Staro 14.05.2009., 13:36   #241
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Ne znam kak je kod vas, ali meni sa ovim zadnjim buildom 1497 ucitava stranice dosta brze nego sa prijasnjim verzijama
Liquid Snake je offline   Reply With Quote
Staro 21.05.2009., 01:38   #242
Markos
Markos's Avatar
Postovi: 1,061
jep istina je dosta je brže ali kod mene dosta tog ne želi upamtiti pa moram opet pisat non stop
Markos je online   Reply With Quote
Staro 27.05.2009., 18:14   #243
Liquid Snake
Postovi: 166
Opera 10.0 (Snapshot) Build 1535 (with preview of the *new* Skin)
Things to bear in mind while you're playing with this:
  • What you see here is neither complete nor final, and there will be more iterations before the final release. Some elements will still look like the current skin!
  • Currently the skin is implemented for the default setup, tabs at the top, panels on the left, panel toolbar on the left and status bar at the bottom. Other setups will look a bit odd - for now.
  • This build doesn't include the new features in Opera 10, so one of the reasons for the revised skin isn't there. All we be clear when the beta comes out!
Novi skin:
http://files.myopera.com/haavard/alb.../10skin-v1.png
Known Issues
  • There are several issues with the skin: Speed Dial is unfinished, there are missing/outdated icons, some things may be placeholders/work in progress, and so on
  • [DSK-253836] When reading mails, headers only show e-mail addresses rather than "name" <e-mail@address.invalid> for senders not in your contact list
Changelogs
  • Some fixes to crash upload dialog
  • Use default search engine rather than a specific search engine when tying two or more words and pressing Enter
  • [DSK-180617] Links opened in external applications closes page if page is opened from a panel or mail
  • [DSK-239506] Can't correct spelling using only the keyboard
  • [DSK-251332] Changing the size of the searchfield when the addressbar is placed on the left causes it to disappear forever
  • [DSK-251349] Search box and address field are misaligned
  • [DSK-252737] No timeout when new spelling checker dictionaries can't be retrieved
  • [DSK-252992] "Other Application..." doesnt' work in the BitTorren Client Selection dialog
  • [DSK-253202] Replace 'Language' with 'Dictionary' in dictionary download wizard and spellcheck menu
Skinning improvements:
  • Made the splitter dividers separately skinable with the sections [Splitter Horizontal Divider Skin] and [Splitter Vertical Divider Skin]. Remember their height/width is always 3px
  • Text-shadow ability in the skin
Search UI updates:
  • Use "?" as a shortcut (instead of, e.g., "g") in the URL field to search with the default search engine
  • Show "Search the Web" and use the default search engine rather than Google specifically in the URL dropdown when typing in one or more words in the URL field
Core
  • Reverted [CORE-14999] Send DOMContentLoaded when the parsing is complete even if it's discovered a little later than usual
  • Partial fix: [CORE-20956] Wand does not submit if form includes two input fields and a password field
  • [CORE-466] vertical-align is not inherited in tables
  • [CORE-3587] Float not reset to none for absolutely positioned elements
  • [CORE-4589] designMode: Text entered after creating link turns into link
  • [CORE-8335] BiDi: Unable to reach end position of hilight text
  • [CORE-17018] WebFonts break when using the OpenType format
  • [CORE-19215] Deleted selected string incorrectly rolls back when composing using IME in editable document
  • [CORE-19836] non-visible WMP not initialized
  • [CORE-20012] Fastmail rich text editing breaks interface
  • [DSK-244367] Error page on unsupported HTTP authentication scheme instead of showing the response body
Stability
  • Mail: Crash fix for opening sent message that didn't have body
  • Spelling checker: Crash fix for dictionaries that seems installed, but do not get picked up by the spellcheck module for some reason.
  • Spelling checker: Fixed crash if the dictionary is downloaded but the check sum is not correct
  • Fixes based on automated crash reporting
  • [CORE-19581] Opera crash on searching text on a specific page
  • [CORE-20406] Opera crashes on positioning tasks in Gmail2
  • [CORE-20470] Calling referenced native function crashes opera
  • [CORE-20598] Blog feed freezes Opera/doesn't load when Delayed Script Execution is enabled
  • [CORE-20930] Inserting BODY element into existing BODY tag causes crash
  • [CORE-20950] Crash at Facebook because of NULL base url (most common crash for Opera Mini)
  • [CORE-21171] Freezes and eats all memory within seconds on certain pages (eztv.it, funfile.org)
  • [DSK-223018] BitTorrent: Unreproducible bittorrent crash when selecting items in transfers panel
  • [DSK-223722] Opera freeze for a long time when viewing transfers
  • [DSK-240287] BitTorrent: Crash after downloading a few torrents
  • [DSK-240724] Going to a fraud URL with a username crashes Opera
  • [DSK-242050] Crash while managing feed items
  • [DSK-249422] Crash when clicking certain mails
  • [DSK-252115] "Feeds > (Feed name) -> Click on Post -> From -> Follow Contact" crashes Opera
  • [DSK-252764] Setting feed update interval to 5 minutes for a lot of feeds makes Opera use too much memory over time
  • [DSK-253542] Check spelling doesn't work or crashes in upgrade installation
Mail
  • Fixed threading of reopened drafts
  • Better error handling to avoid duplicate mails
  • A new error message from m2 when a message fails to be indexed
  • Added format=flowed parameters to the content-type header
  • Fixes to "show sent" mail in threaded view
  • Enable "show sent" when setting Sent IMAP folder
  • Do the consistency check on exit after upgrade
  • Wrapping should depend on account settings
  • Show a bit more relevant context menu when using context menu button in compose window
  • [DSK-189699] Mails are not sorted on latest message in thread view
  • [DSK-199963] M2 doesn't add a name to e-mail address when composing the e-mail from existing address
  • [DSK-233440] Dragging message between IMAP accounts sometimes fails
  • [DSK-239836] Forwarding a feed in HTML will include the word "article" in a huge font
  • [DSK-224803] Cannot view email headers if text/plain not opened by Opera: Force viewer to be Opera when opening raw mail
  • [DSK-244169] Font used in body field doesn't reflect font in drop-down
  • [DSK-246522] The compose action opens webmail page instead of compose window
  • [DSK-247011] Automatic RTL detection on reply
  • [DSK-247788] M2 wrongly claims that there are no new messages when connection to server is interrupted
  • [DSK-248265] Hide HTML formatting in newsgroup compose window
  • [DSK-248267] Directionality detection missing when editing an existing email
  • [DSK-248543] The last part of Japanese Subject is not shown
  • [DSK-249350] Database consistency check should be periodic
  • [DSK-250841] Drafts appear in received folder when any characters was entered into the to field
  • [DSK-251008] Opening a mail copy from Sent, changing its To address and sending it, replaces the copy in Sent instead of creating a new sent email entry
  • [DSK-252156] Forced exporting mail option
  • [DSK-252235] Upgrading results in duplicate and blank messages
  • [DSK-252238] "Show read" gets unchecked for Received view when upgrading
  • [DSK-252495] Bottom border in mail compose area missing
  • [DSK-252658] Fetch all e-mails when switching from Low-bandwidth mode to "Make all messages available offline"
  • [DSK-253417] Mail folder not copied when upgrading from 9.64
  • [DSK-253425] To, CC, and BCC fields not shown when opening Mail in Sent view
Chat
  • Partial fix: [DSK-246177] Connnecting to a malevolent IRC server can render Opera usuable with too many modal dialog popups
  • [DSK-228014] Saving IRC/Chat window silently fails if MHT or "HTML with images" is chosen
  • [DSK-248365] IRC password not memorized when using /join command
  • [DSK-253327] Joining a password protected channel for the first time via a typed join command fails
Opera Link
  • [DSK-249571] Link queue not sent when exiting Opera
Opera Turbo
  • Context menu changes
  • Changes to the Turbo dialog
  • Adding Turbo icons for the turbo notification dialog
  • [DSK-247507] Turbo button not automatically added to status bar in upgrade installations
  • [DSK-248836] Turbo mode not keyboard accessible
  • [DSK-249981] Turbo: Text color for the turbo button is not changeable by skin
  • [DSK-252890] Turbo status icons should respect the text-only option
  • [TURBO-159] A placeholder is needed for plugins that are not loaded yet: Changing the icon
  • [TURBO-183] Turbo state not switched after clicking JavaScript links
  • [TURBO-220] Tabs opened from mail, chat etc. windows should use global setting to determine Turbo Mode state
  • [TURBO-224] Correct handling of history positions when reloading in new Turbo Mode state
Windows
  • Fixed a problem that would prevent the previous opera instance to be registered for uninstallation
  • Added registry value indicating whether installation was done by administrator
  • [DSK-226188] Extension lost when renaming a file in the save dialog to include a period
  • [DSK-231787] Unable to set default browser in the Start Menu
  • [DSK-245142] Removed spellcheck.dll, as it's no longer needed for new spelling checker
  • [DSK-245686] Silverlight crash when reloading quickly
  • [DSK-246447] Can't install Opera with a limited account
  • [DSK-246448] Fix for automatic updates with limited (non-admin) XP accounts
  • [DSK-251584] Hidden popup blocks installation process when Opera is still running
  • [DSK-252544] Information about installation directory missing must not be handled by browser
  • [DSK-253587] Ddouble file extensions added on download
Mac
  • [CORE-19054] Fix for showing print preview)
  • [DSK-248272] Possible to insert non-images using Insert > Image)
  • [DSK-248013] Sub-menu items replace menu items in the Opera menu)
Unix
  • Removed '-nosession' as a separate command line option. It is already handeled as an alias to '-nowin'
  • [DSK-230698] Serious drawing issues in the Qt4 build
  • [DSK-235281] Refresh causes Opera to go backwards in history after interaction with Flash
  • [DSK-251177] navigator.plugins.refresh() takes long time; cache the plugin information
  • [DSK-251573] Don't renice pluginwrapper to 19
  • [DSK-251805] Hang when doubleclicking text while flash is running
WARNING: This is a development snapshot: it contains the latest changes, but may also have severe known issues, including crashes and data loss situations. In fact, it may not work at all.
