Staro 02.08.2014., 18:41   #2041
H@rdc0r3M1nD
H@rdc0r3M1nD's Avatar
Lokacija: Croatia;Velebit
Postovi: 465
ovako kaze error
E:\ Documents and Settings refers to a location that is unavailable. It could be on a hard drive on this computer or on a network. Check to make sure that the disk is proprely inserted, or that you are connected to the Internet or your network, and then try again. If it still cannot be located, the information might have been moved to a different location.
Ma pojma nemam, razbit cu ga od zivaca.
H@rdc0r3M1nD je offline   Reply With Quote
Staro 02.08.2014., 18:47   #2042
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
A što kaže Properties od tih foldera?
Nemam više ideja,nisam još imao takav problem.
Staro 02.08.2014., 19:38   #2043
H@rdc0r3M1nD
Postovi: 465
kaze da je kreirano 2009 godine - sto je istina, i da je velicina 0 bytes-a a to je nemoguce. jer kad gledam ukupno zauzeto diska vidimo da je samo 15% prazno.
Jel ima netko na forumu tko ima ideju?
Postoji li kakav program da moze pristupit svim fajlovima? kako se rijesava kad se nesto formatira pa ipak spasavaju podatke?
idem lec, vec 9 sati ovo istrazujem bez pomaka
Staro 03.08.2014., 01:40   #2044
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,144
ja uvjek koristim erd commander (tj MSDART za win7)
nikad problema takih :P
u biti tako i cistim viruse
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 03.08.2014., 12:40   #2045
H@rdc0r3M1nD
Postovi: 465
HumWeed mozes li malo pojasnit, nisam ja bas toliko strucan. PRogram se zove ERD commander? kako ga koristit?
Sto je MSDART? Ako ne smijes javno javi na PM: samo da spasim tih 2.5 gb fajlova za posao i nikad vise necu takvu glupost napravit. uvijek ce posao na posebnu particiju (daleko do windowsa)
Staro 03.08.2014., 12:56   #2046
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,593
Autor H@rdc0r3M1nD Pregled postova
Ja imam isti problem ali sa externim HDDom na USB 3(HeroVII MBO).Samo s vremena na vrijeme počne nenalazit datoteke ili prekazivat prazne mape sve dok neištekam pa uštekam pa se vrati u normalu.
Pošten trgovac:
1,2,3,
Staro 03.08.2014., 14:08   #2047
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,144
to ti je live cd, sa "shell"-om od windowsa
znaci u biti sprzis taj ISO na cd/dvd, bootas sa njega i imas windows sucelje/explorer
koje se "spoji" sa particijom koju odredis
(to je u biti rescue cd sa win suceljem)
i trebao bi imati neogranicen pristup podatcima jer je to zasebni "live os" nije vezan uz windowse i accounte
trebao bi ih naci preko torrenta jer bar koliko ja znam za to se neplaca (posto ljudi sami to moraju "buildati" iz recovery toolsa)
ak nenadjes sibni pm pa ti uploadam svoj
Staro 03.08.2014., 14:29   #2048
H@rdc0r3M1nD
Postovi: 465
NEmam pojma. DO jucer u jutro, sve je bilo za 5. IMam 3 foldera koja moram spasit, al nikako. evo prenio sam disk u novi komp i opet nista. Pokusat cu potrazit ovaj tvoj ERD commander.
Samo da spasim te foldere i onda mogu total format napravit. samo to. Al zanimljivo je sa tim diskom - 2 su particije - 2 su windowsa XP i win7 (al XP nikad nisam korisito) vec godinama prilikom paljenja "vrti" check disk. I pokazuje zauzeti prostor na disku al nikako doc do tih dokumenata - a tamo su sigurno.
Ajmo ekipa, znam da na forumu ima znalaca kojima je ovo u malom prstu, pomozite bilo kakvim savjetom!
Hvala svima koji su vec pomogli
Staro 03.08.2014., 14:39   #2049
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Skini neku distribuciju xNIX-a, kao što ti je kolega gore rekao. Npr, Kali Linux. Skida se kao ISO, tako da ga trebaš spržiti na DVD. Ako ne znaš kako se snima ISO, imaš ovdje na forumu upute pa pročitaj.
