Staro 06.02.2015., 23:19   #1531
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Autor fastfinger Pregled postova
Intel Core i7-4770K Soc 1150 2831,21 kn
Corsair 1x8GB DDR3 1600 C9 Ve 625,81 kn
Gigabyte GA-H97M-D3H,1150,H97,D3,S3,U3,DVI,HDMI,mA 811,32 kn
MSI R9 270X GAMING LE, 4GB GDDR5, DVI, HDMI,DP 1964,95 kn
SSD disk Kingston 240GB, SSDNow V300 SATA 3 827,28 kn
Optički uređaj Samsung SH-224DB SATA Bulk Crni 145,50 kn
Kućište Antec GX505 Window Blue Edition, Plexy, USB3.0 599,00 kn
Power Supply CORSAIR Builder Series CX AC 100-240V, 750W, Retail, Efficiency 85%761,72 kn
Hladnjak Noctua NH-D14, Intel/AMD 569,00 kn
1 x Intel Core i7-4770K Soc 1150
1 x Coolink Corator DS cooler 115x/2011/AMD
1 x SSD disk Kingston 240GB, HyperX Fury SATA 3 2.5"
1 x Zalman Z3, USB3.0 black, 3x120mm
1 x Seasonic SS-620GM2 EVO, 620W, 80+ Bronze, Modular
1 x LG DVD±RW 24x GH24NS95 SATA black bulk
1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11
1 x Sapphire R9 280 3G GDDR5 Dual-X with boost
1 x GIGABYTE Main Board Desktop Z97X-Gaming_3
Ukupno: 8625,70 kn
Staro 07.02.2015., 05:29   #1532
fastfinger
fastfinger's Avatar
Datum registracije: Feb 2015
Postovi: 7
Hvala ti na odgovoru, puno je pomoglo. Jos cu malo pronjuskati pa uzeti ovo ili nesto vrlo slicno tome
Zadnje izmijenjeno od: coconut. 07.02.2015. u 10:23.
fastfinger je offline   Reply With Quote
Staro 06.04.2015., 18:16   #1533
zormar
zormar's Avatar
Datum registracije: Jan 2010
Postovi: 73
Za iste pare, bolje uzmi 280X preko Njuskala.
zormar je offline   Reply With Quote
Staro 06.04.2015., 19:45   #1534
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Za te pare mu ja dam 290
Staro 06.04.2015., 20:33   #1535
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,164
Pa kasnite samo 2 mjeseca
Staro 06.04.2015., 20:56   #1536
fastfinger
fastfinger's Avatar
Postovi: 7
Hahaha pa bolje kasno nego nikad. 280X je već odradila 80ak sati na dragon ageu. Položila je testove. :-)
Staro 06.04.2015., 21:08   #1537
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
ma zormar reklamira grafe sto prodaje pa da i ja malo svoje poguram :P
Staro 08.04.2015., 19:01   #1538
apekop
Ape
apekop's Avatar
Datum registracije: Jan 2012
Postovi: 157
Konfiguracija za igrice
Pozdrav, brat kupuje konfu za igranje igrica , rang cijena je ajmo rec od nekih 7 000 do 8 500. Kupuje karticom.
Bilo bi super kad bi to sve bilo u istom ducanu, jer ni ja ni on ne znamo to slozit.
To se odnosi samo na kučište, ako imate neki monitor za preporucit super al ne mora ulazit u ovu cijenu. Takodjer ima ovaj hard vec doma pa bi bilo super da se to moze iskoristit. Opet, nije uvijet al je poželjno. To je vise manje to.
Apekop
apekop je offline   Reply With Quote
Staro 08.04.2015., 23:07   #1539
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x AMD FX-Series X8 8320 AM3 Box
1 x Hladnjak Alpenföhn Groß Clockner Rev. C, 120mm, Intel/AMD
1 x GIGABYTE GA-990XA-UD3 (AM3+,DDR3,SATA III,LAN,USB 3.0,Firewire) ATX
2 x Crucial 4GB DDR3 1600 Mhz (PC3-12800) CL11
1 x Sapphire R9 290 4GB TRI-X DDR5
1 x OCZ SSD ARC 100 240GB,R480/W430,95K,S3
1 x Zalman R1 mid tower case / ili po vlastitom ukusu
1 x Super Flower Golden Green 650W, 80+ Gold
7500kn (amex i gotovina) / 8300kn ostale kartice / besplatno slaganje
Staro 08.04.2015., 23:26   #1540
apekop
Ape
apekop's Avatar
Postovi: 157
hvala, koji ducan to?
