Staro 16.10.2017., 00:17   #2941
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Bok!
Može li bolje od 280-290 Sol/s za GTX 1060 (3GB, Hynix)? zCash/EWBF 0.3.4b
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 16.10.2017., 09:39   #2942
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,491
može i preko 300, ovisi koju GTX verziju imaš
Staro 16.10.2017., 09:47   #2943
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Mislim da ne može, ja nisam niti jednu uspio.
Staro 16.10.2017., 10:08   #2944
Alister
Alister's Avatar
Postovi: 1,491
Gigabyte GTX1060 3GB WindForce OC 3G, 3 GB DDR5 - radi ovako samo uz modifikaciju taktova u par sekundi, nisam se igrao s njoj malo ozbiljnije pa vjerujem da bi mogla i bolje
CUDA: Device: 0 GeForce GTX 1060 3GB, 3072 MB i:64
CUDA: Device: 0 Selected solver: 0
Temp: GPU0: 56C
GPU0: 307 Sol/s
Total speed: 307 Sol/s
INFO 09:03:14: GPU0 Accepted share 78ms [A:1, R:0]
Temp: GPU0: 60C
GPU0: 300 Sol/s
Total speed: 300 Sol/s
INFO 09:04:01: GPU0 Accepted share 63ms [A:2, R:0]
Temp: GPU0: 62C
GPU0: 296 Sol/s
Total speed: 296 Sol/s
INFO: Detected new work: 01a6b366d07119e3af80
INFO: Detected new work: d2dc9b70058217db3a03
Temp: GPU0: 63C
GPU0: 299 Sol/s
Total speed: 299 Sol/s
INFO: Detected new work: 944fd76ad2e87411e93e
INFO 09:04:54: GPU0 Accepted share 78ms [A:3, R:0]
Temp: GPU0: 65C
GPU0: 297 Sol/s
Total speed: 297 Sol/s
Temp: GPU0: 66C
GPU0: 298 Sol/s
Total speed: 298 Sol/s
INFO 09:05:59: GPU0 Accepted share 47ms [A:4, R:0]
INFO 09:06:07: GPU0 Accepted share 94ms [A:5, R:0]
Temp: GPU0: 66C
GPU0: 301 Sol/s
Total speed: 301 Sol/s
INFO 09:06:32: GPU0 Accepted share 47ms [A:6, R:0]
pa mislim da bi netko tvog kalibra mogao i bolje napraviti
Zadnje izmijenjeno od: Alister. 16.10.2017. u 10:22.
Staro 16.10.2017., 10:29   #2945
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
To je hynix?
Koje točno postavke?
Staro 16.10.2017., 10:41   #2946
Alister
Alister's Avatar
Postovi: 1,491
Evo, tako mi je podešeno za ono gore, kada radi. Dalje se nisam igrao s tim jer jednostavno nemam vremena ovih dana
Staro 16.10.2017., 10:47   #2947
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Može bolje, ali dali može efikasnije? Odgovor je ne!
Moje guraju i do 330 solsa. do cca 280 solsa je omjer 2,45 sola po 1w. Iznad svi ovi dodatni su 1 sol 1 w. Tako da nema smisla.
Ali kad imaš jednu grafu onda se iz nje to izvlači bez ikakvog beda.
Staro 16.10.2017., 10:49   #2948
markec2102
Datum registracije: Sep 2017
Postovi: 92
Imam jedno (vjerojatno) glupo pitanje ali rekoh da provjerim. Naime, kupio sam za RIG modularno napajanje SAMA ARMOR 750W 80+ GOLD i s njim dobio dva kabela za napajanje grafičke (8 pin na 2+6 pin). Svaki kabel ima 2 izlaza, što znači da pomoću njih mogu spojiti 4 grafičke kartice. Na napajanju imam 3 grupe konektora. 1. Mainboard, 2. IDE/SATA (6pin), 3. CPU/PCI-E (8pin). Imam još 2 kabela u rezervi 6 na 6 pin pa me zanima da li mogu spojiti 5. karticu na 2. grupu konektora (tj. na IDE/SATA). Ne znam da li su isti naponi pa da nešto ne skurim...
