Staro 11.12.2018., 08:20   #91
gearvita
gearvita's Avatar
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Awei Y280 Portable Outdoor Bluetooth Speaker - Music Goes with You As The Shadow
Portable column Awei Y280 speaker is a stylish device in a waterproof case. The model is equipped with a special strap that facilitates easy carrying, maximum saturated sound is achieved thanks to two speakers with a power of 8 watts.
Product Features:
● High Quality Sound
With 360-degree surround sound technology, Y280 enjoys an impressively power sound be free bluetooth play.
● Easy Operation and Portable
Very easy to use, with a hanging strip, you can hang it everywhere and that's really free hands.
● Long Playing Time
High capacity battery for up to 12 hours of continuous playing time on a full charge.
● Large Capacity Battery
4000mAh battery can be charged, keep mobile phone active when outdoor emergency.
● IPX4 Waterproof
Adopt IPX4 waterproof design, allows you to enjoy music indoors or outdoors.
● FM Radio Reception Function
In addition to enjoying music, you can listen to your favorite radio, current affairs, entertainment, news and so on.
● 360-degree Sound Design
Each location is a good listening point.
● Bluetooth 4.2 Wireless Connection
Bluetooth 10 meters free transmission and noise reduction to provide you with an efficient, long-lasting, stable listening experience.
● With Audio Cable
It has an audio cable with a 3.5mm jack that can be connected to a computer for use as a speaker.
● Built-in Noise Reduction HD Microphone
High sensitive, you could answer the call with low interference, like talking to your friend face to face.
● Other Functions
Support USB sound card, AUX in and TF card, be able to connect two devices at the same time, iOS & Android system battery display function and two-way calling function.
Price at $29.99 on GearVita, it is suitable for a variety of scenes such as cycling, backpacking, etc. With it, music will follow you like a shadow: https://gearvita.com/awei-y280-bluetooth-speaker.html
You may also interested in:
cheap xiaomi redmi 6 pro
cheap xiaomi lyej05lm
Best Brand Consumer Electronics Provider GearVita
gearvita je offline   Reply With Quote
Staro 12.12.2018., 09:23   #92
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
JKR-8100 Alarm Clock Bluetooth Speaker - Everything You Need beside Your Bed
Don't let its retro design fool you because the JKR-8100 alarm clock Bluetooth speaker a multifunctional gadget! This cool gadget will serve you as a Bluetooth speaker, FM radio, alarm clock, and LED light - this is everything you need beside your bed. Thanks to the integrated microphone, you can use the Bluetooth speaker with LED alarm clock for hands-free calls.
Listen to your favorite tunes from your Bluetooth-enabled device or FM stations and relax before bedtime or wake up on time the next morning, but you need to set the alarm function. This alarm clock features an LED night light that creates a warm ambient. You can listen to the music from almost any device, thanks to its Bluetooth connection and AUX input. And there is one more music playing option, listen to music from your own TF memory card.
Product Features:
● Unique dual alarm clock function, you can set alarm reminder for two different time periods according to your needs.
● Using the output power of the 52mm dual magnetic horn, achieves a comprehensive sound quality.
● Large LED display that has a smooth mirror surface and shows the time, alarm, battery, etc.
● Equipped with Chinese and English prompts, vocal voice reminding makes you feel closer.
● Night light at the top, three level brightness adjustable.
● Built-in microphone for hands-free calls.
● FM radio function let you enjoy listening to stations from your area.
● Using the integrated buttons, you can set the time, alarm, change track or FM station, etc.
● Bluetooth 5.0 transmission to enhance signal stabilization and reduce signal loss.
● Support TF card to broadcast and common mainstream music format playback.
● High quality AUX audio input supports 3.5mm interface device.
With alarm clock and Bluetooth speaker two-in-one design and two stylish colors for you to choose from on GearVita, the JKR-8100 will bring you a different fun and experience: https://gearvita.com/jkr-8100-alarm-...h-speaker.html
Hot sale products:
cheap oneplus 6T 4g smartphone 256gb
cheap xiaomi mi max 3 4g smartphone
Staro 13.12.2018., 08:09   #93
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Lenovo DP-20 Earphones - Three-frequency Balanced Tuning, Sound Quality More Natural
This Lenovo DP-20 earphones features high grade dual drive unit, capable of creating dynamic and balanced sound quality. Ergonomic design provides long time comfortable wearing and securely fit to your ears. 3.5mm gold-plated pin adopted, universal compatible with most mobile phones, MP3, tablets and laptops with 3.5mm connector.
Product Features:
● Hi Fidelity and High Quality Sound Effect
Adopting high grade dual unit loudspeakers, let you enjoy incredible sound quality with deep bass and crystal clear music.
● Strong Compatible
Compatible with most mobile phones, MP3, tablets and laptops with 3.5mm connector.
● Three Fractional Frequency
Innovative combination of high-frequency, medium-frequency and low-frequency unit for dynamic and balanced sound quality.
● Superior Quality
Tangle-free wire with TPE shell, flexible and anti-corrosion, durable to use. 3.5mm gold-plated pin ensures a stable signal transmission.
● Ergonomic In-ear Design
Ergonomic design to fit most ear canal, delivers a comfortable wearing experience.
● Multifunctional Inline Control
You can use the in-line button to answer/hang up calls, play/pause songs and adjust the volume.
Priced at only $9.99 on GearVita, there are two colors for you to choose from, black and white: https://gearvita.com/lenovo-dp-20-hifi-earphones.html
You may like:
best xiaomi mi a2 lite smartphone
best xiaomi mi max 3 4g smartphone
Staro 14.12.2018., 08:49   #94
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
BM06 Mini Cartoon Speaker - The Best Christmas Gift
This mini cartoon speaker is made of high quality material, durable and sturdy in use. It is lightweight and stylish, can be carried anywhere you want. The practical Bluetooth speaker with super clear and hi-fi sound effects brings you good listening experience.
Product Features:
● Mini Bluetooth speaker, little size, easy to carry
● With a pair of functions, two can be connected to achieve dual-channel effect.
● Connect Bluetooth device to play music.
● Built-in microphone allows you to make and receive calls, you will not miss the important call.
● With selfie function that lets you remotely activate Bluetooth enabled cameras for still shots and videos.
● BT4.1 provides steady wireless transmission distance up to 10m.
● Intelligently compatible with 99% of Bluetooth devices.
● Hi-Fi driving unit delivers vigorous magnificant clear sound.
● Brings impressive, rich, and clear sound with a 3W audio driver.
