Staro 06.04.2013., 15:11   #1741
Futro
Futro's Avatar
Postovi: 31
Hvala , ali tu se mora ugurati komplet tj. monitor do 22" i ostala periferija ?
Intel i7-875K / Gigabyte P55 UD3 /NVIDIA GeForce GTX 770
/720W HIPER POWER /OCZ SSD 128Gb/ 8Gb DDR3 1600MHz ; HP EliteBook 8770w
Zadnje izmijenjeno od: Futro. 06.04.2013. u 15:12. Razlog: dodana veličina monirora
Futro je offline   Reply With Quote
Staro 06.04.2013., 15:33   #1742
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
AMD FX-Series X8 8320 AM3 Box
Hladnjak za procesor Thermaltake Contac 21
Matična ploča Asus M5A97 R2.0
Memorija PC-12800, 8 GB, MUSHKIN Essentials, 997030, DDR3 1600MHz, kit 2x4GB
HDD TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600)
MSI Video Card Radeon HD 7870 GDDR5 2GB/256bit
DVD RW -RW RAM LG DualLay SATA
Zalman 500W GS Series Retail
Linkworld Gaming ATX Case
AOC LED 21.5" E2250SWDNK, 5ms, VGA, DVI
Chicony USB Multimedia Tipkovica
Logitech Gaming Mouse G400
Futura-It.hr 6,998.44Kn Besplatno sastavljan je i dostava
*Ukoliko ti trebaju i zvucnici
Izbaci G400, metni Genius Maurus + 2.0 Logitech Z130 = 7,017.08
Staro 06.04.2013., 15:50   #1743
Futro
Futro's Avatar
Postovi: 31
Zahvaljujem na pomoći , pozdrav.
Staro 06.04.2013., 18:24   #1744
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
@Futro
Ukoliko konfiguracija može biti od Intela razmotri si i ovu opciju:
i5 3350P
MSI B75 P45
MUSHKIN 2X4 GB 1600 MHZ (8GB)
TOSHIBA 3,5 1TB
MSI HD 7870 2GB OC
LG DVD-RW SATA
CORSAIR CX 430W
SILVERSTONE PRECISION PS08
AOC I2367FH AH IPS
WIRELESS SET 100 TIP+MIŠ
GENIUS 2.0 SP-HF 360A
Ukupno: 6994 kn besplatno slaganje i dostava - Futura it
lolofuxy je offline   Reply With Quote
Staro 08.04.2013., 12:47   #1745
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
@Futro
Ploča: ASUS M5A97 R2.0
Procesor: FX-8320
Hladnjak: Thermaltake Contac 21
Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8
Grafička: MSI HD 7870 2GB GDDR5 256bit, R7870-2GD5T/OC, 28nm,dual fan
Kućište: Zalman Z5 Plus mid tower case (USB 3.0)
Napajanje: XFX 550
Disk: Hitachi 1TB, Desktop Deskstar 7K1000.D, 32MB,SATA III-600
DVD: LG GH24NS
Monitor: AOC E2250SWDNK
Tipkovnica + miš: Logitech Desktop MK120, Tipkovnica + Miš, USB
Zvučnici: Genius SP-HF500A, 14W RMS, wood
=6987,97 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr
Ploča: MSI B75MA-E33
Procesor: i5-3350P
Grafička: MSI GTX660 Ti OC 2048MB GDDR5 , N660Ti-2GD5/OC, 941MHz Core
Napajanje: Zalman 500-GS PSU, 500W
DVD: LG GH24NS
=6990,96 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr
Zadnje izmijenjeno od: ShanTech. 09.05.2013. u 14:37.
