#1981 | |
Lokacija: München/Varaždin
Postovi: 4,740
Dakle - nisi odradio po tutorialu gore ![]()
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42 |
#1982 | ||
Postovi: 18,829
Code:
root@Domy-NAS:/var/log# modprobe em28xx root@Domy-NAS:/var/log# lsmod | grep -i em28xx root@Domy-NAS:/var/log# Code:
root@Domy-NAS:/var/log# cat ups.log 2023-01-28T04:08:48+01:00 Domy-NAS synoups: synoups online 2023-01-28T04:08:48+01:00 Domy-NAS synoups: =====log UPS status start===== 2023-01-28T04:08:48+01:00 Domy-NAS synoups: device.mfr=American Power Conversion 2023-01-28T04:08:48+01:00 Domy-NAS synoups: device.model=Back-UPS CS 500 2023-01-28T04:08:48+01:00 Domy-NAS synoups: battery.charge=100 2023-01-28T04:08:48+01:00 Domy-NAS synoups: battery.runtime=1642 2023-01-28T04:08:48+01:00 Domy-NAS synoups: battery.voltage=13.7 2023-01-28T04:08:48+01:00 Domy-NAS synoups: input.voltage=246.0 2023-01-28T04:08:48+01:00 Domy-NAS synoups: output.voltage=230.0 2023-01-28T04:08:48+01:00 Domy-NAS synoups: ups.load=34.0 2023-01-28T04:08:48+01:00 Domy-NAS synoups: ups.status=OL 2023-01-28T04:08:48+01:00 Domy-NAS synoups: =====log UPS status end===== Citiraj:
https://forum.turris.cz/t/dvb-c-usb-...ssues/11383/16 I ovdje je frajer uspio osposobiti ID 2040:026d s kernelom 4.4, znači ista generacija, samo za ATSC. https://github.com/th0ma7/synology Valjalo bi probati prvo na RPi pa ako šljaka, primijeniti i na NAS, ne zeza mi se baš s recoveryem u ovom trenutku. ![]()
#1983 |
Postovi: 4,740
Znaci okrljastena verzija kernela ili nekaj staro. Koja verzija kernela je gore (uname -a)? Jel mozes nekaj tipa kernel-devel ili kernel-source ili kernel-headers instalirat? Idealno bi bilo skinut kernel novi sa podrskom i kompajlirat (mozes i na drugom kompu pa kopirat na to cudo) ali mislim da se nebus usrecil (boot?)....
#1984 | |
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,350
b) mogao sam to riješiti bez da imam linux u malom prstu i riješio sam u nekoliko navrata c) poanta je u tome da mi se to nije dalo raditi toliko često i iznenadno i zato sam odustao od Fedore jer mi nije zanimljivo da se klanje s Nvidiom lomi meni preko leđa Kao što rekoh, ima distribucija koliko hoćeš. Jedna ne paše, biti će neka druga koja će pasati. Nema potrebe da se od ove rasprave radi cirkus ili da se umjereno složeni tehnički problemi mistificiraju. |
#1985 | |
Postovi: 4,740
U tome je stos- kad jednom slozis kak spada - vise nikad ne prckas. Na to sam mislio. Al ko sto kazes - svako koristi kaj mu pase ![]()
#1986 | |
Postovi: 18,829
Code:
domy@Domy-NAS:/$ uname -a Linux Domy-NAS 4.4.59+ #25556 SMP PREEMPT Thu Mar 18 13:00:34 CST 2021 x86_64 GNU/Linux synology_geminilake_420+ Code:
domy@Domy-NAS:/$ synopkg --help usage: synopkg <command> [...] command: start <package> Start a package. stop <package> Stop a package. restart <package> Stop a package, then start it. resume <package> Start a package without enable its service. It will do nothing if enabled flag doesn't exist. pause <package> [skipupgradecheck] Stop a package without disable its service. It will do nothing if enabled flag doesn't exist. start-depend <service> Start all packages depend on specific service. stop-depend <service> Stop all packages depend on specific service. onoffall start|stop [event] [param] Start or stop all the packages. install [--daemon-reload] <spk> Install a package through local spk. install_from_server <package> [volume] [user] [beta] Install a package from server. uninstall <package>... Uninstall one or more package. upgradeall [limitonly] [lang] [user] Upgrade all upgradable package. chkupgradepkg [lang] Find all upgradable packages from server, and decide whether to upgrade accorting to user settings. checkupdateall [lang] [user] Find all upgradable packages from server (use cache first), and decide whether to upgrade accorting to user settings. status <package> Get status of an installed package. is_onoff <package> Check if a package is installed and if its enabled flag exists. version <package> Get version of an installed package. query <spk> Get a package's basic information from the spk. list [--name] [--depend-on <package>] List all installed package. log <package> Get package's log path. checkupdate <package> [lang] Check if a package is updatable. sort_spk_by_dep_order <spk_path>... Sort given spks according to their dependencies. notify_stopped_by_firmware Send notifications about which packages are stopped by firmware. Code:
domy@Domy-NAS:/$ cat /etc/fstab none /proc proc defaults 0 0 /dev/root / ext4 defaults 1 1 /dev/vg1/volume_1 /volume1 btrfs auto_reclaim_space,synoacl,ssd,noatime 0 0 domy@Domy-NAS:/$ ls -alh / total 64K drwxr-xr-x 22 root root 4.0K Jan 27 22:37 . drwxr-xr-x 22 root root 4.0K Jan 27 22:37 .. lrwxrwxrwx 1 root root 7 Jan 18 02:17 bin -> usr/bin drwxr-xr-x 7 root root 0 Jan 27 22:38 config drwxr-xr-x 12 root root 19K Jan 27 22:38 dev drwxr-xr-x 46 root root 4.0K Jan 28 20:08 etc drwxr-xr-x 43 root root 4.0K Jan 18 02:19 etc.defaults drwxr-xr-x 2 root root 4.0K Mar 18 2021 initrd lrwxrwxrwx 1 root root 7 Jan 18 02:17 lib -> usr/lib lrwxrwxrwx 1 root root 9 Jan 18 02:17 lib32 -> usr/lib32 lrwxrwxrwx 1 root root 7 Jan 18 02:17 lib64 -> usr/lib drwxr-xr-x 2 root root 4.0K Jan 18 02:16 .log.junior drwx------ 2 root root 4.0K Mar 18 2021 lost+found drwxr-xr-x 2 root root 4.0K Mar 18 2021 mnt drwxr-xr-x 2 root root 4.0K Jan 18 02:17 .old_patch_info dr-xr-xr-x 255 root root 0 Aug 23 2018 proc -rw------- 1 root root 1.0K Jan 18 02:17 .rnd drwx------ 3 root root 4.0K Jan 21 03:31 root drwxr-xr-x 29 root root 1.5K Jan 28 21:38 run lrwxrwxrwx 1 root root 8 Jan 18 02:17 sbin -> usr/sbin drwxr-xr-x 4 root root 4.0K Jan 18 02:17 .syno dr-xr-xr-x 12 root root 0 Jan 27 22:37 sys drwxr-xr-x 2 root root 4.0K Jan 18 02:17 .system_info drwxrwxrwt 18 root root 1.6K Jan 28 21:39 tmp drwxr-xr-x 11 root root 4.0K Mar 18 2021 usr drwxr-xr-x 16 root root 4.0K Jan 27 22:37 var drwxr-xr-x 13 root root 4.0K Jan 18 02:17 var.defaults drwxr-xr-x 1 root root 602 Jan 28 20:05 volume1
#1987 |
Postovi: 4,740
Malo cudno...na normalnom kompu bi il instalirao noviji kernel ili u postojeci lupio Patch i rekompajlirao. Sa DSM-om nemam apsolutno nikakvog iskustva i nemam pojma kako se ponasa. Ali - github link koji si dao ne izgleda glupo - ako to tak sljaka kako pise - vrlo vjerojatno ce ti rijesiti problem. Zasad ti je to mozda i najbolja opcija. P.S. - neznam dal postoji dmesg kod DSM-a , pa da vidis da te mozda firmware ne hebe....neke distre (Ubuntu/Debian) ne stavljaju firmware za neke stvari po defaultu, pa moras naknadno instalirat i dok taj korak ne odradis - stvar ne sljaka.