● Portable size fits into pocket or hang on backpack.
There are cat, dog, panda, pig, bear and mouse 6 different animals at $9.99 on GearVita for option. The mini cartoon speaker is superior to small and loud voice, it must be the best surprise to your kids, your familes and your friends: https://gearvita.com/bm06-mini-cartoon-speaker.html
Hot sale products:
best xiaomi redmi note 6 pro 32gb
best xiaomi mi 8 lite 64gb
Staro 15.12.2018., 07:53   #95
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Huawei CM33 Type-C Earphones - Classic Design, Hi-Res Audio
This Huawei CM33 earphones are a wired headset with mic and allows you to enjoy your favorite music tracks in crystal-clear clarity. Featuring a response range of 8 to 25000Hz, this headset reproduces deep lows, clear mids, and powerful highs. It features a USB Type-C connector that makes it compatible with many smartphones and tablets. Thanks to the in-line control, you can easily control your music with this headset. Designed with a microphone, this headset can also be used to make hands-free calls while on-the-go.
Product Features:
● Hi-Res Audio
High-resolution authenticated digital output and Huawei Histen 3D audio technology, delivers immersive CD quality sound.
● Ergonomic Design
Classic ergonomic half in-ear design, fit and comfortable.
● 3-button Remote Control
Ergonomic 3-button remote control to free your hands, enhenced wind noise reduction design for crystal clear voice.
● USB Type-C Connector
Seamless and reversible USB Type-C plug with built-in decoder IC, plug and play.
● High-quality Material
Made of excellent materials, durable in use, with simple and stylish appearance.
The classic white design makes it meet different scenarious in everyday life. Price is also affordable, only at $19.99 on GearVita: https://gearvita.com/huawei-cm33-type-c-earphones.html
Hot sale products:
mitu puzzle building block mining truck
meizu pop true wireless bluetooth earphones
Staro 17.12.2018., 09:01   #96
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Awei Y330 Speaker - Four Input Modes, FM Multi-channel Radio
Awei Y330 speaker can provide a new experience for you in listening to music. With the support of a 52mm driver, it allows you to hear loud and pleasant sounds.
Product Features:
● Bluetooth 4.2
Using Bluetooth 4.2 technology can connect smartphones and other Bluetooth audio devices quickly.
● Two-channel Surround
10 meters wireless distance transmission, TWS wireless interconnection, left and right channel separation, synchronous playback, automatic conversion to stereo.
● Heavy Bass
Up and down dual-speaker and low-frequency radiator, subwoofer HiFi restore.
● Large Power, Long Time
Music can be played continuously for about 4 hours, the built-in battery capacity is 1200mAh/3.7V, the voice feedback function can report the remianing power, and send a reminder when charging is needed.
● Powerful Intelligent Chip
Upgraded high performance Bluetooth chip, transmission 10m high speed stable distance. The speaker is placed indoors or outdoors, connected to digital devices at any time.
● Microphone Support
When connected to a smartphone, it can be used as a mic as well as external speakers to answer your phone calls.
● Anti-impact Percision Metal Body
The use of precision metal body and thick silica gel combination, strong and tough, indestructible, seamless body design.
● HD to Receive Multi-channel FM Radio
Built-in FM radio station and signal amplifier, one key automatic station, easy operation.
● Four Input Modes
Bluetooth, TF card, USB and 3.5mm four input modes, switch freely.
● Simple Key Design
Master key symbol design, easy to understand, multi-function mode.
There are three colors for you to choose from on GearVita, black, dark gray, green, and the price of only $16.99: https://gearvita.com/awei-y330-wirel...h-speaker.html
Hot sale products:
best xiaomi mi pad 4 plus 4g
Staro 18.12.2018., 08:51   #97
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Betop G1 Bluetooth Game Controller - Design for Huawei
The Betop G1 game controller is designed specifically for phones of the Huawei Mate 20 series including Mate 20 X and Mate 20 Pro. It comes with an ergonomic design for a great game performance and comfortable use even when playing for long hours. The Huawei gamepad has a joystick, D-pad and, two shoulder buttons. Built-in battery with 400mAh, can be used up to 25 hours with one full charge. Thanks to quick charge support, a 5-minute charging is enough to for another 2 hours of gaming.
Product Features:
● Supports Huawei Mate 20/Mate 20 Pro/Mate 20 X.
● Gamepad setting, game recording, game acceleration, button anti touch by mistake.
● EMUI system 9.0 built-in gamepad application assistant.
● Easy to install and connect.
● One-handed operation.
● Wireless Bluetooth 5.0 (NORDIC Bluetooth 5.0 chip), don't need root.
● Built-in lithium battery 400mA, charging 5 minutes works 2 hours, full charge works 25 hours, standby time of 180 days.
● Compatible with Android mainstream games.
The game controller comes in black and is designed to feel comfortable in your hand even when playing for long. You can purchase it on GearVita for $49.99: https://gearvita.com/betop-g1-blueto...ontroller.html
You may like:
xiaomi mi max 3 4g smartphone in stock
xiaomi mi box s tv box global version in stock
Staro 19.12.2018., 07:56   #98
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Bluedio V2 Subverts All Your Imagination about Headphones
The Bluedio V2 headphones provides rich and accurate audio while isolating external noise, so you can enjoy its high-quality sound for several hours. It has an immersive in-game audio so you can lose yourself in the game while you’re winning, the reversible design is good for a long time wearing. The 40mm magnetic neodymium drivers can bring you vivid sound field, sound clarity, sound shock feeling, capable of various music and game.
Product Features:
● PPS 12 Exclusive Patents Acoustics Technology
Specially built 12 drivers, together with the carefully designed compound cavity will accurately reproduce every frequency to make the bass deeper and more powerful.
● Accurate Positioning
Easy response to scenes such as HiFi music, movie videos and games.
● Bluetooth 5.0
Combined with Bluetooth 5.0 chip circuit optimization, it has better connectivity, less possibility of disconnection and interference, clearer data transmission, lower energy consumption and stronger endurance.
● Intelligent Control Mode
A. When calling, you can choose the normal answer mode.
B. Tap the right ear part of the headset twice or jump twice to answer the call automatically.
C. Say "answer" to answer the call, say"ignore" to decline.
● Technical Upgrade
Professionally customized and developed light and infrared sensors. When you put down your headphones, the music will be paused. When you pick up the headphones again, the music will continue.
