#1591 | |
Postovi: 8,508
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 31.12.2023. u 18:38. |
#1592 | |
Postovi: 7,697
već sam mislio da prelaziš na Intela. ![]() Javi na PM.
__________________ |
#1593 |
DIY DILETANT
Lokacija: Čistilište
Postovi: 3,709
#1594 |
Postovi: 8,508
Nije još riješeno kak spada, ali su se dosjetili raznih načina da umanje burn-in, tj. da ekrani požive što je dulje moguće.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#1595 |
Lokacija: Zagreb, Črnomerec
Postovi: 2,638
Update sa 680M, na kraju sam (zahvaljujući fsr 2.2) zaključio da mi ne treba Geforce Now za Bg3 ![]() Znači stvarno sam iznenađen snagom ove integrirane grafike. Za bg3 sam koristio ove settinge -> https://rog.asus.com/articles/rog-al...best-settings/ pošto rog ally ima vrlo sličan SOC kao 7735U. 1080p, fsr 2.2. na performance, ostalo kako tu piše. Igra se vrti od 50-60 fpsa. Zanimljivo je da se bolji rezultati dobivaju na balanced nego na performance jer se čini da na performance (30W) cpu trpi na štetu gpu-a, dok to u balanced (25W) nije toliko slučaj. Moguće da je to plus jedino za BG3. ![]() ![]() ![]() P.S. https://www.3dmark.com/3dm11/16139727 https://valid.x86.fr/fas8as |
#1596 |
Postovi: 4,455
https://www.amd.com/en/support/kb/re...-01-10-preview AFMF praktički službeni driveri... Probao, radi skroz normalno ali teško je skužiti kaj je tu pravo a kaj lažno, kad si praktički stalno na 150 fpsa u bilo kojoj SP igri ![]() |
#1597 | |
prof.dr. gospodar svemira
Postovi: 432
If you are not paranoid you don't have enough information |
#1598 |
Stari pokvarenjak
Datum registracije: May 2012
Lokacija: KC
Postovi: 20
UV za RX 6700 XT
Pozdrav, ubrah prekjučer Sapphire Pulse RX 6700 XT 12 GB, zanima me undervoltanje, jeli se štogod promijenilo da li su postavke: Power Limit +15% Napon 1100 mV Min/Max Frekv 2500/2600 MHz RAM Frekv 2100 Mhz + fast Timing i dalje preporučene za tu seriju? |
#1599 |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 306
Pa testiraj jel ti je stabilna s tim postavkama. Teško da će 1.1mV bit stabilno na 2600MHz. |
#1600 |
Premijum
Postovi: 1,360
Zar je moguce da AMD i dalje ne uspjeva rijesiti taktove memorije kartice na ''nestandardnim'' frekvencijama u idle.u? Standardno CRU funkcionira ok, podigne se blanking i taktovi se spuste, konkretno je 1440p, 75Hz monitor u pitanju. Međutim u dva AOC monitora, iste postavke kod mene (Q3279vwfd8) rade, dok na drugom kompu ne radi (Q32V4 monitor). Moram se jos poigrati s time ali vrlo iritantno, taj problem vuku vec godinama. Sve ostalo van toga stvarno radi ok. |
#1601 | |
Postovi: 2,438
Nemaš ono automatski undervoltanje? ![]() |
#1602 | |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,513
Sent from my SM-S918B using Tapatalk |
#1603 |
[CTN]Mr.Ti
Lokacija: Zg, Novi Zg
Postovi: 564
XFX Merc 319 RX 6900 XT ne daje sliku Kupljena prije cca god dana rabljena. Nema garanciju. Kada sam ju kupio odvratio par testova da vidim stabilnost i temperature i bilo ok. Nešto jako malo igrano na moj (because 2godisnjak u kući), i poslije stajao komp upaljen 24\7 (Torrent mašina) uz eventualni surf rijetki. Zadnjih par mjeseci ugašen, upogonjen NAS. Nedavno palim komp nema slike, par pokušaja, pa se prebacio na integriranu da dobijem sliku. Probao reinstal drivera, ne dovršava ga jer kao nema kompatibilno nešto. Device Manager vidi 6900xt sa uskličnikom. Enable \ disable makne uskličnik do restarta, ali slike i dalje nema. GPU-Z vidi 6900xt, ali sve brojke (taktovi itd) bez pomaka. Reinstall Windowsa nije pomoglo kao ni reset biosa ploče. Probano u drugom kompu koji inače ima 6900xt, ne daje sliku. Što dalje? Ima smisla probati dati na servis? Baciti ju u smeće ili koristiti kao paperweight ili skupi beskorisni ukras? Poslano sa mog DCO-LX9 koristeći Tapatalk
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO |
#1604 |
Postovi: 12,613
Dual bios? Probao sklopkicu prebacit? Prefleshat bios mozda.