#1988 | |
#erase startup-config
Postovi: 3,676
![]() Stripe/stride postavke služe tome da ext4 pokuša grupirati writeove kako bi write matchirao stripe size od RAID polja. Onda se dogodilo da su SSDovi počeli širiti page size na 8kB (Intel 320 je mislim bio prvi) pa na 16kB kako bi bili brži i radili na full SATA-III brzinama. Zbog toga se kod flasha primjenjuje stripe 16kB. |
#1989 | |
Postovi: 3,676
Imam u produkciji svega. Security fixevi CVE-ova vrlo često prije dođu na Debian/Ubuntu nego na RedHate. Ovo ne čudi s obzirom koliko je Debian community ogroman. Dok to u RedHatu/IBMu prolazi kroz beskrajne korporativne procedure moji Ubuntu serveri su to već pokupili tokom noći dok sam spavao i server ih je sam aplicirao. Do sada nikakvih problema zbog toga, naprotiv. Također službeni Debian repozitorij je također ogroman sa puno repozitorija trećih strana. Na ReHatu je to dosta ograničeno pa svako malo nešto kompajliram. Na RedHatu je sve u /opt dok na Debianima (skoro) ništa. Zbog toga, a i drugih stvari imam drame kada moram raditi upgrade OSa na RedHatu. Debian i Ubuntu se uglavnom bezbolno upgradeaju dok RedHate uvijek dižemo ispočetka ili nam se ne da pa radimo na (pra)starim verzijama. Kada bude problem na RedHatu, plati support. Guglanje problema često dovede u slijepu ulicu: "da bi ste nastavili čitati morate imati support...." To je problem budući da se RedHati često koriste upravo za specifične korporativne stvari. Onda imaš za*ebanciju sa supportom: "imate ili sve patchirano?" Pa ti šalju testne pakete koji mogu ili ne moraju fixati tvoj problem. Pa to sve traje predugo. Obično nije problem u RedHatu nego u softwareu koji je supportan isključivo pod RedHatom. Na Debianima brzo nađem rješenje, brzo ga testiram i u relativno kratkom vremenu ga stavim na produkciju. Ne ovisim o supportu. Da, Debian je sirov a Ubuntu je bloatware. Zato je Linux super jer složim svoj custom Debian ili Ubuntu s kojim radim. Kod stabilnog i ispeglanog RedHata to ne radimo jer "nije podržano...." ![]() |
#1990 |
Lokacija: tu
Postovi: 3,350
Vjerojatno glupo pitanje, ali debian ne dolazi u par opcija upakiran sa raznim DE? |
#1991 |
Postovi: 955
Instaliraš što želiš |
#1992 | |
Postovi: 18,829
![]() Ima dmesg u DSM-u, ali ne kaže ništa pametno osim da je nešto spojeno. Firmware sam prvo ubacio, nije pomoglo. Code:
domy@Domy-NAS:/$ dmesg -HT | tail [Sun Jan 29 20:14:15 2023] usb 1-2: USB disconnect, device number 2 [Sun Jan 29 20:14:26 2023] usb 1-2: new high-speed USB device number 5 using xhci_hcd
#1993 |
Postovi: 4,740
Kolko vidim DSM bi trebao biti u sustini Debian fork koji koristi Upstart...ak s Ubuntu nece sljakat mozes jos to probat...nekaj pametnijeg ti nazalost nemam kaj savjetovat ![]()
#1994 |
Postovi: 3,676
Kada smo već kod DVB stickova ne mogu natjerati Geniatech T230 da proradi pod Linuxom. Pod Windozama radi savršeno bez greške a pod Linuxom imam strganu sliku kao da je preslab signal na anteni. Pokušao sam sve firmware koje sam našao. S nekima je malo bolje, s nekima malo gore ali s niti jednim ne radi kako treba. Ako nekome slučajno radi volio bi znati kako ![]() |
#1995 |
Postovi: 3,464
Provjeri fw još jednom. Pred jedno 3 godine sam po poreporuci frenda koji ima 2 komada na rpi bio naručio baš taj model (MyGica T230), ali sam u kutiji dobio 2 revizije noviji T230C2 ![]() Drugo što mi pada na pamet je probati neki drugi program. Meni se znalo događati s raznim tunerima da iz nepoznatog razloga recimo TVH vidi više/manje kanala nego VDR. Ali nikad greške kakve opisuješ. |
#1996 |
Postovi: 4,740
Ekipa...jel netko mozda naletio na problematiku uzasno sporog kopiranja podataka (lokalni server, RAID5 sa 6 mehanickih HP diskova formatiran sa LVM+EXT4/4k). Dakle 2 ista RAID polja na lokalnom serveru i eto u 2 dana iskopirao 290GB od 5TB. Bez obzira cp ili rsync (-aAHXv) , probao bez kompresije, kemijao sa mount opcijama al bez nekog pomaka. Ima li tko kakvu ideju? ![]()
#1998 |
PRO
Postovi: 4,715
šta kaže log? problem sa metadata zapisima? Koliko su prosječno veliki fajlovi / koliko ih ima? Mreža, njena brzina? možda čak i driveri (iako je to sada zaista rijetkost)? DNS ili direktni IP?
