Staro 10.03.2012., 14:02   #1021
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor Andrija M Pregled postova
Ovo je već 100x prožvakano, sa 4.3.52.21.01 ne radi NTFS.
Pročitaj u ovom threadu postove od 878 nadalje
Pročitao sam. Nigdje nema baš preciznog odgovora no ovo pitanje:
- Postoji li firmware za Gigaset SX763 Iskona koji omogućuje korištenje NTFS diska za fileserver?
(Trenutno je firmware 2.3.52.19.00)
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 10.03.2012., 19:23   #1022
Andrija M
Postovi: 469
Očito da nisi pročitao, evo pogledaj post 880
Andrija M je offline   Reply With Quote
Staro 10.03.2012., 22:06   #1023
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Koliko sam ja isprobavao, a to je bilo davno mislim da na svim fw-ovima radi ntfs ali ne bas svaki put, nekad ga prepozna a nekad ne, ali kazem nisam vec dugo to gledao pa nisam siguran za to.
Staro 10.03.2012., 22:49   #1024
satforum.acc
Datum registracije: Mar 2012
Postovi: 3
Question malo sam glup izgleda..
ima li iko volje, otključat mi taj router jer ja sam već lud. Voljan sam i nadoknadit trud (neka razumna svota). Problem kod mene je taj što sam router kupio, a ne koristim t-com za net već b-net i kemijam nešto s amisom (možda bi prešo kod njih). Uglavnom nemam mogućnost spojit sx763 na internet kad radim otključavanje, a u tutorialu piše da mora imat vezu s netom. Ne znam kak da to napravim. Imam trenutno na probi amisov router Speedtouch TG782i, koji su mi stavili u BRIDGE mod, rekli da samo spojim svoj router s lan kablom i sve bi trebalo bit ok, al nije. Kad to napravim ne dobijem net preko siemensa, a više mi ni Speedtouch ne daje net od kad je u bridge modu (telefon i IP televizija rade ok).
Kako bi ja trebao podesit ovaj neotključani siemens da mi ima izlaz na net preko Speedtoucha (koje postavke u njega trebam unijeti) i kako ga spojiti sa Speedtouchom (koji port na Speedtouchu spojiti na koji port u Siemensu)??
Čemu služi onaj 4 port na Siemensu LAN4/WAN??
Hvala svima koji imaju volje odgovoriti..
LP
satforum.acc je offline   Reply With Quote
Staro 10.03.2012., 23:01   #1025
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Da si procitao vec je odgovoreno negdje sigurno par puta, Ethernet konfiguracija: http://sx763.co.cc/ethernet_configfile to ubaci kako pise gore i fino lan4/wan ustekaj u thomsona i namjesti pppoe pod internet postavkama na sx-u.
Staro 10.03.2012., 23:17   #1026
satforum.acc
Postovi: 3
hvala, probam to čim Mirkec odradi Sefa..
Javim kak je prošlo..
Staro 11.03.2012., 22:49   #1027
konig_karl
lurkerus maximus
Datum registracije: Aug 2008
Lokacija: V.G.
Postovi: 91
Zna se dogoditi da se jednom u tjednu "zblesira" na nacin da izgubim konekciju na internet te dok se na njega spojim pise neka poruka tipa "Disconnected Line-Loopback". Nakon toga samo kliknem connect i dalje se spoji te je sve ok. Inace sam generalno dosta zadovoljan routerom, samo ta rekonekcija jednom tjedna nekad zna malo razivcirati
bok
zanimljiv problem imas, isti imam i sa svojim siemensom (zapravo sagemom jer je made in tunis). koji je isp u pitanju i jel made in germany ili made in tunis?
edit: uf totalno fulavanje, molio bi moda da ocisti temu od moje brljotine...
CPU: AMD Athlon II x4 640
MBO: ASrock 870 Extreme3
RAM: 2x Corsair 2gb DDR3 (1333Mhz)
HDD: WD5000AAKS
VGA: Point of view GeForce GTX 460 768Mb
PSU: Corsair CX400W
Case: NZXT Source 210
Monitor: LG M2262D (22", 1920:1080)
OS: Windows 7 x64
Toshiba A200-23K
ekran: 15,4" WXGA
CPU: C2D T450 1.66 GHz
RAM: 1 Gb
HDD: Hitachi 160 Gb
VGA: HD2600 256MB
OS: Windows 7 x86
Samsung HD502IJ@IcyBox
Logitech Driving Force Pro
Logitech Wireless Desktop MK710
Sony NWZ-E443 + Koss SparkPlug
Creative WP 350
Nokia N97
Scott Sportster P3 2010
Frame: New Sportster Frame Alloy 6061
Fork: Sun tour NEX 4610 V2 HLO, Lockout susspensionfork 1 1/8, 63mm travel, Integrated 700C
Front Derailleur: Shimano Deore
Rear Derailleur: Shimano Deore RD-M592 / Shadow Type
Shifters: Shimano Deore SL-M590
Chain set: Shimano FC-M443-8-S
Chain rings: 48×36×26 Teeth
Bottom Bracket: Shimano BB-ES-25
Cassette: Shimano CS-HG50-9 11-32 Teeth
Chain: Shimano CN-HG53
Pedals: Wellgo C 128
Front Brake: Shimano BR-M486 F/R 160 mm Rotor
Rear Brake: Shimano BR-M486 F/R 160 mm Rotor
Brake Levers: Shimano BL-M 486 Disc
Handlebars: Scott Sportster OS
Stem: Scott Comp
Rims: Alex XC-44 Disc
Front Hub: Scott Comp Disc CL
Rear Hub: Shimano FH-RM65 CL
Spokes: stainless black, 14G / 2mm
Front Tyre: Schwalbe Smart Sam 700×35C
Rear Tyre: Schwalbe Smart Sam 700×35C
Seat post: Scott Sportster/Solution
Weight: 13.10kg
Zadnje izmijenjeno od: konig_karl. 11.03.2012. u 23:10.
