Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 30.11.2013., 15:31   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,717
Intel Xeon Phi - 72 jezgre
"Intel has taken the wraps off Knights Landing, its next-gen, up-to-72-core Xeon Phi supercomputing chip."
Teško da će se ovo naći u mojem sl. render slave-u, ali mogla bi biti najava koncepta na high-end modelima za smrtnike.
EDIT: Sad mi je sinulo da je ovo više za Novosti. Pardon. Može selidba.
It just works. Except when it doesn't.
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
VGA: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: Dell U2715h + U2407WFP
Audio: Asus Xonar U7 MK2 + Logitech Z-5500 5.1
Input: Logitech G915 + Logitech G602
OS: Windows 10 Pro x64
Asus N76VZ
CPU: 7-3610QM @ 2.30GHz
RAM: 2x8GB DDR3 HyperX 1600
VGA: NVIDIA GeForce GT 650m 2GB
SSD: Crucial MX100 256 GB
HDD: WD Scorpio Black 750GB @ 7200
Audio: Fiio Q1 DAC + AudioTechnica M50x
Input: Logitech G915 + Logitech MX Master 2S
In progress...
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
VGA: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
VGA: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3
2016: FX-8320E, Asus M5A97 PRO
2015: i7 6700k, Asus Z170-A
2014: FX-8350, ASRock 990FX Extreme3
2012: i7 3610QM, Asus N76VZ
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4
2009: Intel C2Q Q6600, GIGABYTE EP31
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x
2008: Intel Core2Duo T7200, Toshiba A100-847
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110
2002: AMD Duron 1200, Matsonic MS8127C
2001: AMD Duron 800, Matsonic MS8127C
1998: Intel Pentium II 300 Klamath
1996: Intel Pentium 120
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
