24.03.2007., 19:28 | #1 |
Postovi: 97
FireFox v2.0.0.3
Molio bi vas da mi preporučite neke "esencijalne" plugin-ove za FireFox v2.0.0.3! Koji su plugin-ovi po vašem mišljenu "must have"? Do sad sam bio na IE7, a prešao bi na FireFox pa vas molim za pomoć! Hvala! |
24.03.2007., 19:40 | #2 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,500
Ovo je meni pod mus: Undo Closed tabs Foxmarks bookmark synchronizer adblock plus adblock filterset.G updater PDF download A onda ako oćeš od Coste PCEkspert.com forum meni Otvoreni on the air (ako slušaš Otvoreni, da vidiš koja je pjesma) Sigurno će biti još prijedloga, ali ja nemam previše tih ekstenzija, samo osnovne... |
24.03.2007., 20:04 | #3 |
Postovi: 2,105
Generated: Sat Mar 24 2007 20:02:58 GMT+0100 (Central European Standard Time) User Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.0.11) Gecko/20070312 Firefox/1.5.0.11 Build ID: 2007031202 Enabled Extensions: [15] - All-in-One Sidebar 0.7.1: http://firefox.exxile.net/aios/ - CustomizeGoogle 0.55: http://www.customizegoogle.com/ - Google Toolbar for Firefox 2.1.20060807W: http://www.google.com/ - IE Tab 1.3.1.20070126: http://ietab.mozdev.org/ - keyconfig 20060828: http://mozilla.dorando.at/ - Live IP Address 1.6: http://www.google.com/search?q=Firef...20IP%20Address - MR Tech Local Install 5.3.2.3: http://www.mrtech.com/extensions/local_install/ - PCEkspert.com Forum Meni 1.4: http://www.google.com/search?q=Firef...20Forum%20Meni - Sage 1.3.10: http://sage.mozdev.org - StumbleUpon 3.04: http://www.stumbleupon.com/ - Tab Mix Plus 0.3.5.2: http://tmp.garyr.net - VideoDownloader 1.1.1: http://videodownloader.net/ - Web Developer 1.1.3: http://chrispederick.com/work/webdeveloper/ - WebmailCompose 0.6.6: http://www.jedbrown.net/extensions/ - Yahoo! Mail Notifier 0.9.9.2: http://ymnotifier.mozdev.org Disabled Extensions: [1] - Littlefox 1.7.05 : http://www.google.com/search?q=Firef...lefox%201.7.05 Total Extensions: 16 Installed Themes: [2] - Firefox (default): http://www.mozilla.org/ - Littlefox 1.7.05: http://www.geocities.com/alfredkayse...tlemozilla.htm Installed Plugins: (9) - Java(TM) 2 Platform Standard Edition 5.0 Update 10 - LogMeIn Inc. Remote Access Components 1.0.0.250 - Microsoft® DRM - Mozilla Default Plug-in - PCMan's IE Tab Plug-in for Mozilla/Firefox - QuickTime Plug-in 7.1 - Shockwave Flash - Windows Media Player Plug-in Dynamic Link Library - Yahoo! activeX Plug-in Bridge |
24.03.2007., 20:13 | #4 |
Postovi: 97
Ideš, ima toga puno! Hvala vam dečki na pomoći, budem ih sve proučio koje ste naveli i napravio si prema njima svoju kolekciju. Molio bi da se ne obriše ovaj topic tako da se mogu ravnati prema njemu! Puno hvala! |
24.03.2007., 21:47 | #5 |
daysleeper
Datum registracije: Apr 2004
Lokacija: zaprešić
Postovi: 405
ako slušaš mjuzu dok surfaš, koristan je foxy tunes za skidanje s megauploada https://addons.mozilla.org/firefox/3843/ ...a od google toolbara meni je bolji ovaj pdf download je isto zgodna extenzija... i gmail notifier ak koristiš gmail... |
24.03.2007., 22:52 | #6 |
The All Seeing Eye
Postovi: 1,103
