Staro 30.09.2015., 20:43   #1831
Prezime
Datum registracije: Aug 2013
Postovi: 4,336
name="Time" attr="5408">
name="NTPServer1" attr="6692">time.t-com.hr
name="NTPServer2" attr="6692">1.pool.ntp.org
name="NTPServer3" attr="6692">0.pool.ntp.org
name="NTPServer4" attr="6692">1.pool.ntp.org
name="NTPServer5" attr="6692">2.pool.ntp.org
name="LocalTimeZone" attr="6692">+01:00
name="LocalTimeZoneName" attr="6692">UTC
name="DaylightSavingsUsed" attr="6692">1
name="DaylightSavingsStart" attr="6692">2000-03-26T02:00:00
name="DaylightSavingsEnd" attr="6692">2000-10-29T03:00:00
name="V_DaylightSavingOffset" attr="6692">01:00
name="V_ServerAddressMethod" attr="6692">Static
name="V_Interface" attr="6692">IGD.WANDevice.1.WANConnectionDevice.4.WANIPConnection.1
name="V_Dateformat" attr="6692">DDMM
name="V_Timeformat" attr="6692">hh:mm:ss
name="V_SyncMode" attr="6692">NTP
name="V_SyncInterval" attr="6692">86400
name="V_UseTimeZoneFile" attr="6692">1
name="V_TimeZoneFile" attr="6692">Europe/Berlin
name="ManagementServer" attr="5408">
name="URL" attr="23092">
name="V_PreviousURL" attr="32">
name="PeriodicInformEnable" attr="6692">0
name="PeriodicInformInterval" attr="6692">86400
name="PeriodicInformTime" attr="6692">0001-01-01T00:00:00
name="ParameterKey" attr="5416">
name="ConnectionRequestUsername" attr="6692">
name="ConnectionRequestPassword" attr="6692">
name="UpgradesManaged" attr="6692">0
name="V_ConnectionRequestPort" attr="6692">8085
name="V_ConnectionRequestAuthentication" attr="6692">Digest
name="V_Enable" attr="6692">0
name="V_WaitForNTPSync" attr="6692">0
name="V_DisableSessionLock" attr="36">0
name="V_AlwaysDHCPDiscovery" attr="6692">0
Ne mogu sad restartat jer mi treba ono za gledanje utakmica na satelitskom
Probat cu posle tekmi, ali i meni se cini da je nekaj zeznuto u configu. Posle cu iskopirat taj dio za "Time" i poslat ga, pa mozda nesto otkrijes.
EDIT:
Ovo je moj dio configa koji se odnosi na NTP servere:
Zadnje izmijenjeno od: Nikky. 01.10.2015. u 00:15.
Staro 01.10.2015., 00:04   #1832
back2quick
Datum registracije: Jan 2012
Lokacija: righthere
Postovi: 441
mjenjaš u
name="V_Interface" attr="6692">IGD.WANDevice.x.WANConnectionDevice.y.WANPPPConnection.z
x,y,z - ovisno o tome kako ti je definirana PPP konekcija, potraži u configu
back2quick je offline   Reply With Quote
Staro 01.10.2015., 00:31   #1833
Postovi: 23,535
Jedina razlika je u "V_Interface", kod mene je taj parametar prazno (><),
ili probaj pronaći / pogoditi ovo šta govori back2quick.
Usput sad slučajno vidio u konfigu a nisam prije, možda sam previdio,
u LAN - DHCP ima mogućnost podešavanja DHCPRelay opcije samo je sakrivena,
može biti interesantno u nekim kombinacijama.
Staro 01.10.2015., 11:52   #1834
Prezime
Postovi: 4,336
@back2quick
Bilo mi je prevelika tlaka to trazit configu, pa sam postupio po Nikky-evom naredjenju i obrisao sve Device, tj ostavio to mjesto prazno - i stvar je uredno proradila. Jednostavno rjesenje kojeg se ne bi nikad dosjetio, TNX Nikky
Jos jedno podpitanje, jel moguce nekako preskocit onaj uvodni ekran, nakon login ekrana, na kojem me upozorava kako mi je wifi mreza nedovoljno zasticena, jer imam podeseno da se svi mogu na nju spajati? Nije neka posebna tlaka, ali cemu to upozorenje kad bas tako zelim da mi radi...