● Intelligent Amazon Web Services
A. It can be used for voice query weather, news, schedule and so on.
B. It can be used for voice control home appliances, voice switch songs and so on, which is our life assistant.
C. More freely controlled cloud-based songs are provided.
● Hearing Protection
The App has a hearing protection function while keeping the music dynamic. It can lock the decible level and protects the ears, including normal mode, child mode, protection mode and madman mode.
● Sleep Protection
Open the sleep protection function, when you disconnect your headphones with Bluetooth device up to 10 mins, it will turn off automatically to save power.
● Rotating Cup Design
The rotatable headphone cup is stylish, with the provided portable bag, it is easy to carry anywhere.
Bluedio V2 is a flagship Bluetooth headset with top-level intelligence and cinematic effect, because of its powerful headphone interactivity, it's no exaggeration to call it a cross-era headset from the future. Come to GearVita to see, you will definitely be attracted by its stylish appearance and powerful functions: https://gearvita.com/bluedio-v2-blue...eadphones.html
buy xiaomi mi max 3 4g smartphone
buy xiaomi mi 8 lite 128gb
Staro 20.12.2018., 07:47   #99
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Bluetooth Audio Receiver - Your Contemporary Audio Companion
The Xiaomi Bluetooth Audio Receiver sports a minimalistic and compact design. It is fabricated from advanced polycarbonate plastic, the simple white color exemplifies the classic Mi-looks, which works well as a fashion accessory. The metal elastic belt clip secures the device and makes it ultraportable. It comes with One key operation, that is, all function on board is controlled by a single key which turns on the earphones, connects to Bluetooth, plays, and pulses music, also answer calls, instantly transforming your earphones from wired to wireless.
Product Features:
● One button operation, all functions onboard are controlled with a single key.
● Supports connecting with two Bluetooth devices simultaneously.
● Bluetooth V4.2 wireless connection, 10m transmission distance, great efficiency of receiving, stable and fast signal transmission speed.
● Processed precise tuning and professional amplifier chip, deliver high SNR low distortion signal, return natural and original sound.
● Built-in 97mAh Li-ion battery, charging 2 hours lasts 4 - 5 hours playing time.
● Plug and play, supports using while charging, not afraid of no power.
● Connect the device to car's head unit, wirelessly play music on car's audio system.
● Metal clip-on design, footloose for doing sports.
● Standard 3.5mm audio port, compatible with a variety of earphones or headphones.
No need for a wired smartphone connection while exercising, you can go for a run with your favorite beats! Enjoy your personal time on a lazy afternoon without worrying about smartphone radiations or external disturbances. No need to worry about making a call while the mobile phone is on charge. All this is due to the Xiaomi Bluetooth audio receiver, which priced at $19.99 on GearVita, will give you a wonderful experience: https://gearvita.com/xiaomi-bluetoot...-receiver.html
Hot sale products:
xiaomi lyej05lm in stock
Staro 20.12.2018., 11:56   #100
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
GearVita Smart Watches And Smart Bracelets Discount
Christmas is getting closer and closer to us, and the long-awaited Christmas holiday is coming soon, this is really a happy news. There is another good news now, from December 20 to 31, there is Christmas Holiday Discount on GearVita. This time, it is a promotion for smart watches and smart bracelets. Go to our promotion page and you'll see a variety of popular, hot and new smart watches and smart bracelets of Xiaomi, Huawei, Lenovo, No.1, Microwear, Zeblaze, LEMFO, Oukitel and other brands, all with a 10% discount on the coupon code "XSSWGV10".
If you are interested in our last brand sale of Xiaomi and Huawei, these two activities continue. All Xiaomi products on our website can get a 10% discount with the coupon code "MISALE10". Similarly, all Huawei products can get a 10% discount with the coupon code "HUAWEI10".
Time is limited, hurry to choose and buy! For detailed information, please visit: https://gearvita.com/smartwatch
Staro 21.12.2018., 07:46   #101
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Square Box 2 Bluetooth Speaker - Beautiful Sound, Beautiful Look
Xiaomi Square Box 2 adopts the minimalist design concept, with beautiful sound and appearance, and it supports Bluetooth 4.2 upto an effective distance of 10 meters. Built-in microphone, with CVC noise canceling function, supports answering phone call clearly by simply pressing a button. Built-in 1200mAh polymer lithium battery, up to 10 hours working time.
Product Features:
● Dual 2.5W Acoustic Units
Deliver clear, rich and classic sound.
● Compact, Lightweight and Portable
Measures at 154.5 × 60 × 25.5 mm, and weighs only 155g, you can easily put this speaker into your backpack and take it anywhere.
● Exquisite Look
Silver matte aluminum alloy frame with white shell, matches well with any surroundings.
● Bluetooth 4.2 Technology
Provides more stable signal with lower power consumption and better compatibility, compatible with Bluetooth-enabled Android/iOS smartphones.
● Built-in Mic for Conversation
After connected with your smartphone, you can answer/end the call with just a press on the Power button of the speaker.
● CVC Noise Reduction
Adopts CVC hardware noise reduction technology and offers high definition sound quality.
● Long Music Play Time
With built-in 1200mAh Li-polymer battery, it supports up to 10-hour music play time, so you can immerse yourself in your favorite music for a long time.
● AUX-in Port
Provide wired connection with other devices such as computer, mobile phone, MP3 player and more.
Just imagine, the house is full of sunshine in the afternoon, you take a rest, smell the fragrance of tea and turn on the speaker, let the music accompany you, enjoy a wonderful day. Do you want to have it now? Then come to GearVita to buy it: https://gearvita.com/xiaomi-square-b...h-speaker.html
Recommended hot-selling products:
best huawei honor band 4 smart wristband
buy oneplus 6T 4g smartphone 128gb
Staro 25.12.2018., 09:15   #102
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Lenovo S1 - Lenovo Newest Wireless Bluetooth Earphone
Lenovo S1 wireless earphone is equipped with Bluetooth 5.0, unique RF design makes the transmission more stable. Adopts ergonomically design, firmly attached to the your ears, and comes with a skin-friendly silicone eartips.
Product Features:
● Bluetooth 5.0, unique RF design, more stable.
● True independent cavity brings high fidelity, delivers 3D stereo voice and heavy bass.
● Pull out or push in the earbuds and they will auto power on or power off and charge.
● The 1800mAh big capacity charging dock can charge the earphone about 12 times, work time more than 40 hours.
● Touch it 3 times, wake up Siri, not need take out your iPhone.
● Right and left high-definition dual talk, can also use the right earphone alone.
● Use three anti-paint material, stronger anti-erosion ability, longer service life, more durable.
