#181 | |
Postovi: 14,589
AMD Updates Warranty to Allow Aftermarket Heatsinks Ima smisla, jer ono nije imalo logike Citiraj:
#182 |
Datum registracije: Apr 2017
Postovi: 343
AMD Sampling 7nm Zen 2 CPUs Later This Year
[URL="https://wccftech.com/amd-sampling-7nm-zen-2-cpus-later-this-year-launching-in-2019/"] AMD President & CEO Dr. Lisa Su “We are launching additional Ryzen based products in the second half of the year. We just launched the second generation Ryzen desktop in 12nm and that launch has gone really well. I mean, we’re very happy with the positioning and how customers are reacting to that. In the second half we’ll have some commercial systems and some other updates to our Ryzen lineup that we will launch. We have 7nm GPU based on Vega that we’ll sample later this year. We have a 7nm server CPU that we’ll sample later this year. And then, obviously, we have a number of products that are planned for 2019 as well. So it’s a very, very busy product season for us. But we’re pleased with the sort of the execution on the product roadmap.” |
#184 | |
Postovi: 343
AMD’s Upcoming Ryzen 2000 and Ryzen Threadripper 2000 Series CPUs Spotted
![]() ![]() Evo danas i malo opširnija objava članka od jučer: https://wccftech.com/amd-ryzen-2000-...ies-cpus-leak/ |
#186 |
Postovi: 14,589
Meni se čini i da ti imaš neki OK primjerak. Morat ćeš probat okinit 4.3ghz kad tad, neće ti vrag dati mira ![]() Što se tiče prodaje, vjerojatno ih nije gro prodano, a možda se X model više prodaje, kao i jeftiniji "stari" 1600 Edit Evo omjer na minfactory - kaže 2600 - preko 190 komada, a 2600X preko 290 komada, 2700 - 100 komada, 2700X - 760 komada... Zadnje izmijenjeno od: Manuel Calavera. 01.05.2018. u 12:58. |
#190 |
Nažalost na 4400 ne boota Windowse sa 1.52V. A više mu nedam da ne sjebem trafostanicu u ulici ![]() Ne znam kako i gdje bi ga usporedio kad vidim da na PCE je jedan jedini za sada, a na OCN forumu svi pokupovali 2700X. 2600 ako ima 2-3 komada... ako. Jebiga, vani su ljudi davali po 100+ eura za 200 MHz više ![]() @AMD_Shill Nisam isprobavao. Rebootao komp i vratio na sweetspot vjerojatno nije. A i nemam sa čime to hladiti da i testiram stabilnost na 1.44V.Sent from Mobara |
#191 |
Postovi: 14,589
IMO možda si mogao samo pokrenuti stress test, pa gledati temp. Kad ti krenu smetati gasiš stress Koliko je meni poznato nisu ryzenu neki bitan faktor temperature do 1.45v sa iole boljim coolerom, nego taj silikonski zid u overclocku, kad jednostavno ne želi preko neke točke |
#193 |
Postovi: 14,589
Kažem probaj do 1.45v, pa ako neće abortaj misiju. Nisam ni ja svog htio iznad toga, mislim da je koju minutu izdržao pa je freezao, u tih par min temp. nisu bile problem čak ni za moj cooler Kreni sa nečim laganim tipa ibt standard pa povećavaš ako prođe. Mogao bi ja probati standard sa 4ghz |
#194 |
1.45V prođe 10 minuta pa sam ugasio jer sam opako bio oko 80°C. Tako da bi 4,3GHz @ 1,45V mogao biti gaming stabilan. No, ostaviti ćemo mašti na volju ![]() Četvrtina od 1 Volta za 250 MHz... kak da ne ![]() |
#196 |
Postovi: 14,589
Ma to je ništa. Recenzenti ga nabiju na 90C ![]() Ja sam svoj max vidio u zimu na 83-84C kao sam tražio overclock sa stock coolerom, a LLC nabio na max, a peć nabila ambijentalu do ibera ![]() Kad sam sa freezer 33 tražio 4ghz nedavno sa 1.45v u tih par min što je prošao je bio ispod 80C, mislim negdje 77-78C Ovako sa 3.9ghz i sitno ispod 1.35v mislim ne dođe ni do 70C, ne sjećam se više morao bi tražiti svoje postove |
#197 |
Postovi: 941
Znaci, koliko sam ja shvatio, razlika izmedju 2600 i 2600X je u tome sto je X verzija samo malo vec OC-ana, sve ostalo je isto, i jedan i drugi mogu ici do cca 4.2... Ako je tako, onda mi je bolje uzet 2600 i jaci hladnjak i sam napravit OC, tocno? |
#198 |
Postovi: 14,589
Da, razlika je XFR2 support kod X modela (boosting tehnologija) i bolji stock cooler. https://www.youtube.com/watch?v=xjNwAlT0RRw IMO ako misliš clocat bolje uzeti jeftinije i ušteđenu lovu prebaciti u bolji aftermarket cooler (kojeg ionako moraš uzimati i za X model ako misliš veći OC napraviti), a za "turbo noobs" je od ove generacije OK i X opcija, prošle generacije nije imala nikakvog smisla (skuplja, bez coolera, a XFR bez veze) Zadnje izmijenjeno od: Manuel Calavera. 01.05.2018. u 20:44. |
#200 | |
