Staro 08.10.2009., 02:06   #91
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,129
Evo drustvo, sprojektiral sam si novi stol, trenutno je u pripremoj fazi za izradu. Pa mozda netko dobije neku ideju za svoj stol ili predlozi meni jos nesto korisno
http://img.skitch.com/20091007-crnxy...7yuec46rtm.png
http://img.skitch.com/20091007-kqba5...w543u8y84a.png
http://img.skitch.com/20091007-r9ttt...8tpq6dh38g.png
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 08.10.2009., 05:13   #92
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
U bem ti koji stol
Buraz mi ima maltene isti takav no bez ladica i onih polica gore.
Ja bih monitore ipak ostavio na stolu. Ako zatreba približit, udaljit
ili okrenit baš nema manevarskog prostora. Pogotovo što su dva.
stuc je offline   Reply With Quote
Staro 08.10.2009., 07:29   #93
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
http://www.imagesforme.com/show.php/...lnaverzija.JPG
http://www.imagesforme.com/show.php/723040_drugikut.JPG
Evo ovako ja zamisljam.Stol koji bi trebao biti 160x110cm i sa lijeve strane integriran rack za komponente,u biti 3x police. Planiram uzeti plastificirani medijapan(svi rubovi,netreba kantiranje) debljine 25mm i postaviti ga na 6 alu cijevi koje ce najvjerovatnije biti punjene pijeskom radi cvrstoće
Na http://www.mo-bis.hr/ sam saznao da bi za MDF 25mm debljine dimenzija:
160x110cm x1
50x90cm x3
kostalo oko 1800kn
+ sto bih trebao jos oko 350-400kn za noge.Znam da ce vecina sada reci da je puno ali nije iverica pa je i cijena takva+ sto nema muke oko kantiranja nego su sve povrsine jednake...
Jedino sto me jos muci je postavljanje polica na takve okrugle noge i cable management iako imam za kablove vec dosta ideja...
slobodno mi recite pohvale,kritike,dodatne ideje...im all turned in ear
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 08.10.2009., 11:30   #94
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,016
@stuc: Evo, ovako sam ja to zamislio. Računica je rađena za iveral debljine 18mm (Elgrad). Visina ti je 65cm (1,8cm + 61,4cm + 1,8cm) do gornje ploče. Ali na to moraš dodat još visinu nogica, a njih ima raznih. Inače, 65cm je malo, neki standard je 70 - 72 cm do gornje ploče.
Iz računice ispada da imaš 3,89 m2 iverala ali to uzmi s rezervom pošto obično bude i nešto restla koji također moraš kupit. 3,89 m2 iverala po cijeni od 73,68kn + usluga rezanja iznosi 343,92 kn. To je minimalna cifra, kolko će bit, najbolje je provjerit na licu mjesta. Odeš tamo i zatražiš predračun. Imaš i točno 15 m kant trake. Što je nekih 87 kn ako ideš na melamin traku ili 180 ako ideš na ABS kant (koji je naravno bolji). Možda da napraviš kombinaciju - ormarići u melaminsku traku a gornja ploča koja je izložena svemu i svačemu da bude kantirana ABS-om. To je onda neka sredina i trošak iznosi cca 120 kn.
Na to moraš dodat i 8 nogica (kotačići su dosta jeftiniji) te nešto šarafa.
Možda ako ostane neki restl dužine gornje ploče (a to vidiš kad frajer ubaci u komp mjere pa dobije plan rezanja) da ga se zašarafiš otraga na ona dva ormarića a ispod gornje ploče. Radi podupiranja radne plohe pošto imaš tu mrcinu od monitora.
Eto, mislim da ispod 500 - 600 kn nemoj ni računat da će koštat.
Ak te još šta zanima, reci.
@micek_kc: kad to tvoje preračunaš, dobiješ cijenu mediapana od 580 kn po m2???
To je i dalje mediapan samo što je plastificiran. I što ti znači to da su sve površine jednake? Šta, na iveralu nisu? Muka oko kantiranja? LOL. Pojasni. Odeš tamo, platiš kantiranje i to je to. Iveral od 25 mm košta od 90 - 100 kn/m2. ABS kant 25 mm iverala košta 18 kn/m. Pa ti izvuci računicu. Punjenje nogu pijeskom je isto nepotrebno. Te noge se rade od aluminija da bi bile što lakše. A čvrste su dovoljno. Postavljanje polica na te noge bi moglo predstavljat problem.
