Staro 07.05.2010., 11:59   #1
Razer
Razer's Avatar
Postovi: 11,642
Top10 3DMark 11 @ PCE
Single card rezultati
  1. elina08 - P13640 | HD 7950 @ 1328/1606 MHz, zrak | i7 3770K @ 4.9 GHz, zrak | ASRock Z77 Extreme 6 |
  2. njuskalo1983 - P13047 | HD 6990 @ 1007/1454 MHz | i7 2600k @ 5.0 GHz, zrak | Asus Maximus IV Gene-Z |
  3. sodom - P7683, ORB | HD 5970 @ 920/1201 MHz, zrak | i5 760 @ 4.0 GHz, zrak | Gigabyte P55-UD5 |
  4. Srecko_83 - P7584 | GTX 580 @ 928/1149/1856 MHz, zrak | i7 2600K @ 5.0 GHz, voda | Gigabyte Z68X-UD7-B3 |
  5. Rush xxx - P6679, ORB | HD 6950 @ 1000/1449 MHz, zrak | i7 920 @ 4.3 GHz, zrak | Gigabyte EX58-UD5 |
  6. Wolverine - P6388, ORB | GTX 580 @ 825/1005/1650 MHz, zrak | i7 940 @ 3.8 GHz, zrak | Gigabyte X58-UD4P |
  7. HCS - P6027 | HD 6950 @ 1010/1500 MHz, zrak | Phenom X6 1090T @ 4.0 GHz, zrak | ASRock 890GX Extreme3 |
  8. Razer - P5988 | Gigabyte GTX 560 Ti SOC @ 1070/1200 MHz, zrak | i7 3960X @ 5.15 GHz, zrak | Asus Ramapage IV Extreme |
  9. DraŽ - P5925 | GTX 570 @ 880/1050 MHz, zrak | Phenom X6 1075T @ 4.2 GHz, zrak | Asus M4A89GTD PRO |
  10. d4rk_ch1ld - P5817 | HD 5870 @ 1035/1325 MHz, zrak | i5 750 @ 4.55 GHz, voda | ASUS P7P55D EVO |
Multi card rezultati
  1. zagy1984 - P14881 | Dual MSI GTX 670 Power Edition OC @ 1098/1502 MHz, zrak | i7 3770K @ 3.9 GHz | Asus P8Z68 Deluxe/Gen3 |
  2. Blue_Fatal1ty - P11589, ORB | Dual GTX 660 @ 1046/1502/1111 MHz, zrak | i5 3570K @ 4423 MHz, zrak | ASUS P8Z-77-V |
  3. elina08 - P11333 | Dual HD 6950 @ 970/1350MHz, zrak | i7 950 @ 4011MHz, zrak | Gigabyte X58A-UD3R |
  4. xyan - P11224 | Dual GTX 480 @ 900/1050MHz, zrak | i7 950 @ 4418MHz, zrak | Asus Rampage II Extreme |
  5. St-M - P9018 | Dual GTX 560 Ti @ 950/1005MHz, zrak | i7 860 @ 4.0GHz, voda | Gigabyte P55-UD5 |
  6. Sam Fischer- P7908, ORB | Dual HD 5850 @ 920/1170 MHz, stock zrak, | Phenom X6 @3,87 GHz, zrak, | Asrock 880G Extreme 3 |
  7. NJUNJO_HR - P7519, ORB | Dual GTX 460 @ 920/4100MHz, zrak | i5 760 @ 4.4GHz, voda | Asrock P55 Extreme |
  8. Offshore - 4741 | Dual GTX 550 Ti @ 940/MHz/MHz, zrak | Phenom X4 960T @ 3.8GHz, zrak | Gigabyte GA-990XA-UD3 |
Pravila
  1. Za testiranje se koristi Futuremark 3DMark 11
  2. Na screenshotu se mora vidjeti rezolucija na kojoj se pokreće test, te CPU-Z i GPU-Z gdje se vidi koji su procesor i grafička kartica korišteni.
  3. Za bilo kakvo komentiranje rezultata i slično imate temu 3D Mark 11 rezulati i komentari
  4. Rezultati koji ne slijede template, neće se naći na listi
  5. Za testiranje se koriste default postavke; ili Performance Preset.
Svi rezultati moraju biti postani prema ovoj shemi:
Code:
nick - rezultat (linkan na SS) | poželjan ORB valid |  grafička kartica @ radni taktovi (MHz), hlađenje | procesor @ brzina (GHz), hlađenje | matična ploča |
Zadnje izmijenjeno od: Razer. 08.05.2013. u 00:57.
Staro 08.12.2010., 17:28   #2
Wolverine
Wolverine's Avatar
Postovi: 12,411
Wolverine - P6388, ORB | nVidia GTX580 @825/1005/1650, stock zrak, | Core i7 940 @3,8 GHz, zrak, | Gigabyte X58-UD4P
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.12.2010., 02:01   #3
Verbum
Postovi: 679
Verbum - P4451, ORB | MSI GTX460 Hawk Talon Attack @ 970/1940/1100 MHz, zrak | i5 750 @ 4.20GHz, zrak | ASUS P7P55D |
Zadnje izmijenjeno od: Verbum. 25.12.2011. u 10:45.