Staro 01.06.2009., 20:05   #244
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
Za korisnike Opere korisne lokalne User javascripte...
Staro 03.06.2009., 00:59   #245
Liquid Snake
Postovi: 166
Izasla je i prva beta verzija:
Opera 10.00 Build 1551 Beta 1
Staro 16.06.2009., 11:27   #246
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
User Interface
  • Added menu option to hide the main menu on Windows and Unix. When hidden, it is replaced by a menu button in the tab bar which is also accessible using the Alt key
  • New mailto URL for the fastmail webmail service
  • Additional fix to Bug DSK-255650 (Thumbnail generation called when Opera is shutting down): make sure the speed dial is not loading when the speed dials are deleted.
  • Fixed potential crash when uninstalling a dictionary
  • Fix a bug where the address dropdown might reappear after closing it due to incoming search results: This may also Fix Bug DSK-213883 (Opera crashes)
  • Fixed Bug CORE-21253 (Can't add a word into the dictionary containg special characters.)
  • Fixed Bug DSK-180617 (Links opened in external applications closes page if page is opened from a panel or mail)
  • Fixed Bug DSK-215702 (Crash on various dialogs with 3rd party mouse plugins installed)
  • Fixed Bug DSK-226175 (Converted Japanese are placed outside of text-form)
  • Fixed Bug DSK-237534 (Freeze when setting "Open with other application" to Opera for mailto)
  • Fixed Bug DSK-244687 ("|" makes it past the webmailprovider %s percent-encoder unencoded)
  • Fixed Bug DSK-247823 (Menu item 'Edit > Check spelling' must be updated)
  • Fixed Bug DSK-252725 (crash with incomplete spellcheck dictionaries)
  • Fixed Bug DSK-253258 (Back button on the dictionary installer needs work): Fixed the back and forward buttons so you can go all the way forward and backward and forward again
  • Fixed Bug DSK-253386 (Crash when clicking help in startup dialog): show tooltip for 'no windows' option. Reinstate cancel button on dialog.
  • Fixed Bug DSK-253858 (Sometimes a dictionary can't be uninstalled)
  • Fixed Bug DSK-253989 (Crashes when using Go To Page dialog in crash logger or startup dialog)
  • Fixed Bug DSK-254102 (Words added to the dictionary are not really added )
  • Fixed Bug DSK-204113 (Opera not default handler for supported filetypes with incorrect MIME type)
  • Fixed Bug DSK-254167 (No difference between clickable and non-clickable "text only" buttons)
  • Fixed Bug DSK-254387 (Incorrect label size, that displays error message when downloading new spellchecker dictionary): Rearanging the error page in the dictionary page a bit
  • Fixed Bug DSK-254446 (Ctrl+tab menu looks wrong)
  • Fixed Bug DSK-254733 (Double-click doesn't reduce tab thumbnails to tabs): Only enter drag mode on single click
  • Fixed Bug DSK-255232 (password manager button in prefs too small)
  • Fixed Bug DSK-255502 (Use a specific browser.js file when using Opera in Chinese)
  • Fixed Bug DSK-255638 (menu shortcut out of order)
  • Fixed Bug DSK-241258 (if no contacts present, opera crashes)
  • Fixed Bug DSK-250821 (-nomail command switch isnt working)
  • Fixed Bug DSK-254901 (Opera deletes stored session files when start-up dialog is shown)
  • Fixed Bug DSK-255087 (Reduce time it takes for tooltip to appear)
Skin
  • Fixed spacing between search and the address field
    Revised mail panel icons
  • Reduce padding on Toolbar buttons, panel icon tweaks
  • Small changes to Edit Skin, Toolbar Button Skin and Mac skin
  • Improvements to the toolbar
  • Darker color for browser borders and splitters
  • Tweaks to smilies
  • Revised Lock Page Icon
  • Revisions to push buttons, radio buttons and checkboxes
  • Updated Scrollbars
  • Improvements to Mac Skin tabs
  • Changes to the Lock tab icon for standard and mac skins
  • Updated Panel selector buttons for other positions
  • Moving tab backgrounds to their own folder to make it easier to keep track of them
  • Moving tab thumbnails to the pagebar directory
  • Updated Link Busy animation
  • Reducing padding on Menubar buttons
  • Updated radio buttons and checkboxes to use semi-transparent borders
  • Fix paddings and margins on Addressbar Skin and Dropdown Search Resize Skin
  • '[Addressbar Button Skin]' available to be skinned separately now
  • Added window native close buttons from the standard skin
  • Panel toggle button now has 2 states as it should
  • Further work on Bug DSK-254363 (Panel header button stands out due to the large font size): Toolbar buttons have a new argument with 1 for using bold text
  • Got rid of all inverted icons as they are not used anymore
  • More tabs changes
  • News group icons
  • Position the extender button properly in relation to the new tab floating toolbar when the tab bar is at the bottom or at the top
  • Revised Bookmark icons
  • Updated Push Buttons
  • Updated Smilies
  • Updated button icons
  • Updated toolbar.ini and skin based on new images
  • Using new transfer item default icon (was opera.png)
  • Fix relating to a Link hover problem
  • Fixed so the enable/disable tab thumbnails is also available on inactive tabs
  • Added click to play hover icon (Turbo)
  • Tweaks to windows native skin
  • Improvements to hover state on tabs (better contrast) and tabs on the side
  • Improvements to Fix for Bug DSK-255817 (Need more contrast on access keys list): Also added a new skin section '[Accesskeys Cycler Item Skin]' and set the font size to 150% to make the access keys popup more accessibility friendly
  • Use the Window color instead of a hard code white tint on the access keys dialog - to allow for using customized color schemes to override it
  • Fixed Bug DSK-253115 (right border of contact image field in contacts properties dialog missing)
  • Fixed Bug DSK-253734 (widgets icon in panel too big, or entries in widgets panel too close together)
  • Fixed Bug DSK-253776 (panel selector buttons look good only when left-aligned)
  • Fixed Bug DSK-254150 (Remove white background from Treeview Skin): use window colour for treeview skin background
  • Fixed Bug DSK-254175 (New Skin: Personal Bar items have random widths): Trimmed down the margins for the Toolbar Button Skin
  • Fixed Bug DSK-254348 (Button Mail view/Show filtered uses folder instead of filter icon)
  • Fixed Bug DSK-254363 (Panel header button stands out due to the large font size)
  • Fixed Bug DSK-254662 (Image context menu should support "Use image on Speed Dial")
  • Fixed Bug DSK-254734 (Close button barely visible when hovering inactive tabs)
  • Fixed Bug DSK-254863 ("cached images" button smaller than show/no images)
  • Fixed Bug DSK-254875 (Background appears when pushing Panel and Trash buttons)
  • Fixed Bug DSK-254888 (Unequal horizontal margin for the search field size adjuster)
  • Fixed Bug DSK-254967 (Appearance dialog, "Show thumbnails" on tab bar is not functional)
  • Fixed Bug DSK-255472 (checkboxes clipped at gmail)
  • Fixed Bug DSK-253878 (The Opera Mini target bookmarks folder is missing a new icon)
  • Fixed Bug DSK-253883 (Mailbar background is missing)
  • Fixed Bug DSK-255763 (Avoid mixing up text-shadowed labels and normal ones on toolbars)
Mail/Chat
  • Format default welcome mail with HTML
  • Improvements to HTML email compose support
  • Clicking on a new message notification now will attempt to 1) find a window where the message is visible, 2) open unread if it's visible there, 3) open the account view if not.
