Staro 08.09.2025., 11:00   #1141
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
A i o Win i što si sve nakenjao na njih i slično....puno toga igra ulogu na PCu.
Slobodno me dodajte na PSN
Staro 08.09.2025., 11:10   #1142
Postovi: 8,364
Općenito je sranje, neovisno o sustavu, driverima i modelu kartice, ali nVidiju jednostavno ne dira ni najmanje, sve se prodaje, a ovo su ionako "izolirani slučajevi".
Staro 29.09.2025., 15:59   #1143
Postovi: 8,364
March-April release of nVidia GeForce RTX 50-series SUPER lineup, possible CES reveal
nVidia could release the mid-lifecycle update to the GeForce 50-series "Blackwell" generation with the SUPER brand extension, toward the end of Q1 and beginning of Q2, 2026. The lineup could see some kind of reveal or announcements earlier that year at the 2026 International CES. The SUPER lineup sees nVidia update its product stack with at least three new SKUs, the RTX 5070 SUPER, the RTX 5070 Ti SUPER, and the RTX 5080 SUPER, replacing the current RTX 5070, RTX 5070 Ti, and RTX 5080, respectively.
A key area of focus for nVidia will be shoring up memory sizes, with the all three SKUs receiving 50% memory size increases over the SKUs they replace. The RTX 5070 SUPER is expected to ship with 18 GB of memory, while the RTX 5070 Ti SUPER and RTX 5080 SUPER get 24 GB of it. These increases in memory sizes don't come with proportionate increases in memory bandwidths, as nVidia is tapping into newer 24 Gbit GDDR7 memory chips to achieve these memory sizes. None of nVidia's add-in card (AIC) partners have received notifications for new products, and it's already nearing Q4 2025.
Izvor: TechPowerUp
Staro 30.09.2025., 10:30   #1144
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Sve je u cijenama... Nije problem u memoriji sa jačim modelima, nitko ne jamra protiv 16gb. Više je nice to have, ali ako povise cijenu, onda smo opet nigdje.
Ili u AI teritoriju.
Staro 30.09.2025., 13:54   #1145
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,493
Da cijena 5080S sa 24 gb 1200/300€ more,ali mislin da nece biti taj film
Poslano sa mog SM-S918B koristeći Tapatalk
Staro 30.09.2025., 14:07   #1146
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
5080 i 5070Ti su OK i sa 16GB, to povećanje VRAMa je samo za AI, dok je 5070 solidan bump na opet pretjeranih 18gb, ali zato barem dobiva i nešto samog HW-a tako da će svakako biti bliže 5070Ti, tj vj prestiže 9070 vulgaris i napada 9070XT.
Shvatili su u nV da će im sada AI ekipica kupovati i ove jeftinije jer se i taj profit broji.
Uzmeš si npr 5070 sa 18gb kao neki AI početnik i onda skužiš da ti duplo VRAMa donosi x puta veće perf, pa uzmeš 5090...mislim ne znam, ali Jensen se do sada pokazao kao sve, samo ne glup, a ovo je odjednom opaki skok sa VRAMom.
Zadnje izmijenjeno od: Disco. 30.09.2025. u 15:19.
Staro 30.09.2025., 15:03   #1147
Postovi: 16,950
A vidim nekakve prednosti, pošto 60x0 seriju neće izbaciti tako skoro, ali opet nisam se susreo u ovih 2 mjeseca s problemom s memorijom, što u igrama, što kod nekog zahtjevnijeg rada.
Ali imati će svoje tržište, možda čak i ove "slabije" verzije padnu s cijenama.
Staro 30.09.2025., 15:23   #1148
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
Ma mislim da će njih samo rasprodat i bok.
Vani je npr 5070 u prosjeku 530-540€, dok je 9070 570-590 €, za sada je IMHO 9070 no brainer. Više VRAMa i malo brža grafa, za mrvu višu cijenu.
I to ih vj češe, uz to što se ne može prenamjenit za AI govnarije.