Odi u BIOS, stavi CD/DVD kao first boot device, kad se OS pokrene, upikni flash drive i kopiraj si to šta ti treba.
[GOW]Nec je offline   Reply With Quote
Staro 03.08.2014., 14:49   #2050
H@rdc0r3M1nD
Postovi: 465
jucer sam przio hirens boot - znam sprzit iso fajl. Znam i napravit da se boota sad dvd-a
Idem skinut taj kali linux pa cu pokusat onda pristupit.
Evo slikom prikazan moj problem
Ukupno koliko je zauzeto a koliko kad sve datoteke oznacim i gledam koliko zauzimaju.
Znaci da "Ispod" ima datoteka i to mi treba.
Staro 03.08.2014., 14:57   #2051
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Kali ti to baš puno ne zanima, tamo imaš Root privileges, vidi sve što postoji upisano na tvoj disk i može manipulirati s tim.
Staro 03.08.2014., 15:01   #2052
H@rdc0r3M1nD
Postovi: 465
Sad sam nasao neki Kali Linux 1.08 velik 2.87 gb.
idem pripremit neki DVD za to zaprzit pa cemo vidit. samo da to izvucem, samo to.
Staro 03.08.2014., 16:18   #2053
H@rdc0r3M1nD
Postovi: 465
Evo pokrenuo sam Kali Linux i opet ista stvar. Opet vidi samo datoteke koje sam vidio u windowsu. a pokazuje da je 440gb used a 60 gb free
Edit: kaze SOME CONTENTS UNREADABLE al uredno broji fajlove kad stisnem properties
Zadnje izmijenjeno od: H@rdc0r3M1nD. 03.08.2014. u 16:30.
Staro 03.08.2014., 16:48   #2054
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Jesi se ulogirao kao root, ako te uopće pitao? Znaš po tome što gore desno piše ako si root, user i to.
Staro 03.08.2014., 16:53   #2055
H@rdc0r3M1nD
Postovi: 465
da kao root. nije me nista pitao, vec sam pokrenuo live kali. imam baloncic (kao u stripu) i pise root... pojma nemam, da je to toliko zakopano da niti jedan program ih ne vidi.
Staro 03.08.2014., 16:55   #2056
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
... ili je disk poluispravan.
Staro 03.08.2014., 16:59   #2057
H@rdc0r3M1nD
Postovi: 465
Stvarno nemam pojma. ja nisam strucnjak, neke osnovne stvari znam al ovo je cirkus. Samo da iskopam 3 hebena foldera. doslovno 2.5 gb. Kojim programom je najbolje napravit analizu
stanja samog diska?
Posudio sam kabel USB na IDE/SATA i ista stvar - povezem laptop sa ta kompom i nikako, iste stvari vidi - al ne ono sto treba.
Staro 03.08.2014., 17:02   #2058
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Alatom proizvođača, ako je ikako moguće. Na Hiren's-u ima dosta takvih.
Staro 03.08.2014., 17:04   #2059
H@rdc0r3M1nD
Postovi: 465
Autor [GOW]Nec Pregled postova
OK,ovo je samsungov neki disk. idem vidit s hirensom.
Postoji li u linuxu kakva opcija - show hidden files and folders? jer on uredno broji sve fajlove na disku al nikako ih pokazat...
Staro 03.08.2014., 17:07   #2060
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Nije povezano s tom opcijom uopće, to je potpuno drugačiji OS, i sve podatke koji su u Windowsima vidi čisto kao neke podatke na nekom disku, ne pridaje im nikakvu specijalnu važnost.
Staro 03.08.2014., 17:09   #2061
H@rdc0r3M1nD
Postovi: 465
bezveze pitam... nemam ideju pa svasta razmisljam... kuzim, posto se radi o odvojenom operativnom sustavu on sve na tom disku vidi, ajmo rec kad da stavis usb. al kad ga tako vidi sto ga ne pokaze... pas masters.
napravit cu analizu diska pa cemo vidit dalje.
