04.07.2006., 11:32 | #1 |
Propali Amigaš
Lokacija: Nin
Postovi: 6,959
Li-Ion baterije - optimalno korištenje
The rules for handling Li-ion batteries are as follows: 1. Use them--don't store them, as their maximum useful life is four years regardless of what else you do to them. 2. If you must store them, do so at a charge level of 40%. 3. Don't get them too hot, especially when charging or discharging. They absolutely must be kept cool. 4. Use the correct charger. Using a charger for another type of battery will quickly destroy the Li-ion battery and is likely to make it overheat and catch fire/explode (and that's not "likely" as in "there's a theoretical possibility"--it probably will). |
27.07.2006., 22:28 | #2 |
Software developer
Postovi: 47
E baš mi se ovo prvo sviđa. od kad sam dobio laptop, najviše ga volim pustiti da radi na bateriji no nisam bio siguran koliko je to pametno kad se non-stop upotrebljava. Jesi to skinuo sa neke službene stranice ili? |
28.07.2006., 00:20 | #3 |
Propali Amigaš
Lokacija: Nin
Postovi: 6,959
Nekakav tehnički forum, ko PCexpert |