Hvala!
markec2102 je offline   Reply With Quote
Staro 16.10.2017., 13:05   #2949
ThePornstar
Postovi: 4,403
Autor Alister Pregled postova
Temp: GPU0: 56C
GPU0: 307 Sol/s
Temp: GPU0: 60C
GPU0: 300 Sol/s
Temp: GPU0: 62C
GPU0: 296 Sol/s
Temp: GPU0: 63C
GPU0: 299 Sol/s
Temp: GPU0: 65C
GPU0: 297 Sol/s
Temp: GPU0: 66C
GPU0: 298 Sol/s
Temp: GPU0: 66C
GPU0: 301 Sol/s
Ista kartica i ista memorija, ali za 300 Sol/s mi trebaju puno veći taktovi. Na kojem si poolu?
EDIT: sad sam tek skužio da je jezgra na 2 GHz. Da, tak i kod mene ide. Inače boostam na 1920/4200 i spustim TDP na 85%. To daje od 280-295 Sol/s.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Zadnje izmijenjeno od: ThePornstar. 16.10.2017. u 13:29.
Staro 16.10.2017., 13:09   #2950
Alister
Alister's Avatar
Postovi: 1,491
eu1-zcash.flypool.org ako misliš na to
Staro 16.10.2017., 18:34   #2951
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor markec2102 Pregled postova
Hvala!
Neće ići, različiti su naponi.
Čak i kod istog proizvođača su različiti pinovi/naponi ovisno od modela do modela tj. serije, jer su različiti OEM-i.
Npr. ovakva je situacija kod Corsaira:
http://www.corsair.com/en-us/landing...-compatibility
Stoga, ako vam netko pokloni modularni PSU kabel uz grafu, preporuka je NE uštekavati to u svoje napajanje ako niste sigurni s kojeg je napajanja došlo tj. da li su pinovi kompatibilni.
Nedavno su mi stigli adapteri (8p CPU -> 2x 6+2 PCIe), koji komotno ulaze i u 8p PCIe ... a polovi na PCIe i CPU konektorima su obrnuti. Ako napajanje ima slabije mehanizme zaštite, moze nastati solidan vatromet :/
Zadnje izmijenjeno od: dh41400. 16.10.2017. u 18:41.
Staro 16.10.2017., 19:18   #2952
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
Pitanje za majnere. Sad trenutno ovak malo iz fore majnam sa svojom 270x Zcash claymores miner, nanopool, i dobivam oko 180-185 H/s, sto je oko 16$ mjesecno. Probao sam startat monero miner i tamo dobijem oko 480 H/s i sad mi nije jasna jedna stvar.
Svi poolovi za monero imaju jako veliku iznos za minimalnu isplatu, s time da jos imaju transaction fee koji je za isplatu na mjenjacnicu dvostruk. Pa mi nije jasno, zar onda ispada da transfer fee pojede sve sto zmajnam sa ovom sirotinjom ili sam nesto propustio.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 16.10.2017., 21:11   #2953
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Autor maXonja Pregled postova
Probaj expanse pa vidi koliki ti je hashrate
Posložio sve za expanse. Hashrate je nekih 19-20 MH/s.
Kako da provjerim što je profitabilnije?
Računao sam do sada na cryptocompare.com za ETH.
Nema za EXP.
Staro 16.10.2017., 21:14   #2954
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor PR3DA70R Pregled postova
Nema za EXP.
ima na whattomine.com
Staro 16.10.2017., 21:26   #2955
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Ok hvala, evo vidim.
Kako uopće provjeriti ako ne znam koji hashrate mi daje grafa za neku određenu valutu?
Ili baš moram postaviti majner za recimo, Monero, vidjeti koji je hashrate, pa tek onda na kalkulator?
Staro 16.10.2017., 21:27   #2956
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor Bl@de Pregled postova
Majnaj Zcash, Zen ili ZCL
A jesi probao otići na stranicu i upisati koju grafu imaš? Brijem da je prejednostavno sve skužiti...
Staro 16.10.2017., 21:30   #2957
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Pokušao sam. Vidim samo ponuđeno, među kojim nema GTX 970. :/
Btw, može li vrijediti isti odgovor na pitanje kolegi gore i za mene sa GTX 970?
