09.07.2006., 17:43 | #1 |
Lokacija: Vž
Postovi: 81
CCNA1 Case study - Structure Cabling
Pozdrav! Ima tu netko tko je zavrsio CCNA i radio je taj CS za 1. semestar? Trebam malu pomoc, neda mi se raditi to a nit ne znam radit s power pointom pa bi zamolio nekog da mi posalje mailom ako ima
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore |
