18.11.2012., 17:48 | #1 |
njub
Datum registracije: Oct 2011
Postovi: 183
(riješeno) BSOD problem
Ovo mi se javlja (mislim pojavio se BSOD ali ovo je u safe mode-u windows lijepse ispiso, sad kak da provjerim jel hard otiso vrit il je nadam se neki softverski problem (moram se nadat premda su sanse 1% ). Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1050 Additional information about the problem: BCCode: f4 BCP1: 0000000000000003 BCP2: FFFFFA80088F08F0 BCP3: FFFFFA80088F0BD0 BCP4: FFFFF800039DB460 OS Version: 6_1_7601 Service Pack: 1_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\111812-16801-01.dmp C:\Users\Zen\AppData\Local\Temp\WER-32526-0.sysdata.xml |
18.11.2012., 18:33 | #2 |
njub
Postovi: 183
Ovo mi je sad reko WhoCrashed program, mozete mi objasnit koj mi je slijedeci korak, nadam se da sam vam dosta stvari sad stavio da bi dobio neki odgovor :/ On Sun 18.11.2012. 16:42:16 GMT your computer crashed crash dump file: C:\Windows\Minidump\111812-16801-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0) Bugcheck code: 0xF4 (0x3, 0xFFFFFA80088F08F0, 0xFFFFFA80088F0BD0, 0xFFFFF800039DB460) Error: CRITICAL_OBJECT_TERMINATION file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time. On Sun 18.11.2012. 16:42:16 GMT your computer crashed crash dump file: C:\Windows\memory.dmp This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0) Bugcheck code: 0xF4 (0x3, 0xFFFFFA80088F08F0, 0xFFFFFA80088F0BD0, 0xFFFFF800039DB460) Error: CRITICAL_OBJECT_TERMINATION Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time. On Sun 11.11.2012. 13:02:57 GMT your computer crashed crash dump file: C:\Windows\Minidump\111112-18049-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x7EFC0) Bugcheck code: 0xF4 (0x3, 0xFFFFFA80087C2B30, 0xFFFFFA80087C2E10, 0xFFFFF80002589460) Error: CRITICAL_OBJECT_TERMINATION file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a process or thread crucial to system operation has unexpectedly exited or been terminated. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue. The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time. |
10.12.2012., 14:11 | #4 |
njub
Postovi: 183
Evo nakon dosta ignoriranja a mislim da bi ovo bar mogli pogledat neki strucnjaci, iz debugg toolsa je, sad mi samo trebate rec u cemu je problem sa tim winitom i kako ga popravit hvala. Ajde nisam jos izgubio nadu u ovaj forum Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\Zen\Desktop\120912-15272-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17944.amd64fre.win7sp1_gdr.120830-0333 Machine Name: Kernel base = 0xfffff800`03059000 PsLoadedModuleList = 0xfffff800`0329d670 Debug session time: Sun Dec 9 11:37:08.361 2012 (UTC + 1:00) System Uptime: 0 days 2:39:29.571 Loading Kernel Symbols ............................................................... ................................................................ ............................ Loading User Symbols Loading unloaded module list ...... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck F4, {3, fffffa800a51fb30, fffffa800a51fe10, fffff800033d7460} ----- ETW minidump data unavailable----- Probably caused by : wininit.exe Followup: MachineOwner --------- 2: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* CRITICAL_OBJECT_TERMINATION (f4) A process or thread crucial to system operation has unexpectedly exited or been terminated. Several processes and threads are necessary for the operation of the system; when they are terminated (for any reason), the system can no longer function. Arguments: Arg1: 0000000000000003, Process Arg2: fffffa800a51fb30, Terminating object Arg3: fffffa800a51fe10, Process image file name Arg4: fffff800033d7460, Explanatory message (ascii) Debugging Details: ------------------ ----- ETW minidump data unavailable----- PROCESS_OBJECT: fffffa800a51fb30 IMAGE_NAME: wininit.exe DEBUG_FLR_IMAGE_TIMESTAMP: 0 MODULE_NAME: wininit FAULTING_MODULE: 0000000000000000 PROCESS_NAME: wininit.exe EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s. BUGCHECK_STR: 0xF4_c0000005 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT CURRENT_IRQL: 0 STACK_TEXT: fffff880`1a197e38 fffff800`0345f822 : 00000000`000000f4 00000000`00000003 fffffa80`0a51fb30 fffffa80`0a51fe10 : nt!KeBugCheckEx fffff880`1a197e40 fffff800`0340be0b : ffffffff`ffffffff fffffa80`0b33eb50 fffffa80`0a51fb30 fffffa80`0a51fb30 : nt!PspCatchCriticalBreak+0x92 fffff880`1a197e80 fffff800`0338af04 : ffffffff`ffffffff 00000000`00000001 fffffa80`0a51fb30 00000000`00000008 : nt! ?? ::NNGAKEGL::`string'+0x176e6 fffff880`1a197ed0 fffff800`030d7253 : fffffa80`0a51fb30 fffff800`c0000005 fffffa80`0b33eb50 00000000`00c00440 : nt!NtTerminateProcess+0xf4 fffff880`1a197f50 fffff800`030d3810 : fffff800`03122b7f fffff880`1a198a38 fffff880`1a198790 fffff880`1a198ae0 : nt!KiSystemServiceCopyEnd+0x13 fffff880`1a1980e8 fffff800`03122b7f : fffff880`1a198a38 fffff880`1a198790 fffff880`1a198ae0 00000000`00c01f50 : nt!KiServiceLinkage fffff880`1a1980f0 fffff800`030d7642 : fffff880`1a198a38 00000000`0000aab7 fffff880`1a198ae0 00000000`00c01a28 : nt! ?? ::FNODOBFM::`string'+0x488a4 fffff880`1a198900 fffff800`030d61ba : 00000000`00000001 00000000`00c00b58 00000000`77c9ff01 00000000`0000aab7 : nt!KiExceptionDispatch+0xc2 fffff880`1a198ae0 00000000`77b98e3d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x23a 00000000`00c00b60 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x77b98e3d STACK_COMMAND: kb FOLLOWUP_NAME: MachineOwner FAILURE_BUCKET_ID: X64_0xF4_c0000005_IMAGE_wininit.exe BUCKET_ID: X64_0xF4_c0000005_IMAGE_wininit.exe Followup: MachineOwner --------- |
10.12.2012., 14:20 | #5 |
Administrator
Lokacija: Sesvete
Postovi: 15,944
prvo, nisi konfu naveo. Ova iz my komp? drugo - niš pametno iz svega ovoga osim da je neki od windows procesa po*izdio Najlakše - formati i čisti reinstal windowsa, pa testiraj. Pa jedan po jedan driver gore dok ga ne srušiš opet ili dok ne skužiš jednostavno da je bilo vrijeme za reinstal windowsa. |
12.12.2012., 18:49 | #8 |
njub
Postovi: 183
eto riknul je hdd ja mislim, ne pojavljuje se u UEFI/boisu( javi se nekad kad restartam al kad opet restartam da nasnimim windowse nestane, kablovi i utori na mbo nisu provjereno), to bi znacilo da je hard otiso vrit kolko sam guglo i procito clanaka, jos samo da ovdje potvrdim i u kupnju novog. Sutra mi frend dolazi pa cu provjerit njegov hard jel radi u mojoj kanti i ako radi a 99% je da ce radit to je to 100 % |
