Staro 19.01.2019., 04:42   #121
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Xiaomi Mi Airdots Pro Earbuds - Improved Edition of Mi AirDots
Easily listen to and control your music while on the move with the Xiaomi Mi AirDots Pro. Featuring a wireless design, these in-ear headphones come with convenient touch controls, making it easy to control music and calls. Likewise, you can use the touch controls to activate voice assistants. In addition, they are compatible with both Android and iOS devices. Designed to function independently, you can even use just one of the earbuds. Moreover, the AirDots Pro last for up to ten hours on a full charge, they also take just under one hour to charge completely. Complete with noise cancelation, the earbuds allow you to make clear calls on the go. To ensure a comfortable fit, the earbuds provide silicone tips.
Product Features:
● Adopting the left and right split true wireless design, bid farewell to the wire binding, achieve true wireless.
● 7mm neodymium iron boron magnetic + titanium-plated diaphragm dynamic ring speaker unit, tri-band balance.
● ANC active noise reduction, the sound is purer and the feeling is more real.
● HD sound quality, support AAC advanced audio coding technology, more complete preservation of the original sound.
● Control music, calls, and voice assistant with a simple touch.
● Both the left and right earphones have a built-in high-sensitivity microphone for binaural call, beamforming and ENC noise reduction technology, bringing HD call quality.
● Automatic pairing, wearing the sensor, taking off the earphones will automatically pause the music.
● Magnetic contact charging, Hall magnetic switch and USB Type-C interface, faster charging.
● IPX4 waterproof so that the sweat and rain are not terrible.
● Paired with iOS and Android devices, including tablets laptops, and mobile phones.
These new wireless earphones offer a music-listening experience that is synchronized with the stereophonic, they are small and smart, the music experience is beyond imagined: https://gearvita.com/xiaomi-mi-airdo...earphones.html
Related products:
xiaomi airdots headset
qcy t1c mini wireless earphones
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 21.01.2019., 08:21   #122
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom BX10 Clip Earphones Provides All-day Comfort
Langsdom BX10 earphones connected to a mini remote control with a 3.5mm plug, the control panel allows you to adjust the volume and control the microphone. The device adopts noise reduction technology, reproduces high-quality stereo sound and powerful bass, supports voice control, gives comfortable wearing.
Product Features:
● 2-in-1 Micro USB Interface
The USB interface can be both used for battery charging and earphone connection, convenient to use.
● Magnetic Metal Earphones
With the magnet attraction design, like a necklace, you can wear it around your neck when you don't use them.
● Strong Magnetic Silicone Clip
Innovative magnetic design with silicone, which can absorb on clothing freely, easy for sporting and relaxation.
● Multifunction Buttons
All the control in your hands, 3 buttons for volume control, answer call and skip song, compatible for iPhone, iPad, Android, etc.
● Easy to Pair
Bluetooth v4.1 technology allows you to connect quickly to any smart device or PC.
● Excellent Battery Life
Charging about 2 hours, talking time up to 5 hours, standby time about 120 hours.
● Battery Capacity Display
Supports iOS phone for capacity display, to know your battery status timely.
● High Sound Quality
Low sound quality loss will be prevented and high sound resolution will be warranted by the micro USB connection.
● Wear Comfortable
With human body engineering design, comfortable fit the ear canal, more effective sound insulation to prevent leak.
The unique color and fashionable metal materials, suitable for any combination, give you a different look and possibilities: https://gearvita.com/langsdom-bx10-c...-earphone.html
You may also like:
xiaomi minimalist portable flashlight
raspberry pi 3 model a+ motherboard
Staro 22.01.2019., 05:49   #123
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Edifier M100 Wireless Bluetooth Speaker - Designed for Outdoor Use
The Edifier MP100 speaker is a fully featured ultra portable Bluetooth speaker, compatible with Bluetooth 4.0 technology and microSD functionality, gives you multiple ways to play your favourite tracks. The battery offers up to 20 hours of use, take the MP100 anywhere with its dust proof and splash proof exterior. This small but powerful speaker also acts as a speakerphone for answering calls.
Product Features:
● Portable with Clip
Made for the adventurous type, it is ultra-portable and rugged, the clip at the top is made to clip onto your belt or backpack.
● Amazing Low-frequency
Built-in proprietary skin cavity suspension technology, smaller vibration damping, brings an amazing amount of low-frequency sense.
● 4.5W Power
Uses class D amplifier, which is very efficient and has a palm-sized sound system, it has a 4.5W non-distortion power.
● Good Quality
● Silicone jacket, symbolic button, crystal texture packaging, full of quality taste.
● Bluetooth 4.0
Adopts Bluetooth 4.0 technology, which can transmit farther, connect faster, and consume less power.
● Long Lasting Battery Life
Powered by a high-quality lithium battery, fully charged and played at medium volume for up to 10 hours.
● IPX5 Waterproof
Small three defensed - waterproof, dustproof and shockproof, small wind and rain or splash of water can still make it sing loudly without any worry.
● Wide Compatiblility
Compatible with many devices such as smartphones and laptops. Using Bluetooth 4.0, connecting it to your smartphone, whether it is an iPhone, Android, or Windows phone you can use the MP100 as a speakerphone so you can take calls hands free.
M100 is specially designed to be used outside, with the small body and convenient clip, you can take it with you all the time and go wherever you want: https://gearvita.com/edifier-m100-wi...h-speaker.html
Hot sale products:
cheap xiaomi poco f1 lte 128gb
cheap xiaomi redmi note 5 64gb global version
Staro 23.01.2019., 05:35   #124
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
VITOG T12 Wireless Bluetooth Earphones with Charging Box
VITOG T12 wireless earphones features dual ear stereo design, left and right ear channel separation. You can use the headset solely, or used them in pairs of stereo mode. They weight of only 4g, mini size and 3 sizes of earcaps provide you long time wearing comfort, and guarantees stability when walking, running and more. Built-in high-sensitivity microphone, reduces ambient noises and grasps the detail of voice, ideal for in-car calling or working use. 40mAh rechargeable battery in each earphones ensures 2 hours of working time. Coming with a 280mAh charging box, which enables the earphones charging for about 3 times. The earphones are charged automatically in the charging box and stop automatically after fully charged.
Product Features:
● Comfortable and Soft Eartips
Adopt soft and environmental silicone ear caps, wearing comfortable.
● Excellent Craft
Use special technology to cover the appearance, to protect the earphones well from damage.
● Bluetooth 4.1
Bluetooth version 4.1 technology, adjusted the influence of old profile, improved compatability and stability.
● Innovative Charging Case
Equipped with a mini charging dock, convenient for personal carry, supplier the electricity with a long time when outdoor travel.
● 4g Lightweight
Mini design and light weight, no any pain and uncomfortable feeling in ear.
● Automatical Charging
Magnetic charging method of earphones automatically charging until full power, protects from over charging.
● Charging Indicator
Charger of 5V 1A or USB port both can be charged, red light will be showed during harging, blue light will be showed once full charged.
● Super Mini and Invisible
Small and exquisite shape satisfies the diversified demand.
● Noise Canceling
With the CVC6.0 noise canceling technology, you can enjoy the clear music and calls.
● Wide Compatability
The Bluetooth earphones are compatable with all kinds of Bluetooth devices such as mobile phone, ipad and so on.