Ako ćeš biti old schooler, R5 2600 ti je najlogičniji izbor. Ionako vjerujem da ga budeš fiksno postavio na neki takt 4000+ MHz all core, set and forget. Bila je spominjana neka priča kako su X modeli binnani i sa boljim IMC-om, da idu na više taktove, no na kraju i nema razlike jer kako se baza popunjava na OCN-u, ljudi imaju više "pizdarija" po pitanju većih taktova RAM-a sa 2700X nego sa 2700. Također sam pikirao 2600X cijelo vrijeme, no kad su izašli i kad se vidjelo da je jednostavno 4,3GHz limit i jednom i drugom, bolje je 200+ kuna popit nego dati za nešto na procesoru što ne koristim (malo bolji stock cooler i XFR). Računaj 4,2GHz sa 1,35-1,42V, ovisno kakav te primjerak posere. Uz to, obavezno SoC napon da ti bude 1,025-1,05V do max max 1,1V. A ako se možeš dodatno rastegnuti, B-Die RAM je way to go Ryzeni stvarno vole te čipove. Evo ti svjedočanstvo kolege @QuidZz-a koji je muku mučio sa nekim Corsairom, isprobavao 10 verzija BIOS-a i nije mogao imati rock-stable ništa više 2933. Uzeo B-Die G.Skill i 3200 MHz out of box nakon prvog bootanja i nikad BSOD-a više ako sam kaj izostavio, neka se sam javi Nije da te nagovaram na B-Die ili da se prekenjavam jer ga osobno imam, ali isto tako kako ja tebe savjetujem, tako je mene savjetovao kolega @shar. Isto sam mislio zguziti 200-300 kn kupujući Corsa sa Hynixom, pa sam ipak uzeo B-Die i eto, godinu dana bez greške. A cooler je majka za procesor, tu nemaš brige. Zadnje izmijenjeno od: Brko. 01.05.2018. u 21:15. |
#201 | |
Postovi: 941
#202 | |
![]() ![]() Ili ako baš hoćeš 3200 C14 kao badass, onda ove: LINK Zadnje izmijenjeno od: Brko. 01.05.2018. u 21:26. |
#203 |
Postovi: 14,589
Ako te tvorničkih CL16 na 3000mhz ili 3200mhz (što gotovo sigurno ide) ne mori, možeš komotno uštedjeti 400kn sa ageisom. Maltene si brutalan cooler kupiš sa uštedom na ramu Nego što se tiče XFR2, ide on i po 4150mhz na svih 6 jezgri |
#204 | ||
Lokacija: Sinj
Postovi: 3,538
G.Skill sa B-Die radi ko svicarski sat. 3333MHz bez problema bez diranja voltaze. Al drzim ih na 3200MHz. ![]() |
#206 |
Postovi: 14,589
https://www.bit-tech.net/media/image/2018/4/29c63576-c5eb-43e7-840c-f5ab49312447.png svaka točka je thread U nekoj recenziji sam vidio da sa aftermarket coolerom dobije još 100mhz (na većem broju jezgri/threadova ili svim jezgrama). U biti tek sad je XFR2 ono što su pričali uoči dolaska prvih. Primjetilo se to i uoči dolaska prve generacije, kad su samo prestali pričati o XFR i "automatskom overclocku", prepoznavanju coolera, očito povukli odnosno odgodili planove A mnoge recenzije su sa 2700X u nekim igrama imali lošiji fps sa overclockom, jer im je XFR2 boostao 4 jezgre više nego što su oni mogli napraviti manualni overclock na svim jezgama Zadnje izmijenjeno od: Manuel Calavera. 01.05.2018. u 21:56. |
#207 |
Overclocker
Datum registracije: Nov 2016
Postovi: 523
Ma Brko može ram i na 1.5V za 24/7, ako te baš brine nešto, uvijek možeš montirat jedan vent da puše prema memoriji. |
#208 |
Postovi: 14,589
Ma čemu to forsiranje. Ja nisam vidio niti jedan relevantan benč benefita sa 3000/3200mhz cl16 na maximalne moguće brzine ili max CL. Sve nešto u razini statističke greške (ako ima uopće razlike), te uz 1080Ti ako se radi o gamingu |
#209 |
Overclocker
Postovi: 523
Često ljudi ne vide nikakve razlike kad OCaju memoriju, no u većini slučajeva je to zbog njihovog manjka znanja, volje ili traženja shortcuta. Ne kažem da bi svatko trebao uložit nekoliko dana testiranja da bi natjerao memoriju do maxa, ali ako se već želite uhvatit u koštac sa tim, samo kažem da se bez problema može ići na 1.5V za 24/7 (za DDR4). Veći problem je pretjerivanje sa SoC naponom jer ljudi smatraju da su svi naponi jednaki i da povećavanje svakog napona znači bolju stabilnost prilikom klokanja. |
#210 |
Postovi: 14,589
Ma znam da se može. Samo ne vidim svrhu u tome kad se ne vidi u ničemu u praksi, o tomu pričam. Naravno osim samih memory benchmarka Pa TPU je izvrtio valjda milijun benčmarka i u 95% nema razlike čak ni između 2133mhz i 3200mhz (ne sjećam se CL). a u 99.99% između 2666mhz i 3200mhz. Kakva je tek razlika između ageisa, trenutno najisplativijeg rama koji je već na 3000mhz cl16, vjerojatno ide 3200, te svega iznad toga (makar 4000mhz cl14), kažem nisam nigdje vidio razliku, eventualno par % |