Apekop
Zadnje izmijenjeno od: coconut. 09.04.2015. u 07:25.
Staro 09.04.2015., 00:30   #1541
ssarik
Terror Absolut!
ssarik's Avatar
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
Pitaj Frippera na pm (valjda se neće ljutiti ). Nije dopušteno u ovoj temi promovirati dućane.
Zadnje izmijenjeno od: ssarik. 09.04.2015. u 00:33. Razlog: dodan smisao rečenici
ssarik je offline   Reply With Quote
Staro 15.04.2015., 01:31   #1542
webald0
Datum registracije: Apr 2015
Postovi: 5
Trebam komp za autocad i dialux EVO i gejmanje CS:GO. konfa može proći?
Procesor Intel Core i5-4590 (3.30GHz,1MB,6MB,84 W,1150) Box*
Matična ASUS H97-PRO, 1150, Intel® H97, DDR3, Broj utora*
Grafulja Sapphire R9 270 2GB, OC Boost, 2GB GDDR5 256bit*
SCYTHE Katana 3 SCKTN-3000I White Box, 775/1155/1156/1366
Memorija DDR3 8GB (2x4GB) Kingston, 1866MHz, CL10, HyperX Fury
Intel 120GB SSD 530, 2.5", SATA III-600, R/W:540/480MB/s *
HDD WD 500GB, Caviar Black 5003AZEX, 500 GB, SATA3, 64 MB, 3,5"* 588,01Kn
Napajanje CORSAIR 450W, RM Series, CP-9020066-WW, 80 PLUS® Gold
Kućište Fractal Design Define R4 Black Pearl - Window, Midi tower, ATX
LG 23MB35PM-B 23" Wide LED, IPS panel, Rezolucija 1920x1080(pivot, swivel, tilt)
webald0 je offline   Reply With Quote
Staro 15.04.2015., 02:09   #1543
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Ja bih ovako za tvoje potrebe uzeo:
Monitor:
Monitor 23 " LED LG 23MB35PM-B, IPS, 5ms, 250cd /m2, 10.000.000:1, DVI, D-SUB, crni
Konfa:
1 x Grafička kartica GAINWARD GeForce GTX 960 Phantom, 2GB DDR5, DualDVI, HDMI, DP
1 x Procesor INTEL Core i7 4770K BOX, s. 1150, 3.5GHz, 8MB cache, GPU, Quad Core
1 x Matična ploča ASUS Z97-K, Intel Z97, DDR3, zvuk, G-LAN, SATA, RAID, PCI-E 3.0, USB 3.0, D-SUB, DVI, HDMI, ATX, s. 1150
2 x Memorija DDR3 ADATA, AD3U1600C2G11-R, 1600MHz, 4GB
1 x Cooler LC POWER LC-CC-120, socket 775 /1150 /1155 /1156 /1366 /2011 /FM1 /FM2 /AM2 /AM3
1 x Napajanje 500W THERMALTAKE TR2 Bronze, PS-TR2-0500NPCBEU-B, ATX, 120mm ventilator
1 x SSD 240.0 GB OCZ Vector ARC 100, ARC100-25SAT3-240G, SATA3, 2.5 ", MLC-Chip, maks do 480 /430 MB /s
1 x Tvrdi disk 1000.0 GB SEAGATE ST1000DM003, SATA3, 64MB cache, 7200 okr /min, za desktop
1 x Kućište ZALMAN Z3, MIDI, crno, bez PS
Ukupno:9640 kn
Stavljen je i7 jer mozes imati benefita od njega u radnjama koje si naveo, SSD 240GB jer je 120GB malo ako ces novije igre instalirati na njega a zauzimaju i po 60GB. 8GB rama je dovoljno za sve, a kasnije ako se pocnes ozbiljnije baviti onda mozes dodati jos dvije plocice po 4GB da imas ukupno 16GB, također nvidija grafa zbog CUDA jezgri.