Staro 01.10.2015., 13:42   #1835
Postovi: 23,535
Mislim da ne možeš to preskočiti, vjerojatno negdje ukopano u fw,
slično kao za default pass.
Staro 01.10.2015., 14:00   #1836
Prezime
Postovi: 4,336
Steta.
Crko mi stari ST780 (grom ga pokopao pa sam morao ovog izvadit iz ormara i upogonit. Tolko je stvari jos uvjek sakriveno na tom routeru, iako sam slijedio sve upute za otvaranje skrivenih opcija. Da mi se bar dokopat nekog configga na kojem su otvorene sve mogucnosti tog routera...
BTW, nisam ucitavao u pocetnom postu predlozeni firmware, da kojim slucajem ne izgubim IMS, nego sam sve radio na "triple play" T-Com FW-u. Imam "root" pristup preko SSH-a, ali mi nije jasna potreba za ovim komandama iz 1. posta:
7.
U komandni redak kopirajte sljedeće:
sx763os (stisnite enter)
nvram_util set customer = 0 (stisnite enter)
Jel treba odradit te komande iz nekog drugog razloga, ili samo radi mogucnosti ucitavanja tamo predlozenog Firmware-a?
Zadnje izmijenjeno od: Prezime. 01.10.2015. u 14:17.
Staro 01.10.2015., 14:30   #1837
Postovi: 23,535
Ovo "customer" je ISP lokalizacija, nećeš vidit T-Com rozo nego Siemens (ako se ne varam), u principu nije ti toliko bitno.
Uglavnom mislim da si prešao na bolji uređaj, ima svoje mušice kao svaki,
npr. "traži" reboot svako cca 20 dana, prepoznaš po tome da otvaranje njegovog web konfiga traje ... traje.
Sad igrajući se imaš dekriptirani konfig sa svim važnim parametrima pa je lako ako budeš trebao čačkati ...
Staro 01.10.2015., 15:08   #1838
Prezime
Postovi: 4,336
Eh da, sad si me podsjetio pa su mi i vijuge proradile; vidio sam to negdje dok sam pregledavao ovu "malu" temu, pa sam isao potrazit.
U postu #1094, str. 37 je uredno navedeno:
nvram_util set customer = 0 je generički (narančasti meniji)
nvram_util set customer = 4 je za hrvatski t-com (roza meniji)
nvram_util set customer = 11 je za Iskon
Dakle, ne diram
Staro 01.10.2015., 16:16   #1839
back2quick
Lokacija: righthere
Postovi: 441
Autor Nikky Pregled postova
par puta mi se desilo nakon dužeg šaltanja po ruteru da se webserver malo zaglupi i kod logina ne izbacuje to upozorenje već otvara homepage direktno, tako da bi trebalo nać dio koda koji obavlja tu provjeru i pokušat ga disejblat ako ne iz root shella onda pokušat iz browsera s nečim tipa noscript
Staro 20.10.2015., 02:19   #1840
Rebellion
Killer of your Dreams
Rebellion's Avatar
Lokacija: Final Digit of the Rainbow
Postovi: 107
IMS VoIP
jel itko dosao bar blizu ideje kako natjerati VoIP da radi na OpenWRT?
Uspio sam naganjat T-Com da mi posalje tehnicara "da upise VoIP podatke" (koje naravno imam), medjutim ne znam kako ce to proc, a jedino gdje mi se javlja promet na Rx na 0/50 je na VC MUX koji naravno nema smisla po orig configu, a dok podesim LLC kao tip konekcije mi je promet 0, plus net pocne zezat ponekad ^.-
Zadnje izmijenjeno od: Rebellion. 20.10.2015. u 02:30.
