08.11.2018., 09:08 | #61 |
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Chuwi Hi10 Air Tablet - Smoothness Is More Than Just Talk
Chuwi Hi10 Air Tablet is a cost-effective notebook which supports fingerprint recognition. Equipped with a 10.1 inch FHD display with full IPS screen, brings your photos and videos to life. Powered by Intel Core processor, featuring Gen 8 graphics processor, ensures high performance. 64GB huge hard disk storage brings you smooth using experience. 2.4GHz/ 802.11b/g/n WiFi supported, ensures you high-speed surfing. Main Parameters: OS: Windows 10 CPU: Intel Cherry Trail Z8350 GPU: Intel HD Graphics Gen8 Screen: 10.1 inch IPS capacitive screen with 1200 × 1920 resolution RAM: 4GB ROM: 64GB External Memory: TF card up to 128GB Camera: 2.0MP back camera and 2.0MP front camera WiFi: 2.4G 802.11 b/g/n wireless internet Bluetooth: 4.0 Battery Capacity: 6500mAh Product Features: ● Full Lamination Technology, Holds Glass Closely Chuwi Hi10 Air adopts OGS full lamination technology to reduce the air refraction between TP and glass significantly, making the picture more vivid. Thanks to OGS tempered glass, the Hi10 Air’s high density LCD pixel is only 0.7mm, creating stereoscopic effect. ● Productivity and Creativity Hi10 Air perfectly matches with the 10.1-inches soft keyboard, which is connected by docking port. Along with the Chuwi Hipen H2 Stylus, the Hi10 Air provides more comprehensive and effective usage for productivity and creativity. ● Delicate and Clear, Say "No" to Visible Pixels The combination of IPS display and OGS technology can show colors with unparalleled clarity, 178° viewing angle will give you an amazing experience for watching videos and browsing. ● Solid and Slim, Engineering Aesthetic Hi10 Air adopts the metal uni-body design which went through 64 manufacturing CNC processes, the extremely thin 8.5mm metal body only weights 562g and makes it suitable for everyday carry backpack. ● Robust Intel Chipset, Fluent Gaming Experience Equipped Intel's advanced Cherry Trail CPU(up to 1.84GHz) and Gen8 HD Graphics GPU (up to 500MHz), Hi10 Air possesses powerful performance and fast processing speed to guarantee everything to run smooth. ● The Daily Driver for Everything Hi10 Air comes with 4GB of DDR3L RAM and 64GB eMMC , reading and writing speeds up to 150m/s. With max up to 128GB TF card expandable storage, it meets your needs for movies, games as well as pictures. ● Official Windows 10 Pre-installed Windows 10 OS, Edge browser as well as Cortana will improve your work efficiency and give you the free choice between tablet mode and laptop, great for entertainment and productivity. ● 5V 3A Fast Charging Hi10 Air fully charges in just 3 hours thanks to USB 3.1 fast charging, and now supports data speeds of 10Gbps, you can charge it with a power bank without carring the big laptop A/C charger. ● Not Only A Tablet Hi10 Air's keyboard dock brings back that familiar laptop structure required for productivity, the Hi10 Air can also be connect via Bluetooth for wireless support even the Xbox One controller. If you are looking for a cost-effective tablet, you must not miss it. With the price of $169.99 on GearVita, it is value for money to get a such powerful tablet: https://gearvita.com/chuwi-hi10-air-...-64gb-rom.html Hot sale products: xiaomi mi pad 4 plus 4g redmi note 6 pro 64gb
Best Brand Consumer Electronics Provider GearVita |
09.11.2018., 08:27 | #62 |
Lokacija: China
Postovi: 241
Wearing QKZ CK5 Earphones, Your World Is Only Music
QKZ CK5 earphones is a in-ear ear hook earphones which sounds good and have beautiful design. You can use audio control to answer the phone and control music. It's the newest sports ear-ear headphones which has transparent heavy bass. Product Features: ● Britain imported CSR master control chip, faster and more stable. ● Senior beryllium alloys diaphragm, adopt to senior headset custom meterials, voice more accurate, more pure. ● The import key components drive-by-wire, tactility is clear, long service life, high performance mic, ensure the quality of calls is clear. ● Smart noise reduction technology, filter out the noise environment, pure sound, music more clearly. ● The ergonomic design, nipple grade silicone ear muffs. ● Ear and tail pipe connection with oblique angle design, comfortable and easy to wear. ● Intelligent remote control, easy to operate. It is of $24.99 on GearVita, click here to learn more about it: https://gearvita.com/qkz-ck5-wired-h...-with-mic.html You may also be interested in: xiaomi poco f1 lte 64gb oneplus 6T 4g smartphone 128gb
12.11.2018., 04:22 | #63 |
Lokacija: China
Postovi: 241