  • Fixed the padding for plain text e-mail composing
  • Fixed Bug DSK-239729 (List commands don't display as toggles)
  • Fixed Bug DSK-240878 (localized font-family name in the HTML mail gets garbled)
  • Fixed Bug DSK-244042 (crash on going back after reading thread)
  • Fixed Bug DSK-246290 (Replying to e-mail will break the compose window)
  • Fixed Bug DSK-247455 (Opera hangs completely when doing "Synchronization" on POP3 mail check)
  • Fixed Bug DSK-248267 (Directionality detection missing when editing an existing email)
  • Fixed Bug DSK-248798 (printing mail broken, results in empty page)
  • Fixed Bug DSK-250498 (Chat connection status is broken for multiple accounts)
  • Fixed Bug DSK-250602 (Info field size in the signature editor is too small)
  • Fixed Bug DSK-250756 (Signature doesn't change when changing account)
  • Fixed Bug DSK-253548 (Replying to a thread in Received view set to threaded and sorted by date shouldn't update the sort position of that thread)
  • Fixed Bug DSK-253737 (Opening attachments does not respect the download settings)
  • Fixed Bug DSK-253836 (Headers in mail view tab only show e-mail address, not name and address, for senders not in contact list)
  • Fixed Bug DSK-253998 (From field in newsfeed items is empty, crashes on copy)
  • Fixed Bug DSK-254192 (Adding a large attachment to a message freezes email composing)
  • Fixed Bug DSK-254304 (Superscript and subscript icons in M2 have switched places)
  • Fixed Bug DSK-254408 (Freeze when upgrading POP account)
Speed Dial
  • Speed Dial improvements
  • Fixed a bug where selecting 'Open with Speed Dial' was not respected
  • Added best fit (aka crop/scale/proporitonal strech) mode for speed dial background images and made that the default setting
  • Set image as Speed Dial background
  • Fixed Bug DSK-253075 (Speed dialog configuration dialog should be alligned to the config button and follow the window)
  • Fixed Bug DSK-253271 (Crash on speeddial config)
  • Fixed Bug DSK-253833 (Clicking Configure Speed Dial over and over opens unlimited amount of dialogs)
  • Fixed Bug DSK-254158 (Configure speed dial button goes backgroundless for once on setting speed dial background image)
  • Fixed Bug DSK-254372 (URLs for speeddials above 9 does not resolve)
Opera Turbo
  • Provide functionality for switching Turbo mode off for separate image elements
  • Notification shown when turbo servers are busy
  • Fixed Bug TURBO-159 (A placeholder is needed for plugins that are not loaded yet)
  • Fixed Bug TURBO-242 (Add hover effect to Click To Play)
  • Fixed Bug TURBO-249 (Provide functionality for switching Turbo mode off for separate image elements)
  • Fixed Bug DSK-255261 (Turbo: There needs to be a context menu option to reload images in high quality)
BitTorrent
  • Some optimization work
  • Fixed high memory use related to the disk cache on huge torrents
Core
  • Fixed a crash relating to problems with certain PNGs
    Fixed problems with right click menu behavior relating to plugins
  • Work to prevent Flash freezes
  • Plugin crash fixes
  • Fixed Bug CORE-12827 (Need link on error page for cross network communication)
  • Fixed Bug CORE-13116 (typeof operator in NodeLists returns object but comparison to object and function both return true)
  • Fixed Bug CORE-13465 (multiplying a number and an array fails without valueOf(), facebook applications broken)
  • Fixed Bug CORE-14160 (DSE crashes Opera when something is document.writed into a table.)
  • Fixed Bug CORE-14977 (Doesn't fire DOMContentLoaded when a script is added with document.write)
  • Fixed Bug CORE-15397 (Pipelining should be a site-specific preference)
  • Fixed Bug CORE-15945 (Problem in certain scopes when defining getter for HTMLElement's document prototype)
  • Fixed Bug CORE-17807 (Should not allow linebreaks in input names)
  • Fixed Bug CORE-18102 (Wrong context menu for windowless silverlight)
  • Fixed Bug CORE-20274 (Should add remote updatable preference to disable MD5/MD2 in certificates)
  • Fixed Bug CORE-20475 (Iframe deletion breaks link interaction in other frames (Can't download attachments in gmail))
  • Fixed Bug CORE-20578 (Function defined on appended iframe not available (Map isn't loaded at www.xici.net))
  • Fixed Bug CORE-20755 (Adobe Flash Support Center, images are empty)
  • Fixed Bug CORE-20870 (SSL failure if CRL and/or OCSP requests are redirected)
  • Fixed Bug CORE-20993 (flash causes page to hang on loading and disrupts left-click on asus.com)
  • Fixed Bug CORE-21077 (class cache holding stale string pointers after changing the class attribute to its current value (crash on google video))
  • Fixed Bug CORE-21139 (ccc.de resolves to to 0.0.0.0)
  • Fixed Bug CORE-21240 (offsetTop handling broken for inline-block child of overflow:scroll parent)
  • Fixed Bug CORE-21277 (DOMContentLoaded doesn't always fire when traversing history)
  • Fixed Bug CORE-21394 (Script environment locks up when script interacts with blocked plugin)
  • Fixed Bug CORE-21429 (*.com accepted as wildcard match in SSL/TLS name matching)
  • Fixed Bug CORE-21625 (Support for getting localized strings from javascript)
  • Fixed Bug CORE-21630 (Opera crashes when importing certificates (II))
  • Fixed Bug CORE-21644 (javascript files containing html comments are not interpretted)
  • Fixed Bug CORE-21690 (Make execCommand('formatblock') behave more like IE.)
  • Fixed Bug CORE-21731 (Crash related to DSE and document.write and walking in history)
  • Fixed Bug CORE-21790 (Potential fix for top-crasher at gmail when editing mails)
  • Fixed Bug DSK-241178 (Feed preview doesn't finish loading)
  • Fixed Bug DSK-247269 (video does not load and page becomes unusable)
  • Fixed Bug DSK-248618 (Links opened from mail and newsfeeds stop loading when you focus another mail/feed entry)
  • Fixed Bug DSK-250837 (Flash content misplaced after scrolling)
  • Fixed Bug DSK-252146 (Crash in LayoutProperties::CreateLayoutBox)
  • Fixed Bug DSK-253167 (Right-clicking on flash object breaks Opera big time)
  • Fixed Bug DSK-255557 (Opera crashes when printing page)
Windows
  • Images to be used as desktop background are only saved in the user's profile pictures folder
  • Fixed Bug DSK-222287 (Opera crashes at random)
  • Fixed Bug DSK-241262 (Error message when opening HTML files if Opera is not already running): removed spurious registry entries
  • Fixed Bug DSK-245202 (Crash on nytimes.com page while closing Opera)
  • Fixed Bug DSK-245455 (Two entries in Add/Remove Programs after updating from classic installer using autoupdate)
  • Fixed Bug DSK-253393 (Opera should add itself to exception in Windows firewall automatically)
  • Fixed Bug DSK-253893 (ShellExecuteEx error dialog when cancelling UAC/User Access Control dialog)
  • Fixed Bug DSK-253919 (IME is diabled at Flash based text input field)
  • Fixed Bug DSK-254084 (Two entries in Add/Remove Programs after upgrading with MSI installer (as admin on vista, or limited user on XP and Vista)): fixed permision issues when querying the registry
  • Fixed Bug DSK-255279 (Successfully installed widget crashes during launch on windows): Only refer to HotlistManager if it exists
Mac
  • Mac Skin tweaks
  • Show notification in icon when there is a unite notification
  • Fixes for mac widget runtime icon generation
  • Removed the menu items to enable/disable the menu bar: not needed on Mac
  • Fixed Bug DSK-202492 (File input element allows multiple selection)
  • Fixed Bug DSK-246193 (Key events for some keyboard layouts behave oddly in combination with modifier keys.)
