Staro 07.06.2020., 20:04   #1531
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,195
Nabrzinu sam škicnuo ...
Ta Iyama nema mat premaz obrati pozornost na to
Because the monitor is not matte, there is a considerable reflection visible (with dark images)
Iyama review , samo si stavi prijevod na Engleski sa google translatorom:
https://tweakers.net/productreview/2...-b1-zwart.html
Cini mi se da nemas neki izbor do 4 glave ...
LG 43UD79-B 5650 kn https://www.rtings.com/monitor/reviews/lg/43ud79-b
The LG 43UD79 is a decent monitor for mixed usage.
It has good viewing angles that make suitable for a wide room,
but blacks are not deep and it is not great in dim environments
It has a great low input lag and this is great for gaming
. It has Picture-In-Picture and Picture-Beside-Picture features that can make great use of its large size.
+ Image remains accurate when viewed from up-close
+ Colors appear uniform
- Blacks appear gray in the dark
- Limited ergonomic adjustments
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 07.06.2020., 21:24   #1532
Zaggy111
Zaggy111's Avatar
Postovi: 441
Sranje što Iiyama nije mat. Kak ti se čini da li ovaj AOC koji imam ima više refleksije ili manje? https://pcmonitors.info/reviews/aoc-q3279vwf/
A što se tiče LG, ima i novija verzija, 43un700, a obje su 1000 kn skuplje od Iiyame.
Zaggy111 je offline   Reply With Quote
Staro 07.06.2020., 21:52   #1533
danex
danex's Avatar
Datum registracije: May 2009
Postovi: 378
Koja je razlika imeđu jeftinog 43" tv-a i 43" monitora s također 60hz osim u cijeni na strani tva?
Staro 07.06.2020., 23:16   #1534
Mladenxy
Mladenxy's Avatar
Postovi: 4,390
Monitor ima manji input lag.
Staro 08.06.2020., 00:02   #1535
Zaggy111
Zaggy111's Avatar
Postovi: 441
Da li bi se primjetila razlika ako se monitor koristi samo za surfanje, excel, CAD? Gaming rijetko. Jer gledam sad ima TVa s lagom od 10ak ms, što je super. Koje onda još uopće prednosti ima monitor spram tva, ako je lag isti?
Zadnje izmijenjeno od: Zaggy111. 08.06.2020. u 17:57.
Staro 20.06.2020., 00:17   #1536
zwer54
zwer54's Avatar
Lokacija: Dublin
Postovi: 1,977
Autor Zaggy111 Pregled postova
Mislim da ima veze i sa rezolucijom. TV skalira rezoluciju i cesto se desi da jednostavno ne bude skroz ostra slika na tv. Koristim 55" tv u uredu kao 2nd monitor i definitivno ne bi to zelio kao primarno rjesenje.
Staro 22.06.2020., 11:48   #1537
mierdadeltorro
mierdadeltorro's Avatar
Lokacija: zadar
Postovi: 241
jel ima neko da je nabavio ovaj: gigabyte g32qc
još nema rezenzija samo pcmonitor.info ima najavu, i ima neka manja rasprava na redditu, a cijena od cca 3200kn, se čini ok, za 32" VA, 165Hz 1440P 1500R freesync, g-sync compatible zakrivljeni monitor.
mierdadeltorro je offline   Reply With Quote
Staro 04.07.2020., 11:44   #1538
Joza_Seraf
Joza_Seraf's Avatar
Datum registracije: Jun 2015
Lokacija: Klc
Postovi: 568
E ovako. Kupujemo frendu poklon za 30-ti, i skupilo se nas par. Odredili buđet od oko 3000 kn, može se nadodati gore nije problem. On traži 2k monitor, 144 HZ.. ono sta smo mi nasli dok smo bili na pivi, a da se čini ok je AOC CQ32G1
E sad. Pitanke za stručnjake i one koji se osjećaju tako. Jel dobar? Moze bolji za tu cijenu? Preporuke?
Ima RTX 2060, od gigabyte, ne znam koji model, Ryzen R5 2600, 16 GB memorije..
Hvala :-)
Samo čekam dan kada će mi netko pokucati na vrata i zatražiti me bubreg jer sam negdje odscrollao dolje i stavio kvačicu na "Slažem sa svime"!!