● Power displayed in real time.
● Magnetic absorption charging dock, allows the earphones to be accurately homed.
● IPX5 waterproof, exercise whenever you want without worrying about sweat.
It is the newest earphone released by Lenovo recently, you can get from GearVita and enjoy excellent sound quality without restraint: https://gearvita.com/lenovo-s1-tws-w...-earphone.html
You may like:
buy xiaomi redmi note 6 pro 32gb
xiaomi mi mix 3 128gb in stock
Staro 26.12.2018., 08:01   #103
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Lenovo Air TWS Bluetooth Earphones - AI Antenna for Stable Signal, Binaural Call
Lenovo Air earphones have three main features: stable signal, excellent sound quality and long standby time. It uses a BES 2000IZ AI chipset that works with the AI smart antenna to provide more stable signals on a long distance while also supporting binaural calls. In addition, it is equipped with a 6mm graphene sound unit to restore high quality sound. It supports IPX5 waterproof and comes with a 400mAh charging dock, which can provide a 10 hours music time.
Product Features:
● BES IZ 2000 AI chipset provides a superior performance on a long distance, it supports high-quality music transmission and low power consumption, further enhancing the endurance.
● 6mm graphere dynamic unit acoustic design is used to accurately analyze the details of low, medium and high frequency.
● Professional acoustic team debugging, EQ tone color is moderate, excellent resolution, making music background and vocal positioning more accurate.
● Adopt Bluetooth 4.2, fast and stable connection with phones within 10m.
● Make full use of the internal space of the headphones, small and round, comfortable in the ear.
● Fits the shape of the human ear, 30 degrees into the ear, does not rise for a long time.
● The magnetic charging compartment design is adopted to realize automatic switching, alloy material anti-pressure anti-drop.
● One button operation, easy to use.
● The earphone dock is designed for storage and charging, after the first pairing is successful, the earphone is automatically connected to the paired device, and automatically charged when it is inserted into the box.
● Can be used in both ears or in one ear, even if the two are worn separately, the music is still shared synachronously.
● With a variety of ear caps to adapt to different ear canals.
● IPX5 waterproof design brings high quality music and call experience regardless of the sweaty high intensity exercise or the drizzle travel.
Traditional headphones use single-ear calls, while Lenovo Air on GearVita uses double-ear calls. Its built-in BES IZ 2000 AI chipset and AI smart antenna design can make the voice of the call very clear, non-drifting is one of its highlights. At the same time, the signal is stronger, the connection is more stable, the delay of the call is reduced, and the quality and efficiency of the call are greatly improved. Wearing it while driving makes it easier for you to talk, not to spend more energy on answering and talking, and to focus you on driving, making it safer: https://gearvita.com/lenovo-air-tws-...earphones.html
Hot sale products:
cheap lenovo z5 pro 64gb
buy xiaomi mijia aqara hub gateway
Staro 27.12.2018., 08:01   #104
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
EJOY Flame Lamp Bluetooth Speaker Decorates Your House More Vivid
EJOY flame lamp speaker is a portable wireless Bluetooth 4.2 speaker, compatible with all Bluetooth compatible devices. With Bluetooth function, you could make a connection effortlessly and share music with your friends anytime and anywhere.
Product Features:
● Unique Flame Design
96 LED flickers create dynamic warm yellow lights, gives you a wonderful listening experience and the soft light protects your eyes.
● High Sound Quality
5W high-power speaker excellent stereo sound and powerful bass.
● Two Speaker Shared
Can use a single one or two speakers. When using two speakers, the left and right channels are separated to be on the box. When using a single one, the left and right channels will be combined to output.
● Divided Buttons Control
Finish on/off, next song/last song, v+ key/v- key, play/pause function. Apart from it, you can do these functions by bluetooth control.
● 1800mAh Battery
Built-in rechargeable 1800mAh lithium-ion battery, which can last more than 7.5 hours music play time and 26 hours flame lamp play time with one charge.
● Power Supply Port
Put the USB cable into the lamp, when it is being charged the indicators is red, when full charged the indicator off.
It is also an ideal gift for your friends or children in Christmas that is available on GearVita: https://gearvita.com/ejoy-flame-lamp...h-speaker.html
Recommended hot sale products:
buy lenovo z5 pro 64gb
buy xiaomi airdots headset
Staro 28.12.2018., 09:52   #105
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Huawei FreeBuds 2 Pro Earbuds - Bone Voiceprint ID, Intelligent Voice Control
The Huawei FreeBuds 2 Pro earbuds effortlessly connects to your phone via Bluetooth 5.0, it combines voice recognition and "bone sound pattern" recognition to provide biometric recognition since every individual has a different bone sound pattern. Its AI-assisted voice recognition features enable you to make hands-free phone calls and instantly access Google Assistant. While the case charges through a USB-C port, you can charge them wirelessly as well using the wireless charging case. Alternatively, they can be charged via the back of the Huawei Mate 20 and Huawei Mate 20 Pro.
Product Features:
● Bone voiceprint ID generation biometric technology cooperate with the AI artificial intelligence recognition technology to complete the identity verification in one sentence.
● Make payments with your voice, one sentence direct to payment page, support for WeChat payment and AliPay.
● Bring the headset, the voice assistant is on standby, no need to unlock and other operations, it can arrange everything for you.
● Intelligent voice commands or double-click to control the music and incoming calls.
● With the wireless charging dock, it can be charged anytime anywhere, convenient and fast.
● The wireless charging case will not only charge via a wireless charging pad but also via the back of the Huawei Mate 20 and Huawei Mate 20 Pro.
● Each earbud is equipped with two high-precision and high-performance mics, match the noise reduction technology to achieve better call performance.
● Battery capacity of 420mAh, lasts 2.5 hours talk time on a single charge, up to 15 hours talk time and 20 hours music playback time with the extra charge of the charging case.
● The design is simple and stylish, with a lustrous texture.
● Ergonomic semi-in-ear design, unique smooth curve of the earphone handle, skin-friendly and comfortable.
● Designed with professional nano-coating and waterproof structure to meet IP54 dust and water splash resistance.
● Open the charging box, the earbuds automatically connect.
