Staro 03.05.2010., 13:46   #181
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Pogledajte si mailove opet, gro ljudi dobilo extra key-a za frendove
(da me ne pmate već sam podijelio svoje XD)
@Work HP Zbook15
@Home Acer 5020
Zadnje izmijenjeno od: Deathwish. 04.05.2010. u 10:40. Razlog: Nisam zicer da su 2 keya
Deathwish je offline   Reply With Quote
Staro 03.05.2010., 20:09   #182
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,466
ak netko ima viška nek javi
Staro 04.05.2010., 01:50   #183
The Comedian
It's all a joke
The Comedian's Avatar
Lokacija: unknown
Postovi: 445
eo objavljen datum izlaska - link
27.7. 2010
Once you realize what a joke everything is, being the Comedian is the only thing that makes sense.
The Comedian je offline   Reply With Quote
Staro 04.05.2010., 03:05   #184
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Prosil bi jenega ključeka, ak neko ima
d4rk_ch1ld je offline   Reply With Quote
Staro 04.05.2010., 04:27   #185
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
ključić ako tko ima viška molim
bozzomfeeder je offline   Reply With Quote
Staro 04.05.2010., 09:04   #186
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
gro ljudi dobilo 2 extra key-a za frendove
kako 2?
da imam viška dao bi, no dobio sam samo 1 u onom mailu, nikako 2.
a taj mi je za buraza da nabacimo malo dok ne izađe full igra.
dakle ONE, ne TWO.
by inviting one(1) of your friends to play with you. This email contains your additional beta key(1) for you to send to a friend, along with instructions to help your friend(1) get started.
ideš!
Cijena 150kn
http://forum.pcekspert.com/showthread.php?t=188015
blizzard veli:
it must not be traded or sold.
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 04.05.2010., 10:36   #187
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Autor TomRi Pregled postova
kako 2?
dakle ONE, ne TWO.
ideš!
Cijena 150kn
blizzard veli:
Prosljedujem od kolege s foruma, ja dobio 2 niza znakova ovakvog oblika, sad dal je to jedan key u 2 reda neznam
xxxxxx-xxxx-xxxxxx-xxxx-xxxxxx
@Work HP Zbook15
@Home Acer 5020
Staro 04.05.2010., 12:00   #188
TomRi
TomRi's Avatar
Postovi: 2,073
to ti je jedan key, i meni je u dva reda ali nisu jednake dužine, pa se radi o prelomljenom dugačkom keyu
(uz ono što ti gore piše na par mjesta: one friend, one key...)
Autor Deathwish Pregled postova
Prosljedujem od kolege s foruma, sad dal je to jedan key u 2 reda neznam
pa jesi li dobio na kraju ti
ili frend
(pa širiš neprovjerene poluinformacije na svoju inicijativu)?
jer kako si podijelio svoje ako ni ne znaš koliko si ih dobio,
nisi mogao dati dvojici ljudi po pola keya jer bi ti odmah javili da ne radi.
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 04.05.2010. u 12:24.
Staro 04.05.2010., 14:18   #189
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
ili frend
Ja imam od prije, i sad dobio dodatni, dao jedan red frendu koji nije javio da ne radi,drugi dobio drugi red, isto nije javio da mu ne sljaka. Obzirom da mi nitko nije javio da ne sljaka a kolega na forumu od faksa reko da dobio 2 keya, zabrijao ja da su 2 keya (zasto nisu javili da im ne radi neznam, ja bih to odma instalirao na njihovom mjestu )
Dakle moj zajeb
@Work HP Zbook15
@Home Acer 5020
Zadnje izmijenjeno od: Deathwish. 04.05.2010. u 14:30.
Staro 04.05.2010., 14:22   #190
TomRi
TomRi's Avatar
Postovi: 2,073
ako su te tražili, a preko 30 sati nisu ni probali jel radi...
onda nijedan ne treba key, pa ga daj tu nekome tko ti se prvi javi IMHO
Water cooled PC
Moj najveci MOD
Staro 04.05.2010., 20:33   #191
HONDA type R
HONDA type R's Avatar
Lokacija: Požega
Postovi: 335
HONDA type R je offline   Reply With Quote
Staro 05.05.2010., 16:57   #192
Opaki
Opaki's Avatar
Postovi: 206
evo dobio extra key pa navali narode!!
Ko prvi njegova treba!!
8BKGDB-TKHY-FDZDK6-YWTT-HZVTHW
ZBYBWF-V7MW-F9XT7T-VEJ6-87WEF9
Opaki je offline   Reply With Quote
Staro 05.05.2010., 17:01   #193
Mar
Suit up!
Mar's Avatar
Postovi: 5,970
Fala Opaki
Meni pezde nisu dali ključ još iako sam se prijavija prije godinu dana bit će
- Barney Stinson
Staro 05.05.2010., 17:12   #194
Opaki
Opaki's Avatar
Postovi: 206
np!
Staro 05.05.2010., 17:18   #195
d4rk_ch1ld
d4rk_ch1ld's Avatar
Postovi: 695
Nego jedno pitanje imam, frend mi je dobio beta ključ i dao mi je svoj akaunt. Kad se pokušam logirati veli mi da beta nije u mom battle.net akauntu i da trebam dodati starcraft unutra, ali naravno kad otvorim akaunt starcraft je već dodan. On ga inaće normalno može igrati.
Staro 05.05.2010., 17:27   #196
Opaki
Opaki's Avatar
Postovi: 206
Možda trebaš skinut direktno s tog accounta SCbeta client. Ne bih znao!
Staro 05.05.2010., 17:34   #197
d4rk_ch1ld
d4rk_ch1ld's Avatar
Postovi: 695
Inače je procedura da dobiješ key,napraviš akaunt pa onda skineš igru? Ak je tak onda je to rješenje sigurno.
