Staro 20.07.2010., 22:08   #241
xax232
Postovi: 27
xax232 je offline   Reply With Quote
Staro 21.07.2010., 00:02   #242
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
360kn bez postarine...
gledao sam da ga uzmem vani al ovdje ga imam odmah u rukama
.i.
Razer Blade 15
Staro 21.07.2010., 02:58   #243
xax232
Postovi: 27
Autor Codiac Pregled postova
Ako ga narucis na vrijeme, zakasnit ce ti samo dan-dva, buduci da se sve salje ranje kako bi stiglo na odrediste do dana sluzbene objave. Za razliku u cijeni definitivno se isplati.
Staro 21.07.2010., 04:40   #244
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
Brate mili al ovi naši cepaju. 450kn je too much.
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 21.07.2010., 08:35   #245
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
nisam pratio previše,pa isprika ako je već bilo!
dali plačamo svaki od 3 dijela po 400-500kn ili?
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 21.07.2010., 11:37   #246
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
vjerovatno
.i.
Razer Blade 15
Staro 21.07.2010., 12:54   #247
ezz
ezz's Avatar
Datum registracije: Feb 2010
Postovi: 297
tako je
ezz je offline   Reply With Quote
Staro 21.07.2010., 13:53   #248
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
ah,sjajno...1500kn za cijelu igru!
Staro 21.07.2010., 14:55   #249
Mar
Suit up!
Mar's Avatar
Postovi: 5,977
Kako vas Blizzard vesla, to je nevjerojatno
I onda kažu da je Apple pokvaren
- Barney Stinson
Staro 21.07.2010., 15:55   #250
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Da, znaš kak će kupovat. Pa nebi dal za igricu 1500kn....to su obične gluposti. I još se bude online igraje naplačivalo možda?
Možda bu se online dalo kupiti jeftinije, samo key ili slično!
danc00 je offline   Reply With Quote
Staro 21.07.2010., 16:32   #251
ezz
ezz's Avatar
Postovi: 297
lol, puno dat 4 i pol glave za igru, odes van i odu 4 i pol glave za par cuki, a igru mos igrat i tisucu sati...
Staro 21.07.2010., 16:40   #252
BSA<AK-47>
BSA<AK-47>'s Avatar
Postovi: 1,460
ako sam dobro skužio igra je podjeljena na 3 dijela,svaki za drugu rasu!
kao fanu igre mi i nije baš puno dat ali što ako se zasitim jedne rase i želim probat sa drugom(a 100%budem htio)?
a cijena ista!
Staro 21.07.2010., 19:30   #253
ezz
ezz's Avatar
Postovi: 297
LOOL, drugi nastavci ce bit samo za single player, sa wings of liberty cete moc igrat normalno multi sa svim rasama
Staro 21.07.2010., 22:55   #254
Codiac
bycod
Codiac's Avatar
Postovi: 6,699
Autor Mar Pregled postova
eeee da samo sto kad blizzard napravi igru ona traje 10 godina
imho dao bi i 1000kn za starcraft2 jer cu ga igrati minimalno 5 godina...
.i.
Razer Blade 15
Staro 21.07.2010., 23:42   #255
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Dat ćeš i više od 1000kn ak ga hoćeš igrat
Staro 22.07.2010., 13:53   #256
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,393
Staro 23.07.2010., 12:53   #257
capri
capri's Avatar
Postovi: 62
Ma kupi se samo prvi dio za multiplayer jer on ce vaziti i nakon sto izadju drugi i treci dio, tj multiplayer ce se moci igrati sa prvim dijelom i nakon sto ostali izadju a meni je samo to i bitno
capri je offline   Reply With Quote
Staro 23.07.2010., 14:52   #258
ezz
ezz's Avatar
Postovi: 297
http://img808.imageshack.us/img808/7889/sc2an.jpg
Mod: mogao si barem u thumb staviti.
Zadnje izmijenjeno od: Hamm. 23.07.2010. u 16:14.
Staro 23.07.2010., 16:37   #259
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Autor capri Pregled postova
Zato svi igraj w3 reign of chaos a ne TFT? retardirano....
Dobro znamo da ce bit nove jedinice sa ekspanzijama i da ce svi na netu igrat sa ekspanizijom tako da...
Staro 23.07.2010., 16:47   #260
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,884
Autor ezz Pregled postova
mislio si reć skirmish i online mutliplayer??
Staro 23.07.2010., 18:06   #261
beasthunter
Datum registracije: Jul 2010
Postovi: 37
Autor demetrius Pregled postova
mislio je rec da je ovaj nastavak kaj ce sad izace 1 od ukupno 3.
Ovaj sad nastavak ce bit single play samo za terrane ak se dobro sjecam.
mutliplayer i sve funkcije osim zerg i protos single playa ce se moc najnormalnije odvijat, tak da ak ti netreba single play jer ces igrat samo
preko bneta onde ti ustvari ni netrebaju ostali nastavci, ajmo rec to tak.
A kaj se tice da je preskupo 450 kn za igru,tu se vec da diskutirat,
posto WoW dode punnno puno vise. mene je doso cca 3000, s tim da sam
jos igro i preko piratskih neko vrijeme tak da to ne racunam.
Al kaj se tice SC2 imam doma betu koju sad nemogu igrat jer su izbacili
patch 16 i 17 a loader nevrijedi za njih, mislim da je igra vrijedna tih dinara
i ja bum si ju svakako uzeo
Taman sad u utorak fino u algoritam propeglam karticu i gas doma
beasthunter je offline   Reply With Quote
Staro 23.07.2010., 18:37   #262
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Puff ... igral BETU zahvaljujući pajdi koji je doniral key ...