While the design of the Freebuds 2 Pro may look similar to the Apple AirPods, they actually have some different technology built inside them. You can head straight to this link of GearVita to check out more details and buy it: https://gearvita.com/huawei-freebuds-2-pro-earbuds.html
You may like:
cheap lenovo z5 pro 128gb
cheap yi 4k action camera floating grip
Staro 29.12.2018., 07:51   #106
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Mijia 1S Walkie Talkie Accompanies You to Chat Along the Way
The Xiaomi Mijia 1S walkie talkie is packed with some powerful features – a huge 10km range, 8 days of standby time and up to 17 hours of talk time, GPS positioning and even an FM radio function. It has a detachable antenna for easy storage and has a micro-USB port for charging that can also be powered with a power bank. It supports the Very High Frequency (VHF) range spanning from 136MHz to 174MHz, also comes with support for the Ultra High Frequency (UHF), i.e. the frequency range between 403MHz and 470MHz. On top of that, the device comes with support for FM Radio, allowing you to tune in to your favorite radio stations, also capable of location sharing.
Product Features:
● 41% thinner than last generation, 43% lighter, built-in back clip, one hand handling.
● Not only support 3.5mm earphone port, but support Bluetooth headset with dual mode Bluetooth chip.
● Micro USB charging port, no need to worry about loss of charger, convenient and practical.
● Quick to form a team, once one starts a team, the others can click to join the team without putting complicated frequency.
● Location share function, in the range of calls, it can check the location of teammates by the screen or App even there is no Internet.
● 2190mAh big capacity battery, micro-USB charging design.
● Long time to use, 8 days stand-by time,17 hours for normal use.
● Auto detection function during charging, prevent the risk of overcharge, over discharge, over voltage and other issues.
● FM radio function, it can search channel in 87 - 108MHz, providing entertainment apart from communication, but the talking between walkie talkie have priority when listening to radio.
● Digital filtration, good talking effect even in various complicated environment.
● In order to achieve clearer and louder call sound, the speaker has a speaker volume that is 65% larger than the effective radiation area of the previous generation. The maximum volume is increased by 162%, and in a noisy environment, good call performance can still be maintained.
● Sending voice without pressing talking button when your volume is reached to a certain level,free your hands.
● Suitable for two-way communication from different locations.
● A maximum power of 3W and a call distance of 1-5 kilometers in order to meet the call needs in a variety of scenarious.
● Comes with UHF frequency range of 403-470MHz, and VHF frequency range of 136-174MHz, give it the ability to be used in a densely populated area as well as in the wild where there is little or no obstruction to the radio waves.
● Comes in black and white colors with along with handy display and some buttons on the surface for controlling the device.
The 1S walkie talkie which available on GearVita is a practical gadget, can be used almost anywhere, including metropolitan areas with a high degree of radio interference: https://gearvita.com/xiaomi-mijia-1s...ie-talkie.html
You may like:
cheap airdots headset
buy honor watch magic
Staro 02.01.2019., 08:01   #107
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
HSY-014 Wired Gamepad Controller for PS4 - Comfortable Game Playing Anywhere
This HSY-014 gamepad controller is designed for PS4 which is safe, environmental and durable. It uses high quality ABS material, smooth curves make this game grip easy to control and play. With lightweight, ergonomic design, you will encounter comfortable game playing anywhere.
Main Specifications:
Vibration: Double vibration
Input : 5.5V 1000mA
Operating Current Voltage: 5V 25mA
Sleep Current: 150uA
Motor Current: 100mA
Operating Temperature: 0-40 Celsius
Cable Length : 2m
GearVita offers two options for you, black and white: https://gearvita.com/hsy-014-wired-g...r-for-ps4.html
Hot sale products:
best airdots headset
buy huami amazfit 2 stratos
Staro 03.01.2019., 08:53   #108
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
i7S Mini TWS Wireless Bluetooth Earbuds - Never Limited by Wire
Equipped with i7S wireless Bluetooth earbuds, wireless to connect mobile devices and you can share music with your families or friends. Superb sound quality headset with ultra-low power consumption Bluetooth V4.2, create a best 360 degrees stereo sound and superb bass sound. Coupled with 950mAh charging dock, a mini power bank can charge for your Bluetooth headset 5 times, not afraid of power-off anymore when you have an outing.
Product Features:
● Adopt true wireless technology, never limited by wire.
● Stereo mode or mono mode, up to you.
● Bluetooth CRS4.2 technology, more stable, wider coverage, lower power consumption.
● Support connecting with two devices simultaneously.
● Automatically connect to the phone after the first pairing.
● English voice prompt, expandient for use.
● With built-in microphone, you can enjoy clear handsfree calling.
● Compact and lightweight design, no burden on your ears.
● 950mAh charging base and mini portable design, solve the problems of charging and carrying.
● Seamless music enjoyment of music up to 8 hours on a single charge and 100 hours of standby.
● LED indicators reminds of status of low battery, taking charge, and fully charged.
● Battery status real-time displayed on iOS device.
● Double click to redial outgoing call, one click to play pause music.
● Compatible with most Bluetooth-enabled devices.
The true wireless design mini earbuds at $16.99 on GearVita is great for running, jogging, hiking and other exercise, you can enjoy your wireless sports as much as you like: https://gearvita.com/i7s-mini-tws-wi...rging-box.html
Hot sale products:
buy huawei honor band 4 running version
buy lenovo z5 pro 128gb
Staro 04.01.2019., 07:20   #109
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi BRE02JY Type-C Earphones - Music at Your Fingertips
The Xiaomi BRE02JY in-ear earbuds are designed with dual-unit half-ear, they are P-shaped and with USB Type-C interface. The softened shape ensures a good fit and convenient wear. With the ergonomic design, the earbuds will stay in place even through a strenuous workout and will not disturb you or cause any discomfort thanks to the pleasant texture. They are endowed with noise cancelling technology, built in microphone for clear phone talking.
Product Features:
● Reversible Type-C plug design, no need to check the plug orientation.
● High-quality digital decoding chip has high decoding and high signal-to-noise ratio, greatly reduces the attenuation of audio during transmission.
● Dynamic driver + ceramics driver, produces richer immersive sound.
● Thin ceramic speaker unit produces smooth and high-definition sound quality through two-way vibration.
● Ergonomic bevel in-ear design, brings comfortable wearing feeling.
● High elastic TPE wire, environmentally friendly non-toxic, soft touch, temperature resistance.
● Built-in MEMS microphone, precise feedback, brings a better talk sound.
● Wired control, more convenient to use.
● Hi-Res audio recognized provides CD level sound quality.