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 08.10.2009., 16:32   #95
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Autor fanATIk Pregled postova
To su mi rekli ugrubo cijenu.Ja bi definitvno isao na medijapan jer mi je iveral nekako slabašan.Sa time ulazi i busenje rupa za alu-cijevi po promjeru.Sad samo gruntam kako da slozim postavljanje polica pošto su noge okrugle.
A ovo sto su sve povrsine to sam mislio da se nemora kantirati nego te rubne površine izgledaju isto ko i ostale te nema prijelaza.
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.10.2009., 16:43   #96
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
to je u autocadu radjeno ili?
btw. za ideju
V.I.P je offline   Reply With Quote
Staro 08.10.2009., 17:00   #97
Facelessone
Facelessone's Avatar
Postovi: 4,205
google sketchup
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 08.10.2009., 18:07   #98
fanATIk
NITKOV
fanATIk's Avatar
Postovi: 4,016
Autor micek_kc Pregled postova
Cijena ugrubo? Zaokružimo onda na 600 kn. Bacanje novaca ako mene pitaš.
Iveral slabašan? Predpostavljam da činjenica da je 99,9 % ponude što ga možeš vidjet po dućanima namještaja izrađeno od iverala tebi ne znači ništa. Mislim ono, u životu nisam sjebo komad namještaja ne računajući stolice. Koje su od drveta. Kaj planiraš, testirat građevinsku mehanizaciju na namještaju?
Vauuuuu, i bušenje rupa je u cijeni... OK, bušenje u mediapanu je zajebano, znam, al ipak...
Kantirana površina izgleda kao i ostale. ABS kant je vrlo tvrd i spriječava moguća slučajna oštećenja u uporabi. U principu, inače jedino što i možeš oštetit je rub. A sad, jel taj tvoj plastificiran rub jači od ABS-a i opravdava li 5 puta višu cijenu, sumnjam.
Plastificirani mediapan je po meni OK rješenje za kupaonski namještaj (mada evo svi moji ormarići u kupaoni izgledaju ko i prvi dan a rađeni su od normalnog iverala prije 10 godina). U ostalim slučajevima nema neke potrebe za njim, bar neke normalne koja opravdava tu cijenu.
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 08.10.2009., 18:20   #99
Red Dwarf
Bajker s AMD-om na dresu
Red Dwarf's Avatar
Postovi: 960
@superunknown...
jesi siguran da te nece zaboliti glava ako su monitori ovako "malo viši"...ja sam ih bio imao uzdignute isto [doduse malo vise uzdignute] i ipak malo bolji glava na kraju
i neznam kako tebi ali ja bi ipak uzeo malo dublji stol...70cm...neznam bas...doduse ja nemam ovo za tipk i miša ispod stola nego mi je to na stolu pa zato kazem...meni je stol 80cm i fali mi jos zbog tipk i misa...
Red Dwarf je offline   Reply With Quote
Staro 08.10.2009., 19:03   #100
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Plastificirani medijapan je otporniji na grebanje i sve od iverala.razmisli,vjerovatno iz tog razloga i jest veca cijena.
I btw ne kanim raditi mehanizaciju na stolu ali gle...na police ide receiver koji ima 18kg,kada dodje dvd player koji ima 12...kuciste mi sa svime unutra ima 25kg...pa ti racunaj
Logitech MX500
DELL 2007FP
Abit AV8
Staro 08.10.2009., 19:09   #101
Red Dwarf
Red Dwarf's Avatar
Postovi: 960
@micek_kc :
evo ti izdrzljivost iverice : testirano iverica debela 3cm može izdrzati na sredini stola čovjeka od 100 [malo manje ipak ] + reciever 8kg + 2x5kg monitori + bice kojih desetak komp...
pa nije da ces vrece cementa stavljat na sredinu
Staro 08.10.2009., 19:58   #102
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
Pa to je još i dobro jer za te pare stol takve dužine i da je po mjeri baš nebi našao...
Definitivno kombinirano kantiranje s tim da bi sve što se vidi od naprijed išlo ABS.
Širina stola će biti 65cm, danas mjerio što znači i da će ormarići biti duboki 60cm.
Ako sam dobro skužio sa slike ormarići imaju plohu od 18mm i još na to ide 18mm glavne ploče ?
To bi onda trebalo biti puno čvršće nego ovi gotovi/kupovni stolovi jer oni imaju
samo gornju plohu ispod koje idu drito bočne stranice.
