Povratak   PC Ekspert Forum > Računala > AMD Radeon >ATI<
Staro 12.05.2018., 10:36   #1021
Gigi1
Postovi: 1,092
AMD Super-SIMD Patent, coming to a GPU after Navi
A super single instruction, multiple data (SIMD) computing structure and a method of executing instructions in the super-SIMD is disclosed. The super-SIMD structure is capable of executing more than one instruction from a single or multiple thread and includes a plurality of vector general purpose registers (VGPRs), a first arithmetic logic unit (ALU), the first ALU coupled to the plurality of VGPRs, a second ALU, the second ALU coupled to the plurality of VGPRs, and a destination cache (Do$) that is coupled via bypass and forwarding logic to the first ALU, the second ALU and receiving an output of the first ALU and the second ALU. The Do$ holds multiple instructions results to extend an operand by-pass network to save read and write transactions power. A compute unit (CU) and a small CU including a plurality of super-SIMDs are also disclosed.
ako se tko sjeca terscale arch od ati/amd, odnosno vliw...ovo je ajmo rec na tom tragu
edit: evo malo detaljnije
http://www.legitreviews.com/amd-seek...mputing_205227
Zadnje izmijenjeno od: Gigi1. 12.05.2018. u 10:44.
