Staro 30.10.2015., 22:06   #2521
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Bilo bi dobro ako:
- nebi imala naljepnicu za garanciju na šarafima
- bude jeftinija za barem 300-400kn (taman proper aftermaket cooler)
U suprotnom je odluka smijurija
Staro 02.11.2015., 21:23   #2522
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
I prije Omega drivera Fury X je pretekao 980ti sa 15.9.1 beta driverima.
Najnoviji review sa TPU:
LINK
Fury X is now just as fast as GTX 980Ti in 1080p/1440p and faster in 4K
A ovaj mjesec dolazi i najavljena Omega koja ce dodatno zacementirati mjesto Fury X kao najbrze GPU danasnjice.
Da ne bude opet preveliki hype treba pricekati Omega drivere,ko zna sto donose za AMD.
Hawker je offline   Reply With Quote
Staro 02.11.2015., 23:12   #2523
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Baš mi je drago da si stavio taj link ... da vidimo kakva je situacija sa novim driverima
Btw slične taktove (Lightning OC) hvatam sa ovom svojom referenticom, možda nešto sitno (3%) manje
Staro 03.11.2015., 00:14   #2524
Mladenxy
Mladenxy's Avatar
Postovi: 4,373
Ne vidim neki smisao fury/furyX i Gtx 980 dok je 290 X 2770 kn, čak i jedna 390 vulgaris za istu cijenu je mudriji izbor.
Staro 03.11.2015., 00:53   #2525
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
A tek ova 980ti lightning za 7200kn???
Staro 03.11.2015., 02:54   #2526
Manuel Calavera
Postovi: 14,584
Catalyst ide u povijest izgleda, dolazi Radeon Software.
With this new driver release, AMD is looking to move away from the common criticisms of their drivers that has been near constant in the past. The Catalyst Control Center was well received when it was released, though it’s now grown into something large and unweildy. AMD’s goal, then, for Radeon Crimson is to re-brand their drivers as something new that fits with their new software initiative as well as redesign the interface into something that befits the 21st century.
Staro 03.11.2015., 09:32   #2527
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
dakle neki rezime za amd je da dolazi novi konkurentan hardware i software
MojSkuter
Staro 03.11.2015., 09:37   #2528
Hawker
Postovi: 1,972
Autor Eladio Pregled postova
Plus Omega driveri ovaj mjesec.
Staro 03.11.2015., 10:12   #2529
Mladenxy
Mladenxy's Avatar
Postovi: 4,373
Ili možda pripremaju teren za prodaju Radeon odjela.
Staro 03.11.2015., 11:35   #2530
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
zašto bi prodali odjel koji im trenutno jedini koliko-toliko dobro posluje?
Staro 03.11.2015., 12:04   #2531
Mladenxy
Mladenxy's Avatar
Postovi: 4,373
Zar bi to bilo prvi puta da se nešto poroda što dobro posluje?
Staro 03.11.2015., 12:49   #2532
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,748
Strasno dobro posluje.
Ocito rijec dobro treba predefinirati kad je u kontekstu AMD.
Staro 03.11.2015., 12:58   #2533
Manuel Calavera
Postovi: 14,584
Ma gluposti. Zašto bi redizajn driverskog softvera imao ikakve veze s prodajom?
Također i da je to moguća opcija, trenutak je potpuno loš, jer im se taman market share počeo oporavljat, također uskoro izlazi nova generacija sa potpuno novim arhitekturama po svim linijama, novim proizvodnim procesom i ponekim novim tehnologijama. I sad kad je dobar dio posla odrađen, te kad je neminovno da će im porast vrijednost bi kao trebali prodat?
Prodaja samo gpu odjela nema nikakvog smisla iz razloga što je duboko povezan sa procesorima i već tu cijela priča staje
Staro 03.11.2015., 12:58   #2534
Hawker
Postovi: 1,972
Nece bit prodaje Radeon odjela.
Ovaj software je zamjena za CCC i to je to. I izgleda puno bolje od CCC.