#1999 |
Postovi: 4,740
Bojim se da je upravo do ovoga. Server je HP ML350 Gen9 sa 2x Xeon E5-2643 v4 sa 64GB meme , oba RAID polja su na istom P840 kontroleru. Firmware zadnji na njemu i diskovima. U toku procesa kopiranja sve ostalo deaktivirano. @Ivo > lokalni copy - dakle 2 RAID polja unutar istog servera. Imam osjecaj da rsync ne hendla efektivno transfer lokalno (al opet ni cp nije nikaj bolji) jer se sustav ne znoji.
#2001 | |
Postovi: 3,676
#2002 |
Postovi: 18,829
#2004 | |
Postovi: 4,740
Nista posebno - performance je "on paar". Nikakvih gresaka u logovima sta je povezano sa FS-om ili Hardwareom. Nope - da je to problem nebi ni zapoceo ovo sranje sa migracijom. Prije migracije uvijek cekiram da je sve OK (HDD/Controller/Cache) + imam PRTG Monitoring na HW i SW levelu - sve zeleno. IML ne javlja nista. No kod Gen9 imam sumnju da bas ne javljaju da je disk u banani cak i kad je - imao sam par slucajeva vec da odjednom 3 diska iz istog RAID-a prdnu (naravno uvijek je LD sa podacima korisnika)...do tog trenutka sve radi "normalno"....tu sam dobio samo odgovor od HP-a da im nist nije poznato i da upgrejdamo na Gen10 ![]() Citiraj:
Hm..thanks budem probao ![]()
#2005 |
Postovi: 955
malo u stranu razmišljam već neko vrijeme o ultrabooku/chromebook/2u1 nešto tako 11/12/13" da mogu ssh i nomachine (h264) da linux radi gore kako spada i baterija da traje koji sat kad nisam u uredu da mogu odraditi na brzinu i da nije problem nositi sa sobom na kavu i da ne moram tegliti punjač. inače sam škrt imate kakve hands-on experience i prijedloge za tako nešto ? |
#2007 |
Postovi: 955
imam elitbook 8470p sa Debian/i3 . fantazija kako radi ali daleko je od ultra portable |
#2009 | |
Postovi: 3,676
Što kaže smartmontools za diskove? Pristupaš preko cciss kernel drivera? Usporedi seek error rate i raw error rate na svim diskovima kao i ostale performance countere. |
#2010 | |
Postovi: 4,740
Linux 4.12.14-lp150.12.48-default #1 SMP Tue Feb 12 14:01:48 UTC 2019 (268f014) x86_64 x86_64 x86_64 GNU/Linux hpssa adu report ne pokazuje nist alarmantno. hpssacli kaze - svi diskovi ok. Pa sad buj pametni... HP cickarije su naravno instalirane na serveru: hp-health-10.60-1838.1.sles12.x86_64 hponcfg-5.1.0-0.x86_64 hp-scripting-tools-10.30-39.sles12.x86_64 hp-snmp-agents-10.61-2939.2.sles12.x86_64 hpssa-2.20-11.0.x86_64 hpssacli-2.20-11.0.x86_64 hpssaducli-2.20-11.0.x86_64 Smart ni nemogu ocitat (imam pristup Arrayevima - ne pojedinacnim diskovima)....Ali sumnja je bas na ovo sto si sad napisao - neki disk koji je poceo zezat i koci cijeli array. Jucer je dd read/write bio na svega 190MB/s kaj je - lose. Nije prvi put da tak nekaj sere. Trenutacno samo molim Boga da ne prdne Array, makar sad ima 2 Spare diska nutra. Obozavam ovakva sranja ![]()
Lenovo LOQ 15AHP9 83DX || AMD Ryzen 5 8645HS / 16GB DDR5 / Micron M.2 2242 1TB / nVidia Geforce RTX 4050 / Windows 11 Pro Lenovo Thinkpad L15 Gen 1 || Intel Core i5 10210U / 16GB DDR4 / WD SN730 256GB / Intel UHD / Fedora Workstation 42 Zadnje izmijenjeno od: tomek@vz. 02.02.2023. u 16:15. |