Staro 11.04.2013., 17:18   #1746
Kak si?Pa tak
Datum registracije: Jan 2013
Postovi: 16
e pozz moze konfa u linksu za 7000 kn
uzet cu na amex 10 rata
procesor je adm fx 8350 i ne ulazi u cijenu
komp za gejming
treba mi monitor najbolje 23''
volio bi hd 7950 graficku
Kak si?Pa tak je offline   Reply With Quote
Staro 11.04.2013., 19:38   #1747
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Monitor 23'' LED PHILIPS 236V4LAB, 5ms, 250 cd/m2, 10.000.000:1, D-SUB, DVI, crni
Cooler ARCTIC COOLING Freezer 13, s. 775/1155/1156/1366/754/939/AM2/AM3
Matična ploča GIGABYTE GA-970A-UD3, AMD 970/SB950, DDR3, USB 3.0, FW, ATX, s. AM3 / AM3+
Memorija PC-12800, 8 GB, CORSAIR CMX8GX3M2A1600C9, DDR3 1600 MHz, KIT 2x4GB
Tvrdi disk 500.0 GB TOSHIBA TSH-DT01ACA050, SATA3, 32MB cache, 7200 okr/min, za desktop
Grafička kartica PCI-E XFX AMD RADEON HD 7950 DD, 3GB DDR5, HDMI, DVI, 2xDP, HDTV
DVD±RW LG GH24NS95, 24x, SATA, Dual layer, crna, bulk
Napajanje 560W, LC POWER Silent Giant GREEN POWER LC6560GP3 V2.3, 140mm vent.
Kućište LC POWER Pro-917B Titus X, MIDI, crno, bez PS
ukupno: 7.041,00 KN -ovo sto je na akciji
Staro 11.04.2013., 20:35   #1748
Kak si?Pa tak
Postovi: 16
hvala.
javim dojmove kad stigne
Staro 12.04.2013., 04:02   #1749
shark21
Datum registracije: May 2012
Postovi: 4
molim Vas za konfiguraciju.
Molim poštovane članove ovog foruma da mi pomognu oko sastavljana PC KONF.
Budžet - 6500 - 6800 kn.
Bez periferije ali molim Vas preporuke za "24" Led monitor.
Služi za web diz. i grafički diz. tipa Adobe paleta programa.... i neke free alternative istoga..... ++++ ponekad neka igra čisto radi gušta...
U obzir dolaze AMD i Intel ponude...
Kupujem sve za keš ( ok bi bio popust na keš ).... igraju mi trgovine u ZG.
Koliko sam čuo za ozbiljan rad dizajnera ide samo nvidia pa eto uzmite to u obzir....
Unarpijed zahvaljuem svima .....
shark21 je offline   Reply With Quote
Staro 12.04.2013., 10:03   #1750
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Procesor Intel Core i5 3350P
MSI H77MA-G43
Patriot Viper3,1600Mhz, 16GB (2x8GB)
PoV GTX660Ti 2GB 2 fan
Kingston SSD V300, R450/W450,120GB,7mm
HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600)
Zalman micro tower case black
Futura-It.hr 6,874.82Kn Besplatno sastavljanje i dostava
Monitor LCD DELL UltraSharp U2412M (24", 1920x1200, IPS)
2147Kn
Ako ti je puno za monitor toliko dati, radje smanji onda nesto na kompu, npr ubaci gtx 660 grafu i samo 8gb rama...
Staro 13.04.2013., 00:30   #1751
ShanTech
Postovi: 3,784
@shark21
Ploča: MSI H77MA-G43, Socket : 1155,CPU : Sandy Bridge, Intel® H77
Procesor: Intel Core i5-3470 3.2GHz (Max Turbo FQ 3.6 GHz) ,6MB
Memorija: DDR3 8GB (1x8GB) Kingston, Value, 1600MHz, CL11, KVR16N11/8 *2 komada
Grafička: MSI GTX660 OC 2048MB GDDR5 , N660-2GD5/OC, 1006MHz Core
Kućište: Zalman Z12 mid tower case. 215(W) x 470(H) x 480(D)mm
Napajanje: Zalman 500-GS PSU, 500W, ATX12V V2.3, dual rail +12V
SSD: OCZ SSD Vertex 4 128GB, Indilinx Everest 2, 2.5" SATA III, 5 god
Disk: HDD WD 1TB, Caviar Blue 10EZEX, 1000 GB, SATA3,64 MB, 3,5", 24mj
DVD: DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R
=6.949,95 kn, sastavljanje i dostava u cijeni, dućan www.adm.hr
Monitor: Dell U2412M - 2085 kn, isti dućan, dostava u cijeni
Staro 14.04.2013., 16:45   #1752
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
@shark21
Evo ti i Amd verzije s nešto jačim procesorom:
FX 8320
TT CONTAC 30
AS ROCK 970 EXTREME3
2X MUSHKIN 8GB SILVER LINE (16 GB)
SAMSUNG 840 120 GB SSD
WD BLUE 1TB
POV GTX 660 2GB
LG DVD-RW SATA
CORSAIR CX 500W
LW GAMING ATX
Ukupno: 6845 kn besplatno slaganje i dostava - Futura it
Ak nemaš za Dell-a pogledaj si ovaj LG.