Rebellion je offline   Reply With Quote
Staro 25.10.2015., 18:22   #1841
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,376
pitanjce, kak da sakrijem wifi?
ukućani mi se često spajaju pa bi ja stavio na hide, da uopće ne vide mrežu (ne želim mijenjat password, kad vide mrežu pitali bi za pass ) znači nemrem nać opciju da bude skriven wifi, ak se uopće može sakrit
Staro 25.10.2015., 18:24   #1842
catroot
catroot's Avatar
Datum registracije: Apr 2009
Lokacija: I live in 43 05'04.11"N 17 57'36.71"E
Postovi: 881
Mislim da ne, možeš al neće raditi.
catroot je offline   Reply With Quote
Staro 25.10.2015., 19:45   #1843
Prezime
Postovi: 4,336
Moras ponovno proci kroz "Security Setup wizard" i u trecem koraku izabrat SSID i oznacit jel je vidljiv ili ne (SSID broadcast)...
Staro 25.10.2015., 19:46   #1844
Rebellion
Rebellion's Avatar
Postovi: 107
Iskljucis "SSID broadcast", prva opcija ispod imena mreze
Autor Prezime Pregled postova
Ne, samo kliknes Advances settings->Wireless
Bas bi glupo bilo da Siemens forcea wizzard za svaki detalj o.O
Staro 25.10.2015., 20:38   #1845
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,376
tenks evo isključio sam, sad cekam reakcije
Staro 25.10.2015., 21:23   #1846
crazyy
Datum registracije: Aug 2014
Lokacija: rijeka
Postovi: 158
ako ukucani vec imaju saveanu mrezu na mobitelu, laptopu ili na nekom trecem uređaju, uređaj ce se automatsku spojiti na tvoju mrezu iako si sakrio naziv mreze. spojit ce se pod uvjetom da nisi mjenjao naziv mreze ni pw
crazyy je offline   Reply With Quote
Staro 26.10.2015., 00:41   #1847
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,376
A ako im se na mobitelima odlogiram sa svog wifia, onda ga vise nece vidit to jest nece im se spajat?
Staro 26.10.2015., 08:19   #1848
crazyy
Lokacija: rijeka
Postovi: 158
ako izbrises memoriranu mrezu, a tvoja mreza tj wifi je skriven, tada im se tvoja mreza nece pokazivat na popisu a kako bi se spojili na nju morat ce rucno kreirat novi profil mreze i u njemu napisat ssid, tip zastite i naravno sifru
Staro 26.10.2015., 09:03   #1849
Rebellion
Rebellion's Avatar
Postovi: 107
samo dok se opet rucno ne spoje. trebalo bi obrisati/forget mrezu, ili promjeniti ime svejedno.
ako samo promjenis pw, a ime ostavis, vjerojatno ce dobiti info da im je pogresan pw.
Staro 26.10.2015., 13:06   #1850
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,376
fala tenks, budem ja onda promjenio i ime i password da sam miran
Staro 05.01.2016., 22:15   #1851
bono.tadic1
Datum registracije: Feb 2012
Lokacija: zemlja
Postovi: 23
zelim namjestiti voip na otkljucanom siemensu sx763. napravio sam account na nononh i uplatio 10 eura. u postavkama routera sam upisao sve kako treba i odlazni pozivi rade. problem je u tome sto dolazni pozivi nikako ne rade. moze li mi netko molim vas pomoci kako da to napravim? hvala unaprijed.
bono.tadic1 je offline   Reply With Quote
Staro 05.01.2016., 23:15   #1852
Postovi: 23,535
Smiri malo, ima te po svim živim temama.
VoIp na alternativnim operaterima rade preko Internet konekcije, dok kod naših operatera (IMS = VoIp kod T-Kome) rade preko posebne konekcije.
Kod većine uređaja oboje nemože istovremeno.
Jesi li ovako podesio parametre > https://www.nonoh.net/sip
Šta piše u web konfigu, jeli se uredno registrirao ?
Jeli upaljen UPnP u SX - u ?
Staro 05.01.2016., 23:25   #1853
bono.tadic1
Lokacija: zemlja
Postovi: 23
ja sam na vipu, nemam IMS ukljucen. upnp je upaljen. evo postavke:
Zadnje izmijenjeno od: bono.tadic1. 05.01.2016. u 23:31.