Lenovo Watch 9 Smartwatch Constellation Series - Represents Youth Fashion
The Lenovo Watch 9 smartwatch constellation series is the new color scheme of the Lenovo Watch 9, the exclusive pattern of each constellation is also drawn in the dial. It is a smart quartz watch with sapphire mirror glass and 5ATM waterproof technology, supports message reminder, gesture photo, sports sleep record and the sleep monitor function will tell you your sleep quality. Built-in high quality movement, no need to charge, the battery can be used for 8 months on standby. Libra - Designed for Beauty Libra is bom to pursue beauty, willing to be trivial, willing to be normal, but will not be willing to be mediocre. Ingenious design process, create a sense of security that belongs to you only, looking forward to noble and distant. Virgo - Meticulous Design Inspiration Virgo design inspiration, reasonable and diligent from Virgo, clear mind and the pursuit of perfection. Using a stylish cotof system, generous, calm, stylish. Intellectual, open, pursue your cwn inner beauty. Leo - True Temperament Design Ideas Passion, sunshine, confidence, generous starts design language of Leo, it is difficult to interpret the true nature of the lion. The world's evaluation is not the most important, my feelings are the most important, this is the last and the first reluctance of Leo. Product Features: ● Superb Skill The constellation is inspired by the stars, sapphire glass mirror material, steel case, silicone strap, luminous pointer, let the beautiful watch blend into the stars of the sky. ● Quality Chip, Long Battery Life Imported Citizen gearbox and Nordic imported smart chip, integrating technology with the stars, up to 12 months of battery life. ● Life Waterproof 5ATM grade waterproof sealing process, guarantee normal use under 50 meters water pressure. ● Information Never Missed Personalized hipsters, always master new information. After setting permissions, SMS, information (QQ, WeChat, etc.) including incoming calls will vibrate in the first time, and use the second hand to indicate the user, short press or shake your wrist to hang up. ● New Way to Take Pictures Intimately integrated into the gesture camera function, enter the camera interface of the watch app, short press or shake the watch to take a quick photo, tailored for your self-portrait, don't miss the meteor that is drawn every moment. ● Cares About Your Health Have a motion calculation, sedentary reminder function,let every day of vitality be traced, closer and moreintimate, always pay attention to your health. ● Sleep Monitoring Skin-friendly material straps and lightweight weights for watches, more suitable for sleep wear. More accurate sleep monitoring function, can pass the body movements when you sleep, ahfvays monitor your sleep duration and sleep quality. ● Data Synchronization When Bluetooth has paired your smartphone, you can synchronize your data with your Android phone and iOS phone. It gives you a real-time evaluation of your exercise throughout the day. This Lenovo Watch 9 smartwatch constellation series is designed for Libra, Virgo and Leo. Believe you are no stranger to Lenovo Watch 9, with four different color schemes of watch face and strap on GearVita, this series may be more eye-catching: https://gearvita.com/lenovo-watch-9-...on-series.html Hot sale products: xiaomi mi band 3 bracelet huawei honor band 4 wristband
12.11.2018., 09:40 | #64 |
Lokacija: China
Postovi: 241
Xiaomi AirDots Bluetooth Headset Lets The Melodious Time Slow Down
The Xiaomi AirDots Bluetooth Headset comes with several features that ensure the user is satisfied with the sound output and the user experience is designed to be seamless. If the pair or one of them is taken out of the charging box, it boots automatically and pairs with the previously connected device. Placing it inside the charging box automatically disconnects and switches it off. There are touch panels on both sides of the earphone, which is used to pause of playing, answer and reject the calls, etc. Product Features: ● Elegant and Simple, Delicate Meterial The sleek and compact design eliminates the cumbersome elements, and the appearance is simple and full, which complements its simple operation. The charging box is made of high-difficult two-color injection molding technology, with translucent matte material, which is not only durable and wearable, but also has a sense of beauty, which makes people love it. ● Throw Away The Bondage, Feel The Agility of Music With TWS (True Wireless Stereo) technology, the binaural split body design, from now on without the headset line, enjoy the freedom of the