Verbum je offline   Reply With Quote
Staro 09.12.2010., 03:15   #4
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
Prcko Prcić - 2850, ORB | Palit GTX 460 192 bit @ 800/1600/950, stock | Athlon II X2 245 @ 3.6 GHz, tvorničko | Asrock N68-GS3 UCC |
Prcko Prcić je offline   Reply With Quote
Staro 09.12.2010., 04:04   #5
Tyrant
Tyrant's Avatar
Datum registracije: May 2009
Postovi: 54
Tyrant - P4601, ORB | ATI HD5850 @ 925/1175 MHz, stock zrak | Core i7 950 @ 4,2 GHz, Corsair H50 | Asus Rampage II Extreme
Tyrant je offline   Reply With Quote
Staro 09.12.2010., 12:47   #6
sodom
sodom's Avatar
Postovi: 593
sodom - P7683, ORB | ATI HD 5970 @ 920/1201, AC Accelero Xtreme, | Core i5 760 @ 4,0 GHz, zrak, | Gigabyte p55-ud5
sodom je offline   Reply With Quote
Staro 23.01.2011., 12:23   #7
elina08
Seven
elina08's Avatar
Datum registracije: Jul 2009
Postovi: 97
elina08 - 5311 | HD 6870@1025/1200MHz , Zrak | i7 950@4.4GHz , Zrak | Gigabyte X58A-UD3R |
Zadnje izmijenjeno od: elina08. 23.01.2011. u 17:24.
elina08 je offline   Reply With Quote
Staro 23.01.2011., 13:48   #8
asibulj
Misanthrope
asibulj's Avatar
Lokacija: Neumünster
Postovi: 568
asibulj - 3724, ORB |GTX460 HAWK@ 870/1740/1960 zrak| X4 B20@ 3,0 Hyper 212+ ZRAK | Asus M4N72-E|
x230
asibulj je offline   Reply With Quote
Staro 23.01.2011., 14:47   #9
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,196
jopis - 4982 |HD 6950 @840/1325MHz, zrak | Q6600 @3,2GHz, zrak | Gigabyte X38-DS5
Staro 24.01.2011., 16:44   #10
HCS
Premijum
HCS's Avatar
Postovi: 1,359
HCS - P6027| HD 6950@1010/1500MHz, Zrak | 1090T@4000MHz, Zrak | ASRock 890GX Extreme3
Staro 24.01.2011., 21:07   #11
BojanZD
BojanZD's Avatar
Postovi: 1,396
BojanZD - P4158 / GTX 470@800-1674 /Q6600 3,4GHZ Zrak/ Asus P5Q-E
http://3dmark.com/3dm11/501614;jsess...N6BReVmhdP4wbv
edit:
Autor BojanZD Pregled postova
200MHZ gore i 100 bodova bolje http://3dmark.com/3dm11/521313;jsess...rPtUJMjBPaWbhd
Zadnje izmijenjeno od: Razer. 28.04.2011. u 12:12.
BojanZD je offline   Reply With Quote
Staro 26.01.2011., 17:53   #12
Rush xxx
Postovi: 41
Rush xxx-6679 ORB |HD 6950@1000/1449zrak|i7 920@4,3zrak|Gigabyte x58-UD5
Rush xxx je offline   Reply With Quote
Staro 30.01.2011., 15:59   #13
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
d4rk_ch1ld - P5817 | VTX HD5870 @ 1035/1325 MHz, zrak | i5 750 @ 4.55GHz, voda | ASUS P7P55D EVO |
d4rk_ch1ld je offline   Reply With Quote
Staro 05.02.2011., 17:50   #14
DraŽ
DraŽ's Avatar
Lokacija: Miami, 1984, Ferrari F40
Postovi: 902
DraŽ - P5925 | Palit GTX570 @ 880/1050MHz, zrak | x6 1075T @ 4,2GHz, zrak | ASUS M4A89GTD PRO
Može update rezultata? I molim da se razmotri nepriznavanje rezultata sa radeonkama kod kojih je korišten slider za teselaciju kad već nije PissX priznat kod vantage-a.
Skylake PCIvy bridge Notebook
CPU: Intel Core i7 6700k @ 4.4GHz, 1.28V Adaptive, LLC 4
COOLER: Scythe Mugen Max
MBO: ASUS Z170 Pro Gaming
RAM: Kingston HyperX Savage DDR4 16GB (2x8GB) 2666MHz CL13
GPU: Asus Strix Nvidia GeForce GTX 1080
SSD1: Crucial MX500, 1TB
HDD1: WD Green 3TB, WD30EZRX
HDD2: WD Red 4TB, WD40EFRX
HDD3: WD Blue 6TB, WD60EZRZ
HDD4: WD Blue 6TB, WD60EZRZ
OPTICAL DRIVE: LG CH10LS20, Blu Ray
PSU: EVGA Supernova G2, 550W
CASE: Fractal Arc XL
VENTS: 3x Fractal 140mm, 3x Arctic Cooling F14, 140mm
OS: Win 10 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: Panasonic P47AS650 - 47 inch, IPS, 1920x1080, 3D + DIY Ambilight
MOUSE: Logitech MX Master 2s
KEYBOARD: Roccat Suora FX with HyperX Palm Rest
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD598 SE
DELL Inspiron 15R, 5520
Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
AMD Radeon 7670 + Intel HD4000
OCZ Agility 3, 120GB
15,6 inch LCD, 1366x768
6-cell baterry, 48Whr
Win 10 Pro, 64-bit
Zadnje izmijenjeno od: DraŽ. 20.02.2011. u 19:39.
DraŽ je offline   Reply With Quote
Staro 17.02.2011., 23:12   #15
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 673
NJUNJO_HR - P7220,