Realno - igra je vrlo dobra i moram priznati da mi se sviđa. Kod mene se vrtila bez problem.
Međutim uvijek postoji onaj ali - ma koliko SC1 meni bio dobar prošlo je godina i JA više nisam dobar ...
Twitch kids me rasutraju. Više vremena, više CPS, više svega = mrtav starkelja. Tako da vjerujem kako neću kupovati SC2 isključivo jerbo nemam vremena postati dobar
Inaće - cijena je fuj, ali igra je mrak
Staro 23.07.2010., 18:44   #263
beasthunter
Postovi: 37
Autor Paske Pregled postova
cijena je uvijek fuj kakva god bila
Staro 23.07.2010., 18:51   #264
ezz
ezz's Avatar
Postovi: 297
u tijeku je king of the beta turnir, sve vod-ove mozete pratiti tu :
http://day9tv.blip.tv/posts?view=archive&nsfw=dc
preporučam pogledati sve partije od testera koji je pro gamer u koreji i jednostavno savršeno igra protosa
Staro 24.07.2010., 07:07   #265
beasthunter
Postovi: 37
pogledo sam tih replayeva brdo, i mogu priznat da sam gro toga naucio samo iz replayeva iako znam da ce me prih mjesec dva svi gazit ko beba zvecku dok se malo ne ufuram.
Jedna stvar kaj mi uzasno ide na zivce kod replayeva i komentiranja, zakaj
prvih 3 minute sere o tom kak ta dva lika igraju i ovo ono daj pusti replay
pa onda pricaj...
Staro 24.07.2010., 13:50   #266
Deathwish
overpowered
Deathwish's Avatar
Postovi: 916
Autor beasthunter Pregled postova
pa onda pricaj...
ukucaj day9 u google, to ti njegov site sa gro replayeva i analiza
što se tiče zaš priča o tome, to je iz razloga što je razer sponzor i daje im 2000dolara za 1. i 1000 za drugo mjesto, pa ono, kinda mora dat razerov logo da se vidi
@Work HP Zbook15
@Home Acer 5020
Deathwish je offline   Reply With Quote
Staro 24.07.2010., 22:25   #267
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Je cijena je fuj, ali kad se sjetis kako su blizz igre optimizirane, doradene i prokleto zarazne onda i nije tako jako strasno. Igara tog kalibra na PC-u valjda nema 10 u zadnjih 10-15 godina.
Bljuje mi se kad se sjetim koliko su kostale neke trash igre kao npr pojedini nastavci NFS-a.
Samo neka se drze kvalitete, cijena ce vec doc na svoje
Chuby je offline   Reply With Quote
Staro 25.07.2010., 08:16   #268
beasthunter
Postovi: 37
Autor Deathwish Pregled postova
inace sam gledo HD husky komentiranja na youtubu
a ovo od Day9 sam vidio bas u ovom postu i odma krenu
pogledo sam ih vec podosta
A kaj se tice komenitranja prije pocetka replaya imas pravo al opet
malo iritantno, vjerojatno je sve stvar navike.
Jos 2 dana pa halk, kad kupim i otvorim acc budem tu posto kak bum se nazvo pa me mozete dodat na friend list, bar oni koji ce igrat ^^
EDIT:
ovo mi je brutalno
http://press.razerzone.com/content/view/430/101/
Zadnje izmijenjeno od: beasthunter. 25.07.2010. u 10:23.
Staro 26.07.2010., 13:58   #269
mzaper
Postovi: 41
kupovina igre
Joj kolege moje, ja sam prije mjesec dana naručio SC2 kao preorder i cijena je bila 60$ ili oko 300 kuna. Prije koji dan sam bio u Algoritmu, kažu kod njih je SC2 440 kn – 5% popusta ako se rezervira unaprijed igra. Ja sav sretan, kako sam pametan i genijalan i zgodan i lijep! Pa ja sam prošao 120 kn jeftinije!
Ali onda sam odbio šamarčinu od carine, kažu ovako, carina je 10% na cijenu, dakle 30 kuna i još PDV 23% na cijenu i carinu. Što izađe 426,5 kn! Ne moram ni pričati da me još bridi ovaj šamar naše države.
Ali da bi kao pravi katolik na šamar okrenuo ( ne svojom željom doduše ) i drugi obraz, pobrinuo se Blizzard koji je prije par dana stavio na net mogučnost skidanja SC2 kao Digital copy (opcija skidanja na komp i plati se samo CD key). Cijene Digital copy-a nema, ali pretpostavljam da će biti jeftinije od 425 kuna.
Eto kolege moje, učite na mom primjeru i muci. A zaključak bi bio „strpljen spašen“.
Živjeli i uživajte u ljetu!
Vaš Ja.
ps: poštovani Admini, nije uredu što mi uređujete post bez ikakvih obavijesti i pitanja. Molio bih Vas ako smatrate dio posta neprimjeren da mi to javite a ne obrišete nasilu. Tako smo prije radili i pošteno je bilo, nevidim razloga ovakom pokazivanju "mišića".
asdasfdassda
Zadnje izmijenjeno od: mzaper. 26.07.2010. u 14:35. Razlog: to se i ja pitam.
mzaper je offline   Reply With Quote
Staro 26.07.2010., 15:06   #270
Mar
Suit up!
Mar's Avatar
Postovi: 5,977
Autor mzaper Pregled postova
Po kojem tečaju?
60x5,8= 348kn, a vjerojatno i malo više kad uračunaš razne takse banaka.
- Barney Stinson