Staro 30.09.2025., 15:58   #1149
Postovi: 16,950
Kužim, ali AMD i njihove grafe nisu nešto prepopularne u našem cummunity-u, ja sam im više puta dao šansu, nikad nisam bio zadovoljan.
https://wccftech.com/nvidia-gpu-mark...ce=chatgpt.com
Preko 90%.
Zadnje izmijenjeno od: Mommistake. 30.09.2025. u 16:19.
Staro 30.09.2025., 17:26   #1150
Postovi: 8,364
Ima tu svega u pozadini te priče.
Kaj se pak "novih" nVidia kartica tiče, u 2026. budu izbacili ono kaj su trebali odmah u startu po pitanju Blackwell modela, jebe im se, a malo fali da kupe pol svijeta.
Zadnje izmijenjeno od: The Exiled. 30.09.2025. u 17:36.
Staro 01.10.2025., 23:04   #1151
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,864
meni svako tolko puhne u glavu pa idem gledat kolko je 5070 brža od moje 3080,onda vidim 10-12 fpsa više na 1440p,pa odustanem, ćemo vidjet prognozae da će super verzije bit brže 10% od ne-super,i za koju cijenu naravno.
Staro 02.10.2025., 06:37   #1152
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
Ti moraš min gledato 5070 Ti iliti 9070 XT, sve ispod toga je bzvz.
Po meni ti čak ni ovo što sam napisao nije vrijedan upgrade.
Staro 02.10.2025., 07:30   #1153
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,165
Ja sam prešao s 3080 na 9070xt i zadovoljan sam. Na 1440p igram vecinom, nekad spojim na 4k oled sp igre.mislim da je oko 30% brza, ali je necujna naspram ventus 3080, i vecinom je na 220w undervoltu kada igram nešto starije.
Poslano sa mog SM-S928B koristeći Tapatalk
Staro 02.10.2025., 09:01   #1154
Postovi: 16,950
Autor demetrius Pregled postova
Ma na kraju dana, pustiš brojke i ako si zadovoljan, to je to.
Ja sam kupio novi monitor, prešao s 1080 24" na 1440" 32" i to na 3070 i jednostavno sam osjetio taj pad s 1080p na 1440p, igre su pale čak i na 40FPS-a, i osjetio sam, nisam zadovoljan bio.
Baš Senua's Saga Hellblade 2 sam igrao i vidim taj drop u FPS-u, na 40-50.
5070 je to vratilo na 80+, pa mi je srce bilo na mjestu. Od te sekunde, nisam FPS counter nikakav ni palio. Igre lete, ja zadovoljan. 3080 je i dalje tenk od grafe, tako da, ili čekaj 60x0 seriju, ili 5080 na više, nema druge. Ostalo će biti zanemariv skok od 10-20%.
Ali je preskupa realno 3080 još uvijek. 500+EUR za nju rabljenu bez garancije, no brainer je preći na 5070 za manje od 600 s garancijom, pogotovo ako kupuješ sada i biraš između 3080 i 5070.
Zadnje izmijenjeno od: Mommistake. 02.10.2025. u 09:25.