Sphere je offline   Reply With Quote
Staro 15.04.2015., 02:57   #1544
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ma i i5 mu je overkill, i za autocad ako nije 3d ne treba mu ni nikakava grafa, i za igru je i5 overkill, pentium i i3 su tu fine
https://www.youtube.com/watch?v=1inUAqeVXXg
Staro 16.04.2015., 00:56   #1545
webald0
Postovi: 5
dobar video, sigurno bolje performanse od laptopa na kojem sam igrao do sad
@sphere - dobra konfa al mi je za 1k više od budžeta, ne smijem više od 8k :|, mislim da će i5 biti dovoljan za rendering i csgo usput
Zadnje izmijenjeno od: coconut. 16.04.2015. u 10:08.
Staro 16.04.2015., 02:09   #1546
Sphere
Postovi: 1,254
Ma biti ce dosta, ja sam slozio preko buđeta jer nisam znao sa koliko tocno raspolazes.
Staro 26.05.2015., 18:04   #1547
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 852
trebam konfu za bratića. Objektno programiranje i paralelizacija programa je svrha. treba uz kantu ,monitor, tipkovnicu i miš. buđet do 9000kn .trgovine u zg dolaze u obzir. on je gledao amd platformu , fx x8 8370 i msi 990-gd65 ploču no ne pratim već neko vrijeme pa ne znam što bih mu rekao..help . hvala....
snorky_vk je offline   Reply With Quote
Staro 26.05.2015., 20:00   #1548
Freddy
Freddy's Avatar
Datum registracije: May 2015
Postovi: 76
i7 4790 ti je bolji od bilo kojeg amd-ovog procesora, pogotovo za rad
evo izvoliš...
1 x Procesor Intel Core i7 4790
1 x LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD
1 x Matična ploča MSI H97_PCMATE (S1150, DDR3, USB3.0,USB2.0,SATA III,RAID,HDMI,DVI,VGA,Audio Line-Out,Aud
2 x Kingston 8GB 1600MHz DDR3L Non-ECC CL11 DIMM 1.35V, EAN: 740617225914, KVR16LN11/8
1 x Kingston SSD HyperX FURY, 240GB, 7mm, 2.5"; SHFS37A/240G
1 x Toshiba 3.5" 2TB, SATA6Gb, 7200rpm, 64MB DT01ACA200
1 x Grafička kartica Gigabyte GeForce GTX 750 GDDR5 2GB/128bit, 1059MHz/5000MHz, PCI-E 3.0 x16, 2x HDMI, 2x DV
1 x XFX Pro Series CoreEdition 80 450W PSU, XFX-P1-450S-X2B9
1 x Raijintek kućište Arcadia Black Midi Tower bez napajanja P/N: GERT-003
1 x Optički uređaj LG GH24NSC0 SATA Bulk Black 24x
1 x Samsung Monitor LS24D390HL
1 x Genius SlimStar i8050 tipkovnica i miš, crna
Ukupno: 8992,41 kn (besplatno slaganje uključeno u cijenu)
Freddy je offline   Reply With Quote
Staro 26.05.2015., 20:15   #1549
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Monitor: LCD DELL UltraSharp U2412M (24", 1920x1200, IPS) Black
Tipkovnica: Logitech K280 OEM, tipkovnica
Mišonja: GIGABYTE Mouse FORCE M9 ICE (Wireless, Laser, 2000 DPI) Icy Black
Procesor: Intel Core i5-4460 Soc 1150
Memorija: 16Gb 2x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11
Matična: Asrock H81M-HDS (S1150, USB3.0 Header) mATX
Grafička: MSI GTX 750 Ti Gaming 2GB DDR5, Twin Frozr
SSD: OCZ ARC 100, 240Gb Sata3
HDD: TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III)
Napajanje: SILVERSTONE Strider ST40F-ESB, 400W, 80+ Bronze
Kućište: Xigmatek Mach crno, USB3.0
9000Kn Gotovina/Amex 6rata, Besplatno slaganje i besplatna dostava ako treba
Staro 26.05.2015., 21:55   #1550
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 852
znači ovi inteli su bolji od fx-a? nisam siguran da cu ga uvjeriti da je to bolje jer on veli da želi više fizičkih jezgri, tako mi reče. koliko je tu sad recimo intel s ssd brži of fx-a s sdd-om? pretpostavljam da će mu ssd disk donijeti više brzine nego brdo jezgri na procesoru....