Ako ostane viška od glavne ploče to bi valjalo onda iza stola povuć cijelom dužinom
od ormarića do ormarića pa taman da i 2 monitora imam od 25kg bilo bi ok.
Visina me ne sekira, ne volim visoke stolove a mogu i noge promjenit ako baš dođe do potrebe za visinom.
Ajd pliz samo ubaci ove mjere u onaj crtež pa to ja budem nosio njima tamo
Dužina stola 180cm
Širina stola 65cm
Ormarići su onda duboki 60cm ?
Dasku duplog ormarića bi spustio dolje da imam rupu od 25cm a gore koliko ostane, ~35cm.
Onaj drugi bi lako popunjavao policama ili ladicama postepeno ako bude potrebe za tim i ako kanta nebi bila u rupi.
Jel velika razlika u cijeni ako bi uzeo nešto deblji iveral, prvi deblji od 18mm i dali ima potrebe za tim ?
Staro 08.10.2009., 23:31   #103
fanATIk
NITKOV
fanATIk's Avatar
Postovi: 4,016
Nemaš ti previše blage veze o čem pričaš al dobro. Po tvojoj logici bi se moja komoda koja je podnosila 72cm trinitron davno urušila u sebe. Ono, kolabirala bi ko crna rupa. Želio sam ti dat savjet s ciljem da te ne ogule što se financija tiče al vidim da si ti već zacrtao ono što želiš. Kupi plastificirani MDF i živi sretan i u uvjerenju da je iveral evenutalno malo jači od stiropora.
@stuc: Evo, izmjenjeno na širinu stola 65 i stavljen ABS kant na sva čela. ABS je i na obje bočne stranice gornje ploče. Na ostatku bočnih stranica je melamin. Računaj još i na tu poduporu za gornju ploču ako bude takvog restla. Što se tiče deblje iverice, prva nakon 18 mm je 19 mm. Nju drže u iverpanu. Al to ti je isti k. Prva baš veća je 25 mm. Dosta je čvršča i otpornija na uvijanje. I vizualno bolje izgleda zbog masivnosti. Ali računaj da je i skuplja, plus što se 25mm iveral može kantirati samo ABS-om. Iveral 25 mm s uslugom rezanja je cca 110 - 125 kn/m2, ABS 18 mm je cca 18 kn/m.
Tako da to ispada malo skuplje.
Plus što moraš onda i mjere prilagodit.
Možda samo gornju ploču stavit od 25 mm iverala...
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 08.10.2009., 23:57   #104
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
Da, to sad i ja razmišljam no bojim se da ta teža ploča nebi onda previše pritiskala kompletno tanju konstrukciju.
A išo bi na 25mm ako nebi probilo 800kn max. Sam materijal plus rezanje je ~480kn + kantiranje....
Šta ti misliš, dali je do 800kn puno za takav stol ?
@^SuperUnknown^
Jesi pravio možda predračun za svoj i koliko te izađe ?
Staro 09.10.2009., 00:31   #105
Vendetta
Vendetta's Avatar
Postovi: 919
http://www.imagesforme.com/upload/22a6eb62.png
Evo i ja sebi nesto dizajniram, ovo je ugrubo i okvirno kako bi trebalo izgledat. Tu su ravni djelovi stola pre uski, 45 cm, povecat cu ih na 60 cm.
Za gornji dio stola stavite dvije ploce od 18-19 mm, prva spaja sve stranice itd. i tvori ravnu povrsinu na koju ide druga koja je sira u svim smjerovima od svega za 2-3 cm.
Zadnje izmijenjeno od: Vendetta. 09.10.2009. u 00:45.
Vendetta je offline   Reply With Quote
Staro 09.10.2009., 00:55   #106
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,164
Autor Red Dwarf Pregled postova
@superunknown... jesi siguran da te nece zaboliti glava ako su monitori ovako "malo viši"...ja sam ih bio imao uzdignute isto [doduse malo vise uzdignute] i ipak malo bolji glava na kraju i neznam kako tebi ali ja bi ipak uzeo malo dublji stol...70cm...neznam bas...doduse ja nemam ovo za tipk i miša ispod stola nego mi je to na stolu pa zato kazem...meni je stol 80cm i fali mi jos zbog tipk i misa...
