Staro 23.12.2024., 09:16   #241
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,386
Ček, ove će se zvat 9000, a 8 preskaču ili je ovo sve samo za laptope....nisam baš skužio.
Slobodno me dodajte na PSN
Staro 23.12.2024., 09:25   #242
Postovi: 8,546
Izgleda da su 8000 seriju odlučili iskoristiti za Strix Halo i općenito nove APU modele, pa onda za desktop nastavljaju sa RX 9000.
AMD Radeon RX 9000 "RDNA 4" GPUs & Ryzen 9 9000X3D "Zen 5" CPUs to debut at CES 2025 along with AI-powered FSR 4 technology
Zadnje izmijenjeno od: The Exiled. 23.12.2024. u 09:45.
Staro 23.12.2024., 21:23   #243
Mladenxy
Mladenxy's Avatar
Postovi: 4,472
Po ovome ista kao RX 7900 GRE. Ak je tako veliko razočarenje osim ako ne bude po 550 eura pol godine od izlaska
Staro 24.12.2024., 09:20   #244
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,386
I trosila 180w ili manje plus da ima 20gb vram.
Ce da vidimo, ali mi se cini da ce biti pucanj u prazno.
Ovo mi sve visi lici na reciklazu ala GCN.
Staro 24.12.2024., 10:18   #245
Postovi: 8,546
Daniel "RTX 4060" Owen (1 - 2) kao loša verzija MLID Toma (koji pak nema mogućnost priznati vlasiti zajeb), radi analize nadolazećeg hardvera temeljem procurenih screenshota s kineskih foruma. Jedina nova kartica koju se isplati kupiti je ARC B580, sve ostalo blijedi u usporedbi.
3DMARK Time Spy scores aren’t indicative of gaming performance in modern titles. The benchmark was released in 2016 and was one of the first DirectX 12 benchmarks available. Games have changed a lot over the past eight years, meaning that this benchmark score doesn’t indicate real-world game performance. This is especially true once modern features like ray tracing are added.
EDIT:
AMD Radeon RX 9070 XT expected to boost up to 3.1 GHz, 260-330W TBP depending on a model
The reference (public) version of the Radeon RX 9070 XT will have a TBP (Total Board Power) of around 260W, while custom models may go as high as 330W. This represents a visible gap of 70W (approximately 27%) between AMD’s design and what board partners are working on. However, it is unclear if this will result in a similar linear performance boost. The base clock of the new Radeon GPU is 2.8 GHz, while the boost clock should range from 3.0 to 3.1 GHz, depending on the model. Many current-gen graphics cards can already surpass this frequency with overclocking. With a TBP of 260W, the card is expected to sit between the next-generation RTX 5070 Ti and RTX 5070 in terms of power consumption. The leaker also claims that the RX 9070 XT’s performance is within 5% of the RTX 4080 in games he is familiar with. No data was provided, though. It’s worth noting that the so-called “leaked” 3DMark scores reported by some sites are not accurate. The 3DMark software does not display correct names for unreleased graphics cards this early. So please keep that in mind.
Izvor: VideoCardz
Zadnje izmijenjeno od: The Exiled. 26.12.2024. u 13:40.
Staro 27.12.2024., 23:45   #246
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
Bit ce rx 9070xt zvijer od grafe samo kaj ne bude ispod 600$.
Staro 29.12.2024., 09:16   #247
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,386
Ako bude tako kako piše sa 4080, bit će to super. Naravno da i cijena igra ulogu.
Staro 29.12.2024., 14:14   #248
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,668
Ovaj timespy mi nema nikakvog smisla, bez obzira jel benchmark star ili ne. Ne može grafa bit na razini 7900gre. Mislim, može, ali onda cijena mora bit 400 eura i manje
Budemo vidjeli, ali ako je to istina to će značit da AMD već tri generacije prodaje istu grafu, 6800xt-7800xt-9070xt, sa generacijskim pomakom na razini čuvene Intelove quad ere
Staro 29.12.2024., 14:25   #249
Postovi: 8,546
Mislim da su se dosad već svi ogradili od tih Time Spy rezultata, jer jedino čemu služe je generiranje klikova za pregled videa, tak da se ne treba previše obazirati i zamarati.
