Staro 31.03.2011., 19:17   #1561
FiNiX
FiNiX's Avatar
Postovi: 37
Pricaj mi o potrosnji, jedno vrime san planira kupit jos jednu 4890, al kad san vidija potrosnju prosla me svaka zelja, da ne pricam o radnoj temp od 80°C. :/
Gledan tu 460 2GB GS od Gainwarda i skroz lipo zvuci za cijenu nesto nizu od 2k kuna, al onda opet ATI mi prirasta srcu pa mi pada na pamet i 6950 2GB, tezak zivot pun ovakvih krucijalnih odluka. : ))))
Tko leti - vrijedi
Tko vrijedi - leti
Tko ne leti - ne vrijedi
CPU: AMD Ryzen R9 5950x
CLR: Kraken x73
MBO: Asus Crosshair VIII Hero
RAM: Kingston HyperX RGB 3600 32GB (4*8)
VGA: Gainward RTX 3080 Phantom
HDD: SAMSUNG 970 EVO 500GB M.2 ++ Kingston A1000 480GB M.2 ++ 2x SAMSUNG 850 EVO 500GB ++ WD Black 2TB
PSU: Antec HCG 750 Gold Modular
BOX: beQuiet! Silent Base 801
LCD: Acer Predator XB271HU @ QHD ++ LG 27UD58-B @ 4K
OS : MS Windows 10 Pro 64bit
Stick: Logitech/Saitek X56 + TrackIR5 + Oculus Rift S
CPU: AMD Ryzen R5 3600
CLR: Noctua NH-L12S
MBO: Asus Prime x370 Pro
RAM: G.Skill Trident Z RGB DDR4-3600 2x8GB CL16
VGA: Gainward RTX 2080 Phoenix GS
HDD: Samsung 850Evo 250GB M.2 ++ 2x WD Green 2TB
OPT: LG BD/HDDVD player
PSU: CoolerMaster MasterWatt 650W Modular
BOX: SilverStone GD09B
LCD: LG 49SJ810V @ 4K60Hz
CPU: Intel i3 6300HQ @ 2800MHz (100x28 @ 0,920V)
MBO: Lenovo Ideapad 700-15ISK
RAM: DDR4 2133 16GB (2*8 = Hyundai Electronics 8GB 2133 + Kingston 8GB 2133)
VGA1: Intel HD Graphic 530
VGA2: GeForce GTX 950M 4GB DDR3
HDD: Intel 600p 256gb ++ WD 1TB 5400rpm
LCD: BuildIn 15" FHD + Samsung 22" FHD
FiNiX je offline   Reply With Quote
Staro 31.03.2011., 19:25   #1562
Verbum
Postovi: 682
Autor FiNiX Pregled postova
Ta Gainwardov-a 460GTX sa 2GB je skroz ne isplativa kupnja jer za te novce uzmeš 560GTX koja je ipak bolja grafa.
No trenutni "best-buy" kod 460GTX je po meni:
http://www.instar-informatika.hr/msi...i-n460gtx-hawk
http://www.adm.hr/product_info.php?c...oducts_id=9108
Što se tiće 6950 koje dolaze sa referentnim hlađenjem temperature ti neće biti puno bolje od tvoje HD4890.
Zadnje izmijenjeno od: Verbum. 31.03.2011. u 19:33.
Verbum je offline   Reply With Quote
Staro 01.04.2011., 00:16   #1563
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Ja sam imao referentnu Sapphire 6950 1GB i bio sam zadovoljan i glede tišine/buke i glede hlađenja koje je bilo cca 37c u Idleu i u Loadu nije prešla 75c kod višesatnog igranja mislim da je to OK temperatura i nikako zabrinjavajuća.
Staro 01.04.2011., 00:28   #1564
FiNiX
FiNiX's Avatar
Postovi: 37
Razlika izmedju 1gb i 2gb verzije 460 je nekih 200kuna. Ajd povirit cemo i tu opciju s 560.
Tko leti - vrijedi
Tko vrijedi - leti
CLR: Kraken x73
CLR: Noctua NH-L12S
Staro 01.04.2011., 01:05   #1565
Astral
Postovi: 2,523
2gb gtx460 nema bas smisla, za 1920 x 1200 je 1gb taman
Rade gtx560
Astral je offline   Reply With Quote
Staro 01.04.2011., 01:19   #1566
ECHO
Postovi: 2,354
Za ovu cijenu odlična grafa i bolja od 460 GTX bilo koje glede nVidije.
Gigabyte 560 GTX
Od ATI-a možeš uzeti ovu grafu isto odličan izbor.
