#241 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Svasta, kupis plocu koja radi drljavo, tj. ne radi i ne reklamiras ju. Uopce te nisu trebale zanimati nekakve revizije BIOS-a. Jel treba raditi s doticnim procesorom? Treba. Jel pise na kutiji da je super-iber-mega-ploca za i7? Pise. E pa zato bih ju ja raketnim pogonom vratio njima i daj drugu majstore ili vracaj pare, nismo svi hardverski nabrijani na svakodnevno flesanje BIOS-a i ispravljanje krivih Drina kosookih Tajvanaca. |
#242 |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Istina,na ploči od 2 000kn se na takve stvari promptno reagira. I na mnogo jeftiniji HW ljudi takve situacije odmah RMA,šteta. Sretno! |
#243 |
Datum registracije: Mar 2008
Postovi: 328
c/p sa anandtecha, mozda nekome bude korisno: We are working on a comprehensive overclocking guide for the i7/X58 platform to fully explain each BIOS setting as well as providing an easy to follow set of instructions to get the most out of this new platform. In the meantime, we are showing our initial overclocking results with air-cooling and the i920. To be blunt, overclocking the i920 on air to 4GHz is fairly simple: raise Bclk to 191, enable turbo and HT modes, set VCore to 1.4125V, VTT to 1.30V, VDimm to 1.67V, and set your 6GB kit to 9-9-9-24 as a good base start. After that, it is merely a matter of fine tuning the voltages a little and adjusting memory timings for improved performance and/or stability. Of course, all of this depends on the quality of your memory, cooling, and CPU. In our case, even with very good air-cooling, we found the practical limit for VCore to be around 1.425V without incurring throttling under load temperatures. Based on this setting, we arrived at our 21x191 setting. We will take a further look at overclocking on these boards and others with a CoolIT Systems Freezone Elite shortly. |
#245 |
Postovi: 11,642
Očito je da se radi o B i C revizijama... |
#249 |
Postovi: 518
Podesavanje komponenti u biosu
Nisam znao gdje da ovo postavim i kako ali s obzirom da nekuzim bas nesto clockiranje pokusat cu laicki objasnit iako cu dati ovima u Linksu da pogledaju o cemu se radi jer sam tamo kupio komponenete. 1.RAM PC-16000, 6GB, G.SKILL Trident series, F3-16000CL9T-6GBTD, DDR3 2000MHz, 3x2GB 2.MBO GIGABYTE EX58-UD4P, Intel X58/ICH10R, DDR3, zvuk, G-LAN, S-ATA, RAID, PCI-E, FW, s. 1366.S tim da moja ima dvije mreze i nema je vise na cijeniku.Bila je malo skuplja od ove ali u biti isto sve. 3.CPU INTEL Core i7 920 BOX, s. 1366, 2.66GHz, 8MB c., FSB 1333MHz, 64 bit, QuadCore Memorija radi na 2000 Mhz a i maticna s overclockom to podrzava.Neznam to nikao namjestit a i kad namjestim onda postoji problem.To me u biti zanima jel to normalno.10 sekundi pri resetiranju i paljenju komp uopce ne reagira i dolje se pali slovo C koje tako gori 10s kao da maticna prepoznaje da je komp clockan i tek onda mi se sistem pocne dizati.Isto je i s procesorom.Cim ga malo dignem onda on dize i memoriju. Ono u biti osao sam i do frenda koji je nesto probao i napravio je da sljedece BCLK fREQUENCY je stavio sa 133 na 200 a System memory Multiplier spd sa Auto na broj 10.Proc tada radi na oko 4Ghz i memorija je na 2000 ali problem i dalje ostaje isti pri dizanju sistema.10 sekundi nekog gorenja slova C i tek onda brojke na displeyu pocnu kretati i komp se digne.Kad se digne sve radi normalno.U linksu su mi rekli da ima hrpa opcija za podesavanje toga i da se moraju pozabavit time jako.A ja sam zato i kupio da mi radi na 2000 a ne na 1066 koliko je i bilo na defaultu |
#250 |
its slightly turbocharged
Postovi: 5,430
Ček, normalno radi sve i naklokano samo što ima taj delay od 10ak sekundi? Pa ako radi normalno pusti ga, šta ti znači tih 10 sek. Probaj dići voltažu. CPU vcore stavi na 1.30V za početak, a voltažu memorije na 1.65V
blaa |
#251 |
Postovi: 518
NIsta se nije promjenilo i sa dizanjem voltaze.Taj C1 stoji i dalje destak sekundi i ima dojam da naravno se sporo sve dize sto u biti i je a to nezelim. Nije da mi znaci 10s ali ipak nesto ocito nevalja jer kad ga vratim na tvornicke postavke onda sve radi kako spada tj normalno digne bez dileya |
#253 |
Lokacija: Ivanić_Grad
Postovi: 2,012
Možda bi pomogao flash najnovijeg BIOS-a ? Budući da je to još u biosu. Jel ti je uključena ona opcija u biosu Fast boot, ili tako nešto, ono da se ne provjerava memorija pri startupu ili da se ne traze greške jer ti sistem očito radi normalno. I ima još delay for hdd stavi 0. Ako nađem još koju opciju postati ću. |
#254 |
Postovi: 518
Imam najnoviji bios.Sad cu vam uploadat video pa da vidite sto se desava i kad on u biti krece s dizanjem sistema.Procesor je dobio voltaze kao i ram.Mislim da je sad clockan na 3,6 a memorija je na 2000.Ima jaku zadrsku dok nepocne dizat.Probat cu vam snimit postavke u biosu pa da vidite.Mozda nisam nesto dobro napravio ali iskljucio sam sad i C1E i EIST. http://www.youtube.com/watch?v=OVTL1-d-z3U Ovako dize sistem sada.Postavke cete vidjeti na sljedecem videu u biosu http://www.youtube.com/watch?v=_j5Q0CnrFH8 Ovako je u biosu i cim nesto napravim s memorijom da je dignem ili procesorom dize se onako sa zakasnjenjem sistem (((Zadnje izmijenjeno od: Razer. 07.10.2009. u 15:47. |
#255 |
Postovi: 12,425
Za početak RAM ti po defaultu radi na tim pločama na 1066MHz Za više moraš ručno unosit određen mem množitelj ili enableat XMP profile ako ih tvoj RAM podržava. Dakle koliko vidim ti imaš množitelje od x6 do x18 Stoga ako hoćeš da ti RAM radi na 2000MHz moraš ili postavit bc na 166 i dić množitelj na x12 ili postavit bc na 200 i množitelj na x10 ili već neku takvu kombinaciju u glavnom trebaš se igrat množiteljima. Dalje kada dižeš takt memorije gledaj koje su ti latencije zadane te također ručno unesi odgovarajuće tj one deklarirane od strane proizvođača. Ne zaboravi da ih moraš unijeti tri puta (jednom za svaki kanal) Naravno ako RAM koristi XMP profile ne bi se trebao igrat dizanjem množitelja, postavljanjem latencija niti dizanjem napona... Uz radni napon za memoriju koji ćeš vjerojatno trebat dizat na 1,65V trebaš dizat i napon za QPI. Po def on je tebi vidim na 1,17V a ti ga diži prema potrebi na 1,30-1,35V Naravno da kada dižeš takt procesora preko bc-a da dižeš i takt memorije jer su oni povezani. Također kada se već tako igraš pazi na ukupan radni takt procesora uključujući i Turbo boost. Ako već ideš dizat takt procesora onda Turbo isključi. Za kraj C1 kod Gigabyte-a stoji za RAM check... i stoji ti zato što si vjerojatno krivo postavio latencije ili napon ili oboje za željeni takt. Zato stoji i vraća postavke na default Sad bi još mogao reći da što si kupovao 2GHz RAM jer razliku nećeš osjetit a i dosta 1600MHz memorija se da fino klokat i ujedno koštaju osjetno manje, no kako me netko ne bi prozvao dušobrižnikom to ću ostaviti za sebe ![]() P.S. popuni opciju Moj komp P.P.S. kad već ideš snimat BIOS daj onda približi kameru/fotić jer se ovo tvoje niš ne vidi
