Zaključane teme
Staro 20.10.2013., 21:35   #2371
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Neću ulazit u tu raspravu više. I uopće se ne čudim što neki ignoriraju problem. Takvi su ljudi i to je OK. Moj savjet svima je nosit na servis čim se pojavi bilo kakvo smrzavanje, pošto su to tipični simptomi umirećeg eMMC chipa. Nek se servis zeza s tim. Sve drugo nije pametno. Čak i ako SDS stvarno ne postoji.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
Zadnje izmijenjeno od: estugarda. 20.10.2013. u 22:05.
estugarda je offline
Staro 21.10.2013., 14:07   #2372
Postovi: 34,042
Nakon Snapdragon verzije S4, i Exynos verzija dobiva update na 4.3
http://live.samsung-updates.com/
EDIT: još malo glasina o S5 - jedno je sigurno: imati će 16Mp fotić
http://www.unwiredview.com/2013/10/2...-back-rumored/
Zadnje izmijenjeno od: coconut. 21.10.2013. u 15:11.
coconut je offline
Staro 22.10.2013., 17:23   #2373
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 515
decki jedno pitanje , naime na sgs3 vidim da mi je kontakt na mini usb otisao i nekad puni nekad ne , da li to garancija pokriva ?
pdx je offline
Staro 22.10.2013., 17:58   #2374
The Man
The Man's Avatar
Datum registracije: May 2012
Lokacija: Agram
Postovi: 1,096
Probaj nabaviti novi punjač. Meni je bio sličan problem i ispalo je da je ipak punjač taj kojem je oslabio grip.
I LIKE TO WALK ALONG THE BEACH WITH A RAGING HARD ON. IT'S FUNNY TO SEE THE REACTIONS.
The Man je offline
Staro 22.10.2013., 18:06   #2375
pdx
pdx's Avatar
Lokacija: krk
Postovi: 515
Autor The Man Pregled postova
nije probao sam drugi punjac i osjetim klackanje van nutra ljevo desno
pdx je offline
Staro 22.10.2013., 20:38   #2376
Postovi: 34,042
U Europi se pojavio S4 sa Snapdragonom 800
http://www.samsung.com/de/consumer/m...KADTM-features
coconut je offline
Staro 22.10.2013., 22:54   #2377
dinos3
Dino Saur
dinos3's Avatar
Datum registracije: Jan 2012
Postovi: 941
Na svaki problem koji se javlja na s3 odgovaras sa SDS i onda se cudis da ti ljudi proturijece.
SDS problem je rijesen s updateom boota od verzije I9300XELLA nadalje koji je odavno izasao. Tko je updejtao firmware,nema brige. Tko nije,treba updejtat. S3 firmware je poznat po svom bloatwareu i sitnim bugova pa steka cim se koristi duze vrijeme ako je stock firmware u pitanju. Btw,tvoj Note 2 ima takodjer sds bug,ali si ga rijesio 4.1.2 firmwareom. Nemoj se uplasit ako ti pocne stekati,samo resetiraj na tvornicke i nemas brige
Rebootanje mobitela se ne dogada samo na Samsungovim Exynos mobovima nego na svima i najcesci je problem FW. Nedavno isti problem i kolegica imala sa One S.
dinos3 je offline
Staro 22.10.2013., 22:58   #2378
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,681
Autor dinos3 Pregled postova
Prvi puta cujem, na s2 i sada na s4 mini mi se niti jednom nije restartao.
Bono je offline
Staro 23.10.2013., 00:47   #2379
Mad_Duke
Ja sam imao problema sa HTC Desire. Prvo je bilo sa vremena na vrijeme da bi nakon pol godine počelo češće. Matična u dreku. Nisam pol godine obazirao pažnju jer je rijetko bilo, a tamo sam stvarno vozio sve moguće romove. Mislio da je do njih, a nakon toga, odnosno povratka sa servisa. Divota.
Staro 23.10.2013., 15:57   #2380
Postovi: 34,042
Samsung i Corning (Gorilla glass) ušli u zajednički deal. Kako stvari stoje, očigledno si Sami želi osigurati najbolje i najnovije ekrane od Corninga
http://www.corning.com/news_center/n...013102201.aspx
coconut je offline
Staro 25.10.2013., 17:24   #2381
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Jel se netko možda igrao sa ovom američkom verzijom S2? Osim manje ppi ekrana ( i većeg ekrana) vidim da je harderski isti normalnom S2...