Staro 16.04.2013., 22:55   #1753
Marko 123
Lokacija: ask?
Postovi: 243
Evo da vam javim da mi je stigla konfa,ali bez graficke posto je nije bilo.
A i prirasla mi je srcu pa cu pricekat nju dok ne bude dostupna,pa cu je narucit.
Za zamjenu je privremeno tu 9500gt.
Imam jedno pitanje.
Kad ubacim hard disk s vanjske strane u onaj utor.
Ne ucita mi ga odma nego tek kad restartiram komp?
Da li se to moze kako sredit da ucita hdd cim ga ubacim?
Marko 123 je offline   Reply With Quote
Staro 17.04.2013., 11:59   #1754
Postovi: 34,037
W7 + BIOSu uključiti AHCI opciju pod stavkom SATA Mode.
Staro 17.04.2013., 12:11   #1755
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
pa ne mozes to ukljuciti koliko ja znam, to je hot swap, hdd se metne kada je komp ugasen i kada upalis on ga očita u biosu i tako prikaze u windowsima
stavljati i skidati dok komp radi se ne smije
Staro 17.04.2013., 12:15   #1756
Postovi: 34,037
Otkud ti to? Imam na kućištu SATA dock i hot swap fercera bez problema. Na XP-u sam morao isključiti komp, staviti hard u dock i onda opet uključiti.
Staro 23.04.2013., 21:57   #1757
dema6
dema6's Avatar
Datum registracije: Mar 2009
Postovi: 41
pozdrav, molim ako se netkom da složiti konfu do max 7k kn, ali ako može jeftinije onda super.
Prioritet je apsolutno tih rad, zatim SSD + HD, možda rađe AMD FX8xxx, bez monitora i periferije.
Ne igram se puno, tako da netreba 7950 unutra.
Hvala unaprijed.
dema6 je offline   Reply With Quote
Staro 23.04.2013., 22:42   #1758
ShanTech
Postovi: 3,784
Na kojem monitoru se igraš (rezolucija)? Koja je primarna namjena računala, te koji je način plaćanja?
Zadnje izmijenjeno od: ShanTech. 23.04.2013. u 22:55.
Staro 23.04.2013., 22:50   #1759
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Procesor AMD X8 FX-8320
COOLERMASTER Hyper 212 EVO CPU Cooler
GA-970A-UD3,AM3,A970,D3,S3,U3,FW,A
8GB (2x4) 1600MHz DDR3 CL9 DIMM HyperX black Series
Giga GF GTX650 Ti Boost OC,2GB GDDR5,DVI
KINGSTON HyperX 3K Solid State Drive 2.5" SATA III-600 120 GB MLC, Retail
Zalman Z9+ mid tower case black
XFX CoreEdition 80 550W
Futura-It.hr 6,917.75Kn Besplatno sastavljanje i dostava
ili ovako:
Intel Core i7-3770 Soc 1155
MSI B75MA-P45
Memorija Kingston DDR3 8GB (2x4) 1333MHz
Zalman T1/T2 micro tower case black
Futura-It.hr 6,807.75Kn Besplatno sastavljanje i dostava
Staro 24.04.2013., 09:10   #1760
dema6
dema6's Avatar
Postovi: 41
Hvala na konfi FRipper
Rezolucija je full HD. Primarna namjena je rad u Visual Studiu 2012 i Blendu. Povremeno igram, ali to je SWTOR, koji nije zahtjevan.
Tako da mislim da možda i nije potrebno potrošiti cijeli budget?
Najbitnije mi je da je apsokutno tiho u radu.
