13.05.2004., 01:40 | #1 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,469
NEC 2100A/2500A to Dual Layer 2510A firmware hack
Rezultati: http://www.cdrinfo.com/forum/tm.asp?...y=%F0%90%93%94 Skidanje: http://tdb.rpc1.org/#ND2510A Flash tak jasno svako na svoj rizik |
13.05.2004., 17:05 | #2 |
(°_°)
Postovi: 3,249
naajs :clap: kad kupim przu, apgrejdam firmware jedini sto mi se ne svidja, je sto kazu da neznaju dali se moze vratiti na stari firmware nakon flasha.... pa ono, mogli su provjerit BTW, kad je realno za ocekivat dual layer medije kod nas?
Toshiba m200 TabletPC + Samsung 205BW |
13.05.2004., 22:51 | #4 | |
(°_°)
Postovi: 3,249
di ima medija?
16.05.2004., 11:09 | #5 |
(°_°)
Postovi: 3,249
ok, kad niko nece, moram si sam odgovorit na pitanje ovo kaze afterdawn... "Taiwanese manufacturers, including Ritek and CMC Magnetics, have announced that they plan to start the production of double-layer DVD±R discs this summer. Several manufacturers have already announced plans to release double-layer drives in May. Ritek is currently doing trial production of dual-layer discs for quality certification, and expects to begin volume production by the end of June" dakle, ne isplati se jos upgrejdat sa ovog gigabytea na neca
17.05.2004., 14:08 | #6 |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
flashal bum kad bude medija. Ak neko flasha prije nek veli kak se ponasa. Za sad sam ga flash-o na necov original firmware v 1.07 http://www.necd.de/softwareoverview2.php/id/557
__________________ |
17.05.2004., 19:39 | #7 |
#erase startup-config
Postovi: 2,949
navodno da budu DL mediji koštali oko 10-15 eura |
17.05.2004., 22:34 | #8 |
(°_°)
Postovi: 3,249
cim izadju, da. al oko bozica nadam se da ce past na razumnijih 20ak kn
18.05.2004., 12:15 | #9 |
Postovi: 2,949
nadam se i ja, ali se bojim da cijene ne budu pale tako brzo... However, po testovima na siteovima, vidi se da DL mediji na drugom sloju imaju po jedan do dva reda veličine (!) veći PI/PO error rate od vulgaris DVD+-R medija, te da je kompatibilnost još uvijek veliki problem - većina DVD Playera trza ili uopće neće čitati te medije. A još kad se uzme u obzir da će početna brzina snimanja biti 2.4x za + format (skoro sat vremena!)...... Brijem da je dual-layer za sada kita, jer je preskupo i ne radi kako treba, tako da su moje prognoze da će to biti OK tek za godinu dana. |
18.05.2004., 14:45 | #10 |
(°_°)
Postovi: 3,249
je, i ja se bojim da nece past kako bi ja to zelio. a di to ima testova DL medija?
01.06.2004., 14:04 | #12 | |
(°_°)
Postovi: 3,249
a sta bi drugo rekli? Ljudi flashajte svoje jeftinije uredjaje, radit ce vam ko ovi skuplji ?