Ukoliko kartica ne bude vredu, ne pomogne joj Isus dragi Bog, a ukoliko ispadne u svemu rang RTX 4080 za cijenu od 650€, to bude čist OK.
Staro 30.12.2024., 03:36   #250
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
9070xt vs 7800xt: +20% clock, ~isti bw i 6% extra CU = 50% brža kartica?
Mora da je ta rdna4 neka jebačka arhitektura.
Po meni, best case scenario ~7900xt raster, RT nemam pojma.
Uz nadam se agresivnu cijenu (<$500), bolji upscaler i neki zanimljivi feature.
Rado bi ovu svoju zamijjenio s nečim novijim, ali nakon prošle generacije nekako nemam previše vjere u dobre cijene. Još je i $$ otišao gore...
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 30.12.2024., 20:09   #251
MAGARAC
MAGARAC's Avatar
Postovi: 5,995
7800xt je bila brza od 6800xt sa 20% manje CU. Tak da se komotno moze ocekivat 15% od nove arhitekture..
Staro 03.01.2025., 12:41   #252
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,309
Problem je što je neznatna razlika između 6800XT i 7800XT.
Ostaje problem usporedbe još neizdane katice s nečim što je već dugo na tržištu
Chuby je offline   Reply With Quote
Staro 05.01.2025., 21:51   #253
tole_
Casual Racist
tole_'s Avatar
Postovi: 422
Autor MAGARAC Pregled postova
Je, samo su to postigli na način da su kod rdna3 simd jedinice dobile mogućnost procesuiranja 2 instrukcije po ciklusu, teoretski duplajući broj shadera i compute snagu. Nešto slično, ali različito od onog što je nv napravila još kod Ampera. Uglavnom, nije baš 1:1 usporedba rdna2 i rdan3 CU. Za rdna4 je bilo slabo leakova, sve što sam pročitao je da su ispravili "nedostatke" iz rdna3 (+bolji rt). Ondosi li se to uglavnom na max takt ili ima još nešto vidjet ćemo sutra valjda.
Druga stvar zašto sumnjam da može dostići 7900XTX je bandwidth. Ako su glasine točne, N31 ima 50% više bandwidtha i (vjerojatno) cachea od N48. Za primjer uzmi 7900GRE koja bi po sirovoj snazi trebala biti unutar 5% od 7900XT, a u praksi zasotaje valjda 20% zbog uže sabirnice. Jedino za što se može uhvatiti je navodni 300+W TDP uz nadu da nisu stagnirali ili otišli unazad po pitanju fps/W. Ali iskreno sumnjam i u tih 300W, bar za referentne kartice. Nitro, RedDevil i sl. moguće. Na kraju dana, da može dohvatiti 7900xtx performanse, nekako sumnjam da bi ju zvali 9070xt.
Ali zanimljivo kako imaš 2 leaka, jedan lošiji, drugi bolji. Naravno svi se uhvate za ovaj bolji i kad ispadne da je ovaj lošiji točniji, onda se bude sralo po AMDu. Već viđeno sto puta. Bolje ne očekivat previše, pa biti ugodno iznenađen.
Staro 06.01.2025., 10:05   #254
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
A rekli su da ne idu na high-end, tako da ne treba očekivati čuda. Teško da će biti brža od 7900 GRE. Sve ovisi koliko će nabiti cijenu, rekao bih da će biti između 450 i 500 USD.
Staro 06.01.2025., 12:51   #255
Postovi: 8,546
According to AMD, the change to the RX 9070 series was necessary to “simplify the model system to match direct competitor comparisons.” AMD also confirms that the 9000 series will be synchronized with the 8000 series, which includes integrated graphics within the Strix Halo APUs. While AMD did not present any performance slides today, it did confirm that the RX 9070 series will replace the RX 7900 XT, RX 7900 GRE, and RX 7800 XT tiers, while the RX 9060 series will succeed the RX 7700 XT and RX 7600 XT tiers. Only these two series have been mentioned so far.