  • Fixed Bug DSK-246360 (Crash when importing feeds without a window open)
  • Fixed Bug DSK-248980 (Mac crashes with web fonts)
  • Fixed Bug DSK-251746 (Aborting print from VG.no crashes Opera)
  • Fixed Bug DSK-252855 (Flash spilling over frame on google reader)
  • Fixed Bug DSK-253366 (Can't add attachments from Finder in list view)
  • Fixed Bug DSK-254060 (Move "Check for update" from help submenu to opera submenu)
  • Fixed Bug DSK-254062 (Scaled down images gets corrupted on mac)
  • Fixed Bug DSK-254602 (Speed Dial - black background and text on mac)
  • Fixed Bug DSK-254757 (Opera crashes after installing widget)
  • Fixed Bug DSK-255602 (In speed dials greater than 9, on mac, speed dial number covers speed dial image)
Unix
  • Fixed issue with '-debugdns' command line option being disabled by mistake
  • Adding CJK-fonts as a result of feedback from various testers
  • Fixed Bug DSK-248653 (Login dialogs corrupted on startup)
  • Further fix to Bug DSK-251817 (Crash when opening menus)
  • Fixed Bug CORE-17972 (Change default preference for core X fonts)
  • Fixed Bug DSK-202039 (Default settings for configurable font switching)
  • Fixed Bug DSK-214957 (Flash plugin cannot be in a path containing netscape): This is a work around for a Flash Bug. If the library is a symlink to a flash library then try to use the resolved one, otherwise pretend it is not there
  • Fixed Bug DSK-221875 (Opera fails to read&write font names properly on locales other than en_US.UTF-8)
  • Fixed Bug DSK-252635 (netstat.com doesn't display statistics)
  • Fixed Bug DSK-252689 (Page can only be activated by clicking tab in Qt4)
  • Fixed Bug DSK-253952 (Context menu on windowless Flash not working): Release pointergrab when sending right-clicks to plugins
  • Fixed Bug DSK-253953 (middle-click to paste in linux doesn't work in designMode)
  • Fixed Bug DSK-255278 (New skin does not support dark native themes)
Download
Opera 10.0 (Snapshot) Build 1589 (Opera Unite)
Changelog Highlights
  • Unite: The two-way internet is here
  • Lots of skin fixes and tweaks
  • Easy to hide the menu bar on Windows and Unix and still have it accessible
  • Welcome mail now looks prettier with HTML formatting
User Interface
Skin
  • Tweaks to smilies
  • More tabs changes
  • News group icons
  • Updated Smilies
Mail/Chat
Speed Dial
Opera Turbo
BitTorrent
Core
Windows
Mac
  • Mac Skin tweaks
Unix
Download
Sultan je offline   Reply With Quote
Staro 24.06.2009., 18:31   #247
Liquid Snake
Postovi: 166
Known Issues
  • Native skins are not finished yet. Several issues remain.
  • Opera Unite is not working in Unix Qt4 builds.
  • Synchronizing search engines might not work yet
Changelog
User Interface
  • Changed BitTorrent dialog: Added a Save button to save torrent file to disk (also see DSK-252995)
  • Added a "Synchronize Opera..." button in Speed Dial
  • Opera Turbo: Download min 2mb of data and visit min 8 sites before measuring bandwidth, and dont check again if the network is fast
  • New icons for Dom Console, Who is, Send File, Spell Check, Authormode, Usermode, Check, Send, Check/Send, Search
  • Revised icons for text_select, pan, start/stop listening, HTML Compose Text Color
  • Added Region Locale preference use to handle region specific configuration files
  • Added multiple server support for autoupdate
  • Add some extra code to ensure menu is shown when needed
  • Adding enabled state for fit width button
  • Updating all trash icons to be consistent
  • Adding simple styling to the start bar
  • Improvements to address bar icons
  • Turbo Box UI tweaks
  • Position the menu properly even if the menu button and the menu bar is invisible
  • Adding tab icons (inverted) for panels viewed as tabs
  • Partial Fix of Bug DSK-253880 (Address bar border too fat (and inconsistent)): Fix for unequal paddings
  • Spelling checker: Added a warning about why the dictionaries.xml file sometimes goes missing from autoupdate, and what to do with it
  • Spelling checker: Make it possible to set a new spell UI session without a pop-up menu
  • Fixed a crash bug related to closing tabs while a tooltip is upcoming
  • Give all submenus icons from the skin
  • Making shadow on active tabs less harsh
  • New Dialog Toggle Icons, and revised mail icons
  • Swap send and don't send button of crash report dialog
  • Tweaked the position of the menu button menu
  • Updated Dialog Images
  • Fixed Bug DSK-223637 (Crash on answering "Never" in password manager (Wand))
  • Fixed Bug DSK-236829 (Activate Next Tab does not work when tabs are launched in the background via control shift click)
  • Fixed Bug DSK-239430 (Pressing Enter to select an item in a dropdown box submits a form)
  • Fixed Bug DSK-241168 (background color of alternate rows in list disappeared)
  • Fixed Bug DSK-245191 (Add Open Folder button to file browse control): Adding context menu option to browse folder
  • Fixed Bug DSK-249063 (Non-removable English entry in Spelling > Language should be grayed out)
  • Fixed Bug DSK-251672 (Corruption of Speed Dial with Windows native theme)
  • Fixed Bug DSK-252995 (Opera continuously opening tabs if you choose "Opera Internet Browser" and "Remember choice" in the BitTorrent Client Selection dialog): the BT download dialog now inherits most of the functionality from the download dialog, including the Save functionality
  • Fixed Bug DSK-253364 (Using different sorting in the dictionary dialog, downloads the wrong ones)
  • Fixed Bug DSK-253668 (Allow Speed Dial to have a custom favicon)
  • Fixed Bug DSK-254393 (Padding of progress bar inside address bar is off)
  • Fixed Bug DSK-254413 (Unclear how to enable tab thumbnails: Always make the enable tab thumbnails checkbox enabled in customize dialog, and if selected force wrapping off)
  • Fixed Bug DSK-254862 (IME is disabled in "Save As" input field)
  • Fixed Bug DSK-254964 (Opera sometimes crashes when closing while downloading a torrent)
  • Fixed Bug DSK-255264 (The turbo button should have a left click context menu)
  • Fixed Bug DSK-255044 (Donwloaded files to a Chinese path cannot show Advanced menu in Download Manager)
  • Fixed Bug DSK-255382 (Leaks in crashlogger dialog)
  • Fixed Bug DSK-255449 (New Opera Link settings dialog layout breaks current localization)
  • Fixed Bug DSK-255531 (Strings don't fit in Link Setup dialog)
  • Fixed Bug DSK-255542 ('Abbrecher' don't fit on Unite/Link Setup diag): resizing buttons in feature setup dialog
  • Fixed Bug DSK-255544 (Description strings don't fit on Unite/Link signup and signin dialog)
  • Fixed Bug DSK-255546 (Strings don't fit on buttons on Unite/Link TAC dialog): resizing buttons in license dialog
  • Fixed Bug DSK-255548 (Checkboxes overlap text strings on Link Options dialog)
  • Further Fix to Bug DSK-255677 (You can't delete a spelling checker dictionary if it is in use. Sharing violation)
  • Fixed Bug DSK-255679 (Spelling checker dictionaries that you install, but do not accept the license for, should be deleted)
  • Fixed Bug DSK-255568 (Speed Dial modifications not sent in link until after restart): Also fixes so that if you receive a speed dial position above your max, the number of speed dials are extended to fit it (but not visually)
  • Fixed Bug DSK-255798 (Must middle click twice to switch to tab thumbnail mode when using native skin)
  • Fixed Bug DSK-255806 (Status bar when using Windows Native skin still uses skin background gradient of the new skin)
  • Fixed Bug DSK-255814 (Privacy policy string in crash dialogue gets chopped)
  • Fixed Bug DSK-255864 (Progress bar does not always disappear after page has finished loading)
  • Fixed Bug DSK-256115 (Inconsistent trash icons)
  • Fixed Bug DSK-256314 (Opera crashes when setting a shared unite image as speed dial background)
  • Fixed Bug DSK-256321 (If you cancel the spelling checker dictionary wizard before reaching the end of the process, the dicts are still installed)
  • Fixed Bug DSK-256344 (Progress spinner on thumbnails overlap other tabs when tabs are small)
  • Fixed Bug DSK-256461 (Widget icon in URL field is smaller than the RSS icon)
  • Fixed Bug DSK-256805 (Opera crashes when dragging separator to trash can)
  • Fixed Bug DSK-256900 (Use progressive disclosure control on 'Report a site problem' dialog)
  • Fixed Bug DSK-256919 (Setting Opera Turbo through the Details dialog fails)
Core
  • Notification given when the Turbo servers are busy
  • Fixed problem with recognizing EV certificates issued directly from the Root
  • Webfonts now works with OpenType fonts (OTF)
  • Fixed Bug CORE-16875 (Images appended after page load don't display until "screen refresh")
  • Fixed Bug CORE-19599 (Internet->Intranet override polishing)
  • Fixed Bug CORE-20220 (Crash on spatnav on Yahoo frontpage)
  • Fixed Bug CORE-21668 (Opera sends Cipher Suite: TLS_NULL_WITH_NULL_NULL (0x0000) when it shouldn't (fastmail.fm))
  • Fixed Bug CORE-21920 (FormatBlock incorrectly affects ancestors of contentEditable element)
  • Fixed Bug CORE-21930 (Investigate Move player crash)
  • Fixed Bug CORE-21933 (Crash when loading gares-en-mouvement.com)
  • Fixed Bug CORE-21953 (Make it possible to change certain preference defaults for certain langauges)
  • Fixed Bug CORE-22112 (Crash trying to load and reference non-existing image with JavaScript)