Staro 02.10.2025., 10:32   #1155
mkey
Datum registracije: Sep 2018
Lokacija: tu
Postovi: 3,553
Što se tiče FPSa, puno ovisi o doživljaju. Nekada mi je 20 bilo prihvatljivo, pa me 40 ubijalo, pa mi je 40 prihvatljivo... Puno ovisi i o igri. Ako gledaš FPS counter onda nisi baš skoncentriran na igranje. S time da ovo što ja igram zadnjih godina uglavnom bude 144 FPS na max detaljima na 1070
Autor George Carlin
But there’s a reason. There’s a reason. There’s a reason for this, there’s a reason education sucks, and it’s the same reason that it will never, ever, ever be fixed. It’s never gonna get any better. Don’t look for it. Be happy with what you got. Because the owners of this country don't want that. I'm talking about the real owners now, the real owners, the big wealthy business interests that control things and make all the important decisions. Forget the politicians. The politicians are put there to give you the idea that you have freedom of choice. You don't. You have no choice. You have owners. They own you. They own everything. They own all the important land. They own and control the corporations. They’ve long since bought and paid for the senate, the congress, the state houses, the city halls, they got the judges in their back pockets and they own all the big media companies so they control just about all of the news and information you get to hear. They got you by the balls. They spend billions of dollars every year lobbying, lobbying, to get what they want. Well, we know what they want. They want more for themselves and less for everybody else, but I'll tell you what they don’t want: They don’t want a population of citizens capable of critical thinking. They don’t want well informed, well educated people capable of critical thinking. They’re not interested in that. That doesn’t help them. Thats against their interests. Thats right. They don’t want people who are smart enough to sit around a kitchen table to figure out how badly they’re getting f*cked by a system that threw them overboard 30 f*cking years ago. They don’t want that. You know what they want? They want obedient workers. Obedient workers. People who are just smart enough to run the machines and do the paperwork, and just dumb enough to passively accept all these increasingly shittier jobs with the lower pay, the longer hours, the reduced benefits, the end of overtime and the vanishing pension that disappears the minute you go to collect it, and now they’re coming for your Social Security money. They want your retirement money. They want it back so they can give it to their criminal friends on Wall Street, and you know something? They’ll get it. They’ll get it all from you, sooner or later, 'cause they own this f*cking place. It's a big club, and you ain’t in it. You and I are not in the big club. And by the way, it's the same big club they use to beat you over the head with all day long when they tell you what to believe. All day long beating you over the head in their media telling you what to believe, what to think and what to buy. The table is tilted folks. The game is rigged, and nobody seems to notice, nobody seems to care. Good honest hard-working people -- white collar, blue collar, it doesn’t matter what color shirt you have on -- good honest hard-working people continue -- these are people of modest means -- continue to elect these rich c*cksuckers who don’t give a f*ck about them. They don’t give a f*ck about you. They don’t give a f*ck about you. They don't care about you at all -- at all -- at all. And nobody seems to notice, nobody seems to care. That's what the owners count on; the fact that Americans will probably remain willfully ignorant of the big red, white and blue dick that's being jammed up their assholes everyday. Because the owners of this country know the truth: it's called the American Dream, because you have to be asleep to believe it.
Staro 02.10.2025., 12:08   #1156
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,603
3080 se nađe polovna za 300-350 eura max
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 02.10.2025., 12:19   #1157
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
Meni je 30+ OK, ne palim FPS countere nego se igram. Konzole su me navikle da je 30 FPS dovoljno. 60 mi je super, a sve iznad ne bi znao pošto nemam HRR monitor.
Staro 02.10.2025., 12:20   #1158
Postovi: 16,950
Autor maXonja Pregled postova
A eto, ja ti mogu iz prve ruke reći da za te novce ide 3070, prodao svoju prije 3 tjedna za te novce. A bacio sam oko na Njuškalo, neka srednja cijena je 500.
Može se naći vjerujem, ali pričamo o okvirnoj cijeni.
Autor Disco Pregled postova
Ja ne mogu, kada vidim taj frame switch, gotovo.
Ako na PS ne upalim Performance mode, ne mogu igrati.
Staro 02.10.2025., 12:48   #1159
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,165
ja svoju pred 6 mjeseci jedva za 400 prodao svoju s garancijom, a sada idu za 500, ne vjerujem
radije dodat jos 100 i uzet novu grafu
Staro 02.10.2025., 13:05   #1160
Postovi: 16,950
Ja samo kažem da je moja 3070 otišla za gore navedne novce.
Ali eto, oglasa ima, prodaju li se, ne znam.
Ali čak da je i 400, ja bi radije uzeo 5070 za 580, novu s garancijom i jedno 10-20% jaču.
Staro 02.10.2025., 14:06   #1161
Odinarius
All-rounder
Postovi: 1,338
Ah, klub gaymera koji su kupili predobru grafičku karticu i sad svi moramo rekalibrirati što je vrijedno, a što nije u ovom novom Nvidia svijetu...
