Staro 20.03.2018., 02:20   #91
Gigi1
Postovi: 2,138
ima li tko ovdje da je probao XMR stak i claymore cryptonote gpu miner na istom gpu i da li je bilo razlika u h/s?
moze i neki treci popout sgminera ako je probavan...ugl citam po netu neki govore claymore neki govore xmr stak...
Staro 20.03.2018., 02:23   #92
Neo-ST
Neo-ST's Avatar
Postovi: 8,508
probao sva 3, xmr-stak najbolji (meni).
Staro 28.03.2018., 00:22   #93
...Tihomir...
...Tihomir...'s Avatar
Postovi: 349
Zanimljiva novost za Vega minere: Navodno su izašli novi driveri: 18-3-4 march 23 koji rade kako treba, iliti daju normalan hash rate kao sa beta blockchain driverima :-)
info:
https://forums.overclockers.co.uk/th...-3-0.18815432/
https://bitcointalk.org/index.php?topic=2256917.1900
...Tihomir... je offline   Reply With Quote
Staro 28.03.2018., 07:17   #94
lit
Lokacija: hr
Postovi: 977
Ako je isto kao blockchain driveri onda ne vidim zašto bi ljudi prelazili na nove: don't fix what is not broken.
Kad su već radili nove driver onda su automatski trebali biti 10% bolji, i nakon ovih testiranja u public dodati još 10%. Ovako ne vidim svrhu nikakvu.
Sa btctalk foruma:
Just tested the new drivers vs the old blockchain drivers.
Hash rate is slightly down on each of my Vega's by at least 40-50 h/s (with 8x Vega 64's)
Also even though I applied the powertables, when opening OverdriveN most of the powertable settings get greyed out (I tweak some of the settings with my own profile within OverdriveN) when you apply settings.
And powerdraw is slightly up, might be because of the powertables/OverdriveN not working properly.
So. . .
Switched back using the old blockchain drivers and all working fine (better hash, power and overdriveN working properly)
Needless to say I'll be staying put for now with the blockchain drivers until things get updated.
One thing to note you don't have to reset the drivers after rebooting with the new drivers which is the only plus I can see for now.
Zadnje izmijenjeno od: lit. 28.03.2018. u 07:23.
lit je offline   Reply With Quote
Staro 29.03.2018., 00:29   #95
...Tihomir...
Postovi: 349
Autor lit Pregled postova
Sa btctalk foruma:
So. . .
zanimljivo, točno suprotno od onih linkova. Tamo piše manja potrošnja, ovdje veća. Ipak mi izgleda da je ovaj tvoj detaljnije napravio test
Poslano sa mog SM-N910C koristeći Tapatalk
Staro 08.04.2018., 15:38   #96
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Se isplati ovo sad kopati? Vidim da je težina malo opala.
Uopće ga ne izlista na whattomine.
Staro 08.04.2018., 16:28   #97
Facelessone
Facelessone's Avatar
Postovi: 4,204
Algo je cryptonightv7.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 11.04.2018., 23:49   #98
livada2
livada2's Avatar
Datum registracije: Oct 2017
Lokacija: nigdje
Postovi: 475
al su zakomplicirali s ovim forkovima.
SAd odjednom umjesto jednog imamo tri criptonight algoritma i svaki drugacije daje . cast-xmr cak ni ne podrzava light i heavy nego samo v7.
Ktome ovi heavy nisu isti za sumo i heaven npr. pa ovaj criptonightlite ne radi sa sttelite.Znaci ima ih bar 5 varijacija koje su razlicite
Hevy daje puno manji HR al i trosi manje
light daje duplo od v7
v7 daje mrvicu vise od bivseg criptonight-a
3*vega56:
Criptonight stari 5500-5600HR 520W
v7 - 5800 530W
light - 11000 530W
heavy - 4150 493W
Zadnje izmijenjeno od: livada2. 12.04.2018. u 02:15.
livada2 je offline   Reply With Quote
Staro 14.04.2018., 09:50   #99
...Tihomir...
Postovi: 349
Autor livada2 Pregled postova
3*vega56:
v7 - 5800 530W
light - 11000 530W
heavy - 4150 493W
hvala za share potrošnje i h/s.
Inače, xmr-stak ima config za razne coine u zadnjim verzijama.
Staro 14.04.2018., 10:33   #100
lit
Lokacija: hr
Postovi: 977
@livada2 jel možeš poslati config file od overdriventool-a za svoje vege 56 ovdje https://files.fm/
hvala
Staro 14.04.2018., 11:01   #101
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
hvala
ne radim sa overdriven nego preko wattmena
gpu 900mv
mem900mv
gpu1407mhz
mem 1090-1100mhz kako koja
spomenute su psotavke na prvoj stranici vec,
Staro 14.04.2018., 11:05   #102
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Autor ...Tihomir... Pregled postova
imam 2.4.4 al u njoj ima heavi samo za sumo
jos nisam nasao nijedna u kojem su svi .