#1605 |
[CTN]Mr.Ti
Postovi: 564
Da, dual BIOS je, na oba položaja prekidača isto, zato sam za sada pretpostavio da Flash biosa vjerojatno ne bi pomogao.... Poslano sa mog DCO-LX9 koristeći Tapatalk
#1606 | |
Postovi: 5,992
Svakako probaj jos bios prefleshat.. Zadnje izmijenjeno od: MAGARAC. 04.04.2024. u 21:48. |
#1607 |
Lokacija: Rijeka / Grobnik
Postovi: 4,358
poz. moze savjet jer meni ovdje nis nije jasno sa UV/OC 6800tke. ufatio se toga malo pred par dana i imam rezultate all over the place. znaci dosao sam npr. neki dan do GPU 2450mhz, 920mV, power limit 15% (nadalje PL). VRAM za sad jos nisam dirao. i dobijem ok rezultat nesto bolji u cyberpunk i border3 (sintetika me ne zanima). danas idem probat malo UV i UC jos da vidim razlike. 2250mhz, 900mV, PL 0%. cyber se srusi. ok, no frk, not stable. resetiram komp. nastelam adrenalin nazad na isprobanih 2450, 920mV, PL15% i sad na benchu (cyber i bord3) dobivam manje rezultate nego prije. kako nije mi jasno . jel ta grafa/adrenalin nekak pamte, imaju nekakav safe mode, nesto...vidim i da potrosnja neide do prijasnjih 183W neg se drzi nize, oko 165w. ![]() ![]() edit: nakon 2. il 3. restarta, ne sjecam se vise, se vratilo sve u normalu i ide do 200w. opet mi nije jasno koji vrag je stim. jel ima ikakve koristi se ic igrat sa MorePowerTools jer onda moram to sve research-at prvo, a vremena jako limitirano. u ovo sve sam krenuo neki dan zato jer sam primjetio u cyber-u da imam cesto padove na 40-50fps u jako crowded area, al mozda to ni nije do grafe neg proca. u tim situacija vidim da i gpu opterecenje pada na 70ak %. Zadnje izmijenjeno od: geronimo_2. 05.04.2024. u 13:45. |
#1609 |
Postovi: 4,358
a neznam, moguce jer se najvise desava gdje je puno NPC-a da. drugdje radi sve perf na namjestenih max 75 fps. proc je non-OC, sve default. SAM na off. 1080p sa max resize na 150% (intel verzija). drugim rjecima nikakve koriti od OC-a u toj igri da dignem te minimume u toj situaciji. koji prc bi trebalo imat za nahranit to? OC nebi previse pomogao (ne stignem se tome jos posvetit, al da znam za buducnost dal je vrijedno truda). disk gdje su igre je NVMe sammy 970 evo plus Zadnje izmijenjeno od: geronimo_2. 05.04.2024. u 16:20. |
#1611 |
Postovi: 5,992
U tim situacijama se osjeti poprilicna razlika izmedu 5700x i 5800x3d. Imao sam oba u komb sa rx 6800 i sa 5700x je fps znao past po 20fps dok sa 5800x3d skoro nista. Neki 125w Intel i5 ili 5800x3d su minimum za bilo kaj jace od rtx 4070, po meni. Zadnje izmijenjeno od: MAGARAC. 05.04.2024. u 23:41. |
#1612 | |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,106
Riješil sam se RTX4090 jer ne igram skoro niš, i vratil sam se na 6800XT. Znači, na AMD-u sve radi savršeno. - Nema black screenova. - Nema blue screenova iz sleepa. - Oba monitora se probude umjesto samo jednog, znači kak treba - Nema trzanja kod pokretanja appova nakon boota ko npr Firefox, Telegram, itd., sve radi savršeno - Nema rušenja hw acc u browseru nakon sleepa ako je yt ostal upaljen - Nema blicanja slike kod login prozora na Winsima - Nema igranja sa driverima i skupljanjem dumpova i logova za nVidia support s kojim imam case otvoren više od 2 mjeseca. Nas 4 kaj sa 4090 smo skupljali logove i slali nvidiji jer svi imamo problema, i nikakav odgovor. Čak je došlo do razine da smo kontaktirali web portale da nekak dođemo do inženjera iz nVidie za probleme. https://x.com/tomwarren/status/17860...k92nj3NQJLk0ww https://www.reddit.com/r/nvidia/comm...s_due_to_your/ https://www.reddit.com/r/Monitors/co...rs_stuttering/ Citiraj:
I AMFM dela super. Evo, ne znam kaj da velim, nisam jedini s problemima, frend koji je kupil 4090 od mene nema problem jer ionak ima single 4k monitor, ali smo za test spojili još jedan tak da repliciramo setup i isti drek. Njemu ne smeta, svi sretni, najviše ja jer imam komp koji dela. Evo, moj stint s nvidiom je završil, neće dugo još jakna u moj komp. Toliko živaca i vremena otišlo na ništa. Jasno je meni da dual 4k monitori nisu mainstream i da sam tu bil na nekakvom bleeding edge-u, ali kak to da AMD nema problema s tim? E, evo sad sam se iživciral opet