Ej ljudi, ja sam neki dan (prije par tjedana ) isprobavao taj firefox i kad god bi ušao u bilo koju stranicu slika (ne ekran već slika) bi mi počela titrati odnosno skakati gore/dolje po 1cm! Npr. u google-u sam i počne mi bježati google gore/dolje. Jel imao itko takav problem? Kak da to riješim? |
24.03.2007., 23:09 | #7 |
Postovi: 86
stavi nesto u bookmarkse |
24.03.2007., 23:50 | #8 |
The All Seeing Eye
Postovi: 1,103
To je riješilo problem, ali... Zašto ne mogu imati mirnu sliku bez bookmarksa? Kad su mi oni uključeni to mi smanjuje vidljivu plohu browsera i samo me smetaju!? Ima li još koje rješenje za to? PS: 1) Ovak izgleda bez bookmarksa ali slika skače: - primjeti kako ima slovo B iznad Banner i kako je u dva sloja firefox simbol (toliko mi slika skače gore dolje) 2) Ovak izgleda sa bookmarkom ali mi se ne sviđa jer je ikona debela i velik dio ekrana mi pojede: Hvala unaprijed |
24.03.2007., 23:55 | #9 |
Postovi: 1,530
Pa iskljuci bookmarks toolbar (view>toolbars) |
25.03.2007., 00:00 | #10 |
The All Seeing Eye
Postovi: 1,103
25.03.2007., 00:03 | #11 |
Postovi: 4,060
25.03.2007., 00:12 | #12 |
The All Seeing Eye
Postovi: 1,103
Ma u redu je Tutix, hvala na pomoći! Koristim Alienware temu, nego reci zašto je kod tebe toliko lijepši firefox? Koju verziju koristiš? Jel to neki mod za firefox ili meni ovaj alienware totalno shebe izgled firefoxa (kod mene izgleda kao da je pobjegao iz Win98 )!? |
25.05.2007., 15:04 | #14 |
Lokacija: n/a
Postovi: 898
Od zadnjeg updejta, Gmail Notifier addon neće se ucompatibilati (na 2.0.0.3.). Neće pa neće. Točnije, ili ne otvara Gmail uopće, ili kad otvori, ne radi (nema replyjanja, nema click unread, lijevo di je onaj google chat piše "We're experiencing difficulties atm blabla..."). Za sve naredbe izbaci prozor "Please try again" "Failed"... Nakon disejblanja/uninstalla gmail addona sve radi. Piskaraju dečki po forumima da je nekompatibilan često, al da ga se treba instalirat baš s proizvođačeva sajta, i da onda radi, al nula bodova. Fuj, prešla sam privremeno na neki eksterni Gmail Notifier, al mi se ne sviđa. Oću svoj Ffox gnotifier! Please ako netko ima radeći Gnotifier, nek rekne di ga je skinuo jer sma isprobala već ne znam koliko bezuspješnih raznih lokacija. |
25.05.2007., 15:24 | #15 |
Postovi: 2,074
25.05.2007., 15:45 | #16 | |
Lokacija: n/a
Postovi: 898
25.05.2007., 19:07 | #17 | |
Datum registracije: Oct 2001
Postovi: 2,735
25.05.2007., 20:50 | #18 |
Lokacija: n/a
Postovi: 898
Thx svrtan, al sam se sad prebacila na ovaj gorenavedeni notifier, i čak mi je bolji i lakši za koristiti! Imam na kompu i previše stvari koje određenim redoslijedom trebam pipkati da bi proradile, ova barem radi sama od sebe |
28.05.2007., 20:11 | #20 |
Postovi: 4,060
Može uvijek: Royale Vista link. Autor stavio u jedan paket sve verzije koje je napravio, ova moja je 1.5 . |
28.05.2007., 22:19 | #21 | |
to te ja pitam
Postovi: 572
EDIT: sad je najedamput proradio nakon 10 minuta. nemam pojma kako ni zašto - sam od sebe. Bitno da radi.
1: Intel Badaxe2 () C2Q Q6600 () 2x2GB Kingmax 800MHz () Gigabyte GF 7300GT () 2 x Seagate 7200.10 320GB SATA II () Corsair VX 550W () DVD±RW LG H22 () Rebel 12 Economy 2: Gigabyte GA-965GM-S2 () C2D E6400 () 2x1GB Kingmax 667MHz () Seasonic S12 380W |
29.05.2007., 16:51 | #22 | |
to te ja pitam
Postovi: 572