Staro 24.04.2013., 09:40   #1761
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Ako bi se išlo na trošenje cijelog buđeta napravi ovako:
FX 8320
CM 212+ EVO
GIGABYTE 970A UD3
KINGSTON HYPER X 2X4 GB 1600 MHZ (8GB)
WD BLUE 1TB
POV GTX 650 Ti 1GB OC
LG DVD-RW SATA
XFX 550W 80+
FRACTAL DESIGN DEFINE R4
Ukupno: 6957 kn besplatno slaganje i dostava - Futura it
Sve redom kvalitetne komponente i naravno tihe + kućište je obloženo antinoise spužvom za dodatno smanjenje buke.
- ako želiš malo smanjiti cijenu gore ubaci POV GTX 550 Ti.
Jeftinija verzija bi ti ovako izgledala:
i5 3350P
MSI B75 P45
KINGSTON 8GB 1333 MHZ
WD BLUE 1TB
POV GTX 550 Ti 1GB
LG DVD-RW SATA
OCZ MKIII SILENCER 400W
ZALMAN T2
Ukupno: 5116 kn -II-
U ovom slučaju aftermarket nije potreban što zbog nemogučnosti oc-anja navedenog procesora, što zbog toga jer je stock dovoljno tih i dobro hladi.
Možeš i u ovom slučaju staviti R4 i ATX mbo MSI B75A G41 pa ćeš isto biti ispod 6K.
Zadnje izmijenjeno od: lolofuxy. 24.04.2013. u 10:11.
Staro 24.04.2013., 09:44   #1762
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Gle onda idi na intel konfu jer je tiša i manje se grije a i jača....
Ako neces potrositi 6800, onda uzmi Core i5 3350P umjesto i7 i opet ces imati jak komp, a 1000kn ce te manje izaci, kasnije lako nadogradujes ako bude slab
Ovako je definitivno najtise i neces potrositi sav iznos a imas dobar i jak komp ;=)
MSI B75A-G41
PoV GTX650 1GB GDDR5 128bit AC Hladnjak
Kućište Fractal Design Define R4 Black Pearl
OCZ PSU Silencer Mk III Series™ 400W Modular
Futura-It.hr 6,117.12Kn Besplatno sastavljanje i dostava
SLIKA
Zadnje izmijenjeno od: FRipper. 24.04.2013. u 10:17.
Staro 28.04.2013., 00:36   #1763
yebiwetar
Postovi: 88
@dema6
Svakako bih na tvome mjestu za te potrebe uzeo Intela, AMD-ov stock cooler je po defaultu "raspjevan"..
Evo prijedloga:
INTEL I5 3330
MSI B75MA-E33
KINGSTON 8GB RAM
WD BLUE 1TB
KINGSTON SSD 120GB V300
MSI RADEON 7850 1GB DDR5/OC
SAMSUNG DVD-RW
CORSAIR CARBRIDE 200R
OCZ SILENCER 400W MODULAR
Centro.hr - 5.867,67 - besplatno sastavljanje
Corsair Carbride 200R ima kolega s posla i opako mi se sviđa (kučište, ne kolega, da ne bi bilo zabune), nije skupo a djeluje mi dosta kvalitetno kučište, komp je gotovo nečujan.. ili kako je FRipper predložio, Define R4 od Fractala, izvrsno kučište, samo je 400-tinjak kn skuplje.
Namjerno nisam stavljao 3350P proc iz razloga što je 3330 sa grafikom u procu a kako ti komp služi za posao, ne daj Bože da crkne grafa - samo će igranje čekat, posao ne
yebiwetar je offline   Reply With Quote
Staro 02.05.2013., 14:16   #1764
tvedak
Lokacija: Ivanec
Postovi: 4
1.)
LCD 21,5 Wide , 5ms, 16:9, IPS
Tipk i Miš Logitech Desktop MK120
Intel Core i5 3350P Sck1155
MSI B75MA-P45 Sck1155
PointOfView GTX650 1GB GDDR5 128bit
SEAGATE/SAMSUNG HD502HJ (3.5", 500GB, 16MB, SATA II-300)
Chicony Active 80Plus 400W ATX PSU
Futura-It.hr 5,278.08Kn Besplatno sastavljanje i dostava
2.)