konig_karl je offline   Reply With Quote
Staro 11.03.2012., 23:01   #1028
alengrosevic
alengrosevic's Avatar
Postovi: 3,779
Autor konig_karl Pregled postova
bok
bok!
ovo ti je pobjeglo u krivi podforum ali ovakva je stvar. Sa Original Siemensom (Germany) mi se to cesce dogadjalo dok mi se sa novijim (Tunis - Sagem) to vrlo rijetko dogadja. Ocito su nesto popravili u odnosu na original...
Staro 12.03.2012., 15:19   #1029
satforum.acc
Postovi: 3
Thumbs up prošlo..
..napokon, uspjelo. Trebo sam unijet još svoje parametre od konekcije, DNS-ove, isključiti onaj UPnP i uključiti PPoE PassThrough i radi.
Sad imam još samo jedno pitanje:
Ako ga idem do kraja odradit (otključat da mu rade sva 4 porta za net i skinut T-Comov software s njega), da li će i dalje sve funkcionirat na isti način, odnosno i dalje ostaje spojen s Thomsonom kablom preko tog Wan porta. Mislim neću mu ništa sje.. taj četvrti port ako ga flasham??
Samo ću trebat vjerojatno ponovno sve postavke unijet, al to nije problem sad znam šta i gdje treba upisat..
Puno hvala .Delboy na prošlom savjetu, bez toga bi se još patio mislim..
Zadnje izmijenjeno od: satforum.acc. 12.03.2012. u 17:51.
Staro 12.03.2012., 16:15   #1030
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Jesam. Ali link za FW ne radi.
Osim toga, nisam 100% siguran, ali čini mi se da je negdje netko demantirao tu izjavu...
Dakle, gdje bih mogao pronaći ovaj FW?
I postoje li negdje precizne upute sa instalaciju točno tog FWa?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 12.03.2012., 20:09   #1031
Andrija M
Postovi: 469
To ti moraju kolege Delboy i Hackerivs pomoći ako link za dl ne radi
Staro 13.03.2012., 01:03   #1032
Hackerivs
Datum registracije: Aug 2009
Lokacija: Middle of nowhere
Postovi: 451
@estugarda
ti tražiš 2.x firmware. to su rijetki uređaji na amazon platformi.
ja (a mislim da i ostali u ovom topicu) ne raspolažu pristupom 2.x firmwareima, nažalost.
Hackerivs je offline   Reply With Quote
Staro 13.03.2012., 21:48   #1033
dario123
Postovi: 6
SX783 kao SP3102
Otključao sam po uputama. Hvala. Treba mi kao ATA za analogni telefon sa prolazom analogne linije sa NT uređaja.
Trebao bi se spajati na Asterisk lokalne IP adrese, u njega treba ulazit linije od t-coma.
Kako mu VOIP preusmjerit na LAN umjesto na WAN. Ili kako to spojiti.
Zadnje izmijenjeno od: Nikky. 13.03.2012. u 22:18.
dario123 je offline   Reply With Quote
Staro 13.03.2012., 22:09   #1034
Postovi: 23,548
Uredi post, vidiš i sam šta si dobio.
Po navedenom tebi treba ethernet konfig, tada je wan na Lan4, ulaz ćeš konfigurirat kao DHCP Client ili sa fiksnim ip (ako ima takvu opciju), potom treba definirat VoIp da koristi istu konekciju kao i internet preko wan - a.
Staro 13.03.2012., 23:08   #1035
dario123
Postovi: 6
Pripazim drugi put. Stavio sam ethernet konfig. wan mi ni ne treba, kao ni wireless i USB.
Gdje podesim da VoIp koristi LAN. Kako da mi ne ubacuje ovaj okvir? . . .
Zadnje izmijenjeno od: Nikky. 14.03.2012. u 09:38.
Staro 14.03.2012., 00:50   #1036
hdraskov
Lokacija: Donji Miholjac
Postovi: 2
Pozdrav.
Pitanje za ekipu..... na router mi je spojena fiksna linija u line i fiksni telefon na phone 1... kada me netko zove na fiksunu liniju telefon zvoni i sve ok.... medjutim svi odlazni pozivi mi odlaze preko voip-a.
