Staro 21.01.2014., 03:03   #121
Manuel2
Postovi: 10
Svaka čast mkos ali ja svog thompsona na iskonu ne mogu namjestit da radi ppoe. Prepisao sve u user.ini ali onda kaze u ruterovim postackama da je spojen na internet no nema internet pristupa na nijednom računalu spojenog na njega. Jel mozes mozda poslat svoj cijeli user.ini (izbrisi pass)
Manuel2 je offline   Reply With Quote
Staro 21.01.2014., 13:15   #122
Prezime
Datum registracije: Aug 2013
Postovi: 4,357
Ako je router spojen na internet, onda je dobro konfiguriran, a pristup sa kompovima kroz njega na internet, trebas rijesit na kompovima...
Staro 31.01.2014., 21:38   #123
konig_karl
lurkerus maximus
Datum registracije: Aug 2008
Lokacija: V.G.
Postovi: 91
Autor Prezime Pregled postova
ova patnja s bridge modom za carnetovce postaje povijest
http://www.carnet.hr/novosti/novosti?news_id=3007
hint: zavirite na iskonove korisnicke stranice i tamo unesite podatke od carneta
CPU: AMD Athlon II x4 640
MBO: ASrock 870 Extreme3
RAM: 2x Corsair 2gb DDR3 (1333Mhz)
HDD: WD5000AAKS
VGA: Point of view GeForce GTX 460 768Mb
PSU: Corsair CX400W
Case: NZXT Source 210
Monitor: LG M2262D (22", 1920:1080)
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
CPU: C2D T450 1.66 GHz
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Samsung HD502IJ@IcyBox
Logitech Driving Force Pro
Logitech Wireless Desktop MK710
Sony NWZ-E443 + Koss SparkPlug
Creative WP 350
Nokia N97
Scott Sportster P3 2010
Frame: New Sportster Frame Alloy 6061
Fork: Sun tour NEX 4610 V2 HLO, Lockout susspensionfork 1 1/8, 63mm travel, Integrated 700C
Front Derailleur: Shimano Deore
Rear Derailleur: Shimano Deore RD-M592 / Shadow Type
Shifters: Shimano Deore SL-M590
Chain set: Shimano FC-M443-8-S
Chain rings: 48×36×26 Teeth
Bottom Bracket: Shimano BB-ES-25
Cassette: Shimano CS-HG50-9 11-32 Teeth
Chain: Shimano CN-HG53
Pedals: Wellgo C 128
Front Brake: Shimano BR-M486 F/R 160 mm Rotor
Rear Brake: Shimano BR-M486 F/R 160 mm Rotor
Brake Levers: Shimano BL-M 486 Disc
Handlebars: Scott Sportster OS
Stem: Scott Comp
Rims: Alex XC-44 Disc
Front Hub: Scott Comp Disc CL
Rear Hub: Shimano FH-RM65 CL
Spokes: stainless black, 14G / 2mm
Front Tyre: Schwalbe Smart Sam 700×35C
Rear Tyre: Schwalbe Smart Sam 700×35C
Seat post: Scott Sportster/Solution
Weight: 13.10kg
konig_karl je offline   Reply With Quote
Staro 07.02.2014., 18:33   #124
prileee
laser
prileee's Avatar
Postovi: 2,356
Opla, napokon!
Nije mi bia problem u korisnickim podacima jer nas doma ima 4 studenata, ali je tramak sa pppoe appsima na mobitelima/tabletima, uvik pppoe napori
Odlicno! Hvala na info!
Staro 07.02.2014., 18:35   #125
wnbeeeE
wnbeeeE's Avatar
Datum registracije: Mar 2009
Postovi: 600
ajme napokon... napokon.
btw javlja mi sa ajfona unable to connect, nista vise ni manje. Stavio sam wpa2 i normalno mi radi sa kompa... Zna možda netko u čemu je problem ?
Darker than a moonless night and hotter than hell itself, that is coffee.
Zadnje izmijenjeno od: wnbeeeE. 07.02.2014. u 19:35.
wnbeeeE je offline   Reply With Quote
Staro 07.02.2014., 21:54   #126
prileee
laser
prileee's Avatar
Postovi: 2,356
Zovem cilo popodne korisnicku podrsku jer ne znam podatke za login na moj iskon(nisam se tamo logira valjda 4-5 godina) i ne javlja se nitko. Za popi*dit!
Staro 07.02.2014., 22:16   #127
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
meni su se javili nakon 25min, ostavio na speaker i vojla. Nije poanta u tome da zoveš više puta, jer si svaki put zadnji u redu.
Uglavnom dobit ćeš odma u razgovoru privremenu lozinku i login info, samo pripremi svoj oib.
Staro 09.02.2014., 00:33   #128
prileee
laser
prileee's Avatar
Postovi: 2,356
Drza sam liniju po 20 minuta i kurec ((
Sutra cu to odradit, bas mi je drago zbog ovog "update-a"
Staro 09.02.2014., 12:22   #129
konig_karl
lurkerus maximus
Lokacija: V.G.
Postovi: 91
Autor prileee Pregled postova
Pa nazovi 0800 1000 oni isto daju podatke
HDD: WD5000AAKS
PSU: Corsair CX400W
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Creative WP 350
Nokia N97
Stem: Scott Comp
Weight: 13.10kg
Staro 09.02.2014., 17:58   #130
prileee
laser
prileee's Avatar
Postovi: 2,356
Jutros sam promijenia nacin rada i upisao podatke. Sad kad su spojeni 1 komp na lan, a laptop i mobitel na wifi, ping mi skace i do 1000 u cs:go a nikakvi torrenti ni downloadi ni youtube nisu upaljeni. Sestra je prala rijecalicu na mobitelu a brat isto na laptopu.
Je li to do ovog routed moda? Ako ce tako bit stalno, rade cu vratit bridge i radit pppoe na svakom uredaju da imam urednu vezu nego ovako.
Staro 10.02.2014., 00:11   #131
borisko
Lokacija: .com
Postovi: 519
Nije i ne može biti. Ugasi sva računala / mobitele i restartaj router. Upali jedno računalo i ponovo provjeri.
Vjerojatno imaš nešto što radi ogroman broj konekcija prema van i guši mrežu...uglavnom je najćešće do klijenata (računala).
borisko je offline   Reply With Quote
Staro 10.02.2014., 01:58   #132
prileee
laser
prileee's Avatar
Postovi: 2,356
Zvao sam tehnicku podrsku i pojma oni nemaju, najbolje mi je kad nakon 5-10 minuta razgovora s njima bude tisina na liniji i ono, ocekuju od mene da kazem dobro nista bok. Super ste korisni, hvala.
Vidit cu sutra nakon ponovnog dizanja kompova i restarta rutera jel steka, imam netlimiter na oba kompa i nista ne vuce net posebno pa me zato cudi koji se vrag dogada. Javim sutra jel se fixalo stanje.
Staro 10.02.2014., 02:32   #133
domis
Lokacija: Hrvatistan
Postovi: 4,165
slično se događa meni i frendu dok igramo dotu, na momente ping skoči do 1k, pa je nakon sat vremena dobar.
ja na iskonu, on na optimi, a mislim da su host botovi locirani u francuskoj
Staro 10.02.2014., 18:31   #134
prileee
laser
prileee's Avatar
Postovi: 2,356
Jutros sam iskljucia ruter na par minuti i svi uredaju su nanovo spojeni na net. Ista stvar se dogada. Mobitel i laptop upaljeni, spojeni na net ali niti browser nije upaljen a meni u igri ping skoci do 500.
Vratia na routed nacin rada sa pppoe i radi ko urica. Izgleda da cu ostat na ovome. Ima li tko od vas tko je na carnet.duo paketu a da ima slicne probleme u igrama? Dosta cudan slucaj a ocito da je do tog nacina rada rutera (iako ne bi trebalo bit).
Staro 15.02.2014., 18:34   #135
rodriguez
rodriguez's Avatar
Postovi: 2,066
Događa mi se ista stvar čim priključim smartfon i krenem recimo updejtat aplikacije ili skidat nešto preko mobitela, ping skače na 800 i varira +/- 100.
Staro 15.02.2014., 18:39   #136
wnbeeeE
wnbeeeE's Avatar
Postovi: 600
sta je tu cudno? Pa stavi na torrent nešto skidat pa vidi da li će ti skočit ping
Staro 15.02.2014., 19:28   #137
prileee
laser
prileee's Avatar
Postovi: 2,356
To je normalno, ali meni su se u tom modu dogadali ti skokovi pinga i bez ikakvog prometa (praceno netlimiterom), pa sam sr vratia na pppoe zaye*anciju. Steta, bas sam se ponada da je tlaka sa pppoe zavrsila...
Staro 28.03.2014., 11:08   #138
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,835
Dešava li se vama u zadnjih tjedan dana da imate usporenje veze? Koristim Iskon.DUO i padne mi brzina na 1.8 Mbps i ping sa 18 ms naraste na nevjerojatnih 320 ms. To traje po nekih 15-30 minuta i onda se opet unormali.
Staro 29.03.2014., 17:40   #139
prileee
laser
prileee's Avatar
Postovi: 2,356
Ja imam duo carnet i zadnjih tjedana se svako par dana na kojih 10ak minuta zblesira net, toliko bude zblesiran da pce "loada" po par minuta. Ne znam do cega bi ti moglo bit...