  • Fixed Bug CORE-22139 (Background image change doesn't repaint new area)
  • Fixed Bug DSK-248214 (Crash when saving a picture that has not been fully downloaded)
  • Fixed Bug DSK-253851 (Java crash on multiple sites)
  • Fixed Bug DSK-254653 (Iframe crash)
  • Fixed Bug DSK-255504 (Make it possible to add turbo configuration files per language)
  • Fixed Bug DSK-255541 (Crash when using inline search with Turbo enabled)
  • Fixed Bug DSK-255901 (Yahoo media player crash at learnenglish.de)
  • Fixed Bug DSK-255942 (Spellchecker stops working on pressing del and space immediately)
  • Fixed Bug DSK-256294 (Windowless Silverlight disappears when using context menu)
  • Fixed Bug DSK-256323 (Create search not working when right clicking on a search text field)
  • Fixed Bug DSK-256442 (Silverlight crash at itv.com)
  • Fixed Bug DSK-256640 (Crash when starting Unite)
  • Fixed Bug DSK-256967 (Opera crashes when loading YouTube video)
  • Fixed Bug TURBO-251 (Crash fix: Mime decoder URL context should not interfere with existing contexts)
Mail
  • Added a dialog to warn about the mail database consistency check
  • 8 bit is not the default content transfer encoding anymore
  • Use the account preference to determine if we should restrict the content transfer restriction to 8 bit or 7 bit
  • Fixed Bug DSK-233989 (Mail bodies missing after mail import)
  • Fixed Bug DSK-239113 (HTML keyboard shortcuts work in plain text mode)
  • Fixed Bug DSK-239908 (Formatting radio buttons and labels act as toggles)
  • Fixed Bug DSK-244390 (Mail client selection dialog isn't displayed on first mailto click after upgrade)
  • Fixed Bug DSK-244505 (Blockquote still visible in compose window)
  • Fixed Bug DSK-253679 (When you reply to a message the cursor is invisible)
  • Fixed Bug DSK-254053 (Mail header buttons overlap bottom of toolbar)
  • Fixed Bug DSK-254870 (Pasting a message clears the paste buffer)
  • Fixed Bug DSK-255306 (8bit messages marked as 7bit)
  • Fixed Bug DSK-255905 (Opera Mail welcome message encoding and other string problems)
  • Fixed Bug DSK-255969 (Reopen HTML draft with prefer plain text shows HTML source in compose window)
  • Fixed Bug DSK-255980 (Old draft shown on reopening)
  • Fixed Bug DSK-255990 (Remove from view doesn't decrease the unread count)
  • Fixed Bug DSK-256351 (Changing account breaks the automatic encoding chooser)
Opera Unite/Widgets
  • Fix for a crash that happened when the Trash can is dragged to the widgets area in widgets panel
  • Fixed Bug DSK-249755 (FileSystem.browseFor* callback not executed)
  • Fixed Bug DSK-254636 (Shift + Delete key does not work in widgets and Unite services panel)
  • Fixed Bug DSK-254694 (You can close the security prefs dialog even if the The "Repositories Whitelist Manger" dialog is open)
  • Fixed Bug DSK-255418 ("Opera Unite Services" looks out of place in the "Add/remove panel" menu)
  • Fixed Bug DSK-255516 (First text on service start should be "Service started" not "No activity")
  • Fixed Bug DSK-255524 (It is possible to set special characters as the address for a service)
  • Fixed Bug DSK-255538 (Moving service to Trash should show warning about stopping the service)
  • Fixed Bug DSK-255782 (Unite panel does not open when service installed in all cases)
  • Fixed Bug DSK-256267 (Crash when home/root service is missing)
  • Fixed Bug DSK-256752 (Double-clicking the home service often opens /home/)
  • Fixed Bug DSK-256792 (Invalid device names is saved)
  • Fixed Bug US-515 (Yusef.serveFile() fails when there is some argument in GET)
Windows
  • Initial work on windows native skin - panels, thumbnail tabs and normal tabs
  • Fixed Bug DSK-196535 (Ignore new WMP plugin on Win 9x)
  • Fixed Bug DSK-198255 (New WMP plugin not detected if Firefox is not installed)
  • Fixed Bug DSK-217253 (Plugin detecting method npdsplay.dll->np-mswmp.dll)
  • Fixed Bug DSK-256036 (Opera switches to English when autoupdating)
Unix
  • Updated Japanese font settings on request
  • Fix system tray update issue in Qt3 when switching to/from Unite
  • Fixed Bug DSK-234230 (JavaScript page freeze, causing excessive CPU usage on Solaris)
  • Fixed Bug DSK-252068 (Modifier keys on DOM key events not being reported properly)
  • Fixed Bug DSK-254431 (Crash when using Flash in widgets)
  • Partial Fix of Bug DSK-255278 (New skin does not support dark native themes)
  • Fixed Bug DSK-255831 (Implement Unite notification in tray icon on UNIX)
  • Fixed Bug DSK-256020 (Cannot drag and drop attachements from Nautilus)
Mac
  • Mac skin uses standard Mac delete icon
  • Mac-specific Speed Dial favicon
  • Changing the Mac add-tab icon to be 22x22
  • Fixed Bug DSK-253912 (Crash on startup after upgrade from 9.x)
  • Fixed Bug DSK-256991 (Crash fix for demuths.de)
WARNING: This is a development snapshot: It contains the latest changes, but may also have severe known issues, including crashes and data loss situations. In fact, it may not work at all.
Download
Opera 10.0 Build 1601 Beta
Known Issues
Changelog
User Interface
Core
Mail
Opera Unite/Widgets
Windows
Unix
Mac
Download
Staro 26.06.2009., 19:02   #248
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
Changelog
User Interface
  • Changed name of "Transfers" to "Downloads"
  • Tweaks to the windows native skin
  • Added Turbo warning icon
  • Added Open Folder button to file browse control
  • Partial fix for Bug DSK-247823 (Menu item 'Edit > Check spelling' must be updated) The desktop part of the new rewrite on how to turn on and off spellcheker
  • Fixed Bug DSK-254466 ("Add contact" mail button - inconsistent capitilization)
  • Fixed Bug DSK-255284 (Translated strings in Romanian do not fit Crash and Appearance dialog)
  • Fixed Bug DSK-256214 (Unite status button: More space needed for translation)
  • Fixed Bug DSK-256583 (Double click on note to insert into mail doesn't work when replying)
  • Fixed Bug DSK-257018 (Some buttons get bigger when focused)
  • Fixed Bug DSK-257029 ("Open Service" should be disabled if the service is in the trash can) plus: consistently disable "properties" for trashed Unite services
  • Fixed Bug DSK-257076 (New "synch opera" button in Speed Dial is too small)
  • Fixed Bug DSK-257089 (Windows native: Text in Speed Dial search field impossible to read with dark background image)
  • Fixed Bug DSK-257143 (Tiled background in Speed Dial isn't remembered)
  • Fixed Bug DSK-257190 (Unable to edit file/folder chooser boxes by hand)
  • Fixed Bug DSK-257195 (Panel header text becomes unbolded when customised)
  • Fixed Bug DSK-257223 (Update dialog, new version download size value does not fit)
  • Fixed Bug DSK-257233 (Automatic Turbo mode not reflected in status field)
  • Fixed Bug DSK-257256 (Crash when performing mouse gesture while gesture dialog is open)
Core
  • Fixed Bug CORE-2227 (Onload script not executed in frameset where one frame's src is set to "#")
  • Fixed Bug CORE-22239 (Make sure MultiEdit fields will be spellchecked if the spelling checker is turned on when it doesn't have focus)
  • Fixed Bug CORE-22240 (Make sure there is no active sessions and spellcheckers when a user turns off the spellchecker)
  • Fixed Bug DSK-256927 (File with spaces not opened after download)
  • Fixed Bug DSK-257213 (WMP not painting when going back/forward (and sometimes not on first load))
Mail
Opera Unite
  • Experimental UPnP changes
  • Fix for a bug that prevented every device but the first to notify the correct opened port to the proxy
  • Fixed Bug CORE-22068 (WebServerResponse.closeAndRedispatch sends a 405 under a POST request)
  • Fixed Bug DSK-253872 (Cannot start root service)
  • Fixed Bug DSK-255768 (Wait until the webserver and the services are initialized before restoring unite: URLs from sessions)
  • Fixed Bug DSK-257145 (Opera crashes on startup when Unite is disabled)
Windows
  • Fixed Bug DSK-254084 (Two entries in Add/Remove Programs after upgrading with MSI installer (as admin on Vista, or limited user on XP and Vista))
  • Fixed Bug DSK-254083 (Error dialog when selecting current limited user in the Run As dialog when autoupdating using limited account on XP)
Unix
  • Fixed Bug CORE-21872 (Crash when starting Unite)
  • Possible fix for Bug DSK-224080 (Flash content makes opera crash on Sparc Solaris), add workaround for Sun X bug
  • Fixed Bug DSK-240834 (Qt4-shared build uses Qt3 settings)
  • Fixed Bug DSK-253944 (Plugin wrapper crash)
  • Fixed Bug DSK-255517 (Move ttf fonts from Suggests to Recommends in Debian packages); modernized the list of font packages
Mac
  • Fixed Bug DSK-203698 (Aqua skin progressbar display issues)
  • Partial Fix of Bug DSK-255214 (White artifact cover entire page when reloading using Reload button)
  • Fixed Bug DSK-256977 (Missing background styling for dropdown menus at play.com)
  • Fixed Bug DSK-256991 (Opacity related crash)
Download
Opera 10.0 (Snapshot) Build 1606
We decided to release another build this week to let you have something to play with over the weekend. Since the previous build, there has been a bit of UI work going on, and some fixes to UPnP (Opera Unite). We have also enabled some experimental UPnP code, so please report any unexpected network related issues that you come across. Any crashes can simply be reported through the new crash dialog. In addition to that, we have the first 64-bit Qt4 builds for Linux.
Changelog
User Interface
Core
Mail
Opera Unite
Windows
Unix
Mac
Download
Staro 29.06.2009., 02:14   #249
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Prije tjedan dana sam instalirao operu nakon dugo vremena u nadi da će se pokazati dobrom. No evo danas sam ju izbrisao jer jednostavno nikak ne radi s facebookom i clanbaseom, stranicama na kojima sam svaki dan i po kojima svaki dan prčkam. Neznam u čemu je problem, al neki gumbovi na stranicama jednostavno ko da nemaju funkciju odnosno neko odredište, jednostavno su mrtvi. Naravno posumnjao sam i na rad na tim stranicama, ali sam se uvjerio da je s njima sve ok pomoću drugih preglednika.
Ali vizualno, opera je po defaultu ispred svih drugih preglednika. Da je bar tak i u praktičnom dijelu.
Staro 30.06.2009., 21:04   #250
Postovi: 7,568
Zadnje izmijenjeno od: McG. 15.11.2011. u 20:04.
Staro 03.07.2009., 18:09   #251
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
User Interface
  • Updated standard skin dialogs (brighter, lighter look with more air)
  • Fixed several issues with lacking space for translations
  • Fixed icon height consistency
  • Added some icons to the mail compose menu and changed some of the icons in the tools menu to colored versions that already exist
  • Extensive changes due to lightening the pagebar: Icons can now work on all toolbars, stronger panel color for better differentiation
  • Corrections to dialog tabs
  • Adding 16px icons for the main Opera menu (Bookmarks, help, tools, windows)
  • Changing Speed Dial favicon in standard skin to be more like OS X native skin
  • Small tweak to the background of standard skin close buttons
  • Fixed Bug DSK-232147 (Opera replaces commas with dots when I paste URL to address bar): Stop conversion after first '/' or '?' whatever comes first
  • Fixed Bug DSK-251903 ("Go" button not taking new search field into account)
  • Fixed Bug DSK-253896 (Panel moves when clicking "Unite Services" when "images with text below" is set)
  • Fixed Bug DSK-255662 (The Go button needs a non-text-looking icon when "images only" is set)
  • Fixed Bug DSK-257212 (Button size inconsistencies)
  • Fixed Bug DSK-257851 (No info icon before "what is Turbo in Turbo popup menu): Added info icon on the "about turbo" element in the turbo pop-up menu.
  • Fixed Bug DSK-257591 (Speed Dial merging leaves duplicates)
Core
  • Several crash fixes
  • Fixed Bug CORE-14549 (Positioned empty span descendant of a shrink-to-fit breaks layout via horizontal scrollbar)
  • Fixed Bug CORE-15761 (Regex [^x] fails to match certain characters)
  • Fixed Bug CORE-15893 (Recursive Regular expression causes stack exhaustion)
  • Fixed Bug CORE-18311 (Regex \b is incorrectly matching the point between a letter and underscore)
  • Fixed Bug CORE-19424 (Regex pattern (a|ab){2} fails to correctly match (can't update IP address at DynDns))
  • Fixed Bug CORE-19701 (input type=url can no longer match URLs correctly (regexp related))
  • Fixed Bug CORE-19911 (Regexp of the form /^(b+?|a){1,2}c$/ fails to find match)
  • Fixed Bug DSK-231216 (Opera crashes, likely after a page on a background tab refreshed itself)
  • Fixed Bug DSK-247269 (Video at apple.com does not load and page becomes unusable)
  • Fixed Bug DSK-255591 (Cannot download new .torrent file with turbo enabled.)
  • Fixed Bug DSK-257538 (Decoding error when writing an html mail with a non-ASCII character)
Mail/Chat
  • Center the new account wizard for mail
  • Fixed Bug DSK-203865 (The title in IRC channels always equals the title shown in the app window title bar)
  • Fixed Bug DSK-256468 (text does not fit completely in a few dialogs when switching to Romanian language)
  • Fixed Bug DSK-256580 (Can't paste into inline find in mail view)
Opera Unite
  • Added new dialog for advanced options, adding setting for upload rate
  • Added new preference for UPnP Service Discovery: opera:config#WebServer|UPnPServiceDiscoveryEnabled
  • Delete warning no longer shown when dragging a running service, unless dragging to trash
  • Added warning dialog buttons saying "Delete"/"Cancel" when a user drags a service to the trash
  • Fixed Bug CORE-21715 (Crash when enabling Unite)
  • Fixed Bug DSK-256201 (UI problems when running multiple instances of the same Unite Service)
  • Partial Fix of Bug DSK-256802 (Implement option to toggle visibility on ASD)
  • Fixed Bug DSK-257279 (When renaming invalid usernames containing a '+', the '+' should be escaped as '%2B')
  • Fixed Bug DSK-257458 (Wrong message when dragging opened widget): Service deletion warning shown when dragging widgets
  • Fixed Bug DSK-257609 (Huge properties dialog for unite services)
  • Fixed Bug DSK-257675 (customized panel toolbar doesn't have the Unite panel after upgrading to a Unite build): upgrading hotlist panel selector, adding Unite panel if necessary
  • Fixed Bug DSK-257770 (service download dialog has an 'Ok' button that closes the download dialog): service download dialog shouldn't have an 'Ok' button
  • Fixed Bug DSK-257799 ("Empty Trash" action should be disabled when trash is empty)
  • Fixed Bug DSK-257813 ("Open" in the Unite panel should be disabled when no service is focused)
  • Fixed Bug DSK-257842 (Make it imposible to install a new home service)
  • Fixed Bug DSK-257852 (Unite: Allow to set port via UI)
Windows
  • Additional fix for Bug DSK-249688 (Systemwide settings are not read)
  • Fixed Bug DSK-250578 (Garbled display of tab thumbnail when page uses bitmap fonts)
  • Fixed Bug DSK-253008 (Wrong name listed for Azureus in BitTorrent Client Selection dialog)
  • Fixed Bug DSK-257622 (Upgrading single user install from Opera 9.27 to 10.00 1603, mail and profile is not picked up)
Mac
  • Enabled crash dialog
  • Changes to Mac skin to allow dark tab bar icons, inc. lighter tab bar
  • Styling for '[Content Block Toolbar Skin]'
  • Fixed Bug DSK-205241 (Default font-size for Text field single-line on OS X should be 12px on the CJK system)
  • Fixed Bug DSK-247555 (Enabling single keyshort cut crashes Opera when used with M2 and IME ON)
  • Fixed Bug DSK-255214 (White artifact cover entire page when reloading using Reload button only)
  • Fixed Bug DSK-255532 (Drop SmartCrash Reporter): Due to use of our own crashlogger
  • Fixed Bug DSK-255561 (Focus stays with plugin)
Unix
  • Added more Chinese fonts
  • Fixed Bug DSK-240505 (Middleclick-paste is broken with Speed Dial state 3)
  • Fixed Bug DSK-253531 (Opera prints "opera: X Shared memory extension is not available. ZPixmap not supported" on startup)
Download
Opera 10.0 (Snapshot) Build 1622
  • New advanced settings dialog with setting to limit upload bandwidth in Opera Unite
  • New look for dialogs and tab bar
  • Crash logging on the Mac
Known Issues
  • Crash logging on the Mac does not always work
  • Linux 64-bit Qt4 builds are missing
  • No Linux Intel Qt3 builds due to issues (workaround: Use a Qt4 bundled package)
User Interface
Core
Mail/Chat
Opera Unite
Windows
Mac
Unix
Download
Staro 08.07.2009., 14:57   #252
redbull
redbull's Avatar
Lokacija: Sisak
Postovi: 4
po meni opera mi je bolja od mozilefirefx
redbull je offline   Reply With Quote
Staro 08.07.2009., 15:49   #253
rak21
COD2 expert
rak21's Avatar
Postovi: 1,920
Autor redbull Pregled postova
Staro 09.07.2009., 19:47   #254
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
User Interface
  • Updated opera:* pages, error pages, fraud warning page, and info panel designs
  • Added icon to crash dialog
  • Work on consistent statusbar icons, particularly Turbo
  • Correct icons in the HTML compose context menu
  • Darker selection color to suit new panel background
  • Updating appearance of windows menu, adding hover and selected states
  • Corrected text color on hovered tabs
  • Reverting some of the changes to the skin
  • Update all thumbnails in toolbar that shows a Speed Dial when an entry in the speed dial is canceled.
