Staro 30.10.2009., 20:57   #1261
žile
žile's Avatar
Postovi: 3,074
Apacer,fala puno.Idem vidjet jesmo šta napravili
žile je offline   Reply With Quote
Staro 31.10.2009., 20:45   #1262
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
OMFG ja krenuo stavit tu igru danas malo na komp, pa sto je ovo 1.6 patch 1,2gb
I tu nepresaju problemi, moram sve skinuti, zasad skinuo tri patcha 2.7gb o boze i jos imam dva za skinut....
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 31.10.2009., 21:34   #1263
ONeill
ONeill's Avatar
Datum registracije: Mar 2008
Postovi: 347
Onda te nece uveseliti vijest kako je najavljen patch v1.7, tko zna koliki ce on biti
ONeill je offline   Reply With Quote
Staro 31.10.2009., 22:23   #1264
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Pa pošto su dosad eksponencijalno rasli (600==>900==>1200 MB) ja bi reko gigu i pol
blaa
Staro 01.11.2009., 23:52   #1265
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Mene Treyarch do sada nije razočarao i nemam problema sa patchevim - da jesu veliki ali to je zbog bar tri nove stock mape i jedna zombie - bar je tako bilo do sada.
Više me brine to što je i njima ATVI "šef" pa da ukinu daljnju podršku za W@W
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 15.11.2009., 12:06   #1266
Baja 001
Baja 001's Avatar
Postovi: 7,504
Je li imaju neki kumulativni patchevi ili moram skidat jedan po jedan?
Isto ako netko ima link na PACK patcheva?
Staro 15.11.2009., 17:05   #1267
hammer_of_thor
Postovi: 5,430
Jedan po jedan patch
blaa
Staro 15.11.2009., 19:32   #1268
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
JA od jucer pokusavam igrati CoD: World at War Final Fronts na PS2
Igra i ideja super, ali igranje na kontroleru....neprocjenjivo i bolje se ubiti
Staro 25.11.2009., 00:15   #1269
ONeill
ONeill's Avatar
Postovi: 347
Staro 25.11.2009., 00:31   #1270
hammer_of_thor
Postovi: 5,430
Nisam sada dugo igrao ali skinuti ću i probati
Taman sam negdje na 50-om levelu trečeg levela prestigea
Večinom sam igrao na bolt-only serverima, tu sam nabildao skilla i skilla.
Stvarno za kaljenje ciljanja predobri serveri, bez optike, bez bombi, artiljerije i pasa, automata i poluautomata. Samo Springfield, Arisaka, Mosin-Nagant ili Kar98 sa iron sightsom te bajoneta ili obični nož.
I deri.
Prosjek mi je bio 40ak killova po partiji, uvijek među prvima
blaa
Staro 12.12.2009., 18:30   #1271
RobytheKid
Datum registracije: Dec 2009
Lokacija: ravno pa ljevo
Postovi: 2
Imam problem s instalacijom patcheva. Kupio sam igru kad je već izašo 1.6 patch i normalno ih sve instalirao i igrao normalno igru. Igru sam deinstalirao i neki dan ju opet instalirao. Instaliram 1.1 i sve ok. Onda krenem instalirat 1.2 i napiše mi da je već instaliran(?). Ok ja sad idem instalirat 1.2-1.3 ali mi sad napiše da 1.2 nije instaliran i da moram njega prvo instalirat. Više neznam kaj da radim.Pliz help.
RobytheKid je offline   Reply With Quote
Staro 13.12.2009., 13:07   #1272
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor RobytheKid Pregled postova
Kod instalacije igre - bez obzira na koj drive instaliraš dobar dio ti ide na C: drive po defaltu - tamo nisi počistio staro pa zato imaš problema - search & destroy
1oo1
Staro 19.12.2009., 00:06   #1273
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
evo imam original igru pa ako ocete zombije, ili mp javite.
Hvala!
~Kaiser_Chief~ je offline   Reply With Quote
Staro 19.12.2009., 00:25   #1274
hammer_of_thor
Postovi: 5,430
Moram ju i instalirati, dugo nisam , a nemam baš ni vremena. Vjerovatno ništa prije ponedjeljka, sutra radim cijeli dan.
Ali mogli bi nabaciti Zombie malo, ti, MM, ja i još neko
blaa
Staro 19.12.2009., 00:34   #1275
~Kaiser_Chief~
Lokacija: Zabok
Postovi: 1,189
za zombije sam furt spreman
javi.. imas xf ?
Staro 19.12.2009., 01:07   #1276
hammer_of_thor
Postovi: 5,430
Autor ~Kaiser_Chief~ Pregled postova
javi.. imas xf ?