Staro 03.08.2014., 17:22   #2062
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Kao što si primijetio, alatna traka je gore. Odeš gore lijevo na "mjesta", odabereš ono što je u windozerima "C" particija (vjerojatno će se zvati "XX GB file system") -> documents and settings -> ime -> desktop.
Ako toga tamo nema, to je već drugi par opanaka. Onda se nešto smrdalo na tom disku.
Staro 03.08.2014., 18:38   #2063
H@rdc0r3M1nD
Postovi: 465
Našao sam, našao sammmmmmmm! Svima hvala puno hvala!
Nije bilo tamo vec se pojavio neki folder found.010 i unutra je bilo...
Sad kad povadim sve sto trebam sa tog diska. kako je najpravilnije napravit novu instalaciju win7?
Znaci, kako napravit potpuni format - da disk bude ko novi?
Staro 03.08.2014., 18:59   #2064
Veki-os
Veki-os's Avatar
Postovi: 3,996
Prvo vidi da li "valjaju" ti podaci,kad ih budeš pregledavao iz windowsa,da nisu koruptirani ili nešto.
A za instalaciju Win 7 imaš hrpu tutoriala http://tinyurl.com/npd39t4
Ovaj je dosta dobar http://www.techtalkz.com/windows-7/5...-tutorial.html
Za potpuno brisanje ovdje označiš svoju C particiju i izabereš Delete ili format,iako bi intalacija Winsa trebala to napraviti sama automatski kasnije ako ti to ne napraviš ručno.
Staro 03.08.2014., 19:02   #2065
H@rdc0r3M1nD
Postovi: 465
Da, da...to znam, nego sam mislio dal moram nekim dodatnim programom "detaljnije" formatirat ili je dovoljan klasican format iz tog tutoriala!
Staro 03.08.2014., 19:10   #2066
Veki-os
Veki-os's Avatar
Postovi: 3,996
Dovoljno ti je to iz tutoriala.
I kad staviš Windowse provjeri prvo sa HD tune ili HD Sentinel da li ti je disk ispravan,ne znamo jel se to dogodilo zbog diska ili su se windowsi nešto zblesirali.
Staro 03.08.2014., 19:24   #2067
H@rdc0r3M1nD
Postovi: 465
jos samo jedna stvar kako cu spasit bookmarkse i passworde iz mozille?
koristit cu HD tune
Staro 03.08.2014., 19:53   #2068
Veki-os
Veki-os's Avatar
Postovi: 3,996
https://support.mozilla.org/en-US/kb...ores-user-data
Trebao bi folder biti ovdje C:\Users\Veki\AppData\Local\Mozilla\Firefox
Kopiraš cijeli "Profiles" folder,na novim winsima instaliraš Firefox i prekopiraš ovaj folder preko novoga.Bit če ti Firefox i svi podaci,passwordi kao na starim winsima.
Isto možeš napraviti i za Thunderbird ako ga koristiš.
Staro 04.08.2014., 21:54   #2069
Valley7
Datum registracije: Apr 2012
Lokacija: qsd
Postovi: 567
Nije da je neki turbo problem, više minorna iritacija...
Iz nekog razloga windows nakon par gašenja zaboravi koji je monitor / refresh rate. Pa me nakon bootanja dočeka neki čudan refresh rate i generic monitor (to vidim kad napravim desni klik na desktop i odaberem screen resolution).
Onda u tom istom izborniku kliknem "detect" pa odmah prepozna monitor i automatski stavi normalan refresh rate koji ne izaziva glavobolje. Lupim OK. To potraje kroz par gašenja / restarta pa onda opet zaboravi...
Lako to sredim sa 2 klika kad ustreba, ali ipak pomalo bizarna pojava...
Valley7 je offline   Reply With Quote
Staro 04.08.2014., 21:56   #2070
Veki-os
Veki-os's Avatar
Postovi: 3,996
Ako ti windows update nudi drivere za monitor instaliraj ih,ako ne skini ručno pa ih instaliraj.