  • Update each and every thumbmail that shows a Speed Dial when removing a page from the speed dial
  • Fixed Bug DSK-257221 (Added missing Turbo icon in dialog)
  • Fixed Bug DSK-257242 (When pagebar tail is set to "text only", the "Closed tabs and windows" button has no visual indication of hover)
  • Fixed Bug DSK-255286 (Missing strings for translation in Error Console window)
  • Fixed Bug DSK-256468 (Text does not fit completely in some dialogs when switching to Romanian)
  • Fixed Bug DSK-256472 (Speed Dial info and config background is not completely gray)
  • Fixed Bug DSK-253739 (Problems redrawing a tab thumbnail after canceling configuration dialog)
  • Fixed Bug DSK-257863 (Speed Dial thumbs rendering changes on hover)
  • Fixed Bug DSK-258058 (Menu arrows not horizontally aligned in status bar)
  • Fixed Bug DSK-258162 (Address field appears useless after starting Opera with previous session)
  • Fixed Bug DSK-258338 (Keyboard focus not shown in dialogs)
Core
  • Fixed Bug CORE-21759 (Large read-only textarea freezes Opera when focused)
  • Fixed Bug CORE-22148 (Applet POSTs even with 0 content-length (Wikipedia's Cortado Java Theora player doesn't work in Opera 10))
  • Fixed Bug CORE-22494 (NP_RemoveProperty not calling properly back to plug-in after delete)
  • Fixed Bug CORE-22548 (Posting links on someone's wall at Facebook won't load/post)
  • Fixed Bug DSK-188992 (Leading whitespace characters are stripped/collapsed)
  • Fixed Bug DSK-231216 (Opera crashes, likely after a page in the background refreshed itself)
  • Fixed Bug DSK-252431 (Scrolling repeated SVG background is slow)
  • Fixed Bug DSK-254982 (TinyMCE + Dragonfly crash)
  • Fixed Bug DSK-258304 (Search button doesn't work when enabling and disabling Turbo)
  • Fixed Bug DSK-258331 (SVG background image disappears on hover)
Mail
  • Fixed Bug DSK-250881 (Redirect doesn't work)
Opera Unite
  • Advanced Unite settings revamp: merging upload speed settings into one field, adding another heading for visibility settings, re-grouping
  • Fixed Bug CORE-22019 (Crash when disabling Unite)
  • Fixed Bug CORE-22461 (Service visibility options aren't stored persistently)
  • Fixed Bug DSK-187542 (Cannot use folder nickname as home page)
  • Fixed Bug DSK-254722 (Service installation fails after two dialogs about enabling Unite)
  • Fixed Bug DSK-256802 (Implement option to toggle ASD visibility)
  • Partial Fix of Bug DSK-257590 (Preinstalled services should be downloaded on demand)
  • Fixed Bug DSK-257883 (Service names in installation dialog no longer bold)
  • Fixed Bug DSK-257885 (Opera crashes when closing Unite dialogs in the wrong order)
  • Fixed Bug DSK-257914 (No default bandwidth limit in drop-down)
  • Partial Fix of Bug DSK-257931 (Add visibilty of Unite users on the local network)
  • Fixed Bug DSK-257990 ("Advanced settings" in unite service install dialog is not bold unless hovered)
  • Fixed Bug DSK-258059 (Enabling Unite without restart crashes Opera when disabled in opera:config#UserPrefs|EnableUnite)
Windows
  • Fixed some broken Unite paths
  • Fixed Bug DSK-252107 (File dialog crash)
  • Fixed Bug DSK-257697 (Make file name serialization work for ini files on Windows)
  • Fixed Bug DSK-258216 (Hiding the menu button menu with Alt when opened with a mouse click doesn't work)
Mac
  • Crash logging should now work without having the OS pop up an administrator password prompt
  • Fixed Bug DSK-258242 (Menu button reappears after a restart on Mac)
Unix
  • Proper parsing of non-latin command line urls
  • Made some changes that will assist plugin detection on Gentoo Linux
  • Fixed Bug DSK-224537 (RPM file name does not conform to specification)
  • Fixed Bug DSK-257007 (Leak in unix plugin path dialog)
  • Fixed Bug DSK-257358 (Instances keep reference to deleted wrappers - causing crashes)
  • Fixed Bug DSK-257888 (The folder /usr/lib64/mozilla/plugins/ should be scanned for new plugins)
  • Fixed Bug DSK-257889 (/usr/lib64/opera/plugins and /usr/lib/opera/plugins should both be set for 64 bit Linux versions of Opera)
Download
Opera 10.0 (Snapshot) Build 1631
  • New design for info panel, error pages, internal pages (e.g., opera:about), and fraud warning page
  • Skin fixes, including updated icons
  • Stability fixes
  • Unite fixes
  • Admin password is no longer needed when reporting crashes on Mac
  • Improved plugin detection on 64-bit Linux
Known Issues
  • opera:drives and opera:historysearch not yet updated to new design
  • The bottom (white) part of the new error pages might not load every time
  • The skin is still work in progress
  • Some Unix builds may be missing, but most of them will be continuously uploaded
User Interface
Core
Mail
Opera Unite
Windows
Mac
Unix
Download
Staro 16.07.2009., 13:54   #255
Postovi: 7,568
Staro 21.07.2009., 17:52   #256
Postovi: 7,568
Staro 22.07.2009., 11:44   #257
lnsomnia
Lokacija: Usa
Postovi: 58
opera 10.00 beta 2
Imam nekih poteskoca s novom operom na racunalu na poslu. naime sve radi ok ako su iskljucene java skripte. kada ih ukljucim otvori prvu stranicu koju upisem, na drugoj zablokira i moram ugasiti operu. ima netko ideju u cemu bi bio problem? probao sam pobrisati javu na racunalu pocistiti registry i onda instalirati najnoviju (build 14 nesto) i 0 bodova
lnsomnia je offline   Reply With Quote
Staro 31.07.2009., 17:10   #258
Postovi: 7,568
Staro 01.08.2009., 16:38   #259
Rain Man
Lokacija: x
Postovi: 1,447
Ja koristim sad vec jedno vrijeme betu 1642 i radi ok. S par stranica odredeni problemi u prikazu, za neke stranice nece upamtit lozinke no uglavnom brza i pouzdana. Vidim da novi buildovi rjesavaju neke od problema. U ocekivanju finalne verzije.
Rain Man je offline   Reply With Quote
Staro 01.08.2009., 20:33   #260
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
ova 10 je imho dosta brza i od lisice i od m$a.
.i.
Razer Blade 15
Staro 02.08.2009., 09:59   #261
cropape
Lokacija: solin
Postovi: 211
"Opera unite" services, nikako da mi uspije sharing ???
Dajte ljudi pomozite, jučer sam instalirao novu "Opera unite" i oduševljen sam sa njezinim novim mogučnostima (services) koje bi htio koristiti ali nikako da mi pođe za rukom.
Kreirao sam account na opera unite i instalirao servise: File sharing, Media player i Photo sharing.
To isto je uradila i moja sestra u USA.