Staro 06.01.2016., 00:01   #1854
Postovi: 23,535
Piše da je registred, ovako na brzinu postavke izgledaju ok.
Neznam kad si unio postavke, koliko je vremena prošlo.
Jesi odradio reboot (ne reset) ?
Možda sačekati neko vrijeme ?
Na onom ekranu gdje se postavljaju codeci, probaj postaviti isti raspored kao na onim uputama sa linka poviše.
Ne pada mi na pamet šta bi još moglo biti.
Staro 06.01.2016., 00:10   #1855
bono.tadic1
Lokacija: zemlja
Postovi: 23
nisam jos radio reboot, probat cu. za sto tocno sluzi access code *01?
kabel iz zida ide u adsl port na modemu, a telefon ide u phone 1 port. je li to u redu?
Staro 06.01.2016., 00:52   #1856
Postovi: 23,535
Šta se tiće spajanja to je u redu.
Odradi reboot.
Možda, tamo gdje podešavaš Phone1 treba ostaviti samo VoIp Nanoh, a maknit Fixed line,
Fixed line je "klasična telefonija", ne treba ako je ne koristiš / nemaš.
Staro 06.01.2016., 01:09   #1857
bono.tadic1
Lokacija: zemlja
Postovi: 23
Čuo sam se u međuvremenu s kolegom @alengrosevic i on mi je objasnio da to što ja želim nije moguće na ovaj način. Jedini razlog zbog kojeg želim VoIP je da izbjegnem splitter (jer bez njega imam veću brzinu interneta). Postoji li neki drugi način da izbjegnem splitter ili to ide samo preko IMS-a?
Staro 06.01.2016., 16:11   #1858
Prezime
Postovi: 4,336
Autor bono.tadic1 Pregled postova
Taj 01 je predbroj za Zagreb.
Svugdje gdje trebas upisat broj telefona upisuj iskljucivo cijeli niz, dakle
+385(predbroj grada)broj telefona, dakle +38518234567 za neki broj u Zagrebu...
Staro 15.01.2016., 14:37   #1859
okarm
Postovi: 772
Imam problem s FTP serverom na ovom routeru
Znaci imam doma nekoliko IP kamera koje kad detektiraju pokret na FTP server (USB stick 8GB) salju .jpg sliku.
Sve radi normalno dok ne prodje ponoc i dodje do promjene datuma i tada kamere vise ne mogu zapisivati na server. Ako USB stick fizicki izvadim iz routera, formatiram ga na kompu, vratim nazad u router opet sve proradi do sljedece ponoci.
kamera zapisuje slike u ovaj direktorij koji sama kreira prilikom zapisivanja prve slike:
Z:\kamera 1\192.168.1.9_0012125fef30\2016-01-15\01\pic
pretpostavljam da je problem u tome sto server kameri ne dopusti kreiranje novog foldera za novi datum, jer ako nakon ponoci na postavkama kamere vratim stari datum, ona uredno slike zapisuje u stari direktorij.
ovo su postavke na kamerama i na routeru
http://i.imgur.com/Mu5WVg5.jpg
http://i.imgur.com/lKqxVTU.jpg
Novi sam u ovome, nisam se jos da sada igrao s FTP serverima pa bih bio zahvalan ako mi netko moze pomoci nekim savjetom.
okarm je online   Reply With Quote
Staro 15.01.2016., 19:56   #1860
Postovi: 23,535
Iz posta nije jasno jeli problem pristupa iz vani ili unutar iste mreže,
za pristup iz vani trebaš riješiti DDNS.
Ako slike spremaš na ftp (stick) na routeru onda mu pristupaj sa http ili ftp < ip adresa routera > < ostatak imaš na onoj stranici gdje podešavaš ftp (ako se ne varam \usb_0\)>
na stiku napravi dva foldera (kam1 i kam2), a u onom sw za podešavanje kamera treba ispravno unjeti putanju.