VITOG T12 come with two color options, black and silver. You can wear them to do your favorite exercise without worry about them falling out: https://gearvita.com/vitog-t12-stere...earphones.html
Related products:
cheap xiaomi airdots headset
cheap lenovo air tws bluetooth earphones
Staro 24.01.2019., 07:14   #125
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
OnePlus Bullets 2T Type-C Earphones - Better Audio with a Built-in DAC
OnePlus Bullets 2T earphones continues the design adopted by the first generation of bullets earphones. The main body of the earphone is made of metal and is sprayed with 205 zircon sand. It is anodized twice to make sure that the earphones have a better texture. The wire makes less easy to knot and wrap and has a wire control function. Aramid fiber is also added to the wire to make it more durable. OnePlus Bullets 2T Earphones has a built-in independent DAC digital decoder, which supports 96KHz/24Bit high-definition audio format, can provide better quality sound from its aluminum alloy sound cavity. The most important thing is that a OnePlus Bullets 2T uses a Type-C interface instead of the traditional 3.5mm headphone jack.
Product Features:
● Crafted a listening experience that's immersive, vibrant, and extraordinarily detailed, thanks to an advanced internal DAC with high-res audio support.
● Fitted with a high-quality film diaphragm that makes voices sound more realistic and immediate.
● The flat-wire cables are tangle-free and threaded with tough Karbon fiber.
● No need to take out your phone every time you want to pause a song or answer a call, that's what the three-button in-line remote control is for.
● The left and right channels reproduce sound independently, reducing noise and capturing each note perfectly.
● By removing the MIC signal from the channels, the quality of your phone calls is significantly improved.
● Traits like temperature resistance and plug durability are all put to the test, and only the earbuds that emerge from the tests in pristine condition are good enough for your ears.
● Perfectly compatible with OnePlus 6T.
The Bullets 2T are extra-lightweight at just 1.8 grams, they're made with an aluminum alloy sound chamber, which does not have any negative sides while greatly reducing cavity resonance which causes distortion of sound: https://gearvita.com/oneplus-bullets...earphones.html
You may also like:
cheap qcy t1c mini wireless earphones
cheap huawei CP60 wireless charger
Staro 25.01.2019., 07:57   #126
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Edifier W2 Wireless Stereo Earphones with Charging Box
Edifier W2 wireless earphones use true wireless technology, wireless interconnection of left and right ears. A new generation of true wireless stereo, binaural calls, left and right ear split design, also can be used alone, easy and convenient.
Product Features:
● Mini But Strong
The shape is smaller and more comfortable than most TWS headphones.
● One-button Operation
Both sides of the headset have multi-function buttons for call and music operation. Both sides of the headset have a omnidirectional microphone port to support noise reduction in the voice call environment, and the call is convenient and clear.
● Special Design
When the earphone is taken out from the charging box, the power is turned on, the left and right earphones are interconnected, and the connected device is automatically connected back, which saves time and worry.
● Bluetooth 5.0
Bluetooth technology upgrade, faster transmission speed, lower power consumption, more than 10 meters of barrier-free transmission distance.
● 12 Hours of Battery Life
The texture charging box, the magnetic card slot, absorbs the stability. The headset lasts for 3 hours, the charging box can be recharged 3 times, that is, an additional 9 hours of battery life, to ensure that every trip is uninterrupted.
● IPX4 Waterproof
Effectively prevent rain and sweat from damaging components.
Edifier W2 is suitable for users who need quality and freedom of movement while listening to their favorite songs: https://gearvita.com/edifier-w2-wire...earphones.html
You may also like:
cheap xiaomi mi mix 3 128gb
cheap xiaomi mi band 3 smart bracelet
Staro 26.01.2019., 08:06   #127
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom BT20 Bluetooth Headset - Both Wireless And Wired Modes
Langsdom BT20 headset is foldable, with an attached audio cable, you can still enjoy favorite music when the battery is flat. Also you can share music with your best friend through line-out audio. The adjustable headset rests gently on your head and rotated ear cups which can rotate more than 180° for a personalized fit. Soft cushions cradle your ears, and all materials are lightweight and built to last. With Bluetooth 4.1, even the maximum volume will not breaking the sound quality, super bass HiFi stereo sound quality output. Built in concealed HD microphone, which is noise canceling, delivers more clear and nature sound. One-Key button to answer or reject the incoming phone calls, free your both hands, safety driving.
Product Features:
● Bluetooth 4.1 technology, super bass HiFi stereo sound quality output.
● Built-in amplifier active automatically improving the sounds details in Bluetooth mode.
● The improved neodymium driver brings high-fidelity stereo sound quality.
● Easy one touch pairing with NFC technology.
● Additional audio line input, for use when battery is low.
● Support both wireless mode and wired mode.
● Built-in microphone enables hands-free calling.
● One-key button to answer or reject the incoming phone calls, free your both hands.
● Leatherette earpad fully isolate external noise.
● Soft earmuffs and adjustable headband for comfort fit and long time wearing.
● Built-in 550mAh rechargeable battery, 120 hours long standby time.
● Foldable design, space-saving, convenient carrying.
After several tune tests, just to better represent the natural soundtrack, so you feel comparable to the quality of wired headphones: https://gearvita.com/langsdom-bt20-w...h-headset.html
Hot sale products:
cheap xiaomi mi pad 4 wifi tablet 64gb
cheap xiaomi minimalist portable flashlight
Staro 28.01.2019., 08:36   #128
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom L9 Neckband Earphones - Magnetic Design, Voice Prompt, 10 Hours Music Time
With light and comfortable fit and performance offering about 10 hours music playback time, the Langsdom L9 neckband earphones are simply mind blowing, perfect for the work environment and for exercise routines. The neckband is made of flexible material, capable of twisting without breakage or split. The magnetic design keeps the earbuds in place when not in use. It is compatible with all Bluetooth devices, support vibration and voice prompt, you will never miss any call.
Product Features:
● Vibration and Voice Prompt
When there's coming call, it will remind you with vibration, you will never miss any phone call when you are doing exercise or even in a noisy place.
● Bluetooth 4.1 Technology
More energy-efficient, stable, and faster transmission speed. Very low standby power consumption and quick pairing.
● Long Distance Transmission
Maximum pairing range can be 33ft, offering you impressive dynamic sound even you are 10 meters away from your device.
● Lightweight Neckband and Magnetic Design
Weighs only 0.25Ib in flexible and durable silicone neckband, allows for a more snug and comfortable fit around your neck, magnetic design can prevent tangles in the cords.
● High Call Resolution
DSP noise canceling technology reduces noise and increases call resolution by 30%, which provides you high-quality sound and clearer voice for calls.
● IPX4 Waterproof
Never worry about accidental water leakage when put it in the bag with improved durability withstanding all sweat, wet weather conditions.
● Ultra Long Battery Life
135mAh battery provides 320 hours standby time, 10 hours playback time and up to 11 hours talk time, charging duration is 30-75 mins.
Top quality material TPU unique around the neck design brings flexible twisting ways, comfortable for all day use: https://gearvita.com/langsdom-l9-nec...earphones.html
Hot sale products:
cheap xiaomi redmi 6a global version
cheap xiaomi mi mix 2s smartphone 128gb
Staro 29.01.2019., 08:45   #129
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom T6 Wireless Bluetooth Earphones with Charging Box
Langsdom T6 wireless Bluetooth earphones design in pumps out the bass and ultra-clear midrange earphones provide a super comfortable noise reducing fit for a fully balanced and ultra-realistic soundstage.
Product Features:
● Lightweight Design
5.2g for single earbud, super light and comfortble fit your ears even after longtime.
● Comfortable And Stable
With silicone earplugs, the earbuds can be firmly secured to your ears and do not easily fall off during work or running.
● Stereo And Monaural Modes
Can be used alone, which is equivalent to two independent Bluetooth headsets, you can share music to someone within 10 meters, or you can enjoy the stereo sound of two headphones.
● Sweat Resistant
IPX4 sweatproof keeps it stay in place during sweaty workouts.
● DSP Digital Noise Reduction Call
Chip built-in DSP, effectively eliminate regular noise, professional EQ adjustment, delivers pure and good sound quality.
● Pairing Faster
Bluetooth V4.2 and EDR technology ensure easy to pair and connect, click the button to get ready for connection.
● One Button Control
One button design, press easily and operate conveniently, easily to answer/hang up calls, play/pause/switch music.
● Portable Charging Box
Charge for one hour provides up to three hours of music time, the charging box can charge the headsets four times and power off when fully charged.
● Automatically Paring And Charging
Turn on and automatically connect to smart devices when removed from the case, turn off and charge when put back in.
This real wireless headset lets you share music or video sounds with someone. No more worries, rebounds, framed or kneaded things. Most importantly, it ensures your safety when driving a car: https://gearvita.com/langsdom-t6-min...rging-box.html
Top sellers on our website:
best lenovo air tws bluetooth earphones
best q50 kids gps smartwatch
Staro 30.01.2019., 07:34   #130
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom L5 Pro Bluetooth Earphone - Up to 10 Hours Playtime
The Langsdom L5 Pro Bluetooth earphone is the update version of L5, it has two shells to balance the weight on both sides, separate Bluetooth module and battery to improve Bluetooth stabilityh. You can use the silicone eartips for more comfortable wearing and anti-fall out. Weight of only 16g, you won't feel its existence when exercise. Built-in magnet, the earbuds will attach each other when not in use. The improved battery ensures up to 10 hours music time, you can get a long music trip.
Product Features:
● Strong Bass
The latest decoding technology and the latest 10M NdFeB unit provide a pure high quality sound similar to a CD.
Bluetooth transmission range up to 33 feet and high compatibility for most devices, such as iPhone, iPad android smartphones, tablets and other bluetooth music devices.
● Powerful Sound
Produces an incredible HiFi stereo sound, frequency of up to 20-20000Hz, can reach high pitch and pick up deep bass easily, suitable for most musical style.
● Secure Fit
Equipped with soft silicone eartips, can not only fit your ears comfortably, also hold the earphones in place during rigorous workouts.
● Lightweight and IPX4 Waterproof
Only weighs 13g, you can not even feel its existence. Ergonomic design for a good fit for the ears, can reduce the effect of the culture effectively. IPX4 waterproof range for water splash and sweat, you can run without any pressure.
● Magnet Design
Aluminum design built with magnet, join the two parts as a necklace when not in use, it is a practical way to carry them.
● 10 Hours Playtime
Fully charged within 1.5 hours, the powerful rechargeable battery provides up to 10 hours playtime, the remaining battery power of the earphones will be displayed on the iOS phone screen.
● HD Calls
CVC 6.0 noise cancellation technology reduces the noise around and offers you a clear conversation experience in HD.
● Multifunctional Button
Easy control for handling phone calls, song change and volume control, you will not miss any phone call and massage.
It is easy to setup and pair, only two steps needed and it is available with two color options: https://gearvita.com/langsdom-l5pro-...-earphone.html
Related products:
best xiaomi airdots headset
best xiaomi lyej05lm mini earphone
Staro 14.02.2019., 11:23   #131
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Meizu Flow Three-driver Hybrid Earphones - Feel Nothing, Hear Everything
Meizu Flow earphones are made in the form factor of internal gagging for good sound insulation, and together with the hybrid design of the Meizu Flow emitters, reproduce sound with a sensitivity of 105dB at 1KHz. The curved shape of the Meizu Flow is made with regard to the anatomical shape of the ear canal, fits perfectly to your ear, which allows you to stay in the headphones for a long time without discomfort.
Product Features:
● Flowing Aesthetic
Producing a texture through wiredrawing, gloss using powder metallurgy, high precision CNC line dissection, creating a liquid aesthetic of light and shadow.
● Three Hybrid Drivers
A high-fidelity dynamic driver to enhance the depth of the bass and two highly sensitive balanced armature drivers to enhance the resolution and layering in mid and high frequencies, accopanied by a specialized frequency dividing circuit, producing balanced multiband audio performance.
● Bass Venting System (BVS)
Customized conduit extends the low frequency response time, utilizing a dynamic driver with improved space, paired with an ingenious curved microfilter to further increased the clarity and dynamic range of the sound.
● Comfort Wearing
Adopting ergonomic design, through countless adjustments, making the curved surface fit perfectly to the ear. The curved arc design ensures stability and comfort so that you can immerse yourself in music and forget that you are even wearing earphones.
● Quality Wire
Quality silver-coated copper wire to ensure a low resistance and high conduction rate across the entire wire. The selected quality MEMS microphone enables outstanding call quality. Using separate microphone and audio wires, to further electrical interference from the wire, guaranteeing authentic sound restoration.
Silicone earplugs, dual layer earplugs, and inert earplugs, the customized airplane jack and portable silica gel case are provided to satisfy your requirements: https://gearvita.com/meizu-flow-hifi...-with-mic.html
Hot sale products:
best xiaomi mi box s tv box global version
best xiaomi mi mix 3 128gb global version
Staro 15.02.2019., 09:00   #132
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Langsdom BX9 Bluetooth Sports Earphone with Magnetic Suction Design
Langsdom BX9 earphone is light to 24g, with skin friendly coatings, comfortable to use. Adopt oblique ear design, eliminated the trouble of falling. Imported Bluetooth chip CSR4.2 keeps the volume at a safe level, and ensures stable connection in all directions within 10 meters. It is equipped with CVC6.0 noise reduction function, provides a perfect shocking sound quality. Adopt IPX5 waterproof design, you do not need to worry about rain and sweat when doing outdoor sports. 150mAh battery capacity provides standby time up to 200 hours to meet your needs.
Product Features:
● 45° Centrifugal Shaft Design
Ergonomic design, 45° will be more fit ears and no easy to fall off.
● Large Capacity Battery
Built-in 150mAh large capacity lithium battery, 10 hours music play time and up to 200 hours super long standby time.
● Natural Sound
Uses 14.2mm composite diaphragm sound unit that the voice will be more pure and better sound quality.
● IPX5 Waterproof
IPX5 water resistance and sweatproof ensure flawless performance when you doing exercise.
● HD Calls
The HD microphone guarantees HD calls when you are in noisy environments.
● Comfortable to Wear
Adaptive soft round neckline, no sense of wearing a full day.
● Voice Command
Answer/reject calls, control music and calls from the headset, easy to operate.
● Automatic Fit
Memory wire automatically maintained in the U-shape.
It is available in three optional colors: black, blue and red: https://gearvita.com/langsdom-bx9-sp...-earphone.html
You may like:
best xiaomi mi pad 4 wifi tablet 64gb
best xiaomi mi pad 4 lte tablet 64gb international version
Staro 18.02.2019., 08:18   #133
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi 2nd Generation Headphone Brings Almost Studio Quality Sound
The Xiaomi 2nd generation headphone sports large earmuffs that are made from soft PU leather and weighs only 240g, so you won't feel discomfort even if you wear it for long periods. High fidelity sound is provided by graphene vibration diaphragm and low frequency passive radiator, make music sounds very clear, even on low and middle frequencies. Enclosed aluminium alloy sound cavity guarantees good separation from ambient noise which helps immerse in music. Thanks to 32ohms impedance and high sensibility driver unit, you can feel almost studio quality sound while wearing the headphone. High sensitive built-in microphone reduces the noise, so you can use it for phone calls, especially that there is song switch and answer calls button.
Product Features:
● Adopted graphene vibration diaphragm and low frequency passive radiator.
● Closed aluminium alloy sound cavity provides high fidelity music.
● 32ohms impedance and high sensibility, easy to drive and no need to connect with headphones amplifier.
● Has functions of voice control, songs switch and answering calls.
● High sensitive built-in microphone reduces the noise, bring a high-quality conversation.
● PU earmuffs and protein headband, more comfortable and soft.
● Detachable design, easy to carry and maintain.
● Switzerland SGS security monitoring guarantees innocuity and no radiation through RoHS, REACH, FCC, CE authentication.
In comparison with the first generation, the 2nd generation headphone is upgraded on every level. It is a bit more expensive than previous model, but given all these advantages over other earphones, it is definitely worth to pay for premium features and Xiaomi quality: https://gearvita.com/xiaomi-tdsej02j...eneration.html
Related products:
honor AM-H1C flypods
VITOG t12 stereo tws
Staro 19.02.2019., 08:20   #134
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Awei X680BL Earphone - IPX4 Waterproof, Intelligent Noise Reduction, 4 Cavity Sound
Awei X680BL earphone is supported by the very stable Bluetooth technology version 4.2, the connection to the device does not break, and the transmitted audio band is not distorted. It is controlled by a modern CSR processor, which intelligently manages the energy of itself, one charge of 1.5 hours lasts 5.5 hours of listening to music or 7 hours of voice talking.
The earphone adopts a flat cable, placed behind the neck and does not interfere with movement. It has a built-in HD microphone, which in combination with the CVC 6.0 technology, eliminates all kinds of noise, achieves HD voice calls. The remote makes it easy to control the music being played or the conversation, it has buttons to change the song/sound volume, and the play/pause button, which is also used to accept and end voice calls.
The whole is finished with a very elegant plastic, pleasant to touch and does not crack at the pressure of the finger, the transparent front of the casing looks very impressive. In addition, mounted magnets with opposite poles, allows the connection of two earpieces, so that it will not slip off your neck when not in use. It is also worth mentioning the 3D sound technology, which was created thanks to the use of independent composite membranes. The diaphragms work independently, for two separate units, the first is responsible for deep bass, and the second is responsible for the treble.
Product Features:
● Built-in 6mm dual dynamic quad-core driver unit, creates HD stereo surround sound and lossless music.
● Bluetooth 4.2 CSR technology pairs with most phones, laptops and tablets with a range of 10 meters.
● Multi-point pairing function enables connecting two phones at the same time and intelligently switching between them.
● Comfortable ergonomic in-ear design with soft silicone ear tips for comfortable wearing.
● Magnetic design lets you connect the earpieces together whenever you are not using them.
● CVC intelligent noise redution helps reduce background noise significantly.
● 90mA/3.7V long life lithium batteries brings up to 7 hours working time or 200 hours of standby time after only 1.5 hours of charging.
● Sweat-resistant and splash-proof IPX4 level prevent the headphones from sweat or light rain while running, jogging and gyming.
Wearing this earphone, you can enjoy the immersive feeling brought by it without feeling uncomfortable, and won't oppress the ear canal and ear for a long time: https://gearvita.com/awei-x680bl-spo...aterproof.html
Hot sale products:
honor band 4
xiaomi airdots
Staro 20.02.2019., 08:01   #135
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi AI Portable Wireless Bluetooth Speaker - One-key AI Activation, Powerful Bass
The Xiaomi AI portable Bluetooth speaker uses DRC technology to provide a rich sound output with a dynamic sound compression algorithm, delivers a cleaner sound with no distortion and adequate bass. The speaker comes with voice assistance feature powered by XiaoAI, offers useful functions such as weather forecast, establishing a telephone connection to someone on the contact list. The speaker is an affordable companion with robust sound output capable of prolonged music playback. Thanks to its 480mAh battery, the speaker boasts of 45 days standby time and 4 hours of music playback. It can also be used to receive calls via a connected smartphone.
Product Features:
● Light and Exquisite, Compact and Portable
Weighing 52g, only one egg size and weight, can be easily carried on the palm of the hand, or be hung with the lanyard.
● One-click Activation of XiaoAi
Short press or long press the voice activation button at the bottom of the speaker to easily activate the AI speaker, achieves intelligent voice control.
● Powerful Bass
With a small diameter large magnetic circiut design, the low-frequency dive is better, and the bass performance is strong. With the DRC dynamic compression algorithm, the sound is bright and undistorted.
● Handsfree Call
Built-in microphone, call without a mobile phone by simply pressing the bottom voice activation button.
● High Speed Bluetooth Wireless Transmission
Supports Bluetooth 4.2, which is conncted with high speed stability and strong anto-interference ability, can easily connect mobile phones, computets, TVs and other equipments.
● Long Battery Life
With 480mAh lithium battery, it can play for 4 hours continuously, ensuring stable high-quality music output whether it is outdoors or indoors. In standby mode, standby can be up to 45 days.
● Visible Quality
The top sound hole is designed with reference to the Fibonacci spiral, making the sound line seem visible. The whole material is ABS + PC material, which is not easy to change color and is not easy to be scratched.
With muti-language support and waterproof built, the Xiaomi AI Bluetooth speaker bring a shocking listening experience by its petite figure and the ultra-high volume of stable output: https://gearvita.com/xiaomi-ai-porta...l-version.html
You may also like:
xiaomi mini subwoofer bluetooth speaker
xiaomi mi airdots pro
Staro 21.02.2019., 08:37   #136
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
AWEI AK5 Sports Bluetooth Earphone - Magnetic Intelligent Switch, IPX4 Waterproof
The Awei AK5 Bluetooth earphone uses 6mm copper ring coils, strong rubidium boron magnets and high class carbon fiber diaphragms, deliver deep low frequency, solid medium frequency, more abundant high frequency details. Vacuum ear cushions gently sit in the auricle and do not press under prolonged use, durable flat cable does not interfere with movements. Magic magnet attraction design makes you no need to worry about it would slid down. Built-in microphone, you can receive calls without interrupting your favorite business, the microphone transmits high-quality sound without interference and noise. With the long battery life, it can play music for 10 hours, and calling for 12 hours. Thanks to its IPX4 waterproof performance, you are able to enjoy sports with passion, no fear of sweat and rain.
Product Features:
● Multiple Process Metal Appearance
Popular metal materials through anodizing, Seiko sandblasting, CNC cutting and other processes create deep polished fashion earphones.
● Enthusiasts Class Sound Quality
6mm metal strong magnetic unit, 92dB ± 3dB high sensitivity of the horn, super bass, clear high frequency, HD music strong explosive, bilateral surround cavity structure gives the ears of 360° surround stereo sound effect.
Food-grade silicone ear caps and fit to human ear contour line's shark fin ear hook, snug and secure, effectively enhance the wearing stability.
● Magnet Attraction Design
Gently absorb or separate to turn the earphones on/off, abandon traditional button, novel and simple. Connect two earphones easily, hanging on neck like a necklace when not in use, avoid loss.
● Fast Connection
With Bluetooth 4.1 technology is faster than other devices, the transmission distance is up to 10m, perfect compatibility with all Bluetooth devices.
● Intelligent Connection
Supports connect two phones simultaneously, and automatically connects after being paired successfully for the first time.
● CVC Noise Reduction
Automatic noise reduction function effectively reduces the noise of the call environment, provides high-definition call quality even on the street or inside shopping mall.
● On-ear Control
Intuitive and easy controls for freely switching and pausing/playing songs, the built-in mic for effortless call handling, avoid removing earphones from ears or dealing with tangles wires.
● Long Battery Life
Dual battery innovative design, built-in 2 × 65mAh li-ion battery, offers 10 hours of playing time and up to 240 hours standby time with a full charge in around 2 hours. If connected with iPhone, the residual electricity can be displayed in iOS system, convenient for you to charge im time.
● IPX4 Waterproof
Through IPX4 waterproof Khan test, suitable for different exercise environments, whether it's sweaty in the gym or cloudy and rainy, the outdoor long-distance race.
Awei AK5 earphone is perfect sport earphone provides pure stereo sound and powerful bass, the stylish look is sure to suit everyone. Let the beautiful music silkily fall in ears and keep in memories: https://gearvita.com/awei-ak5-sports...-earphone.html
You may also interested in:
mi box s
xiaomi mi a2 lite global version
Staro 25.02.2019., 09:32   #137
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
AWEI AK9 Wireless Bluetooth Earphone - Intelligent Magnetic Switch, 10 Hours Playtime
AWEI AK9 wireless earphone adopts intelligent magnetic switch design, built-in Hall switch, separation and absorption for automatic power on/off, without any button operation. Bluetooth 4.1 enables the headset to pair with smartphones instantly, and can connect with two Bluetooth devices at the same time. Ergonomic design makes it comfortable to wear for a long time, the shark fin ear hook that fit to human ear contour line's make sure the headset steadily. CVC6.0 intelligent noise cancelling reduces outside noises, provides perfect shocking sound quality. With IPX4 waterproof and sweatproof design, it is the best choice when you doing sports or running.
Product Features:
● Full metal body, deep anodizing process. Magnesium-aluminum alloy body with CNC diamond cutting process, wear-resistant and anti-corrosion.
● Built-in magnet switch, headset can be automatically on/off when the are magnet separate/attract, no need any key operation.
● Built-in magnets makes the two earphones attached together when not using, can be worn like a necklace around neck, convenient to carry.
● Bluetooth 4.1 technology, easy and fast pairing with smartphones, tablets, and other Bluetooth enabled music devices.
● Can connect with two bluetooth devices at the same time, and automatically connects after being paired successfully for the first time.
● CSR4.1 audio decode technology, offers perfect sound.
● CVC6.0 intelligent noise cancelling, provides clearer microphone sound.
● Vibration alert on incoming call, allows you answer the phone anytime and anywhere.
● Voice command for picking up/rejecting calls.
● Calls hands-free, drive travel more at ease, so you can enjoy your driving.
● Dual battery 130mAh capacity, 10 hours play time with full charge.
● Support iOS system power display, know the remaining power at any time.
● IPX4 waterproof technology, which prevented sweat, rain or water from permeating electrical components.
Multicolors as options, colorful and fashionable, the active appearance delivers irresistible beauty: https://gearvita.com/awei-ak9-wirele...-earphone.html
Related products:
airdots pro
qcy t1c
Staro 26.02.2019., 08:43   #138
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
QCY T1S Mini TWS Earphones - Bluetooth 5.0, Auto Pairing, Stereo Talking
QCY T1S Bluetooth earphones support high-sensitive Bluetooth 5.0, have stronger and quicker voice transmission. Feel free to enjoy natural and beautiful songs at anywhere anytime, no problem of wire can truly free your hands. Powerful connection, auto-pairing design, and ergonomic earbuds, also provide you with simple and comfortable experience.
Product Features:
● Automatic Connection And Pairing
Pick up the earbuds from the charging box, they will automatic power on, pair with each other, and instantly connect with your phone.
● Bluetooth V5.0 Technology
Sound transmission speed is twice higher, the anti-interference performance is enhanced and the connection is more stable, to make sure each calling and game-playing is in real time, avoid sound delays.
● Dynamic HiFi Sound Quality
Bluetooth 5.0 chip with codec supports AAC/SBC, reveals original sound. Boast with 6mm dynamic driver, to play the qualitative HiFi sound.
● Excellent Call Experience
Binaural call supplemented by noice isolation and enviroment monitoring in stereo mode, delivers clear and efficient talking.
● Lightweight and Comfortable
4.6g small like the fingertips, invisible to wear. Ergonomically designed, exactly fits the contours of the ears, no tenderness over hours wearing.
● Flexible Switching Between Single and Double Earbuds
The two earbuds can be used together or separately, you can connect dual earbuds to listen to music, or connect the single earbud while driving. The two earbuds can also be connected to two different mobile phones, which is equivalent to two independent mini Bluetooth earbuds, use it the way you want.
● Long Working Time
Small charging case built inside a 800mAh battery which can recharge the earbuds for 8 times, supposed to work for 32 hours after full charge.
● Low Battery Reminder
When the charging box is low, the indicator light flashes 5 times every 20 seconds, indicating that the charging box is in a low battery state.
● IPX4 Waterproof
Pass the life-grade waterproof and nano-scale anti-sweat test, support for outdoor sports in rainy days, without hindering the enthusiasm of the gym.
The T1S is an upgraded version of the T1C, it comes with a clamshell magnetic charging box, strong magnetic adsorption to charge, and portable storage will not fall: https://gearvita.com/qcy-t1s-mini-tw...tooth-5-0.html
Related products:
qcy t1c mini
vitog t12
Staro 27.02.2019., 09:02   #139
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Sabbat E12 Wireless Bluetooth Earbuds - Let The Music Return to The Essence
The Sabbat E12 Bluetooth earbuds is designed with an infinite charging box, automatic matching after being removed from the charging box. It is equipped with Bluetooth 5.0 technology, ensures powerful Bluetooth signal. The ergonomic in-ear design and comes standard with 7 pairs of ear caps, make the earbuds perfectly fit with ears. It adopts heavy metal plating process, delivers distinctive high-level feeling. Supports bilateral call, the call sound quality is more clear and natural. One-click voice access makes life faster and easier, 32 hours battery life lets you continuously enjoy the fun of music.
Product Features:
● Auto Pairing
When taken out of the charging box, the pairing between two earbuds is successful.
● Electroplating Process
The panel is made of electroplating technology, the metal texture is strong, the touch is delicate and smooth.
● Hi-Res Certification Chip
Adopts 10mm moving coil horn with bio-fiber paper film, and cavity structure after repeated experimentation, tri-band equalization. The chip supports Hi-Res certification, allows you to get the real atmosphere of the original singer or performer's performances.
● Bluetooth 5.0
Subversive technology improvements, faster transmission speeds and longer transmission distances.
● Smart Noise Reduction
4 microphone noise reduction technology for clear call and music sound quality, 10mm high-end speaker can adequately filter the background noise.
● One-click Voice Access
Whether it's driving or everyday life, or running to relax, voice commands make everything easy, with one-click access to Siri, you can use it anywhere in your life.
● In-ear Fit Auricle Design
Compact and lightweight, ergonomic design that fits the auricle, wearing for a long time does not cause pain.
● Charge and Store
Place them back to the box directly after each use, the earbuds will power off and recharge automatically.
Three colors for choice, to create an unique experience exclusive to you: https://gearvita.com/sabbat-e12-tws-...tooth-5-0.html
You may also like:
xiaomi wireless keyboard
samsung evo plus
Staro 28.02.2019., 08:56   #140
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Sabbat X12 Pro Wireless Earphones - Ten Dreamy Colors for Choice
Sabbat X12 Pro wireless earphones use the latest Bluetooth 5.0 chip, which has faster transmission speed and more stable signal, the transmission distance is increased to 15 meters. The chip supports HD binaural stereo calls, making higher quality voice calls. Thanks to the 750mAh charging box that holds multiple additional charges, so that you can enjoy more than 30 hours of listening time. Take the earbuds out from the charging box, they will automatically turn on and connect. According to the design of the auricle of the human body, the depth fits the ear canal, more comfortable and fit to the ear. Sabbat X12 Pro is IPX5 waterproof, you can wear them to do whatever you want. Other convenient and practical functions are such as connecting with Siri and displaying remaining battery on the phone.
Product Features:
● Bluetooth 5.0 Technology
More stable signal, faster transmission, not stuck, no delay, and less power consumption.
● 30 Hours Duration with Charging Box
Earbuds battery capacity is 60mAh, with 750mAh charging case, which can charge 4 times for the earbuds. Charging time only 1 hour, the playing time can up to 6-8 hours, usage time is longer.
● Simple Touch Operation
Single press to play/pause music, answer or hang up a call, double click to turn up/down volume, triple click for last/next track.
● Easy Access to Siri
Access to Siri by double clicking the function button.
Pull the earbuds out of the charging case, they automatically turn on and connect to your device.
● Double Noise Cancelling Technology
Adopts DSP and CVC noise cancelling technology to effectively reduce the noise of wind and environment, let you enjoy the HiFi music in the quiet condition.
● Mono/Stereo Mode
Support binaural calls, the two earbuds can be used together or separately, you can share the same music/movie with your friends or enjoy the clear stereo sound by using both earbuds.
● Chinese/English Free Switching
Support incoming call number broadcasting, with free switching between English and Chinese, enhances driving safety.
● Comfortable Fit
Adopting ergonomic design, the earbuds fit perfectly in your ear for great comfort, and they will stay in place without falling off.
● IPX5 Waterproof
Suitable for any occasion whether you are showering, swimming, exercising or just out and about.
With the water transfer dyeing process, the patterns and colors of the earbuds will be different, creating the unique color of each pair of earbuds. Ten dreamy colors, with your favorite music, instantly immersed in the situation and listen to everything: https://gearvita.com/sabbat-x12-pro-...earphones.html
Hot sale products on our website:
xiaomi poco f1 lte 64gb
mini subwoofer
Staro 01.03.2019., 08:50   #141
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Syllable HBQ-Q13S TWS Earphones - HiFi Stereo, Mini Invisible
Syllable HBQ-Q13S wireless earphones adopt mini and ergonomical design featured with mini size and light weight, comfortable to wear, you will not feeling the burden even wearing for long time. HBQ-Q13S supports multi-point pairing, two headsets can be connected to a single device, also can connect two Bluetooth devices at the same time. Noise cancellation function can improve talking quality significantly and offer a superior sound quality in talking and music. Multifunctional switching operation such as answer/hang up, play/pause and power on/off can be achieved by one button. The battery capacity is 60mAh, which provides up to 5 hours talking/playing time and 120 hours standby time. 600mAh charging box with magnetic charging interface, can recharge the earbuds for 4 times.
Product Features:
● Easily pair with the universal Bluetooth-enabled device.
● Built-in noise-reducing microphone.
● One button to answer/hang up/reject calls and redial the last number dialed.
● Automatic voice prompt including incoming phone number report
● Each earbud can be used alone with full functionality.
● Share your favorite tunes with friend anytime anywhere by sharing the earbuds.
● A single earpiece weighs no more than 4 grams, with a maximum diameter of the size of a coin.
● Charging dock for convenient charging and storage.
● Metal composite diaphragm and unique cabity design, for professional tuning tri-band equalization.
● IPX5 waterproof, no fear of sweat and rain during exercise.
Binaural wireless design, farewell to the troublesome wires, enjoy your travel with this earphones: https://gearvita.com/syllable-hbq-q1...ooth-v5-0.html
You may also like:
raspberry pi 3 a+
redmi 6a
Staro 02.03.2019., 07:47   #142
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Syllable Q3 Gunner Wireless Gaming Earphone - Innovative Dual Mode, 3 Tone Adjustment
Syllable Q3 Gunner wireless gaming earphone adopts independent dual software and built-in 10mm speaker which makes sound in the game much clearer, so you can easily distinguish the enemy direction. Special surround sound creates a stereo-sound field for the game and gives you a fully immersive experience.
Product Features:
● High-Performance Chip and Great Compatibility
Equipped with Bluetooth V4.2 chip, quickly and easily pair with any Bluetooth devices at a distance up to 10m range, compatible with most Bluetooth-enabled devices.
● High Fidelity, Delicate Soundtrack
Customized dynamic drive unit for powerful low frequency response, rich vocal detail and realistic sound reproduction.
● Easy to Control
Both the gaming and chatting volume can be controlled via only 3 buttons on the headset, you just need to adjust the mode you want before the game.
100mAh Li-ion battery brings more than 6 hours gaming time with a quick charge of only 2 hours.
● Display Power in Real Time
As the earphone power is displayed in real time, so the usage is clear.
● Game Mode and Music Mode
Innovative dual modes make you fully enjoy the pleasure while playing games or listening to music. Simultaneously press the power button and "+" button can switch from default music mode to game mode. In the game mode, the effects of gunshots and footsteps strengthening bring you a more real smooth gaming experience. Short-press "+" and "-" buttons simultaneously can reset the earphone to the initial music mode.
● 3 Tone Adjustment
Freely switch standard EQ tone, bass weakening, and treble weakening mode by pressing "-" and multi-function bution simultaneously, music mode(48 bits) provides a HiFi original sound quality, supports Apt-X.
● Neckband and Magnetic Design
Silicon neckband and ergonomic in-ear design, multi-size accessories are nicely and softly padded to make it comfortable to wear even after long period of gaming. Earphone magnetically clip can absorb together and be hung around your neck for easy, tangle-free use.
Syllable Q3 Gunner is a perfect companion for music and game. The innovative dual mode design with 3 tone adjustment allows you to fully enjoy the pleasure while playing games or listening to music: https://gearvita.com/syllable-q3-gun...-earphone.html
Recommended hot sale products:
xiaomi portable flashlight
xiaomi mi pad 4 tablet pc
Staro 04.03.2019., 08:19   #143
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Baseus D02 Foldable Wireless Headphone Presents More Beautiful Sound to You
Baseus D02 foldable wireless headphone adopts silicon headband and round smooth appearance design, trendy in terms of trends. Lightweight soft protein leather fits ears, comfortable to wear, no pain even after wearing for a long time. It is able to adjust and rotate to fit for different shapes of head to wear, also can be folded into the size of a palm for convenient carry. The 450mAh battery offers a performance of 25 hours of operation and up to 300 hours standby with full charged via USB in 1.5 hours. If ever the battery is run out, you can keep using the headphone by pluging a 3.5mm aux-in cable. The Baseus D02 Bluetooth wireless headphone supports hands-free call thanks to the integrated microphone, you can answer incoming calls on your phone without stopping what you are doing.
Product Features:
● Simple and Plain
Round and smooth appearance design with simple color matching as black and white, clean and pure appearance.
● Foldable Design
Able to adjust and rotate to fit for different shapes of head to wear Can be folded into the size of a palm with the spindle design.
Lightweight, soft protein leather to fit ears silicon headband to protect your head, adopting ergonomic design to cover your ears and make sure your ears do not get hurt after long-time wearing, the headphone will not easy to fall off when jogging.
● Enjoy Powerful and Passionate Music
Adopting double composite membrane to design the speaker, it will be more shocking when you listen to rock and roll DJ, and delicate pop music.
● Big Battery Capacity
Polymer battery with a big capacity of 450mAh, listen to 350 songs by charging once, 300 hours standby time.
● Turn into A Wired Headphone in A Second
Plug a 3.5mm aux-in cable into the headphone 3.5mm port, switch to the wired mode at any time.
● 360° Microphone Accurately Catches The Sound
No matter which direction your mouth is pointing to, accurately catch your voice information and guarantee a clear and high-fidelity phone call.
● Easy to Operate
Music mode and talking mode can be adjusted by the buttons.
Baseus Encok team invited many music and headphone lovers to experience the product after the headphone was finalized, long-time audition and continuous sound tuning and improvement were made, a more beautiful and great sound was finally presented to you: https://gearvita.com/baseus-d02-fold...tooth-5-0.html
Related products:
qcy t1s
mi airdots pro
Staro 05.03.2019., 07:33   #144
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Flydigi Stinger Game Trigger - Long Press Continuous Click, Mouse Button Touch Feel
This Xiaomi Youpin Flydigi Stinger game trigger has the ability to either send a single touch response or multitouch response to the game (turbo fire/rapid fire). In a game like using guns, its definitely useful when you are using a AK47 with rapid fire than using it on single touch to take your enemy down. You can switch the button response to single or multi at the back and the multitouch will respond up to 8x, meaning it can fire 8 times in a single touch. But in a game of basketball like the NBA 2k19, you wont want to do the rappid fire as you can only release the ball once you get off the ground.
Product Features:
● Adopts the unique capacitance spacer mapping technology, which can achieve instantaneous response without failure.
● One-key switch between normal mode and continuous click mode.
● In the continuous click mode, long press the trigger button can achieve high-frequency continuous click, 8 times per second.
● Unique tensile structure for stable and convenient grip, with a better feel.
● Short key range of mouse-level microswitch, highly sensitive and responsive.
● A physical connection, common to iOS and Android systems.
● Using a stable stretch structure, lined with rubber anti-skid pad, clamped tightly with the mobile phone.
● The inside slot is designed to reserve space for volume keys and lock screen keys to avoid accidental touch.
● Maximum thickness support is 9mm, maximum stretch support is 82mm.
● Use time 80 hours with a full charging time of 1.5 hours.
Flydigi Stinger is designed for a more user-friendly experience, you don't have to take off your phone case when using it. Also, connection and control sensitivity will not be affected by screen protectors either: https://gearvita.com/xiaomi-youpin-f...e-trigger.html
Other good products worth buying:
xiaomi mi portable mouse
xiaomi redmi 6 pro 64gb
Staro 06.03.2019., 08:59   #145
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Flydigi X8 Pro Game Controller - Double Wireless Modes, All Platform Adaptation
Are you looking for a titanic gamepad capable of supporting wireless connection with a variety of smart devices? Flydigi X8 Pro game controller is a more than interesting alternative for those looking to play on smartphones with the game comfort offered by a gamepad with 2 joysticks, button mapping, crosshead and triggers.
Making use of the integrated Bluetooth 4.0 connection, you can pair your Android or iOS phone to play the catalog of the device available in the store, placing the mobile in the removable and folding support that includes the package to turn it into a portable console. By including a 2.4G USB Dongle receiver, the remote also supports wireless connection to Windows computers, tablets, smart TV and Android TV.
From mobile to tablet, from tablet to computer, so comfortable and practical. You can play on the bus with your mobile, play big on a smart TV or play the PC catalog with a single command. The correctly optimized 300mAh battery offers up to 80 hours of play with a full charge. As professional competition controller, less than 6ms delay, the Flydigi X8 Pro features high sensitivity and accuracy in overall performance.
Product Features:
● Wireless Transmission
Compatible with Android 4.4 or above devices and Window 7 or above PC, connected by Bluetooth 4.0 or 2.4GHz wireless USB receiver dongle.
● Motion Sensing Aiming
Built-in 6-axis gyroscope acceleration chip provides great motion sensing control and enables air mouse mode.
● Flymapping Button Mapping Technology
Flymapping function is developed based on button mapping technology, enables you drag button to adjust button position, makes the experience more smooth and convenient. Describe 120 points of high speed mapping per second, quick response to small changes of stick angle.
● Flydigi Utool
No need root for Android phone, with the included Flydigi Utool, connecting the power for 10 seconds to activate button mapping. Then you can play any mobile games with controllers.
● More Buttons
Has 3 function buttons more than other normal controllers, left and right triggers are used with mouse microswitch, enable you get higher shooting speed in FPS games.
● Dual-vibration Motors
The left and right grips adopt built-in asymmetric motors and using Japanese ALPS rocker, more realistic vibration feedback can be easily and fully experienced in racing, sports, shooting and other games.
● Battery Power
Equipped with Nordic 32bit Bluetooth chip, special for esports keyboard and mouse. Switch seamlessly between Bluetooth 4.0 low power mode and 2.4G wireless mode, the delay is less than 6ms and the built-in 300mAh polymer lithium battery lasts for 80 hours in normal condition.
● Ergonomic Design
Comfortable and exquisite stripe texture on the surface, anti-sweat, anti-slide, with better hand feel.
This Flydigi X8 Pro Bluetooth wireless joystick gamepad is designed to bring you brand new gaming experience. The detachable bracket makes installation more easier and reduce the head weight which make it comfortable to play games and it is widely compatible with 3.5~6.8 inch Android smartphones: https://gearvita.com/xiaomi-flydigi-...ontroller.html
lenovo k5 pro
xiaomi mini flashlight
Staro 07.03.2019., 08:15   #146
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Youpin Bluetooth Vinyl Player with Professional Debugging Capability
The Xiaomi Youpin Bluetooth vinyl player has a broadcast and release feature which eliminates the traditional complex configuration. In addition, the phonograph optimizes the complex configuration of the vinyl playback system, ensures simple and easy to use. It uses an original triangular magnetic pickup which allows you to use this player for a considerable long period of time and comes with a professional debugging ability which ensures there is little or no record loss since most of the music plates will be pretty old. Its excellent seismic performance and stable needle pressure further deliver a good and clear sound.
The player comes with its own portable speaker in the front which produces good sound. Also, it supports Bluetooth connection, thus the player can switch between Bluetooth mode and ordinary mode, you can use the speaker of this device to play music on your mobile phone via Bluetooth. Interestingly the phono arm can be locked when the phonograph is not working.
Product Features:
● Using the original triangle MM magnetic pickup, cost-effective, quality assurance and longer life.
● The volume is small, but the sound quality is not inferior, dynamic and sound field are powerful.
● Professional debugging, reducing record less, excellent seismic performance, stable needle pressure.
● Equipped with a pair of high-quality sound units, dynamic and vocal expression.
● Metal texture, conveying modern aesthetics.
● Digital music Bluetooth connection, switches the Bluetooth mode with one button and connects playback device.
● The phono arm can be locked when the phonograph is not working, and the material is good.
● Control the hydraulic lifting device of the phono arm, which has a comfortable damping and excellent hand feeling, and at the same time protects the stylus and the record.
● Wool disc pad, maximize the protection of vinyl records.
● When the function knob is turned on, the turntable will automatically start and stop with the position of the arm, convenient for operation.