Staro 26.05.2015., 22:02   #1551
Freddy
Freddy's Avatar
Postovi: 76
pa pokaži mu razne benchmarke između i7 4790 i bilo kojeg amd-ovog procesora sa osam jezgri i vidit ce sam da je intel puno bolji izbor, a što se tiče ssd-a nema ti to veze sa kojim je procesorom, dat ce ti iste performase
Staro 26.05.2015., 22:08   #1552
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 852
Autor Freddy Pregled postova
ma znam da ssd nema veze s procom nego sam htio reći da će općenito dobiti više na brzini ako stavi ssd u konfu jer mi je poslao nešto sto je on il netko složio i nema ssd-a već samo wd black . malkice sam se nespretno izrazio.
Staro 26.05.2015., 22:24   #1553
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ako hoce AMD onda ovako samo uzme:
1 x AMD CPU Desktop FX-Series X8 8300 (3.3GHz,16MB,95W,AM3+) box
1 x CPU Hladnjak LC-CC-120, Intel/AMD, 120mm, PWM
1 x GIGABYTE GA-990FXA-UD3 (AM3+,DDR3,SATA III,LAN,USB 2.0/3.0,Firewire) ATX
Digne proc na bar 4GHz i vozi....
Staro 27.05.2015., 03:18   #1554
Manuel Calavera
Postovi: 14,589
Pa baš i ne, ako mu treba multithreading fx 83XX tu jako dobro stoji naspram intelovog quada + HT. Evo ti takvi benchmarci izvađeni iz tomshardware, anandtech i sl. recenzija
http://forum.pcekspert.com/showpost....&postcount=214
Sad za koju kn preko 1000 kolaju 8300 i 8320E
Staro 27.05.2015., 10:17   #1555
Freddy
Freddy's Avatar
Postovi: 76
ja ne vjerujem, pa nemožeš mi reć da je fx 83** bolji od i7 zbog nekoliko multithreading benchmarka koji su rađeni sa i7 3770K koji je slabiji i stariji od i7 4790, nemoj čovjeka zbunjivat i navlačit ga na slabiji procesor, ima 9000 kuna budžet i i7 mu komotno stane u njega
Staro 27.05.2015., 10:19   #1556
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Za to što on treba bolje je kvalitetniji i veči monitor nego i7...
Staro 27.05.2015., 10:21   #1557
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Za razliku u cijeni od tog i7 do 83xx se skupi lijepa suma para za monitor.
Hawker je offline   Reply With Quote
Staro 27.05.2015., 10:33   #1558
Freddy
Freddy's Avatar
Postovi: 76
pa stavio sam mu samsung 24" monitor sa pls matricom koji mu je i više nego dovoljan, nema smisla bacat više para na monitor, ja neznam jel vi trolate ili šta sa komentarima, uvijek je bolje uzet jači procesor poput i7 , jer si duže miran
Staro 27.05.2015., 10:34   #1559
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Mislio sam vecu rezoluciju, jer uvijek je dobro imati bolji monitor za npr programiranje, web dizajn itd... I nije uvijek bolje uzeti jači procesor, pogotovo ako mu ne treba i bolje je ostalo poboljšati... Monitor, dobar miš...
Znam po sebi, radije uzmem i5 ili fx x8 nego da imam loš monitor, tipkovniu, miš... radije ja puknem 3k u periferiju Drugo je da je komp za gaming, onda ajde...ni vazno...ali ovako ja biram ono drugo
Staro 27.05.2015., 10:39   #1560
Freddy
Freddy's Avatar
Postovi: 76
joj daj molim te, najbolje da si mu na budžet od 9000 kuna predložio pentiuma, a ostale pare utuko u monitor, nema smisla više se raspravljat s tobom, aj bok