There are a few things that Xiaomi are noted for, two of them being good price-quality ratio and design "affinity" to Apple devices. The Xiaomi BRE02JY earbuds are the perfect example of both, at least at the first glance. They look very similar to Apple earbuds, and are priced at just $24.99 on GearVita: https://gearvita.com/xiaomi-bre02jy-...r-earbuds.html
You may also like:
best xiaomi mi 8 lite 128gb
buy xiaomi airdots bluetooth headset
Staro 05.01.2019., 09:15   #110
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Meizu BAR01 Bluetooth Audio Receiver Brings Your Wired Headset to Wireless Experience
Meizu BAR01 Bluetooth audio receiver is designed for owners of wired headset that cannot be used with a smartphone or other device without a 3.5mm audio jack, it also serves as a music playback control console.
Product Features:
● Simple and elegant, adopts the moon arc design, the surface is made of special specular material.
● Unique ring light offers a warm indicator. The back clip is designed with a brushed spring, which is firm and intimate.
● Bluetooth 4.2 wireless transmission technology, low power consumption, providing wide-band sound coverage of 20Hz-20KHz.
● 100mAh large capacity battery brings 6h play time with 1.5h charging.
● Small and exquisite, lightweight to 8g, easy to carry.
● Built-in highly integrated chip, gives your audio equipment wireless function with 3.5mm interface.
● One-button control to answer/hang-up call, pause/play music.
● Comes with 3.5mm audio cable, enjoy the wireless music at anytime.
● Compatible with external headset, home speakers and car stereo with 3.5mm jack.
This Bluetooth audio receiver costs only $17.99 on GearVita, which is equivalent to the price of an audio tieline. Whether you are an Android user or a user who is about to purchase a new iPhone X, this product will reactivate your 3.5mm wired headset: https://gearvita.com/meizu-bar01-blu...-receiver.html
You may also like:
cheap xiaomi mijia aqara hub gateway
best xiaomi redmi note 5
Staro 07.01.2019., 08:36   #111
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Meizu LIVE Quad-Driver Earphones with Professional HiFi Headphones Configuration
Meizu LIVE quad-driver earphones feature an ergonomically-engineered design, the wrap-around structure prevents auscultation effects while balancing stability with a snug fit, making it usable in different occasions. Applying unique transparent case combined with a metallic body, revealing the interior components in a complete structure what allows you to "see" the sound.
Product Features:
● A mix of transparent polycarbonate and metal parts constructed using metal powder metallurgy.
● Inside the earphones are four precisely engineered balanced armature unit which has low-frequency armatures and medium and high-frequency armatures.
● High-quality wire with 8 high-purity silver plated OFC core weaving, low resistance to ensure high-quality signal transmission.
● Split-type audio transmission structure, to achieve superior sound separation and imaging.
● Replaceable tuning nozzles allow you to change the frequency as you deem fit.
● Universal interchangeable MMCX coaxial connectors are used in most of high-end headphones.
● Comes with 7 pairs of earbuds of different sizes and an IPX7 rated carrying case.
What is the equivalent of these elements come together on Meizu LIVE? It is equivalent to the configuration you can see in the professional HiFi headphones you can see on the market, this is a complete free combination system. Buy it from GearVita if you feel tempted: https://gearvita.com/meizu-live-quad...-earphone.html
buy xiaomi 70mai dash cam pro
buy airdots headset
Staro 08.01.2019., 07:50   #112
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
OnePlus BT31B Bullets Wireless Earphones - Free Your Music
The OnePlus Bullets Wireless earphones comes built-in with aptX Bluetooth support and Energy Tube technology for clearer and accurate sounds, as well as support for OnePlus's proprietary Dash Charge fast charging technology, when any USB-C charger is used to power up, it gets up to 5 hours of usage with just 10mins of charging. It is sweat and rain resistant, Google Assistant enabled and also has a Magnetic Control feature (works only with the OnePlus 6, 5T and 5) which automatically turns on the Bullets Wireless and resumes music when each ear is kept separate. Once the ears are clasped back in place, music is paused and the earphones switch off.
Product Features:
● Comes with a neckband design, no winding and entanglement.
● The earplugs can stick together due to the magnetic design, easy to store, also has a functionality of pausing and resuming the earphones power state (only available with OnePlus 5, 5T and 6).
● Supports Dash flash charging, charging for 10mins, can listen to songs for 5 hours.
● apt-X wireless transmission technology provides you with millisecond efficient connectivity and better wireless sound quality.
● Sustom-built bile bass technology improves the standing wave that disturbs the sound in a sound cavity of only 9.2mm, makes the bass of the cloud ear clear and through.
● Support life waterproof, help you to resist perspiration during sports, or rain during outdoor activities.
● Perfectly compatible with OnePlus 6.
The OnePlus BT31B which available on GearVita is the perfect ally for lovers of good sound and portability, being wireless devices that provides comfort to you and good connectivity at all times: https://gearvita.com/oneplus-bt31b-s...earphones.html
lenovo air tws bluetooth earphones
best oneplus 6T 4g smartphone 128gb
Staro 09.01.2019., 08:00   #113
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Edifier H230P Earphones - Super Distortion-free Bass Effect
Edifier H230P earphones, pure sound, comfortable to wear, the appearance of outstanding, compatible call, is a hundred dollars within the rare mobile phone standard earbuds alternative.
Product Features:
● Single button control to play/pause video and music, answer/reject/end phone calls.
● With in-ear design and passive noise isolation, dynamic heavy bass and high-resolution terrible sound.
● Compatible with all 3.5mm audio jack smartphones and other devices.
● Designed with an ergonomic tilt-angle.
● Made of soft silicone sweat-proof ear-tips and resistant to water damage.
● High tensile wire characteristics, capable of being stretched.
Priced at $10.09 on GearVita, with the super distortion-free bass effect, it is a great choice for gaming and listening music: https://gearvita.com/edifier-h230p-i...earphones.html
Hot sale products:
cheap huami amazfit 2 stratos
best xiaomi poco f1 lte 64gb
Staro 10.01.2019., 09:28   #114
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Huawei Myna AI Smart Speaker - A Wisdom Steward of Professional Tuning
The Huawei Myna AI smart speaker uses Danish speaker company Dynaudio audio technology, paired with Huawei Histen algorithm, which can be found on Huawei phones. The 2.25 inch high-fidelity, 10W speaker has six microphones and voiceprint recognition to distinguish different family members voices.
Product Features:
● Dynaudio Sound Quality
Hand in hand with Dynaudio joint tuning, unique Dynaudio concept concept speaker, superimposed Huawei Histen algorithm, high pitch clear, bass vigorous, true restore the sound, bring you the feeling of listening like a concert.