Slicno razmisljamo. I za monitore (probao i odustao) i za dubinu stola. Kod mene je 230 sa dubinom 128cm. Ispod metra dubine lovi me nervoza. Obecao sam nekolicini staviti sliku u "radno mjesto" temu pa cu baciti za koji dan. Ali SU je i prije imao po dubini nesto slicno, barem po starim slikama koliko me pamcenje sluzi. Vjerovatno mu je to dovoljno pa ne dozivljava kao ogranicenje.
Staro 09.10.2009., 01:18   #107
Vendetta
Vendetta's Avatar
Postovi: 919
http://www.imagesforme.com/upload/cbcd5d20.png
Evo na ovakvu izvedbu sam mislija.
Dobije se debljina od 37-38 mm.
Staro 09.10.2009., 03:49   #108
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Da li se to meni cini ili si ti "nabrijan" na mene nesto samo zato jer spominjem MDF umjesto iverice/iverala?
Informiram se i trazim nesto sto ce biti dugotrajno jer ne kanim svakih godinu-dvije mjenjati stol.Da ti srce bude na mjestu,cjenim tvoj trud i zelju da me ne oderu i uzeti cu u obzir iveral.
Prvenstveno zbog cega sam htio plastificirani MDF je jer su svi rubovi isti ko i gornje povrsine.ovo je sto cu sada reci je subjektivno ali meni kantiranje izgleda ruzno jer nije u boji s gornjom/donjom povrsinom.
Jos uvijek je stol u fazi planiranja jer imam kao sto velim brdo ideja samo to treba pretociti u nesto konkretno...
@fanATIk,nadam se NHF
Btw da li netko ima volju nacrtati prema slici neki 3D model?
Znaci ideja je da ove 4 noge na lijevoj strani idu kroz police tj da police budu busene.ako tko ima volje bio bih zahvalan.
Logitech MX500
DELL 2007FP
Abit AV8
Staro 09.10.2009., 07:43   #109
fanATIk
NITKOV
fanATIk's Avatar
Postovi: 4,016
Autor stuc Pregled postova
Ništa deblja ploča nebi opterećivala gornju konstrukciju. Iveral je jak sam po sebi a da ne pričamo da se oslanja na ormariće relativno male širine. Najbolje ti je otić tam di to režu i napravit predračun.
A dal je 800 kn puno, jebga, to samo ti znaš.
Ma nisam niš nabrijan, božesačuvaj, nego mi tvoje tvrdnje o iveralu nemaju veze s realnošću.
Na tvojoj skici je najveći razmak između alu cijevi, kolko, cca 80 cm. I komp koji je najteži stoji skroz desno, dakle nema utjecaj na uvijanje iverala. Hifi komponente će bit svaka na svojoj polici malog raspona, one nemaju nikakvog utjecaja što se težine tiče.
Da si ti napravio skicu stola koji se sastoji od samo gornje ploče i 4 noge u krajevima, te na sredinu poslagao i hifi i komp, mogli bi pričat o eventualnom nekom mogućem uvijanju nakon dužeg vremena.
Al po tvojoj skici to apsolutno možeš izvest s 25 mm iveralom a hifi police i s 18mm. Mdf je još jači, apsolutno, al je i puuuuuno teži. Iveral je težak vrlo, al MDF... Što nekad u real life zna predstavljat problem. Ono, treba ga pomaknut ponekad zbog usisavanja i slično.
I dalje ne kužim tvoju tvrdnju da kantiranje izgleda drugačije od ploha. Kant je istog dezena kao i iveral. Eventualno ako greškom uzmeš drugu boju kanta. A i to se ponekad radi. Meni konkretno crne plohe s bijelim kantom izgledaju fantastično.
I nema nikakvih hard feelinga.
Asrock FM2A78M-DG3+
Palit GTX 460
Corsair VS550
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Win 10
Avatar BIG SIZE
Staro 09.10.2009., 11:07   #110
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja imam u zagorju stol od 25mm iverice sa metalnim podnožjem, gore sam znao i stajati dok sam bio manji i ništa se nije uvijalo onda godimnama gore stoji monitor kojeg se manipulira viljuškarom...
Have a nice day...
Staro 09.10.2009., 14:02   #111
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
U bem ti koji stol
Namjerno sam izdignuo monitore sa stola, da mi ostane vise prostora na stolu, jer je meni stol redovito nakrcan sa svime i svacime
Autor Medulin Pregled postova
btw. za ideju
Faceless je dobro pogodio, Google SketchUp Za ovakve stvari dusu dalo A i lako si izbacis .obj pa delas kasnije s njim kaj god hoces...