Staro 07.01.2025., 08:21   #256
BinaryJesus
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 307
BinaryJesus je offline   Reply With Quote
Staro 07.01.2025., 10:36   #257
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,386
Pa nije baš kurčina, ako baciš oko na nV drlog koji izbacuju.
Imat ćeš 5070 sa 12gb VRAM za nekih 600+€, 5070Ti sa 16gb VRAM za 900+€, 5080 16gb za 1200+€ i za kraj vrhunsku 5090 sa 32gb za 2300+€.
9070XT će nadam se imati min 16gb, a možda i 20-24gb VRAM i neka košta 600injak€ ili još bolje 500injak i mogla bi biti jako dobra u tom rangu cijene.
Slabiji modeli da budu isto cijenom kako treba.
nV sa cijenama i količinom VRAMa gori od applea.
Staro 07.01.2025., 15:07   #258
Chuby
Chuby's Avatar
Postovi: 1,309
Autor MadBoY Pregled postova
Zvuci mi preoptimisticno.
Ako fakat isfuraju takvu cijenu i zarade nesto pri tome onda su stvarno na dobrom putu
Staro 07.01.2025., 17:53   #259
Mladenxy
Mladenxy's Avatar
Postovi: 4,472
Mogli su jučer nekaj i pokazati od toga ..pobjegli ko pizde
Staro 07.01.2025., 17:59   #260
Postovi: 8,546
Ah, tu se više ne zna ko pije, a ko plaća, ali svi mediji su unaprijed dobili RDNA 4 informacije i onda ispadne da na CES keynoteu, nema ni riječi o tome, tak da valjda ide popravni.
Staro 07.01.2025., 18:11   #261
Mladenxy
Mladenxy's Avatar
Postovi: 4,472
Ne miriši na dobro, sigurno se negdje u nekom zapećku svađaju staviti 50$ veću ili manju cijenu. Naravno stavit će veću pa kad nebu nitko kupovao čudit će se pura dreku.
Staro 07.01.2025., 18:40   #262
Postovi: 8,546
Da, lako bi opet mogla ispasti sad već standardna AMD PR i marketing pizdarija, jer očito da su kartice spremne, svi partneri su ih imali i pokazali na CES-u.
Staro 07.01.2025., 19:51   #263
Exy
Exy's Avatar
Postovi: 2,668
Mislim da nije 50 dolara presudno, ljudi jednostavno (općenito govoreći) ne žele AMD kartice.
Inače ovaj slide gdje je 9070 u rangu 7900xt-a mi govori sve što trebam znat, AMD sprema re-re-release 6800XT-a Bude brža od 7800xt 15% i to je to. Uglavnom, ako tako bude a s obzirom što je nvidia pokazala - katastrofa. Lako moguće da ovo budu zadnji Radeoni. Low end će pokrivat Intel a bogati i viši srednji sloj će kupovat od Jensena.
Staro 07.01.2025., 20:18   #264
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Ako je u rangu s 4080 s dobrom cijenom ja je razmatram
Poslano sa mog SM-S928B koristeći Tapatalk
Staro 07.01.2025., 20:36   #265
Postovi: 8,546
Ukoliko AMD stvarno odluči ugasiti Radeon za desktop potrebe i općenito im ta divizija ostane samo za razna APU, mobilna i semi-custom rješenja, IMHO nemaju se kasnije krajnji korisnici kaj previše žaliti. To kaj su tražili, to su i dobili, nVidia u najboljem izdanju s podjednako prikladnim cijenama na koje su svi svaki put gunđali, a onda uredno kupili i tak iz serije u seriju. Intel bojim se da nema kaj tražiti ni u low-end izdanju, jer koliko imamo prilike vidjeti, low-end B580 treba high-end 9800X3D ili 14900K tak da lakše ponudi mainstream performanse RTX 3060 Ti i RX 6700 XT modela - četiri godine kasnije. Žalosno sve skupa, ali ako dođe do toga - super, ionak je cijeli svijet u Idiocracy i Don't Look Up TikTok režimu, pa kaj, ako ostane samo nVidia kao jedini izbor. Ne pitaj(te) previše, dobro je, a neoptimizirane igre se fino vrte u lažnom i što većem broju AI sličica u skundi.