● Schedule Steward, Intimate Service
As your schedule steward, Xiaoyi has the functions of meeting time reminder, life memo, travel shopping list, etc., and can help you synchronize to the mobile phone schedule, provides personal intimate service.
● A Conversation, Liberates Hands
It is a speaker, also a smart phone. You can pick up and dial the phone through Xiaoyi or talk directly to your friends and relatives' Xiaoyi speakers. While chatting with friends and relatives, continue to focus on the tasks on hands and release your hands completely.
● Your Life Up to You
Easy to turn on and off the light, adjust brightness and air conditioning temperature, customize go home/read/sleep/away home modes, and control a variety of home appliances in one sentence.
● Massive Home Appliances, Follow Your Sound
Xiaoyi can regulate a large number of household appliances, from big air conditioners and purifiers, to small sockets and drying racks, all of which can be adjusted in response to the sound.
● Capture Your Voice without Fear of Interference
Six annular microphones, advanced anti-jamming algorithm, full-scale capture of sound within five meters, even in the noisy environment, Xiaoyi can respond sensitively to the instructions you send.
● Smart Encyclopedia, Versatile
Xiaoyi has a lot of skills, from searching maps, learning English, to talk shows, telling children's stories, to enrich your listening content.
● AI Life, Know What You Think
Xiaoyi can set the answer to your questions and home linkage according to your preferences. Every instruction that you send out, Xiaoyi answers, is what you think.
● As Intimate As A Loved One
Just like a family, Xiaoyi cares about your life in an all-round way: wake you up in the morning, remind you of the weather, and kindly advise you to dress appropriately. Before you go out, helps you broadcast traffic information, avoid congested roads in advance.
● Smart Speaker, Also Bluetooth Speaker
You can tell Xiaoyi the songs you wants to listen to, can also play music through the speaker APP. You can easily connect to Bluetooth and play music from your mobile phone, pad, and computer with the phrase "Xiaoyi, Open Bluetooth".
The Huawei Myna with simple design, dexterous shape, exquisite fabric, and more powerful dustproof. Whether the nebula white or space black on GearVita, both can be easily integrated into the home environment: https://gearvita.com/huawei-myna-ai-smart-speaker.html
Top sellers on our website:
cheap qcy t1c mini wireless earphones
xiaomi mi 8 lite 128gb in stock
Staro 11.01.2019., 08:46   #115
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Edifier TWS3 Wireless Bluetooth Earphones - Ready Play Your Favorite Music
Enjoy a true wireless sound with the Edifier TWS3 wireless Bluetooth earphones. No longer be tied down by cables again, each ear is separated on their own making them incredibly portable and compact. Bluetooth V4.2 ensures the connection remains stable and strong like Bluetooth was first envisioned as.
Product Features:
● Left and right ear separated design, wireless implicated.
● Small and lightweight, casual and fashionable new items.
● CSR Bluetooth chip transmission is smooth, reducing latency.
● 8mm neodymium drivers produce natural highs and deep bass.
● Split model in left ear and right ear, wireless connection.
● Omnidirectional microphone, CVC call noise reduction.
● Multifunction button, answer/hang up, change music.
● Textured paint charging box, magnetic card slot, stable storage.
● Total running time of up to 12 hours
● Charging case can charge earphones up to three times.
● IPX4 splash and sweat proof for sports.
● Built-in hall magnetron sensor, when removed/inserted from the charging box, the earphones turn on/off automatically.
● Bluetooth V4.2 with CSR technology with control button on each earphone.
● Included eartips allow for finding the fit perfect for the size of your ear.
GearVita provides four color options, with powerful bass details and force, the Edifier TWS3 will create sound and feeling listeners relaxed wearing earphones like not wearing: https://gearvita.com/edifier-tws3-tr...ones-2pcs.html
cheap xiaomi airdots headset
best lenovo z5 pro 64gb
Staro 14.01.2019., 08:09   #116
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
JBL T110 Bluetooth Stereo Earphones - Listen On The Go
Featuring JBL pure bass sound, the JBL T110 earphones offer a wireless solution anytime, anywhere for your everyday usage along with the ability to make or take hands free calls and 6 hours of battery life. The earphones can be quickly charged in 2 hours, feature a flat tangle free cable and are lightweight enough to comfortably wear for hours on end. When you combine magnets that ensure the earphones are not dangling when not in use, the tangle-free cable, comfort of the ergonomic eartips and neckband design, easy to see how the JBL T110 earphones can become an essential part of your day-to-day music loving life.
Product Features:
● JBL Pure Bass
With high-performance titanium dynamic drivers, reproduces that same JBL sound, punching out deep and powerful bass.
● Magnetic Suction Design
Ensures the earphones remain comfortably secure and tangle-free around your neck when not in use.
● Flat Tangle-free Cable
The tangle-free cable can effectively avoid knot problem.
● Hands-free with Mic
Built-in microphone enables hands-free calls to set free your hands when doing sports, it also supports multi-point technology.
● 3 Buttons Line Control
Easy to control playing/pausing music, adjusting the volume, previous/next songs, answering/ending calls.
● Long Battery Life
Micro USB charging built-in battery provides 6 hours of playing time, with quick recharge in just 2 hours.
● IPX4 Sweat-proof
Sweat resistance design, suitable for sports. Don't be afraid of the sweat in your earphones, don't worry when exercising for a long time.
The T110 has been built to accompany you on all your adventures. Lightweight and durable, it is meant to be carried around wherever you go. Get it from GearVita and take it on adventure whenever you feel like: https://gearvita.com/jbl-t110-blueto...earphones.html
You may also like:
cheap xiaomi redmi 6a global version
best oneplus 6T 4g smartphone 256gb
Staro 15.01.2019., 07:15   #117
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Xiaomi Xiaoai HD Bluetooth Speaker - 360° Sound, Intelligent Interaction
Xiaomi Xiaoai HD Bluetooth speaker is equipped with a high-power full-range speaker array, 104mm large-caliber woofer + dual passive passive radiator, 360° omnidirectional sound, with strong performance and rich musical expression. The speaker unit has been carefully designed into a three-dimensional stereo structure to give you an immersive wrap-around listening experience. And support DSP dynamic compensation and Bluetooth connection, built-in small love classmates powerful, it is an indispensable entrance for high-quality smart home.
Product Features:
● Internal components effective dust protection without affecting the sound transmission effect.
● Four buttons on the top — power button, volume up, volume down, and play/pause button.
● High-power full-range array offers strong performance and rich musical expression.
● Optimized sound field and the 104mm large-caliber woofer have a more accurate transient response.