Staro 16.10.2017., 21:34   #2958
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
I ne treba ti ponuđeno, sam upišeš svoj hashrate, nemoj biti lijen...ionako su njihove defaultne vrijednosti pogrešne
Zadnje izmijenjeno od: FRipper. 16.10.2017. u 21:45.
Staro 16.10.2017., 21:57   #2959
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Ma nije mi jasno to sa tim "pod vrstama" valuta. Tj. sad sam skužio da je sve ovo ethash, groestl, x11gost... Zapravo algorithm. Što bi značilo da su EXP, ETC, MUSIC itd. sve dio ili podvrsta ETH-a (glavnog coina), tj. ethash kao što to piše na whattomine. Jesam dobro razumio?
Ali to ne znači onda da isti hashrate vrijedi za sve što spada pod ethash?
Moram za svaki coin, bez obzira na glavni coin ili valutu općenito, prvo provjeriti hashrate u softveru za majnanje bilo kojeg coina ili ne moram?
Ah, questions, questions... Sorry davim, znam.
Staro 16.10.2017., 22:09   #2960
renaTq
renaTq's Avatar
Datum registracije: May 2017
Postovi: 387
Uspio upogonit i trecu RX 580-icu nakon 1h i nesto. Ukupno 90mh/s i 420w potrosnje.
#propo
renaTq je offline   Reply With Quote
Staro 16.10.2017., 22:09   #2961
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ma skoro isti hash je za sve...
Staro 16.10.2017., 22:11   #2962
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Za sve unutar glavnog coina misliš?
Staro 16.10.2017., 22:16   #2963
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,603
Uz neke iznimke
Recimo R9 280X ETH/ETC rade oko 13MH/s, a EXP oko 24-25 MH/s
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 16.10.2017., 22:19   #2964
ludizec
ludizec's Avatar
Datum registracije: Oct 2017
Postovi: 5
Čitam redom, ali ne nalazim detaljan odgovor, pa isprike ako postavljam isto pitanje na koje je već odgovoreno, ali trebam pomoć:
1. kad rudarim , mogu direktno izrudareno "slati" na kraken account?
2. kako na kraken acc povisiti dnevni limit povlačenja s 20€, iako piše da je dnevni limit 2000 €?
3. koji je proces prodaje preko localbitcoinsa? i koliko je siguran?
hvala
ludizec je offline   Reply With Quote
Staro 16.10.2017., 22:26   #2965
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1. da
2. verifikacijom, mislim da je sve lijepo tamo opisano
3. Regaš se, uplatiš bitcoin ljudima i daš svoj broj računa i podatke, čekaš da sjedne lova, kada sjedne "otpustiš" svoj bitcoin koji si uplatio. Sigurno je, pogotovo preko Marina i Nikole iliti direkt preko njihove stranice https://bitcoin-mjenjacnica.hr/#buy-sell
Staro 16.10.2017., 22:33   #2966
ludizec
ludizec's Avatar
Postovi: 5
tnx,
kraken verifikacija je odrađena, Tier 2, no stoji Maximum withdrawall 20.95€, ne kužim kako to promijeniti?
Staro 16.10.2017., 22:37   #2967
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
tier 3
Staro 16.10.2017., 22:40   #2968
ludizec
ludizec's Avatar
Postovi: 5
hvala
Staro 16.10.2017., 23:00   #2969
markec2102
Postovi: 92
Autor dh41400 Pregled postova
Hvala na odgovoru. Koje su mi onda opcije. Naručio sam 8 na 6+2 pina kabel s ebaya. Kako provjeriti da li su pinovi kompatibilni s mojim? Prijatelj mi kaže da spojim s molex kablom...
Staro 16.10.2017., 23:17   #2970
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ni mi jasan ovaj odgovor od dh41400... ili sam ja krivo shvatio
Jer nije mi jasno, što je tu komplicirano.
Ako imaš napajanje sa 4 pcie konektora, ta 4 spojiš 4 grafe a 5tu grafu spajaš preko molex/sata na 8pin adapter...
https://www.hdcabling.co.za/images/8...le_adapter.png
a ako je grafička sa 6pin, onda ovaj http://titan-ice.co.za/images/detail...olex_6pcie.gif
mislim, to je sva mudrost...