1 x Logitech Desktop MK120, Tipkovnica + Miš, USB
1 x Zvučnica Logitech Z-120 zvučnici, 2.0, 1.2 W (RMS) , USB
1 x Spire Sonex 6010, kućište ATX/micro ATX
1 x Napajanje Zalman 500-GS PSU, 500W, ATX12V V2.3, dual rail +12V
1 x HDD WD 500GB, 5000AAKX, SATA 3, Buffer 16MB, 7.200 rpm , 8,9 ms
1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R
1 x XFX HD7770 1000M 1GB DDR5+Far Cry 3 & Hitman Absol, CORE EDITION
1 x DDR3 8GB (1x8GB) Patriot Viper3,1600Mhz
1 x Procesor AMD FX-Series X6 6300 3.5GHz,14MB,95W,AM3+, FD6300WMHK
1 x Asrock 970 Pro3 - AMD 970, AMD SB950, ATX, FSB2400,4xDDR3
1 x LG 22EN33S-B, 21,5", 16:9, 1920x1080, 200 cd/m2, DC 5.000.000:1
5.070,95Kn
3.)
i5 3350P
AS ROCK B75 PRO3-M
PATRIOT VIPER 3 8GB 1600 MHZ
WD BLUE 500 GB
KINGSTON V300 60 GB
MSI GTX 650 1GB
SAMSUNG DVD-RW SATA
CHICONY HP 400W 80+
ZALMAN T2
ADM
+ AOC 22" AH-IPS u Diskontu - sve zajedno je cca 5,6k
Molim pomoć između ove 3 ponude što uzeti.
Hitno mi je!
Hvala!
tvedak je offline   Reply With Quote
Staro 02.05.2013., 14:40   #1765
ShanTech
Postovi: 3,784
Ja bi to malo drugačije sastavio...za koje namjene bi se koristilo računalo? Vidim da treća konfiguracija nema tipkovnicu i miša? To treba ili ne? Kešom se plaća?
Staro 02.05.2013., 15:04   #1766
tvedak
Lokacija: Ivanec
Postovi: 4
Autor ShanTech Pregled postova
Računalo bi se koristilo za uobičajene potrebe (internet, filmovi, pokoja igra) i za AutoCAD, 3D modeliranje i još neke slične programe.
Ma tipkovnica i miš se doda, nije problem to.
Plaćanje keš.
Staro 02.05.2013., 15:18   #1767
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
A koliko ti je max budzet?
Opcija 1 ako imas toliko love, preporuka da ides na to
MSI B75MA-E33
Kingston DDR3 1600MHz,C11, 8GB
PoV GTX650Ti 1GB GDDR5 128bit
HDD Desktop TOSHIBA DT01ACA050 (3.5", 500GB, 32MB, SATA III-600)
Kingston SSD 60GB V300, 2.5" 7mm, SATA 3 6G, drive only
Futura-It.hr 5,689.51 Kn Besplatno sastavljanje i dostava + Mogucnost da osvojiš poklon bon 500kn
Opcija 2 sa slabijom grafom
MSI B75MA-E33
Futura-It.hr 5,516.33 Kn Besplatno sastavljanje i dostava
Zadnje izmijenjeno od: FRipper. 02.05.2013. u 15:28.
Staro 02.05.2013., 15:35   #1768
tvedak
Lokacija: Ivanec
Postovi: 4
Autor FRipper Pregled postova
MSI B75MA-E33
MSI B75MA-E33
5.500 kn, može i sitno više...
Staro 02.05.2013., 19:08   #1769
tvedak
Lokacija: Ivanec
Postovi: 4
Sviđa mi se ova tvoja prva opcija i mislim da ću ići na to...
Thanks!
Staro 18.05.2013., 22:41   #1770
bobosmrad1
Datum registracije: May 2013
Lokacija: vtc
Postovi: 1
poz namjeravam uzet ovu konfu, savjeti dobrodošli
Procesor Intel i5 3350p
MSI B75A-G43
DDR3 8GB (1x8GB) Corsair,1600Hz Vengeance
OCZ 550W Fatal1ty Series Power Supply
Kingston SSD 120GB V+200
Thermaltake Commander MS-III sa USB 3.0 Midi tower
cijena 5.932,99Kn u adm-u
Zadnje izmijenjeno od: bobosmrad1. 19.05.2013. u 00:19.
bobosmrad1 je offline   Reply With Quote
