#151 | |
Lokacija: Sinj
Postovi: 3,538
Vidis kad si stavio nove winse da radi bez beda ![]() |
#152 |
Postovi: 5,997
Geronimo 2 ˇ@ Nije to bas neko modanje. Raspakiras skinuti driver u fajl, nades nv_dispi i samo prekopiras nv_dispi iz nekog drivera koji podrzava gtx 770. Onda najnormalnije instaliras sa setup itd.. Radio sam to sa Titan driverom na 670 i nekoliko puta ranije bez problema. Zadnje izmijenjeno od: MAGARAC. 11.06.2013. u 22:41. |
#153 | |
Lokacija: Rijeka / Grobnik
Postovi: 4,474
meni totalna paranoja stavit 320.18. svaki dan pratim kako se novi javljaju sa crknutim grafama il problemima nakon tih drivera. ![]()
"We all must hang together, or surly we will hang separately." AMD Ryzen7 7800x3D+Noctua NH-D14 | MSI Tomahawk WIFI AMD B650 | 2x16GB Corsair Vengeance DDR5-6000 CL30 1,39v | SAPPHIRE Pulse RX 9070xt UV/OC | 1tb NVMe sammy 970 evo plus, 2TB Samsung 990 EVO Plus, Crucial MX500 500GB, Kingston 480gb | Riotoro ENIGMA G2 850W 80 Gold | Corsair Carbide 300R modded | Win10 ENT LTSC IoT (work) + Win11 ENT LTSC IoT (gejming) | logitech g403 | ROCCAT Horde | AOC CQ27C4 + AOC C24G1 + 50" Hisense H50A6140 AMD Ryzen5 2600+Xilence Cryon M806D.B | Asus x370 Prime Pro rev1.03 (bios 6203) | GSkill Aegis 32GB (2x16) DDR4@3,2GHz | 2x Intel 545s 128GB, 1x Crucial MX500 500GB | Gigabyte GTX960 | sisa 620w | Fractal Design Focus G | Win7 x64 + Win10 ENT LTSC IoT | logitech g403 | ROCCAT SuoraFX intel i5 2500k@4,5ghz (1,28v)+FSP Windale 4 | ASRock Z68 Ext4 Gen3 (bios 1.20) | 2x8gb DDR3 HyperX Savage, 1866mhz, 10-10-11-27,1,5V | Samsung SSD 64gb, 2x256gb SSD | iGPU | corsair vx450w | CoolerMaster Centurion 534 modded | Win7 x64 |
#154 |
Xulos :)
Postovi: 7,580
The Rich pays to win. The Poor spends to lose. Zadnje izmijenjeno od: JuiceBox. 11.06.2013. u 23:52. |
#155 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Gledam malo te Heaven rezultate i radim usporedbu sa stock 680-kom (stock CPU) - 36.0 Gdje god sam gledao, svugdje je 770-ka bila brža od 680-ke, a sad pak ispada da i nije toliko brža. Ili su to bili skorovi onih MSI Lightning, EVGA SC i inih modela ![]() Evo za usporedbu i stari OC rezultat (proc i dvije 680-ke), samo podijelite sa 2 rezultat za skor jedne grafulje - Link Bilo bi lijepo za vidjeti koliko te grafe mogu potegnuti, pa ako se nekome da nabaciti jedan Heaven skor tek toliko da napravimo suma-sumarum anallizu ![]()
The Secret ... Zadnje izmijenjeno od: dh41400. 12.06.2013. u 00:02. |
#157 |
Postovi: 12,613
@dh41400, krive linkove si postao. ![]()
#160 | |
Postovi: 5,997
#162 | |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Uglavnom ništa bitno, ali je velika vjerojatnost da ću se ipak zadržati na trenutnom. Jedino bi eventualno popravio hlađenje nekakvim EK blokovima, te isprobao Hotwire "Vmod". Koliko sam vidio po rezultatima, bez nekakvih većih problema (i uz malo sreće) bi trebale Keplerice proraditi na 1300-1350MHz tj. 7-7.5GHz za memoriju. O tišini, temperaturama i kompaktnosti da i ne pričam ... Ukrajinci su dobili primjerak koji poteže na zraku gotovo 1300, te 7750 za memoriju (Samsungovi čipovi kao i u 770-kama) ![]() Praktički je samo hlađenje regulacije problem (na takvim postavkama), koji bi voda vrlo solidno riješila. U suprotnom, prelazak na 780-ku sa blokom bi me koštao (barem) obje vrhunske 680-ke, a to mi se ne sviđa :/ To je s ovim gore taktovima pretpostavljam? Da, sve je to tu negdje, više-manje nezamjetna razlika naspram 680-ke. Jesi možda stigao isprobati te sve nove OC finese?
