 400, 6100
ION series:
ION LE, ION
Staro 23.05.2012., 11:24   #2
JuiceBox
JuiceBox's Avatar
Lokacija: Keebwork
Postovi: 7,470
Rade kao zmaj . Prije su me zayebavali klokovi u WOW-u , s ovima vise toga nema.
Staro 23.05.2012., 12:00   #3
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,528
Ne pise nista za GTX 600 seriju? ( mislim na poboljsanje perf. u igrama )
o.O
EDIT:
Autor DeadMan+ Pregled postova
jer su poboljsanja u performansama u odnosu na 296.10 drivere, a ti driveri ni ne podrzavaju GTX 600 seriju
Zadnje izmijenjeno od: QuidZz. 23.05.2012. u 12:19.
Staro 23.05.2012., 12:05   #4
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor QuidZz Pregled postova
o.O
DeadMan+ je offline   Reply With Quote
Staro 23.05.2012., 12:48   #5
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 838
hmm, ja sam jučer stavio ove drivere i prvi puta mi se dogodilo na bf3 (sharqi peninsula mapa) da imam poskakivanje s 60 fps na 30 fps. iritantnije nego da je cijelo vrijeme bilo 30 fps. uglavnom vratio sam na stare 301.24 drivere i sad opet radi normalno.
Full Throttle je offline   Reply With Quote
Staro 23.05.2012., 20:06   #6
dean225
DD9512
dean225's Avatar
Postovi: 1,869
prvi pravi gtx560sli driveri.. Bez greske za sada..
dean225 je offline   Reply With Quote
Staro 23.05.2012., 23:19   #7
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,107
Probao maloprije BF3, radi bez problema.
Staro 24.05.2012., 01:05   #8
JuiceBox
JuiceBox's Avatar
Lokacija: Keebwork
Postovi: 7,470
Takoder bf3 klizi kao podmazan, nikakvih problema.
Staro 28.05.2012., 01:34   #9
poker
poker's Avatar
Lokacija: osijek
Postovi: 225
meni su 301.24 jučer prestali raditi kako treba ,mislim ono u igrama je pao fps na 5-10 probao sve pa na kraju uninstal i stavio nove 301.42 i sve radi kako treba
poker je offline   Reply With Quote
Staro 09.06.2012., 23:37   #10
Ivica121
Ivica121's Avatar
Datum registracije: Feb 2010
Lokacija: underground
Postovi: 71
Moram i ja pohvalit drivere, odlično rade, stabilni su. Bravo Nvidia.
Ivica121 je offline   Reply With Quote