Staro 07.01.2025., 20:51   #266
Exy
Exy's Avatar
Postovi: 2,668
Nema tu razloga za ljutnju na korisnike, da je AMD ponudio bolji proizvod, ljudi bi kupovali. Ali nije. Recikliraju jedne te iste grafe iz generacije u generaciju (7600XT kao najgori primjer). I bez tih fejk frameova nvidia ima bolji proizvod, tržište možeš ignorirati ali to ima svoje posljedice.
Nek počnu radit nešto što ljudi žele kupit, il nek bar ulože u marketing inače idu van. No sumnjam da bi ih to previše pogodilo jer po svemu sudeći sve će bacit na AI, ko hebe igrice
Tu isto se vidi kak samo prate trendove, ne određuju ih.
Staro 07.01.2025., 21:00   #267
ansha
¯\_(ツ)_/¯
ansha's Avatar
Lokacija: Sibenik
Postovi: 1,156
Najjace su mi price o marketingu i kao fol ljudi ne zele kupovati AMD kartice. Pa jako dugo nisu zeljeli ni AMD cpu-ove pa ih sad zele - kako to? Jednostavno, dok im proizvod nije valjao nije se ni prodavao, kad su izbacili bolji proizvod razvalili su Intel.
Ovo sad im je neka kao prelazna generacija, ili ce nakon ovog izbacit nesto stvarno konkurentno ili se gasi gpu divizija....
Staro 07.01.2025., 21:03   #268
Postovi: 8,546
Autor Exy Pregled postova
Da, ali koliko god AMD bil šrot firma s podjednako lošim marketingom, mislim da se možemo složiti da kad su imali i sasvim vredu i konkurentne proizvode, opet je bila ista priča. Zato velim da se nemaju kaj ljudi kasnije žaliti, jer sad se tu ponavlja Intel - AMD priča, ali ovaj put u GeForce - Radeon režiji. nVidia već danas nema previše razloga za išta novo ponuditi, jer su se financijski osigurali za sljedećih tisuća godina, a kad-tad bude došlo do stagnacije i onda imamo desetljeće quad-core GeForce pizdarija, makar ni sad nismo daleko. Kaj se AI i trendova općenito tiče, na taj vlak su skočili svi živi, a koliko bude dugoročno održivo, pitanje je, možda preživi neka šačica firmi uz tak jasno nVidiju koja nema previše razloga za brigu. I opet, AMD kad i postavi totalno nova rješenja i trendove, poput recimo chiplet dizajna koji je sad sveopće prihvaćeni za CPU i GPU, opet se nailazi na kojekave prepreke i negodovanja, kak je zapravo i bil slučaj za većinu stvari tokom povijesti te firme i nažalost izgleda da budu vječno u toj sjeni prošlosti.
Zadnje izmijenjeno od: The Exiled. 07.01.2025. u 21:08.
Staro 07.01.2025., 21:18   #269
Mladenxy
Mladenxy's Avatar
Postovi: 4,472
Imam dojam da se općenito manje kupuje gaming hardvera jer je došlo do zasićenja komplet gaming industrij, pogotovo AAA igara koji koštaju sve više i sve veći su rizik.Neke od najboljih igara poput alan wake 2 npr. je još uvijek u minusu za Epic. Sony je sa zadnjim spidermanom popušio hrpu love , microsoft je uložio hrpu love koju nebu nikad vratio itd Novi igrači nisu ulazili a stari su sve već vidjeli više puta. Osobno nakon stalkera 2 mogu se prestati igrati....nebum al zaboli me za novi hardver. kupil bum si buduću konzolu.
Staro 07.01.2025., 21:18   #270
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
vecina ljudi zeli konkurentan proizvod, samo da se srusi nvidiji cijena, i onda kupe tu nvidiju grafu koju su htjeli prvotno