#256 |
Postovi: 518
Sta god napravio da memorija radi na vise Mhz nevalja.Danas sam jedva i upalio racunal jel se stalno resetirao.E sad sto trebam podesiti i kao zaista vise neznam nazalost ali u petak im nosim racunalo da to podese.Nema sanse da to meni tako radi jel radi za klinac.Cim odem na XMP profile on automatski sve odradi da memorija radi na 2000 i da nemoram unosit rucno latencije koje su 9 9 9 24.E sad cim to napravim komp se dize onako nikako.Lud sam vise. |
#257 |
Postovi: 12,425
A kada ideš ručno podešavat jesi li dizao napon za QPI i ako jesi na koliko si ga postavio? IMHO radije zamjeni taj RAM za neki na 1600MHz
#258 |
Postovi: 518
Probat cu se sutra pozabavit time.Nisam dizao napon to sam se kasnije sjetio.Proc necu dizati nego cu prvo probati rame postaviti na 2000.Jel trebam obratiti paznju na jos nesto?? Na koliko trebam postaviti taj Qpi i koliku voltazu rama trebam staviti.Mislim da mi on automatski stavi na 1,65.Wolverine hvala ti puno sto se trudis.Vec sam bio u Linksu pa ce oni probati rijesiti ali moram i ja malo se namuciti.Sutra cu kazem jos malo dumati pa ti javim.Svakako hvala ti na trudu.Ako nebude radilo kako spada vracam taj ram i uzimam drugi kako si i savjetovao. |
#259 |
Postovi: 12,425
Napon za QPI probaj prvo stavit na 1,3V pa vidi kako će raditi... ako još nije stabilno stavi 1,35V Napon za RAM stavi na 1,65-1,66V Latencije postavi ručno na 9-9-9-27 (ne zaboravi da na Gigabyte ploči moraš unosti latencije zasebno za svaki kanal)
#261 |
Postovi: 11,642
Svejedno je... |
#263 |
Postovi: 12,425
#264 |
Postovi: 518
Da vam javim da nazalost nisam rijesio problem.Zasto zaista neznam samo znam da sam probao dosta toga.Da memoriju naredim da tocno radi na 2000Mhz morao sam se igrati i sa procesorom tj njegovim dizanjem jer nema sanse da mi je postavi ravno na 2000 osim ako proc nije malo clockan.Ovako mi da cak nekih 2100 i vise a to nisam stavio jer ne podrazava niti sam zelio.Kad sam nekako naredio da mi je memorija ravno na 2000 uz clockan proc naravno stavio sam voltazu na procu CPU vcore na 1.30V voltazu memorije naredio na 1.66V jer kod mene nema bas na 1.65V-ima 1.64 ili 1.66 i to je vec u ljubicastom podrucju, C1E i EIST su na disable, napon na QPI sam prvo stavio 1.3V i nisam uspio dignuti sistem.Zatim sam stavio na 1.35 i opet nista.Sistem se sa svim tim postavkama sam restartira i jedva sam usao u bios.Ostavio sam sve na serijski jer vise ni sam neznam sto da napravim.U sva tri podrucja latencija za memoriju su unjete sljedece latencije 9-9-9-24.Sutra ide u links,jedino mi je zao sto ja sam nisam uspio malo produmati ali bojim se da taj ram ili cak ploca mozda nevalja ili uopce ne podrzava.Ukoliko je to slucaj ovo cu im vratit jer nisam uzeo komponente da se drkenjam sa klokanjem istih osim mozda dizanjem proca na 3,5Mhz a ocekivao sam da memorija radi kako je i u specifikacijama.Eventualno da se to samo podesi u biosu a ne ovo drkarenje.To je kao da kupim auto od 500 konja ali znate on vam ima sad 350 pa se mora elektronika namjestiti da on ima 500.A u toku podesavanja elektronike ja necu moci upaliti auto ili jos gore on ce se gasit.Malo karikiram ali nisu to mali novci za toliko drkarenje. |
#267 |
Postovi: 518