melody. ● Take Out The Box and Automatically Boot Xiaomi AirDots Bluetooth Headset incorporates new technology, changing traditional manual operations and simplifying complicated paining steps. After being taken out of the box, it can be automatically turned on, automatically conneted and paired, and enjoy the song, it is so simple and easy. ● At The Touch of Button, Control by Heart The built-in touch panel of the headset is reponsive and can be used to complete your commands with a soft touch at your fingerprints. Avoid the pain of pressing with traditional buttons, and open a new era of touch with you. ● Hello, Xiaoai Classmates Tap twice to wake up the Xiaoai voice assiatant, no need to take time to pick up the phone. In a word, it helps you to solve the trivial things of life. ● Find Better, New Bluetooth 5.0 A new generation of Bluetooth 5.0 technology, compatible with various protocols such as Bluetooth 4.2 and below, achieves a comprehensive upgrade of performance, achieves long-distance transmission with ultra-low power consumption, has stronger anti-WiFi signal interference capability, and keeps the signal smooth, gives you a more smooth experience. ● Stereo Call, Hear More Clearly The Xiaomi AirDots Bluetooth Headset uses a new version of the chip to achieve two-channel stereo. Listen more clearly, and the call is close at hand. ● Double Bass, Make The Sound More Sensation The special 7.2mm strong magnetic moving ring speaker has wider bass range and more explosive sound. It is equipped with a rear cavity sounding structure and then optimized by the tuner to make the mid-low frequency more powerful and melody more sensation. ● 12 Hours of Battery Life, Happy and Uninterrupted The dual headphones are fully charged for 4 hours of continuous listening, and with the exquisite and compact charging box, it can provide about 12 hours of battery life, and the outdoor travel is not afraid of power failure, so that the songs accompany you all the way. ● Close to Both Ears, Comfortable and Endless When you wear it you dont want to take it off, listen to music, it should be so comfortable. Repeatedly calibrated curved arcs make the earphones fit the contours of the ears, the beveled ear structure is designed to comfortably penetrate the ear canal, three sets of soft silicone ear caps of different sizes are designed to create comfort for everyone. ● Work, There Is Also "Enjoy" Accompanied Both headphones can be used separately for easy office work, while allowing boring work to accompanied by misic. The Apple AirPods brought a true wireless headsets experience to the market and quickly became popular, but the new AirPods cost are overpriced for the average person. Never mind! The new Xiaomi AirDots Bluetooth Headset is priced only at $45.59 on GearVita. Thus, for the 1/3 of AirPods price, you can have the same true wireless experience: https://gearvita.com/xiaomi-airdots-...h-headset.html Hot sale products: xiaomi lyej05lm qcy q26 pro mini wireless bluetooth headset
13.11.2018., 03:28 | #65 |
Lokacija: China
Postovi: 241
UMIDIGI A3 - Triple Slots, Dual 4G VoLTE, Worldwide Frequencies
Featuring 5.5 inch 720 × 1440 resolution display on the 2.5D curved glass body, the UMIDIGI A3 smartphone as technology fashion pioneer uses a 12.0MP + 5.0MP dual rear cameras setup to deliver excellent photos. It is equipped MTK6739 quad core 1.5GHz high-performance processor and Android 8.1 OS to handle your daily tasks with ease, offering a power boost compared to previous generation. 3300mAh battery with low consumption is for full-day use, two ways to unlock your phone just a glance, global LTE bands is available in most of world’s countries. Product Features: ● 5.5 inch Incell 18:9 Full-screen Display Thanks to the 18:9 format 5.5 inch advanced in-cell technology full-screen display, UMIDIGI A3 will fit your hand like a glove, delivering the perfect experience of one-handed operation. ● MT6739 1.5GHz High-performance Processor Powered by a MT6739 1.5GHz Quad-Core A53 64-bit processor, the UMIDIGI A3 is able to handle your daily tasks with ease. It offers a power boost compared to previous generation, while reducing power consumption. ● Stock Android 8.1 System Android 8.1 has an easy-to-use interface, bringing amazing features and having security at its core, the A3 offers great and smooth use speed without interruption. ● Dual SIM + Dedicated Micro-SD Slot With a triple tray, you don't have to choose between having 2 SIMs or 1 SIM and 2 Micro-SD. Now you can carry both your SIM cards and expand the storage of the phone up to 256 extra GBs using a Micro-SD card. Store more, delete less. ● 12.0MP + 