Sapphire 6950 1GB
Ukoliko je to puno novaca onda uzmi neku od predloženih 460 GTX modela ili od Gigabyta ili MSI-a naravno verzije sa 1GB memorije jer ti više netreba i bezpotrebno ćeš baciti novce jer za tu razliku od cca 200-300kn razlike za 2GB-ni model možeš dobiti neku od gore navedenih koje su bolje i jaće grafe.
Staro 04.04.2011., 19:31   #1567
beli14
beli14's Avatar
Datum registracije: Mar 2011
Lokacija: Gotham City
Postovi: 519
najvjerovatnije ću kupiti novu grafu i sad jel bolja MSI N460GTX ili MSI R6850 ( ima i OC verzija nesto jača)
Koja je bolja? Koja je tiša? Koja bolje hladi?
mislio sam uzet ovu od ATI-ja MSI R6850 al sam se malo preplasio kad sam procitao ovo
beli14 je offline   Reply With Quote
Staro 04.04.2011., 20:08   #1568
raliSHA
raliSHA's Avatar
Datum registracije: Feb 2010
Postovi: 971
hawkica je i jača i ima bolje hlađenje
raliSHA je offline   Reply With Quote
Staro 04.04.2011., 20:12   #1569
ECHO
Postovi: 2,354
Od te dvije uzeo bi bolje jaći model tj. 460 GTX Night hawk odlična grafa tiha i hladna i da se dobro clockati. A glede Ati-a uzeo bi model od MSI-a ali sa boljim Cyclon coolerom i nešto nabrijaniji model OVO. ili Sapphire Toxic.
Staro 04.04.2011., 20:25   #1570
Verbum
Postovi: 682
Autor ECHO Pregled postova
Koji je to model "460 GTX Night hawk"?
@Beli14
Nemaš tu kaj puno mudrovati jer 460GTX je jača grafa od HD6850, pogotovo kad je kloknuta kao navedena MSI Hawk onda je po performansam blizu HD6870.
Staro 04.04.2011., 21:51   #1571
beli14
beli14's Avatar
Postovi: 519
hvala vam, tak sam i ja mislil nVidiu i gotovo....a sto se tice napajanja graficke.....moram bas koristiti onaj adapter ( 2 MOLEX na utikac za graficku) ili mogu izravno iz napajanja....mislim jos uzet CORSAIR VX550
Staro 04.04.2011., 21:53   #1572
beli14
beli14's Avatar
Postovi: 519
TOXIC je dosta bucna u loadu ako se ne varam
Staro 04.04.2011., 21:59   #1573
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Autor beli14 Pregled postova
Samo ti uštekaj izravno iz napajanja, ti konverteri su namjenjeni onima koji nemaju napajanje s pci-e konektorom ili ih nemaju dovoljno. E i slobodno uštedi koju kunu i uzmi si VX450 ili Seasonic S12 II 520W. To su za tebe i više nego dovoljna napajanja.
doky je offline   Reply With Quote
Staro 04.04.2011., 22:22   #1574
beli14
beli14's Avatar
Postovi: 519
tu piše da MSI N460GTX treba 347W ( mislim da krivo piše ) .... al ak uzmem dogodine Intel 2500K i ASRock Pro3 ...onda mi mislim treba 550W možada jos neki overclock
Staro 04.04.2011., 22:26   #1575
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Nije sama graficka, nego kompletan racunar. Bolje citaj.
Staro 04.04.2011., 22:35   #1576
Astral
Postovi: 2,523
ustedi na napajanju, slobodno napravi kako ti je Anphonic rekao, moja konfa ful naklokana i pod load ne vuce iz uticnice ni 300W
Znaci ovako...kada jednom nesto napises tj odgovoris, drugi puta kada zelis opet nesto napisat, a nitko jos poslje tebe nije nista napisao, stisni gumb EDIT koji se nalazi tocno pokraj gumba QUOTE kojeg ocito znas koristit, hvala.
Staro 04.04.2011., 22:41   #1577
beli14
beli14's Avatar
Postovi: 519
krivo sam vidio....al ak za 1godinu zamjenim procesor i maticnu za INTEL i5 2500K i ASrock pro3....jel će biti onda dosta 450W ( izracunao sam na Corsair-ovoj) stranici i kaže da će biti dosta al bas nevjerujem
edit...znam to koristiti....al mi je glupo jer neke napisem onda mi je jednostavnije samo napisati novi komntar
Zadnje izmijenjeno od: beli14. 04.04.2011. u 22:51.