Najviise me zivcira sto ima podvarijanti pa jedan heavi ne radi sa svim coinovima nego bas moras izabrat coin a ne algoritam sto znaci da svaki coin moras nesto cackat .
Lako je onom ko je baziran na jednom coinu, al ja svako malo idem kopat neke nepoznate coinove da se nadju
onda se neki forka pa moram 5 varijanti staka isporbat dok ne nadjem s kojim radi
onda nadjem nek is manjim fee i ima u popisu i heavi i lite al npr ne radi s TRTL mada pise da podrzava lite a i heavi mu radi samo s sumo
* aeon7 (use this for Aeon's new PoW)
* cryptonight (try this if your coin is not listed)
* cryptonight_lite
* edollar
* electroneum
* graft
* intense
* karbo
* monero7 (use this for Monero's new PoW)
* sumokoin
Zadnje izmijenjeno od: livada2. 14.04.2018. u 11:11.
Staro 17.04.2018., 02:26   #103
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Isprobao sam SRBMINER i pokazao se jako dobar za novi Cripronight.
Podrzava sve verzije-normal -lite-litev7-heavy-ultraheavy
Dev fee je samo 0,8% a HR daje cak nesto veci od cast-xmr a dosta veci od staka i sgminera
npr na staku sam imao na sumu 4100 i nisam mogao natjerat nikako na vise a sad imam 4440 .
litev7 na cast daje oko 10800 ovdje preko 12000
tako je sa svim podvarijantama. naravno da onda i vise struje povuce...
evo par rezultata za 3*vega56
lite 540W
lite v7 555W
heavy 500W
ultraheavy 520W
Zadnje izmijenjeno od: livada2. 17.04.2018. u 02:31.
Staro 17.04.2018., 14:01   #104
lit
Lokacija: hr
Postovi: 977
Monero je light v7 ?
Staro 17.04.2018., 16:33   #105
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
normal v7
- Cryptonight
- Cryptonight V7
- Cryptonight Lite
- Cryptonight Lite V7
- Cryptonight Heavy
- Cryptonight UltraHeavy
Cryptonight: Electroneum, Karbowanec, Bytecoin, Dero
Cryptonight v7: Monero, Graft, Stellite ...
Cryptonight Lite: Aeon
Cryptonight Heavy: Sumokoin
Cryptonight UltraHeavy: IPBC
Staro 02.05.2018., 22:22   #106
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
TEST SRB MINERA sa VEGA 56 karticama
INFO - TEST VEGA 56 PowerColor
3*Vega56 flashed to 64
Crimson-ReLive-Beta-Blockchain driver
SRBminer 1.4.9
GPU - 1442/1437/1407mhz 905-907mv
MEM - 1095/1100mhz 900mv
Cryptonight V7(monero)
"intensity" : 120 HR=6000 - 560W
Cryptonight lite(aeon)
"intensity" : 235 HR=12900 - 570W
Cryptonight liteV7(trtl)
Cryptonight ultraheavy-lightv3(ipbc)
"intensity" : 239 HR=11100 - 550W
Cryptonight heavy(sumo)
"intensity" : 56 HR=4550 - 530W
Cryptonight artocache(arto)
"intensity" : 118 HR=5400 - 550W
Staro 02.05.2018., 23:09   #107
lit
Lokacija: hr
Postovi: 977
Odlično, nego daj reci jel si koristio onaj overdriver ili wattman ili neka druga kombinacija.
Jel rade stabilno?
Staro 03.05.2018., 00:10   #108
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Jel rade stabilno?
sve preko watmena. kad sam ustanovio tocno kolko koja kartica moze onda sam to ubacio u registry windowsa da ne moram stalno upisivat nego su mi sad to defaultne vrijednosti. npr u watmenu kad je gpu na 0% onda je prva kartica 1442mhz i 905mv a 3 kartica kad je na 0% onda je na 1407 i na 907 mv jer jedino tako radi stabilno
Na ovim postavkama sve radi stabilno vec danima.
Ovo gore su maksimalne postavke za moje kartice i tu bi se jos mrvica potrosnja dala smanjit jer ovo je makismala na HR.
npr heavy kad se stavi na 4400hr trosi ispod 500w a ovako na 4550Hr trosi 530W. Pa zato i ventilatori vrte cirka 300okretaja brze za istu temperaturu.