Pa povisene monitore imam i sad na poslu, cak i za jos jedno 20-ak cm vise nego na ovom nacrtu, pa nemam problema Ovdje na skici sam ubacio 2x30" ako se ikad odlucim na takav setup, ali najvise da vidim koliko imam manevarskog prostora za police. Sto se tice dubine, imam doma trenutno stol iste dubine i pase mi savrseno. Trik i je u toj ladici na izvlacenje, koja te odmakne od stola jos kojih 30-ak cm, sto je taman za ispruziti noge na neki tabure ili staro kurciste A monitori ce ic na wallmountove (koje cu sarafiti na zadnju, drvenu stranicu) pa cu ih moc jos priblizit ili udaljit, ovisno o potrebi. Kad sve slozim, jos cu izbusiti rupe za kablove tamo gdje mi se ucini najzgodnije.
Nisam, ocekujem predracun uskoro pa cu javit koliko ce izac. Ali mislim da nece biti nesto preskupo, obzirom da je tu i ladicar u pitanju, koji ce bit na zakljucavanje.
Autor Visage Pregled postova
Bas tako, premjerio sam ga tako da mi ispadne ni prevelik ni premal, a opet udoban za sjedenje Ravnao sam se po stolu koji si vidio vec po slikama kojekuda
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 09.10.2009., 17:03   #112
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
ajmo samo reci da me netko uvjerio da je iveral smeće i ja se držao MDF-a ko pijan plota
Pa otprilike udaljenost na lijevoj strani je 50ak cm od cijevi,i onda do one skroz desne noge nekih 80ak cm...Cilj mi je da mogu sjediti na sredini stola a da i dalje imam dosta mjesta sa desne strane dok su s lijeve komponente.ne volim stolove kao ovaj sto sad imam kojem su police na lijevoj strani a ti sjedis skroz na desnoj strani prakticki na rubu stola...Nadam se da kuzis sto pokusavam reci.
Shvatio poantu
Ne znam kako bih to objasnio trebao bih bas naci sliku da ti objasnim.
I normalno uvijek za
@SU
Imas kakve volje baciti onaj moj crtez stola u google sketch?
Logitech MX500
DELL 2007FP
Abit AV8
Staro 09.10.2009., 17:11   #113
^SuperUnknown^
Prečupavi mod
Postovi: 9,129
Ma taman posla, imas na webu od Sketchupa jednostavne video tutorijale pa udri... meni je trebalo niti sat-dva da skuzim kako se radi u njemu
Primary macine:
Apple Mac Pro 5,1
Kingston 120GB SSD
30 TB HDDs
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
Mac OS X 10.10.3
Work rig:
Geforce GTX 660 2GB
2xWD Black 1000GB
Mac OS X 10.10.3
Apple Alu Keyboard
Logitech MX518
LAP:
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
* Connected via:
* "Powered" by:
* Playing:
Tama Arstar II
Staro 11.10.2009., 02:58   #114
Postovi: 10,286
Htio bi si složiti malo veći stol, ali htio bi i da bude ergonomski. Nisam nigdje našao, a volio bi znati koje su preporuče dimenzije stolova glede ergonomije. Visina mi je najbitnija jer mi je trenutni stol nizak, onda dubina stola da budem dovoljno odmaknut od ekrana itd. Postoje li neka "pravila"?
Fokusirao bi se na Elgrad jer imaju poslovnicu u mom selu.
Pitanja:
- Koja je optimalna dubina stola ako ne mislim koristiti ploču na izvlačenje? Na poslu sam imao takav stol i bilo je neopisivo lakše raditi nego s pločom ispod. Podlaktice su mi uvijek bile naslonjene na stol. Na stolu će biti LCD i recimo da on zauzme max 20cm dubine.
- Razmišljam o alu nogama ili drvenim pločama umjesto njih. Stol bi bio kutni L profila s ladicama na mjestu kraće noge (kao što je postao SuperUnknown). Gledam najjeftiniju nogu u Elgradu (Camar, 710mm) =300kn... Jel to podrazumijeva par nogu, jednu nogu, četiri? Nema nikakvog asteriska s napomenom.
Bit će još pitanja, al najbolje ići redom
Staro 11.10.2009., 16:52   #115
Demon Hunter
Postovi: 999
Što se visine tiče mislim da je 75cm neka norma. No i visina stolice je naravno bitna.