Ja bi zelio da mogu nekako na telefonu birati da li cu zvati preko fiksne linije ili preko voip-a. ono mozda * prije broja... ili 99 pa broj...
U postavkama routera sam nasao dialing plan.. u kojem mogu predefinirati odredjene brojeve kada biram preko cega da idu.
Ima mozda netko kakvu ideju ili rjesenje?
hdraskov je offline   Reply With Quote
Staro 14.03.2012., 09:46   #1037
Postovi: 23,548
@dario123
Pa pogledaj gore url, kao da si otvorio forum kroz neki prevodioc, očisti cache browsera,
direktni link na forum: http://forum.pcekspert.com/index.php
WAN ti "treba" za to šta želiš, taj priključak je ulazno - izlazni i fw uređaja je tako koncipiran da promet prema vani ide preko njega, (u drugom slućaju / konfigu je to adsl modem).
@hdraskov
Otvori full manual i vidi koje su ti opcije na raspolaganju. Možeš promjenit dial plan da std. koristi fiksnu liniju za pozive a da za VoIp treba dodavati komandu / predbroj ili nauči napamet komandu / predbroj za izbor. Provrti ovu temu, možda smo i to spominjali.
Staro 14.03.2012., 11:20   #1038
dario123
Postovi: 6
Evo Opera je ok. Znači u switch trebam spojiti i WAN i LAN. Ne prikazuje mi broj koji me zove. Kad je telefon spojen u NT sve je OK. Treba li što podesit jer ne nalazim opciju.
Staro 14.03.2012., 11:45   #1039
Postovi: 23,548
Ne, dovoljno je u wan (Lan4) dovest internet, pretpostavljam u tvojoj kombinaciji sa switcha.
U vezi prikaza broja pogledaj dostupne opcije.
Staro 14.03.2012., 23:28   #1040
dario123
Postovi: 6
Skužio, LAN mora imati neku bezveze adresu, a WAN adresu lokalnog LAN_a. Treba dozvolit remote control, ali kao što je i očekivano, elastix neće da ga registrira.
Softphone na istim postavkama radi. Greška u SX_u je_:
Jan 1 02:18:22 War cma: 011-00-00 Realm of WWWAuthenticateHeader '"asterisk"' does not match user realm '103'
Jan 1 02:18:22 War cma: 011-00-00 SIPRegistration::handle401 no response build to AuthenticationRequest for user 103.
Jan 1 02:18:22 Cri cma: 019-00-00 CMA: EV_SIP_USER_STATUS_IND for Voip-Account: 1 [1-6], Enabled = 0, Registration reason = realm_mismatch
Jan 1 02:18:32 War scm: 995-00-00 WebGUI:repareDataForPageLoad Apply Rollback on existing scm session:
Staro 14.03.2012., 23:43   #1041
Postovi: 23,548
Prije nego ga izbaciš iz kombiniranja, u postavkama odaberi da VoIp koristi istu "konekciju" kao i internet. Ovo odgovara samo u tvojoj kombinaciji / situaciji.
Staro 16.03.2012., 21:12   #1042
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor Hackerivs Pregled postova
@estugarda
Ne kužim.
Ja tražim 4.3.52.21.01 FW sa linka u postu 878. Tražim ga zato što je netko rekao da na tom FWu radi ntfs.
Sve što ja hoću postići je dobiti ntfs podršku u fileserveru na mojem Iskon-ovom SX763.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 16.03.2012., 22:38   #1043
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Gore si napisao:
Autor estugarda Pregled postova
Da li je onda 2 ili 4 na pocetku verzije fw-a kojeg sad imas?
Staro 16.03.2012., 22:56   #1044
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
2!
FW koji sad imam je 2.3.52.19.00. Tako je Iskon dostavio prije par godina.
Znači li to da se ne može staviti 4.3.52.21.01?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 17.03.2012., 00:24   #1045
Andrija M
Postovi: 469
Ne može. Ti imaš stariju verziju (hardverski različitu) SX763 i na koju ide 2.xx firmware i na te siemense ne paše 4.xx firmware
Staro 17.03.2012., 11:57   #1046
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
A-ha! To objašnjava zašto nisam uspijevao napraviti FW update kako je opisano.
Dobro, ajmo ovako:
Postoji li FW za moj uređaj na kojem može raditi NTFS disk za fileserver. Ako da, link bi bio super. I po mogućnosti upute koje odgovaraju tom FWu i hardveru. Hvala.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 19.03.2012., 02:40   #1047
Hackerivs
Postovi: 451
kratko i jasno - ne.
Staro 19.03.2012., 17:12   #1048
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
E to bi onda trebalo staviti u prvi post. To bi mnoge (poput mene) poštedilo višednevnog prčkanja uzalud.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 19.03.2012., 19:39   #1049
Hackerivs
Postovi: 451
ti si drugi slučaj u ovom topicu (s 2.x fw)
Staro 19.03.2012., 20:26   #1050
Postovi: 8,218
Malo ulijećem, no, da li se može natjerat SXa da radi na optimi? Selim uskoro di je optima, pa da ako može radit da nenabavljam drugi (jer ovaj što je sada u stanu za optimu nema wifi)
tnx