Staro 03.05.2018., 21:36   #109
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
skinuo sam overdrive i evo SS iz njega i iz GPU z pa mozda nekom pomogne
GPUz SS - GPU Z odma ugasi HBM memoriju i HR sa 1500 padne na 1300 i ond amoram uplait xmr-stak da mi opet upali hbm nemam pojma zasto
Staro 04.05.2018., 02:15   #110
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Moze preporuka za MBO a da provjereno radi barem 6 VEGA bez puno postelavanja.
Po netu se spominje GA-H110-D3A(6card) i asus PRIME Z270-P (8 card) al treba nesto postelavat po biosu.
PA ako netko koristi 6 ili vise vega rado cu poslusat savjet.
Sad mi 3 vege trosi 500-550w iz zida (znaci 6 bi trosilo oko 1000W a po netu svi spominju za 6 vega 2*1000 sto mi se previse cini
Dal bi mi 2*650 gold / 750W bronce ili silver bilo dosta?
hvala
Staro 04.05.2018., 15:53   #111
lit
Lokacija: hr
Postovi: 977
Na d3a matičnoj radi 6 komada, provjereno.
Staro 04.05.2018., 19:12   #112
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Thx
Danas sam malo isprobao cast_xmr-vega-win64_100.zip i evo rezultata
Postavke su potpuno identicne bile i test je radjen na istom algu (SUMO) u par minuta
CAST-xmr: 4520hr
SRBminer 1.4.9: 4552hr
Staro 19.05.2018., 11:47   #113
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Sta je moguce da saphire nitro vega 56 daje slabije rezultate nego obicna power color vega 56?
Mislio sam da je nitro najbolja izvedba kartice. Ok hladna je i ne zuji al rezultati su joj koma u odnosu na uvu powercolor.
powercolor ima samsung memoriju i na hevy daje preko 1500hr na v7 2000hr.
na postavkama. gpu 1442mhz 905mv i mem 1100 900mv.
ova nitro ima hynix memoriju i daje na hevi 1430hr na v7 1850hr.
na postavkama gpu 1427mhz 920mv i mem 1020 910mv al i tu puca.
ova nitro se neda dic ni blizu 1100mhz memorije :
trosi vise struje a daje slabije rezultate. Jedini dobitak je sto je stvarno tiha i hladna mad da i powercolor stavim da kopa tak malo i ona bi bila tiha ...
ako netko ima nitro+ vegu 56 modanu na 64 da posalje ss overdrivetoolsa.
thx
Staro 19.05.2018., 21:19   #114
ruthr
Datum registracije: Dec 2017
Lokacija: os
Postovi: 5
Pozz
ko zeli majnat xmv (monerov) ima server u HR xmv.cyberideas.hk pa nek navali dok je jos diff mali.
ruthr je offline   Reply With Quote
Staro 20.05.2018., 22:12   #115
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Negde sam danas nešto pročita da ce kina zabraniti ove valute (coine) koje su anonimne
(Dash, monero, sve skupa 4) nešto u vezi zakona o pranju novca!!! Neznam koliko ce to uticat na cijenu! Eto samo da spomenem.
tipkano sa mog T98 4G八核(C6R3)
MinigRig*H110-D3A*5*rx570nitro8GB OC.
gloginjaR je offline   Reply With Quote
Staro 21.05.2018., 00:04   #116
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Jel netko uspio automatizirat vege da rade na HEAVY algu? imam automatizaciju da se resetiraj ukartice al na hevy algu to ne pomaze i ne radi _HBC memoriaj dok ne promjenim intenzititet na vise pa na manje a to neznam izvest u skripti koju koristim.
znaci trbao bi upalit miner na 60 intenzititet pa ugasit pa opet upalit na 56 i onda tek proradi hnc memorija .
Staro 26.09.2018., 17:11   #117
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,604
Iz kojeg si ti oblaka ispao?
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.10.2018., 17:43   #118
dada-as
Bot Maker
dada-as's Avatar
Postovi: 2,741
meni hashrate na novom mineru na koji smo morali preci jucer sad radi slabo, 1500.
Koristim XMR-stack, jel ima kakvog rjesenja, prije je radilo od 1950 do 2000...
Staro 19.10.2018., 18:59   #119
livada2
livada2's Avatar
Lokacija: nigdje
Postovi: 475
Autor dada-as Pregled postova
v8 daje manji rezultat na vegama otprilike 5% i trosi puno vise struje cirka 30/35W vise po kartici.
6 vega nitro na v7 davalo cirka 11660HR i trosilo 970W iz zida
a na v8 daje 11100HR i trosi 1170W iz zida
SAMOANA: Nije u šoldima sve
Nadmudrivanje sa budalom je kao hrvanje sa svinjom u blatu ..... nakon nekog vremena skužiš da svinja uživa