Ovi OC settings per game je jako zanimljiv.
Staro 03.11.2015., 15:12   #2535
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Pa da vec prodaju, nebi sigurno sada prodavali, nego nakon sta izbace nove procesore i grafe, pa nakon sta vide jesu uspjeli onda donesu odluke sta i kako, sada nema smisla ista prodavati, zato jer sve mirise na oporavak i stvari vec sada idu na bolje...
Sphere je offline   Reply With Quote
Staro 03.11.2015., 22:40   #2536
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
Ma ludilo, eno jedna dionica 10k dolara koliko su svi osjetili napredak prema gore, namirisali brokeri oporavak.
Staro 04.11.2015., 02:23   #2537
Manuel Calavera
Postovi: 14,584
Pa normalno da slijedi oporavak. Dolazi prvi cpu nakon 4 godine (uljučujući i high-end desktop, serverske, semi-custom SoC-eve i ARM), dok je gpu market share nerealan tj. zavaravajući (jer zapravo od 10 mj. 2013 do 6. mj. 2015 nisu izdali novu generaciju, dok konkurencija jest). Kao što je pisalo u jednom članku, nakon rekordno niskih udjela na tržištu postoji samo jedan put - put prema gore.
Staro 04.11.2015., 09:34   #2538
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor xulos Pregled postova
Skok od 27% u zadnjih mjesec dana je popriličan, druga je stvar ako se ti ne kužiš u dionice pa misliš da je to malo
Da si negdje posudio milijun kuna i kupio dionice, sad si mogao 250k pospremiti u džep
Staro 04.11.2015., 10:56   #2539
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Mislim da bi svi prvo sa miljom kupili AMD dionice
Bez potpisa.
Staro 04.11.2015., 11:00   #2540
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor RaneZ Pregled postova
Nije bitno što se kupi nego kad i koliko se pritom zaradi. Ovi što kupuju emocijama uglavnom popuše
Staro 04.11.2015., 11:38   #2541
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Pa pošto mogu ići samo gore, a propasti neće, mislim da je to lukava kupnja!
Staro 04.11.2015., 11:53   #2542
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Tanka je granica između ova dva stanja
Staro 04.11.2015., 12:43   #2543
Sphere
Postovi: 1,254
Standardna lupetanja Nvidijaša
Staro 04.11.2015., 12:51   #2544
Manuel Calavera
Postovi: 14,584
Pa to sam i ja govorio. 2017 dionica mora ići gore osjetno. Jedan forumaš nas je čak i informirao o postupku kupovine. Da imam viška love jebo me pas ako nebi to pokupovao. Naravno nije vrijedno rizika da netko jedinu ušteđevinu tj. svu lovu spiska na to, rizik svakako postoji, ali tko ima baš ono viška mogao bi možda za godinu i pol - dvije imati jahtu gratis
Staro 05.11.2015., 13:27   #2545
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
U sridu
Staro 05.11.2015., 20:02   #2546
Postovi: 16,942
Za ljude koji ne prate temu nadogradnje konfe, molim mišljenje o Gigabyte R9 390 8gb! Hvala
Staro 05.11.2015., 20:16   #2547
ravkan
ravkan's Avatar
Postovi: 753
Super grafa, ja ih ugradujem vecinom. Mogu ti toplo preporucit.
Red Vishera Blue Devil
ravkan je offline   Reply With Quote
Staro 05.11.2015., 20:39   #2548
Hawker
Postovi: 1,972
Topla preporuka.
Ja imam Sapphire R9 390 i prezadovoljan sam.
Staro 05.11.2015., 22:13   #2549
Sphere
Postovi: 1,254
Gigabyte nema uvijek top modele kartica, ali mozes biti siguran da sa njime neces nikad pogrijesiti
Staro 05.11.2015., 23:20   #2550
Postovi: 16,942
Onda r9 390 8gb će biti. Vidjeti ću samo koliko ću biti ograničen lovom.
Ali između 2700-3000 ću ulagati u grafu.