5.0MP Dual Rear Cameras UMIDIGI A3 uses a 12.0MP + 5.0MP dual OV cameras setup, driven by a large F/2.0 aperture, 1.25 μm large pixels, OV12870 sensor, to capture shoots with richer colors and less noise. ● 8.0MP High-resolution Front Camera The 8.0MP selfie shooter offers the possibility to get nice selfies and make high quality video calls, either for having fun with friends. ● Fingerprint and Face Unlock Unlock your phone just a glance to capture your face features with face ID technology, combined with other unlocked way, fingerprint recognition, so conveinent and safe. ● Dual 4G VoLTE, Worldwide Frequencies Support UMIDIGI A3 is equipped with dual 4G VoLTE technology, which brings benefits such as a high data throughput performance, more reliable coverage, lower power consumption and a consistent HD call quality when you make calls via either cellular connection or using your datas. It supports more than 15 LTE bands, which means you can take it have a global round travel, 4G LTE signal will be available in most of world's countries. UMIDIGI also brings latest trends to the budget segment, delivering two amazing colors for UDIMIGI A3: Gold and Black, you can come to GearVita to choose, the price is also very beautiful, only at $79.99: https://gearvita.com/umidigi-a3-4g-s...-16gb-rom.html Hot sale products: xiaomi redmi note 6 pro xiaomi mi a2 lite smartphone
13.11.2018., 07:32 | #66 |
Lokacija: China
Postovi: 241
Zealot B570 Bluetooth Headset - Strut Down The Street with Great Music
Never miss phone call with the new Zealot B570 headset vibration prompt feature, that will notify you to incoming phone calls. With the built in noise cancelling system, you’re able to listen to music without external sounds running your music track. Product Features: ● LED Colorful Display Simple user interface is the LCD screen to display the status of headphone and change modes for visual operation. ● Foldable Design After folded, the B570 becomes small and convenient to carry with when go out and can be storage in small space. ● Comfortable Wearing Experience The head beam made of environmental aviation rubber, which is coupled hardness with softness and can be extremely bended. With telescopic design, you can adjust the wearing tightness. Earmuffs are made of soft breathable protein leather and adopts the surrounding-ear style, providing you comfortable wearing-on experience. ● Shocking Bass With 30mm super big diaphragm and closed stereo sound field, the bass directly march into your heart. Whether listen to music or watch a movie, you will be fully immersed in the virtual reality. ● Built-in HD Mic The protruding mic is easily to break off, while the built-in mic effectively avoid it. Also B570 adopts noise canceling technology and makes you satisfied and easy to call and voice intercom. ● Built-in FM Radio Support FM radio local broadcast playback, you can listen to music, storytelling, financial and economics through the FM radio. ● Support TF Card and Breakpoint Continuing Playing Built-in intelligent decode technology, B570 supports playing music in main formats and breakpoint continuing playing. Micro TF card slot included, you can listen to music and audio you want using TF card, the max storage of TF card is 32G. ● HiFi Stereo Music Crystal clear and full-range sound let you feel the music coming with details realized through B570 40mm dynamic drivers. ● Steady Signal Transmission Compared with normal Bluetooth version, Bluetooth 4.0 is with faster transmission speed, longer transmission distance, more stable, lower power consumption. ● Wired Connection The design of audio line port makes it possible to switch freely between wireless and wired, any electronics audio equipment without Bluetooth can be easily connected. ● Detachable Battery B570 adopts detachable 600mAh battery, whether on a journey or outdoor, you can replace the battery with extra one. With the B570 bought from GearVita, you can take the best out of your playlist. Whether you are into pop, hard rock or jazz, there will surely be a perfect Zealot B570 Bluetooth headphones MP3 player for you: https://gearvita.com/zealot-b570-bluetooth-headset.html Hot sale products: xiaomi mi lyej02lm bluetooth headset xiaomi airdots headset
14.11.2018., 04:02 | #67 |
Lokacija: China
Postovi: 241
Lenovo Z5 Pro - Slide Cover, 95.06% Screen, AI Quad Cameras