Joza_Seraf je offline   Reply With Quote
Staro 04.07.2020., 12:23   #1539
Max_Damage
Max_Damage's Avatar
Lokacija: Krapinske Toplice
Postovi: 959
Nisam od pomoći ali ste trendovi svaka čast! Respect
Max_Damage je offline   Reply With Quote
Staro 04.07.2020., 15:46   #1540
axo
Datum registracije: Sep 2017
Postovi: 1,432
Autor Joza_Seraf Pregled postova
Hvala :-)
Ovako sam ja trazio best buy 2k 144hz plus budet.
amazon lista 2k 144 i 165hz
Koliko vidim best buy trenutno je taj aoc sto si naveo.
Skrolaj dok ne pocne lista pa procitas komentare i review i vidis na forumu dal ce neko nesto odgovoriti.
Ili opcija b tj na trznici imas lg 27gl850 star 3 tjedna za 3200kn.
Staro 05.07.2020., 11:28   #1541
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Drugi koji smo gledali je isto od AoC-a CQ27G2 ubiti 27 incha i noviji. Neš im razlike. Ne znamo ni sami šta i kako
Staro 05.07.2020., 13:04   #1542
axo
Postovi: 1,432
Oba sva su dobra jedino meni vise od 27 ne treba...
Tak da imam lg 27gl850...
Staro 05.07.2020., 14:28   #1543
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Autor axo Pregled postova
I mi ćemo vjerojatno taj G2 jer ima i podesavanje po visini. Jel RTX 2060 preslaba za 1440? Igra wot, brodove i cod mw
Staro 05.07.2020., 16:02   #1544
Postovi: 17,037
Za to nije.
Za neke SP AAA igre, je.
Staro 05.07.2020., 17:40   #1545
Joza_Seraf
Joza_Seraf's Avatar
Lokacija: Klc
Postovi: 568
Za to nije.
Ne igra tipa tomb raider, gta, rdr 2... tako da
Staro 05.07.2020., 19:17   #1546
Postovi: 17,037
A jesi usporedio 3 igre, ni slične po performansama.
GTA i Tomb Raider još nekako, ali RDR2, iznad 30-40 FPS-a nikako. Sigurno se da to smanjiti da bude i više, ali eto, meni 2060 nije za 1440p.
Osobno, 1080Ti, 2070, 2080, 2080Ti i RX 5700 XT su meni grafe za 1440p. Ništa drugo. Ali to nije pravilo to je osobna preferencija
Znam brdo ekipe ovdje koja igra na 1070/1070Ti i 1080 u 1440p i zadovoljni su.
Staro 05.07.2020., 20:34   #1547
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Ni 2070 nije grafa za 1440p, no ovo nije tema za to. Tko ima 1440p, ispod 2080 ne treba gledati ništa, pričamo o AAA naslovima a ne doti, lol-u, wot-u... kao (bivši) vlasnik 2080ti, vrtio sam sve i svašta i uspio sam ju zakucati na nekim naslovima do ibera i to na već 75hz 1440p
Staro 06.07.2020., 01:11   #1548
Blue Spirit
Postovi: 2,195
I opet dolazimo do toga da onaj koji nije procitao komentare vlasnika RTX 2080 Ti sa ovog foruma (da ni ona u pojedninim naslovima ipak nije dostatna za 80+ FPS-a a kamo li za 144 FPS-a @ 1440p) i koji ce otici na npr techpowerup da provjeri snagu pojedine grafe.
Naici ce na ovaj graf koji nije baš reprezentativan za one igre koje on ne obuhvaca, jer nekom logikom mogli biste očitati i steci dojam da RTX 2080 Ti melje apsolutno sve pred sobom.
Tj vjerovati da ce i u najnovijim igrama imati iznad tj +130 FPS-a jer je eto toliko techpowerup navodi prosjek za 22 igre @ 1440p za RTX 2080 Ti.
https://www.techpowerup.com/review/p...pro-oc/28.html
RTX 2080Ti @ 1080p Average FPS = 174.4 na donjem 1080p grafu
RTX 2080Ti @ 1440p Average FPS = 131.3 na donjem 1440p grafu
Bez obzira što je tema monitor, graficku karticu ne može se ne spomenuti; jer direktno utjecu jedno na drugo (uzajamna korelacija rezolucije monitora i FPS -a / Hz i obrnuto).