Cijena za noge u Elgradju ti je za set (kao što sam i napisao stranicu-dvije prije), a i imaš na cjeniku to naznačeno
Demon Hunter je offline   Reply With Quote
Staro 11.10.2009., 20:32   #116
Postovi: 10,286
Autor Demon Hunter Pregled postova
To bi moglo proći pošto sam visok, a i računao sam da bude oko 73cm.
To mi je očito promaklo, uporno sam tražio asterisk, a nisam gledao vertikalno napisani stupac u kojem fino piše set/kom
Ugl noge će otpasti jer radim kutni stol s policama/ladicama na jednom kraku. Danas ili sutra budem stavio par skica iz SketchUpa..
edit:
http://www.imagesforme.com/show.php/729544_stol.jpg
Zadnje izmijenjeno od: xlr. 12.10.2009. u 11:47.
Staro 11.10.2009., 20:46   #117
Joke
N00B
Joke's Avatar
Postovi: 3,886
Odlicno zamisljeno! Ajde javi koliko te samo izade na kraju (ako nije problem )..
IE6
Linux is Not Windows
Staro 18.10.2009., 17:05   #118
srale7
srale7's Avatar
Postovi: 5,798
Ja se sad upustam u izradu stola za komp, treba mi nesto klasicno, jednostavno, cvrsto. nacrtao sam nesto u sketcUp-u, pa daj te neke komentare, prijedloge, kritike.
To mislim sam doma spojit, sa onim l kutnicima za spajanja, iako ne znam kako to uopce izgleda, pa ako netko ima neki link?
Stol ce biti klasicnih dimenzija, 120x60, visina 70cm. Ove police sa desne strane ce posluziti, jer mi je prevelika tlaka radit i ladice, i cijena bi bila visa. Slobodno prokomentirate..
[56k warning] BMP 3.57 MB
http://www.imagesforme.com/show.php/738878_untitled.bmp
Ovo je bila prvotna zamisao, ali sad samdosao na ideju da napravim samo gornu plocu i stavim ju na 4 noge i sa strane stavim ladicar.
Jedini je problem sto ladicare sto sam viđao kostaju oko 600-700 kn, a ja bi za cijeli stol dao max 600 kn.
Ako imate kakave prijedloga, samo dajte..
pozz
Staro 18.10.2009., 17:34   #119
RAMONES
Datum registracije: Aug 2008
Lokacija: Mostar
Postovi: 115
Autor TomRi Pregled postova
također preporuka za samogradnju,
kupiš dasku, odmah ti i naprave pvc rubove da to izgleda fino,
ušarafiš noge, napraviš koju rupu za kablove ako treba, eventualno postolje za ekran i to je to
čvrsto i vjerojatno jeftinije nego neki takav kupovni.
a sam si odrediš u centimetar dimenzije koje želiš. (visina nogu je po meni najvažnija, a to sve imaš na biranje...)
(prodaju ploče u velikim dimenzijama, ne manje, pa ti izrežu na mjeru,
meni za stoj je bilo dosta pola ploče, a pošto nisam imao potrebe za 2 stola,
složio sam ga od dve ploče pa je dosta čvršći nego od jedne,
ova donja se izreže par cm uža po svim rubovima,
i ne vidi se odozgora, a stoj je prečvrst, npr staneš na njega i ne savija se)
http://www.imagesforme.com/out.php/t399_PB160073.JPG
http://www.imagesforme.com/out.php/t394_PB160083.JPG
http://www.imagesforme.com/out.php/t395_PB160079.JPG
http://www.imagesforme.com/out.php/t188760_2.JPG
http://www.imagesforme.com/out.php/t407_PB160072bc.JPG
I kod mene je tako sličan stol. Ispričavam se zbog nereda
Dimenzije su 160x80, debljina 2,5cm , visina cca. 75cm .
http://www.imagesforme.com/show.php/739624_DSC00442.JPG
http://www.imagesforme.com/show.php/739623_DSC00441.JPG
Bez linkova i reklama u sigu.
RAMONES je offline   Reply With Quote
Staro 18.10.2009., 18:33   #120
Vendetta
Vendetta's Avatar
Postovi: 919
Moj koncept, malo treba police doradit, al to je manje vise to...
Ako imate koji prijedlog, slusam.
http://www.imagesforme.com/upload/b23ea5ad.png
http://www.imagesforme.com/upload/4c3ef58c.png