Staro 05.05.2010., 18:17   #198
wnbeeeE
wnbeeeE's Avatar
Datum registracije: Mar 2009
Postovi: 600
ako je netko sluuučajno dobio ključić bio bih zahvalan !
wnbeeeE je offline   Reply With Quote
Staro 10.05.2010., 19:31   #199
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
Neki dan mi frend poslao beta key, isprobao rundu dvije, nije loše. Danas odigrao još tri runde, navuko sam se
Reaperi i vikinzi su bolesni, drop par tenkića marinaca i gg
Al najluđa stvar mi je dok onaj dropship primi onog ogromnog transformera i vozi naokolo(sry nisam još pohvatao imena jedinica).
Super su mi zvukovi, jedino imam zamjerku na to što su sve jedinice jednako glasne i nije mi tolko nabrijano. Znači, hoću reć da kad su svi jednako glasni dok selektiram jedinice,dok pucaju itd itd. Dok je prije recimo zvuk tenkova u siege modu dominirao, to mi nekako fali dok 5 tenkova okine u isto vrijeme i niš drugo se ne čuje osim njih
Također vrijedi za nuklearku, skroz tih i pasivan glasić kaže 'nuclear launch detected'.
Al sve u svemu, uff, ja sam već sad zadovoljan
Ima ko za dva vs dva? -ja nisam niš posebno dobar, al niam ni toliko glup
Staro 10.05.2010., 21:09   #200
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,466
ak ima neko key nek šera
Staro 11.05.2010., 00:02   #201
PhnX
PhnX's Avatar
Lokacija: lepoglava
Postovi: 182
ak ima neko da mi dade lekciju, nek me pm-a...
ne kontam bas battle net,nije moj acc...ak je moguce nek me doda na listu...djubre je nick..slika je marinac s klempavim ushima..
PhnX je offline   Reply With Quote
Staro 11.05.2010., 00:56   #202
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Elem, jel ima itko još tih keyeva, častim pivom relaciju zg-sk
Da i tata proba malo kako izgleda podmladak najbolje igre ikada, sad baš špilam stari BW i reko aj baš da vidim jel ima kakvih novosti kad ono neki keyevi se dijele, a vidim ima i datum izlaska...
Brijem da ću nakon duuugo duugo godina ići na kupovinu full igre, znači ono ne samo key nego i dvd i te fore, hoću onu knjižicu pod svaku cijenu
D-I-A-B-L-O je offline   Reply With Quote
Staro 11.05.2010., 14:34   #203
rak21
COD2 expert
rak21's Avatar
Postovi: 1,919
Meni kolega s foruma poslao beta key, hvala mu
E sad, battle.net acc imam, kako da napokon zaigram igru?
Staro 11.05.2010., 14:56   #204
Verbum
Postovi: 682
Eto još jedan ključ, pa tko prvi...
DJHDWC-CJX4-BJCXDN-M7VW-YXMR94
6G7BD9-WM2B-ERHXKB-TR7K-8JVMCC
Info za instalaciju:
PLEASE NOTE:Each beta key can be used only once, so please make sure you are upgrading the Battle.net account you wish to use to play the StarCraft II beta. Once claimed, your beta key cannot be transferred to another Battle.net account.
1. Apply Your Beta Key- Log in to your Battle.net account. Under "Manage My Games," click "Add or Upgrade a Game." Enter the above beta key in the "Enter Game Key" field and select "Add Game."
2. Get the Installer - In your list of games, click the “Manage Game” button under the StarCraft II beta image to download the installer.
3. Install the StarCraft II Beta - Once you’ve downloaded the installer, run it and follow the directions to install the StarCraft II beta client on your machine. Note that your participation in the StarCraft II beta test is governed by a Beta Test Agreement that you are required to accept before you can install the beta client.
4. Run the Game & Log in to Battle.net - After the StarCraft II beta installs, the launcher interface should automatically appear on your screen. Log in with your Battle.net account and you’ll be able to begin playing. You can launch the client at any time by clicking the desktop shortcut or by going to the Windows® Start Menu.
Any questions? Check out the FAQ.
Verbum je offline   Reply With Quote
Staro 13.05.2010., 13:54   #205
krip
Postovi: 75
Zamolio bi ako neto slucajno ima key viska
Hvala puno !
krip je offline   Reply With Quote
Staro 13.05.2010., 15:38   #206
Deathwish
overpowered
Deathwish's Avatar
Postovi: 915
Ako netko nije dovoljno nabrijan, evo par animacija koje su radili fanovi (caution, awesome level over 9000!)
First Contact
http://www.youtube.com/watch?v=s06Ua...os=wwb-YK5EFYQ
Final Metamorphosis
http://www.youtube.com/watch?v=DO7He...os=2WzUq6u3UFk
Legacy of the confederation
http://www.youtube.com/watch?v=oFq5V...os=6muiQegZ8mU
@Work HP Zbook15
@Home Acer 5020
Staro 13.05.2010., 15:40   #207
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Ima još netko viška key?
xGAME je offline   Reply With Quote
Staro 25.05.2010., 11:48   #208
SanjaDJK
SanjaDJK's Avatar
Lokacija: đakovo
Postovi: 1
i ja bi jedan key...pleaseeeeeeee
SanjaDJK je offline   Reply With Quote
Staro 28.05.2010., 02:07   #209
domina
domina's Avatar
Lokacija: KC (HR)
Postovi: 917
Kad gase betu? jel zna netko
Staro 28.05.2010., 02:34   #210
ezz
ezz's Avatar
Datum registracije: Feb 2010
Postovi: 297
31.5.
ezz je offline   Reply With Quote