#1613 |
Postovi: 8,508
Nažalost nema nekog pravila, čušpajz je općenito uvijek u pitanju, nekome sve radi bez ikakvih problema, dok drugi imaju havariju za sve živo na relaciji hardver, softver, firmware, driver. Slična stvar je bila s Radeon RX 5700 (XT) modelima i famoznom black-screen problematikom, koja je tak jasno svaljena na užasno loše drivere. Nitko od recenzenata u to vrijeme nije bil u mogućnosti replicirati to, da bi na kraju ispalo da su tu i sfušani/jeftini DisplayPort kablovi u pitanju, ali do onda više nitko nije maril, makar izgleda da DisplayPort 2.1 nastavlja svoj čudnovati put. ![]()
#1614 |
V.I.P. član
Lokacija: Hennef, DE
Postovi: 806
Pozdrav! Bojim se da sam na svojoj Merc XFX 6800 smrdao nesto a neznam kako. Problem je da graficka ne radi sa punom snagom. Power consumption ne prelazi 120W i sve igre sada rade debelo losije. Prije problema sam igrao npr. Stalker 2 sa 80 FPS gdje je potrosnja bila 200W a sada nikako da predje 120W. Priznajem, mrdao sam onu sklopkicu na njoj amo/tamo ali neznam dali je to uzrok, nekako mi se cini da su problemi poceli tada, ali kao "povremenom gameru" nisam nista tada primjetio. Do sada sam probao slijedece: - Reinstall AMD Adrenalin drivera - Energy plan u windows (11) stavio na ulltimate performance - vracao postavke adrenalina na default - Pokusao Overclock GPU mode - opet mrdao sklopkicu amo/tamo ![]() - Provjerio hardware: utvrdio da graficka kao i kablovi nisu nestabilni - Bios postavke provjerio, vecina je na automatic glede PCIe slota - Pokusao manual power tuning slider pojacati do kraja Nazalost uvijek isti rezultati. Mozda netko od Vas ima iskustva/znanja o tome, sta bi izazvalo ovo ponasanje? Ja ostajem bez ideja... Ostatak konfe je pod moj komp EDIT: Eh da, cak niti temperatura grafe ne prelazi 45°C a znam zasigurno da je isla do 70-75°C EDIT2: Pisajuci ovo sam "overclockirao" GPU u adrenalinu na MIN 2200-MAX 2300Mhz i digao power consumption opet i onda dere na 230W. Dakle negdje je problem u postavkama a nemam pojma sta ni kako kada default ocito ne vrati kako je bilo... Zadnje izmijenjeno od: Vjeko. 04.01.2025. u 22:18. |
#1615 | |
Postovi: 8,508
Svaki put kad prebaciš dual-BIOS sklopku, resetiraš si Adrenalin postavke, jer je sve povezano. ![]() Jednom kad sve u Adrenalinu namjestiš kak spada imaš opciju za eksport svih postavki, tak da sljedeći put imaš spremno.
#1616 |
V.I.P. član
Postovi: 806
Shvacam sta zelis pokazati, to ne objasnjava zasto je snaga gotovo prepolovljena. I sada npr. sklopkicu nisam vise dirao, vratio sam ju gdje je bila (pomaknuta prema smjeru monitor izlaza) i stavio adrenalin na default i i dalje radi sa pola snage. Tek kada ju "rucno" overclockam, radi (valjda) kako treba. |
#1617 |
Postovi: 8,508
Koji je uopće bil razlog za prebacivanje dual-BIOS sklopke, ako ti je prije sve radilo kak spada? Inače to podesiš jednom i ostaviš, a sve ostalo kroz softver, tj. drivere/Adrenalin. Uvijek možeš kompletno sve resetirati na tvorničke postavke, karticu, BIOS ploče, te deinstalirati drivere pomoću DDU alata i provjeriti kakva je situacija sa svim friškim ispočetka.
#1618 | |
V.I.P. član
Postovi: 806
Mislim da cu sada rucno podesit adrenalin i kada bude dobro radilo, sacuvati postavke kako si i preporucio. Pokusat cu i sa DDU kako si preporucio. Zahvalan sam! Naucio sam nesto novo i saznao da ipak nemam hardwerski kvar ![]() Hvala! |
#1619 |
Postovi: 8,508
Jedino kaj može biti da kartica naživo ne podržava prebacivanje sklopke, pa se onda ovak malo zblesiralo sve. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 04.01.2025. u 23:00. |
#1620 |
V.I.P. član
Postovi: 806
Nije bilo "naživo", komp je bio ugašen pri svakom pomicanju switcha. Čisto iz znatiželje sam sada ponovno obrisao adrenalin i sa DDU maknuo ostatke i nakon ponovne reinstalacije adrenalina sa upaljenim vraćanjem default postavki, grafa opet radi sa pola snage. A ništa, "popravit" ću ručno i mirna Bosna |