Large caliber woofer, double passive radiator, surging bass shock every nerve.
● Three-dimensional stereo structure, delivers an immersive 360-degree surround sound.
● DSP automatically compensate and adjust the audio according to the volume, dynamically adjust the tri-band loudness for a balanced sound field.
● Uses dual band WiFi and Bluetooth 4.1 technology to support A2DP music playback.
● Ring high sensitivity microphone array that consists of six high-sensitivity microphones, ensures accuracy in voice recognition and quick response to those commands.
● Supports the intelligent voice interaction with XiaoAi smart assistant, controlling the smart devices in the home.
Xiaomi Xiaoai Bluetooth speaker adopts minimalist design and Morandi color matching, dark gray models are made of textured weave, and light gray models are made of sofa woven fabric, which is both harmonious and distinctive: https://gearvita.com/xiaomi-xiaoai-h...h-speaker.html
Hot sale products:
xiaomi qi standard wireless fast charger
Staro 16.01.2019., 08:45   #118
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Huawei Honor Flypods Youth - Tap Control, Noise Reduction, 12H Playtime
Huawei Honor Flypods Youth is a TWS Bluetooth earphone that supports double-clicking touch control, allowing you to get rid of the constraints of cables and bring a free experience. With the in-ear style design, it is very convenient when driving and doing sports.
Product Features:
● Automatic Matching
Automatically sense the wearing state, remove the headset will automatically pause the music.
● Compatible with Android and iOS System
With a signal distance of 10m, whether you are traveling, shopping, sports or home, your mobile phone is inseparable.
● Exquisite Fashion
The color is beautiful, the earphones are streamlined surface design, simple and stylish.
● Double Click to Summon Voice Assistant
Double-click the left earphone to call the mobile voice assistant, support Huawei Honor voice assistant YOYO, Siri and so on.
● Double Click to Control the Music and Incoming Calls
When you call, double-click on either side of the earphone to answer or hang up. When wearing the earphones, double-click the earphone on the right to play/pause the music.
● Noise Reduction Call
The left and right earphones are equipped with two high-precision and high-performance silicon microphone, which match the call noise reduction technology, and collect and process the environmental noise during the call to achieve better call performance.
● Smart Binaural Calls
You can switch between the left and right earphones when calling, and you can answer the call with one ear and two ears.
● Stereo Sound
The high-quality dynamic unit and balanced adjustment technology make the sound clearer and the middle and high frequency more thorough, bringing a rich and detailed sound effect.
● IP54 Dustproof and Splashproof
After professional nano-coating treatment and waterproof structure design, the earphone has passed the IP54 third-party professional certification. Whether it's sweating or raining, the earphones work properly.
● More Comfortable to Wear
Ergonomic in-ear design with three models of earmuffs and sporty breathable earmuffs, skin-friendly silicone for comfortable fit.
With the coupon code "HUAWEI10", this Honor Flypods youth version can enjoy 10% discount: https://gearvita.com/huawei-honor-am...earphones.html
xiaomi mijia quartz smartwatch
Staro 17.01.2019., 08:12   #119
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Make Your Music Mobile, with JBL Go Bluetooth Speaker
Featuring Bluetooth connectivity, the JBL Go speaker streams music from smartphones and tablets through wireless pairing, powered by a rechargeable battery with up to 5 hours of playtime. It features a convenient noise and echo cancelling microphone, allowing you to pick up calls without turning the speaker off. The JBL Go has a compact and light weight design, built-in strap-hook and optional carrying strap, allow you to bring your music everywhere. With a smooth and durable double-injection finishing, it provides exciting, eye-catching contrast wherever it goes and easily compliments anyone's style. The speaker has a range of buttons that let you adjust the volume and change the settings according to your preferences.
Product Features:
● Take with You Anywhere
Weights only 130 grams, excellent for those constantly on the move.
● Bluetooth 4.1 Wireless Connectivity
Supports Bluetooth 4.1 up to a maximum diatance of 10 meters.
● Handsfree Calls
Using the built-in HD microphone which with noise and echo cancellation to answer calls with the touch of a button.
● 5 Hours Listening Time
Uses high performance polymer batteries, providing up to 5 hours of continuous listening time.
● Multi-device Compatibility
Can be used with smartphones, tablets, laptops, and music players via Bluetooth or AUX lines.
In a world where style and audio go hand in hand, the JBL Go is everyone's perfect companion: https://gearvita.com/jbl-go-mini-por...h-speaker.html
You may also like:
lenovo z5 pro 64gb
Zadnje izmijenjeno od: gearvita. 17.01.2019. u 08:24.
Staro 18.01.2019., 08:08   #120
gearvita
gearvita's Avatar
Lokacija: China
Postovi: 241
Lenovo B613 8G Micro Recording Pen - What You Hear Is What You Get
Lenovo B613 micro recording pen is equipped with a high-definition microphone, high sensitively recordes all sounds without any reservations. The saved files are lossless HD audio, just like what you hear with your own ears. Recording starts when sound is detected, and turns off recording when there is no sound, saving memory and power. There is no light and no sound during recording, and the file generation time and end time are recorded, which is convenient for browsing and finding files.
Product Features:
● Full Aluminum Housing
Aluminum material is durable and high quality, one button to record, unique and fashionable design.
● 0.9 inch Display
Shows real time recording state, clear recording time and file name.
● Superior Sound Quality
Records 1536Kbps crystal clear voice with noise cancelling technology, perfect for class, lectures, meetings, interviews, court sessions and more.
● Voice Activated Recording
Starts recording automatically when sound is detected, you can also set it to start recording at a specified time.
● Long Working Time
Built in 8GB internal flash memory and rechargeable battery provides up to 15 hours of continuous recording and 20 hours of playback via the integrated MP3 music player.
● Easy File Management
Recorded files are saved with timestamp, easy for you to manage recorded files, you can also connect it to your PC via the provided USB cable to manage audio recordings or MP3 files.
● A-B Repeat Mode
Mark A, B in a recording being played and the file repeats from the 'A' mark to the 'B' mark.
● Intelligent Power Detection
When the power is off or low voltage, the recording files are automatically saved to ensure them are safe.
● A Few More Extras
Foolproof design, REC key to start and save the recording, auto recording, record monitoring, fast forward and rewind during playback, lock to avoid misoperations.
A variety of functional configurations give you more extraordinary, multiple scenarios help you complete your work and study: https://gearvita.com/lenovo-b613-mic...ng-pen-8g.html
You may also like:
xiaomi mi mix 2s smartphone 128gb