The Xiaomi Bluetooth vinyl player promises to bring your home the classical music of vinyl records with a high fidelity and a modern way. Just close your eyes, feel the texture of vinyl, the sound quality of which is closer to the original sound in all media: https://gearvita.com/xiaomi-youpin-t...yl-player.html
High cost-effective products:
meizu pop wireless earphones
xiaomi mi pad 4
Staro 08.03.2019., 08:20   #147
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
X8 TWS Bluetooth Earbuds with 5D Stereo Sound
X8 wireless earbuds are true wireless Bluetooth 5D stereo headsets with touch function, easy to use, you will never worry about wire tangles while wearing them. Adopting Bluetooth 5.0 technology, which with faster pairing, lower power consumption and more stable signal, the earbuds widely compatible with all Bluetooth-enabled devices and can be connected to two mobile phones at the same time. 10 meters barrier-free transmission, even the mobile phone away from your hand, music is still with you.
Coming with a charging box, which is slim enough to be held in your hand, portable to carry. With the 2200mAh big capacity, apart from charging the earbuds about 25 times, the charging box can even be used as a power bank to power up your mobile in an emergency. There is an indicator light on the charging box, it turns on red when charging and turns on blue when fully charged.
The earbuds will automatically pair and power on after being taken out from the charging box. Once restarted, they can be connected to the phone automatically after the first connection. Left and right channel seperation, the earbuds can be used independently or paired to enjoy wireless stereo.
With CVC8.0 and DSP noise reduction technology, the earbuds automatically filtering the noise from the surroundings. Aided by the sensitive pickups, high-definition microphone, and bilateral call function, facilitates your communications clearly, even in the noisiest of industrial settings. Thanks to the support of Siri, the X8 also features intelligent Chinese and English voice prompts .
One button operation, you can achieve music switch, answer/reject calls, power on/off, music play/pause, volume +/-, Siri control without the need of watching your smartphone.
The X8 earbud provide a high-performance sound with striking bass, you can have a rich and dynamic stereo experience anywhere, anytime: https://gearvita.com/x8-tws-bluetooth-5-0-earbuds.html
Other hot selling TWS wireless earbuds:
mi airdots pro
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 12.03.2019., 08:34   #148
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Flydigi Q1 Converter Turns Keyboard And Mouse into Mobile Game Control Handle
Flydigi Q1 mobile game mouse keyboard converter is developed to make you play thousands of games even the game doesn't support controller before. Flydigi gamepad assistant has a Flymapping feature, which is developed based on button mapping technology, you can drag buttons to adjust custom configuration on any Android games. The App describes 120 points of high speed mapping per second, quick response to small changes of controller, enables you customize the button settings to make the experience more smooth and convenient.
Product Features:
● 120 Frames Per Second High-speed Mapping
Flymapping keypad cloud mapping can simulate 120 screen clicks per second, to achieve faster response and high smoothness of operation.
● Bluetooth 4.0 BLE Connection
Connects with the mobile phone through Bluetooth 4.0 BLE low power technology, stable and smooth without any sense of delay.
● Double USB Ports
Dual USB port connection, fully compatible with various types keyboards and mouses.
● Support Mouse 7 Buttons
Mapping support of the mouse's two side keys and rollers makes releasing skills faster and gives you a head start in a minute-by-minute battle.
● Preset Key Position And Able to Be Customized Adjust
Preset standard key position for the major shooting mobile game, so that you can quickly get started, but also free to adjust the key.
● Mouse Algorithm Optimization
Different from the floating mouse experience, does a careful optimization to mouse algorithm, copy the end of the mouse feel, head sniper, pressure gunfire easily enjoyable.
● Flymagic Interface
The second USB is a Flymagic interface, the Android device can automatically recognize and activate the mapping (the Apple device does not need to be activated), start better game experience.
● Directly Connected The Power Supply
Directly connected to the power supply, let you enjoy long hours play without worry about the power.
Sized in 64 × 60 × 15mm, the converter is portable and you can take it anywhere as you go. The included mobile phone holder is adjustable in multiple gears, so you can choose the comfortable viewing angle: https://gearvita.com/xiaomi-youpin-f...converter.html
Other cost effective products:
xiaomi redmi go 8gb
microwear l5
Staro 13.03.2019., 09:19   #149
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
CoolBaby RS-07 Retro Handheld Games Console Take You Back to Childhood Memory
The CoolBaby RS-07 retro handheld games console has a classic arcade game machine appearance design, recalls your childhood memory. Built-in 3000 top ten simulator games, take you back to that memory, offers you great happiness during leisure time. It is equipped with a 4.3 inch HD color display paired with a 2200mAh battery, capable of delivering working time of 5 hours.
Product Features:
● 4.3 inch high-definition color screen, resolution is 480 × 272.
● Dual core 528MHz CPU, DDR2 128M, 16GB memory, support TF card expansion up to 32GB.
● External 18650 2200mAh lithium battery, 5 hours battery life.
● Ten simulators support for top ten game formats, shift value game/Arcade CP1/CP2/NEOGEO/GBA/SFC/MD/FC/GBC/GB.
● Support for 26 languages, including Chinese simplified, Chinese traditional, English, Japanese, Korean, etc.
● Lossless music APE, MP3, WMA, DRMWMA and other formats of audio, high quality speaker, support 3.5mm stereo headphones.
● External two wired handles, USB interface, support the game console as the host to connect the handle, also possible to connect to the TV.
● Energy saving settings, display and free settings of various function attributes such as display brightness and interface background.
● High quality rocker, high rebound button, precise interface.
With the retro arcade game machine appearance design, mini and portable volume, the RS-07 will recover your childhood memory: https://gearvita.com/coolbaby-rs-07-...s-console.html
You may also like:
lenovo air earphones
xiaomi tdsej02jy
Staro 14.03.2019., 08:59   #150
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
M6S TWS Bluetooth Earphones - Bluetooth 5.0, Binaural Call, HiFi Sound
M6S wireless Bluetooth earphones are equipped with one-step paring technology, which makes them easy and fast to connect. They automatically turn on and are available to be paired with your smart phone when removed from the case, automatically turn off and charge when put back in the case. Bluetooth 5.0 and HD rendering technology, producing incredible high quality sound with deep bass. Adopts CVC6.0 noise cancellation technology, reducing ambient noise and echo, ensures sound clarity. Built-in high-quality audio chip, upgraded super balanced bass and premium vibrating diaphragm technology, making you feel personally on the scene of music.
The earphones can be can be used in pairs or separately to connect with two devices at the same time. The headset does not have complicated buttons, all functions in a touch key, the operation is more simple and convenient. Intuitive gesture controls allows you to listen to music, answer phone calls or wake up the voice assistant on the go without worry of wire entanglement.
Product Features:
● The battery uses pure drill core, stable power release and reliable performance.
● Equipped with Bluetooth v5.0 technology, the sound transmission speed is twice higher, the anti-interference performance is enhanced and the connection is more stable, to make sure each calling and game-playing is in real time, avoid sound delays.
● After the first time pairing, automatic storing Bluetooth info, and auto pairing next time.
● Single use time is 6-7 hours, used in conjunction with the 400mAh capacity charging case which can power the earphones for about 5 times, continuous playback can last up to 30 hours.
● Adopt CVC echo noise reduction technology to effectively filter environmental noise and HD call, delivers pure and natural sound quality.
● One-button multi-control design, all functions can be controlled with one click, easy to operate.
● Double click the function button to wake up the voice assistant, voice commands provide the greatest convenience.
● Binaural separation design, earphones can be used independently, and two devices can be connected at the same time to meet the needs of many users.
● IPX6 grade waterproof and anti-sweat design, easily cope with all kinds of life scenes, exercise and fitness, without fear of sweat and rain.
M6S features a stylish streamlined design, comes in two classic colors, lightweight and comfortable. Ergonomically designed, the earbuds exactly fit the contours of the ears, and there is no tenderness over hours wearing: https://gearvita.com/m6s-sports-runn...earphones.html
Related products:
qcy t1s