The Secret ... |
#163 |
Xulos :)
Postovi: 7,580
Iskreno, nemam potrebe za OC, ja sam jedan od onih, dok radi ne klokam ( sto se grafe tice jel) , 480ku sam skoro 2 g vozio na def dok ju nisam dignuo u nvidia inspectoru za 100 mhz. A i iskreno malo mi je sve to neppoznato ,to klokanje boosta itd itd tako da cu to preskociti za sada ja zadovoljan, u bf3 sa 4x msaa , ultra na full hd imam 120 fpsa, pametnom dosta ![]()
#167 |
Xulos :)
Postovi: 7,580
ja neznam koji je njim k, nek su .14 zadnji, najgore je to sto su jedini za seriju 7. Znaci imam grafu koja jede malu djecu, a sluzi mi da citam 24 sata i kao stalak za cvijece jer u svakoj igri jedino sto vidim je paleta boja ...
#168 |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,176
Nije da flejmam... ali... taj ATi/AMD ima baš smeće drivere ![]() JBG, ovim se nVidia nije baš proslavila. Ali to je ono što ja pričam, pa me stalno brišu. Oba proizvođača imaju svoje "trenutke" što se tiče drivera. Ja sam eto imao sreću da nisam naletio ni na jedan od tih bugova koji su se dogadjali (ni sada ni kad sam imao nVidia-u). Uglavnom želim vam puno sreće i uskoro rješavanje problema s driverima. Šteta je kad je grafa tako brza, a slika koma ![]()
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#169 | |
#170 |
Bazinga
Lokacija: Križevci
Postovi: 3,933
Ja sam sa 660Ti imao odvratnih problema sa driverima. Svako malo krešanje drivera, pa artefakti... Kartica je odlična, ali su driveri odvratni.
#171 |
#172 |
Xulos :)
Postovi: 7,580
#173 |
#174 | |
Bazinga
Lokacija: Križevci
Postovi: 3,933
Čitajući po forumima, kartice su u potpunosti ispravne, ali driveri su u banani. Dosta ljudi je završilo sa spaljenim čipovima zbog overvoltanja.
#176 |
#177 |
Postovi: 2,398
Brkane, imao sam 9800 non-pro i 4870x2, ali nekih problema sa driverima (osim što je jedna igra imala problem sa CF-om) se baš i ne sjećam. Molim te elaboriraj. ![]() A da ne bi bilo zabune, nisam ati fanboy jer sam u međuvremenu imao 6800gt, 7900gtx i 580gtx, s kojima sam također bio zadovoljan. |
#178 |
Xulos :)
Postovi: 7,580
Šojiću, nije bas cicin dim, ne rade igre, imas artifakte, komp se ne budi iz sleepa svaki put ( da, budio se sa 480kom bez problema), imam dual boot na skoro svakom paljenju( sa 480kom nisam imao tih problema), jest da je ovo sa loopom i sleepom do asusa i da moraju azurirati bios na maticnoj za nove grafe jer sam na pocetku i sa 480kom imao slicnih problema koje su rijesli biosom ali opet, trebali su se dogovoriti da se to ne ponovi. I grafa mi do daljenjg sluzi kao drzac kave samo moram tabletić neki lijep nabavit ![]()
#179 | ||
nisam ni ja nVidia fanboy, ali između 2 zla, biram ono manje zlo.4850 me je klala sa raspadanjem tekstura u World in Conflict. rFactor nije htjela ni vrtiti, CoD4 mi je bacao artefakte, STALKER SoC mi je divljao svaki puta kada je pala kiša sa raspadanjem slike. Odgovore koje sam dobio su bili "Pričekaj nove drajvere" ili "glup si jer ne znaš podesiti drajvere". A reinstalirao windowse zbog te grafe, tako da nije bilo zasotataka od 8800GT. X1650Pro mi je na tada sekundarnom kompu vječito bacala refreš rate 60Hz na CRT monitoru. Svaki puta naštelam monitor na 100Hz i radi, ali kod svakog reboota natrag na 60Hz, vratio u taj komp Ti 4200 i normalno je radilo. Kasnije sam stavio neke prsatare drivere i onda je radilo. Dakle, nije bila greška ni u monitoru i u kartici, nego u driverima. 9800 Pro, sad se više točno i ne sjećam točno što je bilo jer to u biti i nije bila moja kartica, nego posuđena dok nisam dobio 6600GT, ali nekih pizdarija je bilo u HL2, pa sam popizdio. Također driver related. Ne kažem da je uvijek tako, jučer sam jedan komp slagao sa starom 3870 pekarom i stavio zadnje beta drivere, vidim da to sve lijepo radi. Ali užasavam se pomisli da mi se opet nešto slično dogodi. Samo strah, ništa drugo 3 puta sam imao ATI, 3 puta sam imao sranje. 100%-tni učinak ![]() Citiraj:
tako je i meni bilo kad sam odma istog momenta kupio P45 matičnu ploču. prvih 10-tak dana sam ludio dok nisu izašli novi BIOS-i i novi intel driveri. Buš se strpio malo. |
#180 |
Xulos :)
Postovi: 7,580
Budem, al samo do prvih iducih drivera, ako nema poboljsanja, doviđorno, nemam ja zivaca za ovakve pizdarije.