Dakle bio sam kod njih u linksu i naredili smo proc i memoriju da radi ovako roc radi na 3900Mhz, memorija radi na 1950, povisena je voltaza proca memorije i ostalog.Latencije memorije su spustene 8-9-8-24 i u testu na Everestu sijem sve zivo i nezivo u svim podtestovima.I dalje komp ima zadrsku na pocetku dizanja windowsa sa porukom C1 i to tako 3x.Objasnjenje je navodno sto je memorija clockana pa se samo pri prvom dizanju provjeravaju sva 3 modula.Opteretili su ga i njihovim testom koji se zove i koji imam na kompu ORTHOS gdje se full strsira i ram i proc.Nigdje nije bilo gresaka ni nista i jos smo igrali igru Cryostasis a ovaj program je bio u pozadini.NISTA. Danas mi je komp gorio cijeli dan i surfam i skidam i nista.Igricu nisam igrao ali ono sto sam probao jest osao sam u everestov program u kojem se testira isto tako sve.Stavio kvacice na sve osim na hardove i cim krenem s tim njegovim testom neprodje ni minuta i pojavi se plavi ekran???Sva tri modula memorije sam ispremjesto ali nije pomoglo.Sto je najveca fora moj komp je leden kad pipnem bilo koju komponentu, bio to ram ili proc sto se vidi i iz mojih podataka o racunalu.Zasto se s njihovim testom zablokira neznam a s ovim ne nemam blage veze.Temperaturu sam u biosu postavio da mi javlja teka na 80 jer su se maximalne vrijednosti u stres programu kretale oko 70 i ne vise.Graficka je od jucer nova xfx 275 Geforce.Da li me ram zahebava jer plavi ekran je vezan uz ram ili sto vec neznam.MOzda maticna a mozda sam vec poludio.Imate li kakvo objasnjenje ili trebam dizati jos neke vrijednosti u biosu? |
#268 |
Postovi: 12,613
Nemoj se brinut za Everest, i ja sam imao jedan 100 % ispravan Office PC na kojem bi samo kod pokretanja Everesta bacio BSOD.
#269 |
Postovi: 518
Ovakve su mi sada postavke u biosu i u everestu mi nije pokazivao plavi ekran pri testu ali cim odem malo nize odmah steka.U biti sve sam dizao linearno pa mozda negdje treba oduzeti a negdje dodati sto se tice voltaza.Ako netko ima jos neki prijedlog neka kaze.Igre i sve to super sljaka.Neznam mozda je procu malo za tu frekvenciju jer radi na 3,9??Evo slika http://slike.hr/slike/11102009001_3b35a.jpg.html http://slike.hr/slike/11102009002_d9d85.jpg.html http://slike.hr/slike/11102009003_009a8.jpg.html http://slike.hr/slike/11102009004_7c953.jpg.html http://slike.hr/slike/11102009005_ddb58.jpg.html http://slike.hr/slike/11102009006_172c9.jpg.html http://slike.hr/slike/11102009_15629.jpg.html |
#270 |
Lokacija: doma
Postovi: 964
zadnja slika performance enhance stavi standard. vtt i vdimm su previsoki za 24/7 setup. 1.90v vdimm / 1.20v vtt = dead after 1 day (Engineering Sample CPU rev B) - rev B? 1.90v vdimm / 1.20v vtt = dead after 10 days (Retail 965 rev C) - most likely freak accident/bios/board bug 2.25v vdimm / 1.45v vtt = dead after 1 day (Engineering Sample CPU rev C) - buggy board? 1.88v vdimm / 1.50v vtt= dead after 1 week (Retail 965 rev C) - most likely freak accident/bios/board bug 1.65v vdimm / 1.20v vtt = ok forever according to intel 1.80v vdimm / 1.30v vtt = ok for 7 weeks 1.95v vdimm / 1.40v vtt = ok for 5 weeks 2.05v vdimm / 1.45v vtt = ok for 5 weeks 2.05v vdimm / 1.36v vtt = ok for 6 weeks 2.00v vdimm / 1.50v vtt = ok for 8 weeks (cold) 2.00v vdimm / 1.60v vtt = ok for 2 weks 2.00v vdimm / 1.65v vtt = ok for 8 weks 2.25v vdimm / 1.70v vtt = ok for 4 weeks 2.30v vdimm / 1.35v vtt = ok for 2 week (cold) 1.75v vdimm / 1.75v vtt = ok for 1 day (cold) Izvor |