Nakon toga oboje smo otvorili operu, u ljevome okviru sam označio file sharing i kliknuo na open. Nakon par sekunda desno se prikazao folder sa svim fajlovima koje sam dao za sharing. Pod acces control sam odabrao limited i kopirao URL koji se prikazao gore u polju "Send this URL to share the files:"
Taj URL sam dao sestri i kad ga ona umetne u adress bar, nakon 10tak sekunda dolazi joj poruka:
----- The service is overloaded or offline. Please try again later.
You tried to access the address http://home.mate.operaunite.com/file...ntent/97NVGSH6, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working
Zna li ko u čemu je problem
cropape je offline   Reply With Quote
Staro 02.08.2009., 10:31   #262
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
First of all you need to register yourself at "My Opera"
Staro 02.08.2009., 13:14   #263
cropape
Lokacija: solin
Postovi: 211
Jesam registrirao sam se na "My opera"
Staro 07.08.2009., 19:32   #264
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
User Interface
  • Changing the red notification dot to blue
  • Further work on pagebar elements
  • Improvements to appearance and hit area of standard skin floating, head and tail buttons
  • Minor fix to ensure the menu button is shown even if the panel toggle is removed
  • Minor fix to to UI customization to ensure the correct toolbar is highlighted
  • Moved the tail toolbar to the top when tabs are on the side. Max width is also now 50% larger than the default
  • Removed some of the redundant spacing on the right of the floating pagebar toolbar
  • Removing text bold and blue colour from attention tabs
  • Fixed Bug DSK-236184 (Localized "Preview" text doesn't fit in speed dial)
  • Fixed Bug DSK-259720 (Tabs wrapping not set back to no wrapping when setting tab placement back to top from left or right)
  • Fixed Bug DSK-259754 (Resizing tab thumbnails on the left or right side is slow)
  • Fixed Bug DSK-260044 (Drag scrollbar skin leftover if changed tab bar placement from top/bottom to left/right)
  • Fixed Bug DSK-260065 (Clicking on the thread expander selects the message but should only expand/collapse)
  • Fixed Bug DSK-260111 (The tab bar tail has incorrect background)
  • Fixed Bug DSK-260157 (Discrepancy in language names in prefs)
  • Fixed Bug DSK-260333 (When hovering speed dial thumbnails they get a black line on the left and right side)
  • Fixed Bug DSK-260396 (Thumbnails not shown on the side after restart if head toolbar is off)
  • Fixed Bug DSK-260690 ([Pagebar Tail Button Skin] & [Pagebar Thumbnail Floating Button Skin] styling doesn't show)
  • Fixed Bug DSK-260786 (Clicking on where the thread expander would have been doesn't show the message)
  • Fixed Bug DSK-252540 (Error console no longer has a clickable link/icon to the filenames of the files throwing the errors)
  • Fixed panels-as-tabs-toolbars in the Mac Native skin
  • Fixed some menu button negative margin issues
  • Fixed the layout of the floating + button when on the sides
  • Fixed to prevent the menu button disappearing when entering the prefs dialog and changing something then pressing Ok
  • Fixed various minor issues when Visual Tabs are shown on the side
  • Further Fix to Bug DSK-259960 (Remember last email used in crashlog upload dialog)
  • Partial Fix of Bug DSK-236446 (Encoded (unreadable) address in URL auto-complete)
Core
  • Fixed Bug DSK-235730 (Crash when saving the session)
  • Fixed Bug CORE-22963 (A web font redefined in a style sheet that doesn't get applied to the page breaks the previously defined webfont)
  • Fixed Bug CORE-23336 (use error.css for cross domain warning page)
  • Fixed Bug DSK-260106 (Blocking content that is added as an iframe src using JavaScript causes page to never stop loading)
  • Fixed Bug DSK-260744 (Text under Appearance not updated after language change)
Mail
  • Fixed Bug DSK-257667 (View > Period doesn't work on PowerPC and SPARC)
  • Fixed Bug DSK-236094 (Panel selector unread count not updated when marking mulitple mesasges)
  • Fixed Bug DSK-236950 (Inaccurate naming of "published" column for feeds)
  • Fixed Bug DSK-256504 (clicking on a popup email notification brings up the unread messages tab without the icon in the tab)
  • Fixed Bug DSK-259266 (M2 doesn't handle From header in message when QP encoding starts inside quotes)
  • Fixed Bug DSK-259594 (Use system selected fonts for html compose font chooser)
  • Fixed Bug DSK-259386 (Inlined images sent from Thunderbird are recognized as attachments and not content id elements)
  • Fixed Bug DSK-260254 (Mail Column Header Alignment)
  • Changes to make the database consistency check dialog appear less often
Unite
  • Added messenger unite service
  • Stability improvements and crash fixes
  • Fixed Bug CORE-22311 (%5C on the url will make the Unite webserver unresponsive)
  • Fixed Bug CORE-23304 (Opera freezes when unite access folder with many files)
  • Fixed Bug DSK-255935 (Upgrade from non-Unite to Unite build does not add Unite status icon)
  • Fixed Bug DSK-260153 ("Computer name is in use" dialog sometimes appears more than once)
  • Fixed Bug DSK-260230 (Unequal padding and minor adjustments needed in "Service Settings" dialog)
  • Fixed Bug DSK-260317 ("Install as a new service" input fields not correctly aligned)
  • Fixed Bug TURBO-259 (No Turbo for local Unite services)
Spelling Checker
  • Fixed Bug DSK-259958 (Wrong compose context menu)
  • Change so that when the UI is set to a language other than english, the dictionary wizard is opened when Check Spelling is enabled
Windows
  • General improvements to Win Native theme
  • Fixed Bug CORE-21083 (Copy of nbsp (non-breaking space) puts unexpected data on the clipboard)
  • Fixed Bug DSK-257572 (Dropdown buttons in windows native skin overlap the select box)
Mac
  • Fixed Bug DSK-260185 (Pagebar is missing attention state when hovering a tab)
  • Fixed Bug DSK-260298 (Mac native's startbar is a lot wider than Mac standard's startbar)
  • Fixed Bug DSK-259775 (Mac skin top dragbar knob repeated on left/right)
Unix
  • Fixed Bug DSK-260216 (Crash after dragging a tab to a second window, closing it and then activating the first window)
  • Fixed Bug DSK-243508 (Opera tray icon transparency issue in Qt4 builds)
  • Fixed Bug CORE-954 (Opera does not add .html extension when saving pages with images)
  • Fixed Bug DSK-260188 (Upnp memory leaks on linux)
Download
Opera 10.0 (Snapshot) Build 1691
  • Attention state red dots are now blue. The red dots got some flak the last time around, so after a bit of shilly-shallying and random trepidation we decided to switch out the racuous red for a balmy breeze-like blue. We hope you like it.
  • There's a brand spankin' new Unite service called Messenger, use it to chat with your buddies on My Opera.
  • Tab thumbnails on the side interface has been spiffed up a bit.
  • Unite stability has been given a once-over, we think you'll find it to be improved.
Known Issues
  • No auto-update this time around.
  • Java has issues on the Mac.
  • A few Unix builds may be missing, though most of them will be continuously uploaded.
User Interface
Core
Mail
Unite
Spelling Checker
Windows
Mac
Unix
Download
Staro 13.08.2009., 12:09   #265
Sultan
Six Blade Knife
Sultan's Avatar
Postovi: 292
Opera 10.0 beta 3
User Interface
Added
  • Translated into 38 languages including English
Improvements
  • Visual tabs now available on the left or right side of the browser window
  • Further tab improvements with better attention state design
  • Spellchecker menu item moved to Preferences > Advanced > Browsing dialog box
  • Additional debug skin tooltip information: skin information of the parent element, plus what skin type is active (top, left, right, bottom or default)
Fixed
  • Problem when trying to open a .pdf file
  • Problem when saving a session
  • Pages using webfonts which caused a problem in Windows 98®
  • HTML clipboard now works with both MS Office® and OpenOffice.org®
Mail, News, Chat
Fixed
  • System selected fonts now used for HTML compose font selector
  • Mail column header alignment
Staro 13.08.2009., 12:16   #266
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Jel netko stavio osim mene?
Ne želi mi napravit upgrade kao prošla beta 2.
žmnpp
Staro 13.08.2009., 12:21   #267
vercetti
vercetti's Avatar
Datum registracije: May 2003
Postovi: 1,226
Kod mene upgrade normalno prosao.
vercetti je offline   Reply With Quote
Staro 13.08.2009., 12:24   #268
Rain Man
Lokacija: x
Postovi: 1,447
Ni meni nije htio napravit update. Mozda su im serveri pod opterecenjem.
Staro 13.08.2009., 12:46   #269
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Jedno je update a drugo upgrade.
A meni oba nisu radila
žmnpp
Staro 13.08.2009., 13:09   #270
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Lol, meni update ne zeli poceti skidati, ali zato sam "manualno" dloada i upgradea. Sve stima...