Staro 04.04.2011., 23:35   #1578
Firkraag
Firkraag's Avatar
Postovi: 32
to ovisi koliko ces klokati, koliko diskova, optike imas itd. Ipak bih ti preporucio da uzmes Seasonic 520 W, tko zna mozda za godinu dana uzmes graficku koja vise trosi ili postanes heavy overclocker
Firkraag je offline   Reply With Quote
Staro 05.04.2011., 00:39   #1579
Astral
Postovi: 2,523
da si ne znam kolko heavy ocer, 450w ce bit itekako dosta, jedino ako ces prelazit na novu jacu grafu onda tko zna...naravno, slobodno uzmes sisu 520
Staro 05.04.2011., 14:08   #1580
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Bit će ti dosta, bez dileme.
Al ako se već može onda si uzmi jače, iako uz te komonente nema potrebe. Skoro sve isto to moj cx400 drži bez problema.
Core2Duo22 je offline   Reply With Quote
Staro 05.04.2011., 16:31   #1581
beli14
beli14's Avatar
Postovi: 519
hvala....bit će 450W dosta
Staro 05.04.2011., 20:24   #1582
beli14
beli14's Avatar
Postovi: 519
u Protisu su te 2komponente najjeftinije. Nudi li Protis narudžbu putem interneta i plaćanje robe u njhovoj poslovnici?, znaci prek neta narucim robu i za 2h dođem u Zagreb po nju i tamo platim?
Staro 05.04.2011., 20:37   #1583
Astral
Postovi: 2,523
Mozes narucit prek neta al dobit ces sljedeci dan a ne za 2h
Staro 05.04.2011., 22:35   #1584
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Pa naruči preko telefona...
Staro 05.04.2011., 22:45   #1585
Astral
Postovi: 2,523
ne vole to bas preko telefona, mozda cak ni nebi dali
samo se registriras u 2min i narucis...skoro odma dobis ponudu od njih, uplatis novce ili preko internet bankarstva ili odes kod njih platit i onda ti naruce robu koja dode sljedeci dan
Staro 06.04.2011., 09:36   #1586
beli14
beli14's Avatar
Postovi: 519
imao sam loše iskustvo prilikom dostave ... a nemogu doći do njih i platiti a oni mi daju robu?
Zadnje izmijenjeno od: beli14. 06.04.2011. u 12:07.
Staro 06.04.2011., 13:08   #1587
Astral
Postovi: 2,523
krivo si shvatio, oni naruce robu sa svojeg skladista, a dode njima u poslovnicu, tamo ides po robu
platiti moras unaprijed
Staro 06.04.2011., 13:59   #1588
Verbum
Postovi: 682
Autor Astral Pregled postova
Nije istina, molim te nemoj širiti dezinformacije.
Sve se da sa njima dogovoriti no umjesto da ovdje laprdamo najpametnije je da ih beli14 sam nazove i dobije informacije iz prve ruke.
Staro 06.04.2011., 14:19   #1589
Astral
Postovi: 2,523
lol kakve dezinformacije?? kupovo sam kod njih mali miljon puta, kad napravis zahtjev za komponentama oni ti daju ponudu i u ponudi imas kolko trebas uplatit i na koji racun, nema tu nikakvog dogovora, vjeruj mi pokuso sam!
tek kad oni zaprime uplatu onda ide nabava robe i ti dolazis po nju sljedeci dan, nikakve dezinformacije znam o cem pricam - obavjeste te mailom da je roba spremna za isporuku
uplatu mozes napravit preko internet bankarstva ili mozes doc kod njih platit karticom ili keshom, ali onda moras PONOVO dolazit do njih sljedeci dan po robu
JEDINO kad ne vrijedi ovo sta sam napiso je kad vec imaju to sta trebas u poslovnici u krapinskoj, a to su obicno tinte za printere, usb stickovi, misevi i slicne sitnice, onda mozes doc i kupit to sta je tamo na licu mjesta, u suprotnom ide ovako kako sam napiso
prije su dopustali narucivanje preko telefona pa platis kad dodes po robu, ali su ih valjda previse puta zaj*** ljudi koji nisu dosli po robu i prestali su tako radit
Staro 06.04.2011., 15:38   #1590
Verbum
Postovi: 682
Ocigledno da se nisi dovoljno dobro potrudio. Eto ovaj monitor u koji gledam je prvo dostavljen kod njih u pordavaonicu pa zatim kupljen i placen na licu mjesta.
Zato i dalje tvrdim da širiš dezinformacije jer se iz navedenog primjera vidi da je moguce doci u ducan i platiti proizvod te ga odmah preuzeti.
Sve je stvar dogovora i sposobnost pojedinca da komunicira sa prodavateljem proizvoda tj. usluga.