Kod nas su cijene Radeona toliko dobre naspram Nvidie da se Nvidiu ne isplati niti pogledati.
A sve mi se čini da ću gurati 3080 do kraja.
Staro 02.10.2025., 14:43   #1162
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,318
I ja uvijek koristim performance mode, ali ne idu sve igre zakucane u 60 koliko sam skužio.
@ordirnarius: imaš npr asrock steel legend 9070XT trenutno za 642€ na amazon.de plus nekih 15ak € dostave sa mailboxde.
Staro 02.10.2025., 15:18   #1163
Postovi: 16,950
Dobro si skužio. Performance mode samo otključa FPS iznad 30, koliko PS može gurati, to je drugi par cipela.
Staro 03.10.2025., 23:24   #1164
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,864
to bi bilo to mislim,prije 2 tjedna u windowsima surfam artefatki restartam sve ok,prije tjedan dana isto,danas surfam crni ekran no signal/check signal,zato uvjek kupuje ploču sa integrušom,znači ostaju mi 3 opcije rtx 5070/9060/9070 xt.
sad je van izvadio još sutra probat ali mislim da je dala svoje kupljena 11/2023 polovna s ebaya s 1 god garancije.
na amazonu.de imam 20 eura gift card.hmhh trenitno nema rtx 5070 gaming oc,kako ide skaliranje kod gigabyta od najgore,eagle,windforce,gaming oc,aorus,znam da gaming oc i sigurno imaju 4 godine garanceije ostale 3.
https://www.amazon.de/-/en/Gigabyte-...ps%2C99&sr=8-6
na kraju u instaru naručio jer mogu na 24 rate,da su imali gaming oc u instaru za 650 bi je uzeo,gamershop ima za 650 ali ga niste nahvalili pa odusto.
https://www.instar-informatika.hr/gr...m_medium=click
što se tiće moje danas upalio radi jedno 20 sekundi,no signal/check signal/going to standby morat ću odnest na servis da testiraju ako se možda opet pregrijava,već je bila na zamjeni padova u češkoj dok je bila u garanciji što su česi napravili kakve padove stavili ko će ga znat.
jedno pola kile lakša 5070 ili više.
Zadnje izmijenjeno od: demetrius. 08.10.2025. u 22:46.
Staro 10.10.2025., 10:43   #1165
Postovi: 16,950
Google kaže oko pola kile razlike.
Javi dojmove ako primjetiš kakve nakon 3080.
Ja sam s 3070 baš osjetio skok, no 3080 je druga priča.
Staro 10.10.2025., 22:25   #1166
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,864
posto rezultate u 3dmarku od obje radi usporedbe,nego na kojim si driverima?? ja još na 566,36 jer su novi radili problema na seriji 3000,mogu zadnje stavit 581.47??nema problema s njima.
Staro 11.10.2025., 12:31   #1167
Postovi: 16,950
Ja sam na 577 od prvog dana, nisam ništa dirao, radi bez beda.
Staro 14.10.2025., 17:05   #1168
Postovi: 8,364
Nekolicina izoliranih slučajeva pregorenih 12VHPWR/12V-2×6 konektora, jer 15 godina stari "you're holding it wrong" argument nikad neće prestati biti relevantan.
Ukoliko Jensenu zbog ovog konektora ne izgori neki AI datacentar + obližnji grad, šanse da se sfušanost uz pregaranja i službeno povuče s kartica je nepostojeća.
Zadnje izmijenjeno od: The Exiled. 14.10.2025. u 17:13.
Staro 14.10.2025., 20:26   #1169
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,493
Ma to neš ti to, teke vatre i dima, i dalje su rekordne zarade(kao nekad kod jedne druge firme)
Staro 15.10.2025., 00:06   #1170
mkey
Lokacija: tu
Postovi: 3,553
Ovaj kojem su dva izgorila, to je očito neki amater koji ne razumije mehanizme.
Autor George Carlin