Zadnje izmijenjeno od: Blue Spirit. 06.07.2020. u 06:16.
Staro 07.07.2020., 12:42   #1549
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,573
Tako je, to je moj komentar i ostajem pri tome. Eventualno bi amper mogao pomaknuti tu granicu.
Staro 14.07.2020., 17:05   #1550
gunther
Postovi: 1,365
Pitanje za vas koji pratite monitore...
Ima li barem u najavi neki monitor od 32 incha, 4K, IPS, 144Hz?
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 14.07.2020., 17:45   #1551
Postovi: 17,037
Imaš na inače na tržištu, ali košta preko 15k kuna. I to su PRO monitori, nema veze s gamingom.
Asus PA32UC-K.
Inače, ne. 144hz na 4k, nema smisla.
Staro 14.07.2020., 17:46   #1552
bor1s
bor1s's Avatar
Lokacija: Vratlo
Postovi: 301
Ima samo očekuj astornomske cifre oko 2k Eura pa na više.
Innolux i AU Optronics počinju sa proizvodnjom 32'' 4k 144Hz panela u drugoj polovici ove godine.
PS taj Asus nije 144Hz
Zadnje izmijenjeno od: bor1s. 14.07.2020. u 17:54.
bor1s je offline   Reply With Quote
Staro 14.07.2020., 17:52   #1553
Postovi: 17,037
Staro 14.07.2020., 17:57   #1554
bor1s
bor1s's Avatar
Lokacija: Vratlo
Postovi: 301
Da vjerovat ću shopu prije nego službenoj Asus stranici LINK
Znači vertikalna frekvencija 60Hz
Staro 14.07.2020., 21:45   #1555
gunther
Postovi: 1,365
Autor bor1s Pregled postova
Odlično! i konačno više!
Na 32 ips 4k vec sam, a barem 5 godina (Asus pq321qe) i ne da mi se prelaziti na ista manje ili niže rezolucije... a volem da vidim i tih 144hz
Staro 16.07.2020., 15:35   #1556
thunder11
thunder11's Avatar
Datum registracije: Dec 2013
Postovi: 1,699
Staro 17.07.2020., 21:06   #1557
Alfredo nr.3
Alfredo nr.3's Avatar
Lokacija: Požega
Postovi: 1,255
Kakav je monitor LG 29UM69G-B? Ima li dobru sliku? Razmišljam da ga uzmem.
Alfredo nr.3 je offline   Reply With Quote
Staro 17.07.2020., 21:33   #1558
Max_Damage
Max_Damage's Avatar
Postovi: 959
Autor Alfredo nr.3 Pregled postova
Ja ga imam već skoro 2 godine, meni je ok, bleedinga ima malo ali to sve ovisi kak te strefi. Build quality nije nekaj, bezeli malo strše ali mi to ne smeta. Ja zadovoljan. Sljedeći monitor bi htel 34" 144hz 1440p ali je zasad cijena uf!
Staro 17.07.2020., 22:18   #1559
Alfredo nr.3
Lokacija: Požega
Postovi: 1,255
Ja sam upravo prodao 32, 144hz i shvatio da meni tih 144 ništa ne igra. Igre koje volim igrati stavim na ultra detalje sa uključenim ray tracing shaderom i onda fps bude oko 70, tako tih 144 mi ništa ne znače. Ono što mi igra je freesync.
Kakva je oštrina detalja na tom monitoru? Je ista kao na 27 1440?
Razmišljam da ga uzmem ovdje https://iponcomp.hr/shop/termek/lg-2...m_medium=click
košta 1669kn. Koliko si ga ti platio?
Gledao sam i na njuškalu ali nema polovnih.
Staro 18.07.2020., 07:40   #1560
Max_Damage
Max_Damage's Avatar
Postovi: 959
Kaj se tiče oštrine, meni je super. Niš se ne mučim dok gledam u monitor. Ja sam svojeg platil 2000kn na akciji ali to je bilo prije 2 godine tak da je ova cijena ok.
Monitor može OC na 75Hz bez beda i nema šanse da igram na 60 jer se osjeti "sporost".