Lenovo, which has long predicted the launch of the slide phone, has finally unveiled its Lenovo Z5 Pro smartphone after Xiaomi and Honor. The sliding front-facing camera module and massive 95.06% screen-to-body ratio are the core selling points of the device. Main Parameters: Display: 6.39 inch super AMOLED screen with 2340 * 1080 pixels CPU: CPU: Qualcomm Snapdragon 710 System: ZUI 10.0 is based on Android O Storage: 6GB RAM + 64GB ROM Cameras: 16.0MP + 24.0MP rear cameras and 16.0MP + 8.0MP front cameras Bluetooth: 5.0 Special Function: NFC SIM Card: dual Nano SIM, dual standby Battery Capacity: 3350mAh Product Features: ● Comprehensive screen innovation of 6.39-inch Samsung AMOLED has no bangs suspension full screen, hides the front camera under the screen. ● Fingerprint of the fifth generation photoelectric screen greatly improves the accuracy of fingerprint recognition. ● Uses a sliding structure to hide the front camera, just need to slide gently to meet your unlocking and self-timer needs. ● Traditional structure carries out the six-position gold fixation, the slide rails and the mobile phone screen are accurately positioned to ensure the stability of the sliding. ● 24 million (4 in 1) and 16 million pixels SONY AI rear dual-camera camera for a clearer, more delicate image quality services, smart photos. ● A 1.8μm (4 in 1) large pixel high-sensitivity imaging sensor effectively enhances the camera's imaging ability in dark light conditions, whether it is photos or videos. ● The front-facing 16-megapixel beauty camera is based on the beauty standard, star face deep learning and oriental aesthetic features of the self-portrait. ● The 8 megapixel fast infrared in vivo camera detects 4 times the resolution of an ordinary infrared camera for a safer experience. ● A unique AI algorithm, easy to switch between natural, temperament, tough, sweet, net red and other idol styles. Also provide an additional micro-shaping solution that can adjust the facial features of the five senses. ● Lenovo Air wireless Bluetooth music headphones, using IPX5 sports waterproof design. The AI smart antenna is not easy to disconnect, and it can cope with wireless interference in a variety of scenarios. ● Dolby Atmos has a good transient response and more realistic restoration of music sound effects. ● IntelliGo AI chips solve noise problems fully and efficiently for true HD call. ● Deeply optimized Snapdragon 710 AIE processor, with 6GB of running memory, and powerful performance. ● AI game acceleration engine, CPU acceleration, GPU acceleration, memory acceleration, reduce network latency. ● Built-in independent security chip gives you a lot of security protection. ● More advanced unlocking method, infrared face recognition, no fear of all black environment. ● Provide protection from the source of payment, seven-fold secure payment. ● 3350mAh battery capacity, longer battery life, farewell to frequent charging. ● Intelligently judge the user's attention to the timeliness of the message and the frequency of using the mobile phone to achieve intelligent frequency conversion power saving. ● AI smart recognition can quickly scan and identify ID cards, documents, QR codes, etc., it can also be quickly translated. ● The ZUI 10.0 system is fully upgraded to create a smart life of deep experience. As for pricing, the Lenovo Z5 Pro will be available for $349.99 on GearVita, that makes this one of the cheapest slider-type devices available: https://gearvita.com/lenovo-z5-pro-4...h-version.html There is also Lenovo Z5 Pro 128GB storage model costing of $399.99: https://gearvita.com/lenovo-z5-pro-4...h-version.html
14.11.2018., 09:01 | #68 |
Lokacija: China
Postovi: 241
Xiaomi Hybrid Dual Drivers Earphones - Great Music with Sensory Fashion
Xiaomi hybrid dual drivers earphones adopt the coolest hybrid technology, the combination of dynamic driver and balanced-armature driver. The balanced-armature will be handling on high-frequency audio while dynamic driver will handle the low-frequency audio thus providing a more 3D surround effect. Product Features: ● Combine the dynamic and balanced drivers, sounds produced are resoundingly richer and fuller. ● Wire control microphone, easy to control, play music and make calls. ● Adopts graphene, thinnest, strongest, and most eco-friendly material able to transmit sound fast, more ductile under high frequencies, producing sounds that are rich, sharp, and crystal clear. ● High-elasticity TPE fiber wire provides an excellent resistance to pull and perspiration resistant ability. ● L-shape plug, no easy to break and wear. ● Comfortable fit with ergonomic contoured form. ● Come with 4 pairs of XS/S/M/L size soft silicone eartips for comfortable wearing experience. Price at only $19.94 on GearVita, it is really a earphone value for money: https://gearvita.com/xiaomi-qtej03jy...earphones.html You may also be interested in airdots headset lyej02lm bluetooth headset