Imam neku ponudu za njega, a srce me ionako vuklo nazad na S2... a ako je veći ekran još bolje
blackened je offline
Staro 25.10.2013., 17:38   #2382
Postovi: 34,042
S5 će biti 64-bitan. Pitanje je hoće li raditi Snapdragon verziju i hoće li i ona biti 64-bitna?
http://www.gforgames.com/gadgets/sam...laxy-s5-39297/
coconut je offline
Staro 25.10.2013., 17:59   #2383
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Hih, a najbolje je dok izađe S5, cijena S3 će ostati ista.
karabaja je offline
Staro 25.10.2013., 23:56   #2384
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor blackened Pregled postova
Koliko vidim ima mrvicu brzi procesor i jacu bateriju, veci ekran je isto plus tako da go for it. Jos mu uzmes ovo ( black, i pase bas na taj model ) i imas pilu.
QuidZz je offline
Staro 26.10.2013., 00:27   #2385
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Odvratan je taj case.
sinisa1989 je offline
Staro 26.10.2013., 00:55   #2386
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Autor sinisa1989 Pregled postova
Pa crni ce ubost
Kako kome, meni je osobno odlican i upravo ga cekam iz Kine da stigne ( narancasti za I9105P ).
QuidZz je offline
Staro 26.10.2013., 10:17   #2387
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Ne poričem činjenicu da case odlično štiti uređaj, ali njegov izgled, to je već drugi par čarapa. Naravno, o ukusima se ne raspravlja.
Staro 26.10.2013., 10:57   #2388
blackened
blackened's Avatar
Postovi: 1,281
i meni je užas
Kad uzimam caseove onda uvijek uzmem neki tanki tek toliko da se mob ne izgrebe, ne volim kad mi se podupla mob od case-a.
Staro 27.10.2013., 07:31   #2389
Postovi: 34,042
Počinju dolaziti 4.3 updatei. Za sada samo za USA verzije S3, S4/Active i N2, ali vjerojatno ubrzo i drugdje
http://www.sammobile.com/2013/10/26/..._Flkt0.twitter
coconut je offline
Staro 27.10.2013., 07:38   #2390
trpi
nadam se samo da update nece negativno utjecati na trajanje baterije
Staro 27.10.2013., 07:59   #2391
Postovi: 34,042
Mene veseli TRIM support, bolji management RAMa i novi fw za fotić.
coconut je offline
Staro 27.10.2013., 20:20   #2392
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor coconut Pregled postova
Mislim da si malo krivo skužio. Ovo je samo leak testne verzije kakav se već dogodio prije 10ak dana za ostale zemlje. Dakle ameri kasne. Daleko je to još od finalne verzije. Barem za s3 i n2. Rekoše u 11. Ili 12. mjesecu.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 28.10.2013., 13:41   #2393
Postovi: 34,042
coconut je offline
Staro 29.10.2013., 14:35   #2394
Postovi: 34,042
Zadnje izmijenjeno od: coconut. 30.10.2013. u 15:32.
coconut je offline
Staro 31.10.2013., 20:59   #2395
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 974
Stigao 4.3 za SG4 na vipu, upravo se skida
I eto, malo kasnije, skočio antutu na 29k
Zadnje izmijenjeno od: raliSHA. 31.10.2013. u 21:59.
raliSHA je offline
Staro 31.10.2013., 23:21   #2396
gin.tonic
gin.tonic's Avatar
Postovi: 2,438
Galaxy Nexus ne dobiva službeni Android 4.4...
http://www.phonearena.com/news/Googl...id-4.4_id48950
Ali zato ima brdo ROM-ova za utjehu
gin.tonic je offline
Staro 03.11.2013., 02:21   #2397
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Bluzer je offline
Staro 03.11.2013., 08:01   #2398
Postovi: 34,042
Ajde, bilo je već i vrijeme. Ali, 930Mb je poprilično veliko. Trebati će imati full punu bateriju da se ne skrši tokom d/l i instalacije.
coconut je offline
Staro 04.11.2013., 13:04   #2399
Postovi: 34,042
Gore navedeni 4.3 update je postao služben
http://www.sammobile.com/2013/11/04/...-iii-gt-i9300/
coconut je offline
Staro 04.11.2013., 13:43   #2400
Sanjo00
Datum registracije: Mar 2013
Postovi: 202
@coconut u slučaju da mobitel nema HR izbornik dali bi se ovog nadogradnjom moglo šta napraviti ili bi automatski dobio taj izbornik? Možda glupo pitanje,ali se stvarno ne kužim u to... Hvala
Sanjo00 je offline
Zaključane teme