Naravno da imam XF, samo ga ne koristim otkako igram MW2, prije češ me ovdje na PM dobiti
hrvoje1985 je XF
blaa
Staro 26.02.2010., 20:54   #1277
juiced
juiced's Avatar
Lokacija: Okolica Zagreba
Postovi: 153
Ljudi sori za bump "stare" teme, ali sam upravo instalirao WaW. Koliko vidim, zadnji patch je 1.7. Pošto patcheva ima podosta, a i poveći su () molim vas za info koje patcheve mogu preskočiti? Hvala.
juiced je offline   Reply With Quote
Staro 27.02.2010., 01:24   #1278
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Autor juiced Pregled postova
Ovako ja radim,stavim patch 1.2(498mb),patch 1.2 to 1.4(581),patch 1.4 to 1.5(974mb),patch 1.5 to 1.6(1.6Gb) i na kraju patch 1.6 to 1.7(16mb).Pokušavao sam stavljati posebno ali uvijek dobijem errore.Nažalost ovo je jedini način kako kod mene to radi.Naravno igra mi je original.
Xenomorph je offline   Reply With Quote
Staro 27.02.2010., 11:05   #1279
juiced
juiced's Avatar
Postovi: 153
Hvala ti. Ponadao sam se već da neću morat sve to skidat.
Staro 01.04.2010., 13:06   #1280
hammer_of_thor
Postovi: 5,430
Nakon malog zasičenja sprejerskih BC2 i CoD 4 i MW2, vratio sam se sinoć fenomenalnoj petici i Bolt Only serveru.
Rano je jutro bilo pa nije bilo ljudi, ali ni ja nisam izgubio touch
blaa
Staro 02.04.2010., 22:32   #1281
hobitxxx
hobitxxx's Avatar
Datum registracije: Jul 2009
Lokacija: Koprivnica
Postovi: 412
aleluja da neko i cod 5 igra evo javite mi se da odigramo koju ja sam napokon poceo igrati ... moj xf hobbitxxx
hobitxxx je offline   Reply With Quote
Staro 24.07.2010., 08:18   #1282
Aaron
Datum registracije: Jul 2010
Lokacija: Neverland
Postovi: 2
Ajde valjda još nije zastarjela tema,
evo imam pitanje!
Svako malo mi dođe mali bratić u posjetu, a ja se nemam vremena (čitaj neda mi se) zafrkavat se s njime, pa mu lijepo stavim Cod WaW,
i naravno mali izgubi živce kad se tek spawna i killaju ga za sec.,
i idem mu namjestiti šifre za bezmrtnost,
piše da utipkam "devmap mak" i onda se cheatovi omoguće,
ali kad to utipkam onda ti igra krene iz početka pa je moraš od tamo igrati...
Ali problem je kada prođeš 1. misiju,
naravno šifre ti se resetiraju i nestanu, i znate več treba ih se ponovno upisati...
Ali kad ih ideš upisati piše "cheats are not enabled on this server" (ili tak nešto),
što bi značilo da opet moram napisati šifru za "Enable cheats",
ali ako to upišem, opet se igra vrača na sam početak igre! (znači ona prva misija gdje si zarobljen).
Zašto prilikom prelaska 1. staze se ostanu postavke za cheatove omogučene?
Znači samo 1 misiju možeš igrati s šiframa!
Da li ima netko isti problem (tj. nije to problem, ali bratić me davi "daj popravi to, zašto neće, nemrem igrat kad me ubijaju" itd...)
Kako to zaobići da mu složim te šifre i nek igra do mile volje (na taj ne kompetitivan način).?
Hvala unaprijed!
Aaron je offline   Reply With Quote
Staro 24.07.2010., 11:49   #1283
Strider
Nuclear Experiment
Strider's Avatar
Datum registracije: Aug 2009
Postovi: 650
Koliko sam skuzio govoris o sp-u.E sad stvarno nekuzim kak je on tvom braticu tolko tezak.Pa nek stavi na najlakse pa ce valjda moc nekog ubit.I jos nest aj ipak ti je bratic pa mu mal pokazi kak se bacit na pod, koristi cover te kak ubit nekog Valjda ce naucit nekaj.
For everything you gain,
You lose something else
Strider je offline   Reply With Quote
Staro 14.04.2011., 07:57   #1284
Xenomorph
Arroyo settler
Xenomorph's Avatar
Postovi: 316
Pozdrav ljudi!Evo imam problem koji ne mogu riješiti.Nakako se poremetio Cod waw,ja ga reinstalirao par puta i kad stavim bilo koji patch javlja mi da već postoji.Par puta sam igru izbrisao sa Revo pro,Windows Installer Clean up utility,u registry sam izbrisao sve ostatke ostataka igre(sve što sam našao na Googlu).Reinstalacija windowsa mi se ne da raditi jer rade super.Naravno igra je original.Ako netko ima kakav prijedlog kako riješiti problem bio bih mu jako zahvalan.Hvala unaprijed.
Staro 18.04.2011., 20:51   #1285
Xenomorph
Arroyo settler
Xenomorph's Avatar
Postovi: 316
Evo nisam našao nikakvo riješenje čak i "trejarč" ne zna o čemu se radi pa sam reinstaliro windowse i sada je naravno sve u redu.
Staro 07.01.2012., 17:10   #1286
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Znam da je ovo dizanje i velike prašine, ali video je prejak!
54' / 74' / 90' / 2014
