Staro 23.05.2008., 00:53   #991
rams
80286
rams's Avatar
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Moze se napravit blic pri dolaznom pozivu ubacivanjem ovog patcha, to kopiraj u Notepad i promijeni ekstenziju u .vkp, dalje slijedi upute za ubacivanje patcheva:
; W800 SW-R1BC002
; Flashlight with incoming call
; (!) MP
; © IronMaster
; (P) Joker XT, -=Alex=-
+44000000
de2d10: 206B1549 15498847
de2d68: 3D2FDE44 01571D45
de37fa: 311C 9047
de3894: F4160000 59571D45
ea9828: 00E0 0047
ea9854: F2E70000 67571D45
de3942: 2063 8847
de39b8: 7BE60000 71571D45
11d5700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 206B2249FFB51D4D01212970264827F0
11d5710: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 77FC0CD06E6019494E680D78002D06D0
11d5720: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 70781F4DA847B0781649174B9847FFBD
11d5730: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFB5F0E7FFB511494E680D78002D07D0
11d5740: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0020174DA847F0780D490F4B9847FFBD
11d5750: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0020134DA847FFBD0E4A311CFFB50749
11d5760: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00250D70FFBD0A48FFF7F8FF0B490847
11d5770: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 09492063FFB5FFF7F1FFFFBD0478034C
11d5780: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 31571D4535571D45251EE8443D2FDE44
11d5790: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF F2E70000F41600007BE600002D98EA44
11d57a0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 4D5BEB44E4D3C2B10235000000000000
11d57b0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 000000007B703D60426C696E6B696E67
11d57c0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20666C6173686C696768742061742069
11d57d0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6E636F6D696E672063616C6C60206964
11d57e0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D333530322063703D49726F6E4D6173
11d57f0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 746572207665723D322E317D7B696E66
11d5800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6F3D60287029204A6F6B65722058542C
11d5810: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 202D3D416C65783D2D607D7B31206220
11d5820: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 604272696768746E6573736020723D30
11d5830: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 2E2E31303020763D35307D7B32206220
11d5840: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 604475726174696F6E206F66206F6E65
11d5850: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20666C6173686020723D302E2E323535
11d5860: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 20763D35307D7B332062206054696D65
11d5870: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 206265747765656E20666C6173686573
11d5880: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 6020723D302E2E32353520763D35307D
11d5890: FF 00
A slikanje se koliko ja znam nemoze prebaciti na joystick. Barem jos nije napravljen patch za tako nešto.
rams je offline   Reply With Quote
Staro 23.05.2008., 12:46   #992
CrOKilLEr
W750i Owner, SAMP Player
CrOKilLEr's Avatar
Lokacija: ZADAR
Postovi: 5
evo naso sam gotovi patch i uspio sam ga sa gslideom stavit
al isto tnx
i jos me nesto zanima dali postoji neki layout s tankim fontom a da nije fullscreen imam neki patch za tanki font al nerade ljevi i desni botun butun budu samo kvadratici a ne recimo opcije i odabrati ono kao kad na kompu nesto pise nekim fontom kojeg nemas al sve ostalo radi i svidilo mi se to samo mi je glupo sto nerade botuni pa sam mako i sad bi htio nabavit layout
Zadnje izmijenjeno od: CrOKilLEr. 23.05.2008. u 23:27.
CrOKilLEr je offline   Reply With Quote
Staro 23.05.2008., 23:56   #993
CrOKilLEr
CrOKilLEr's Avatar
Lokacija: ZADAR
Postovi: 5
daj odgovorite neko
EDIT: evo naso sam grid layout bez imena operatora i tankim fontom izgleda odlicno
Zadnje izmijenjeno od: CrOKilLEr. 24.05.2008. u 00:34.
Staro 25.05.2008., 17:20   #994
CrOKilLEr
CrOKilLEr's Avatar
Lokacija: ZADAR
Postovi: 5
adasdas
Staro 25.05.2008., 17:25   #995
rams
80286
rams's Avatar
Postovi: 1,724
Daj si zapali jednu zelenu!
Staro 30.05.2008., 20:42   #996
piroman007
Postovi: 20
Re:
Kako da patcham cid36 u GSlide-u? Pod header mi stavi red_49 pa ne znam oće li radit? Htio bi pachat ovo blicanje pri pozivu i btw. ima li netko patch koji daje mogučnost paljenja svjetla tj. konsantne bljeskalice pritiskom na gumb kamere?
Pozz
P.S.
Crni tj. tutorila, ostali forumi su fakat žnj
piroman007 je offline   Reply With Quote
Staro 30.05.2008., 21:07   #997
rams
80286
rams's Avatar
Postovi: 1,724
Pogledaj ovdje,ovako patchas CID36
http://forum.pcekspert.com/showthread.php?t=84460
Staro 30.05.2008., 21:46   #998
piroman007
Postovi: 20
Ovo je bilo stvarno brzo.. Fala puno, izgleda malo komplicirano, al i flashanje na w800 mi je izgledalo teško a sad mi je lako.. Bacam se na čitanje
Pozz
Staro 30.05.2008., 22:09   #999
piroman007
Postovi: 20
Hmmmm, patchao sam to za blicanje.. ali neće. Napravio sam sve kako je opisanu na onom linku i umjesto da mi blica bljeskalicaa, ekran mi pobijeli. kad prekinem poziv ekran blinkne dva puta, zacrni se i vrati me u izbonik. Gdje je problem?
Staro 30.05.2008., 22:27   #1000
piroman007
Postovi: 20
Ja sam maknuo taj tvoj patch, stavio sam drugi (dolje je napisan) i sada šljaka savršeno
;W800 SW-R1BC002
;Blinking a small lamp at an entering call
;Ver. 1.1
;(C) IronMaster
;(P) Joker XT, -=Alex=-
+44000000
de2d68: 3D2FDE44 61591D45
de37fa: 311C 9047
de3894: F4160000 89591D45
ea9828: 00E0 0047
ea9854: F2E70000 97591D45
de3942: 2063 8847
de39b8: 7BE60000 A1591D45
11d5960: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 206B1F49FFB41A4801210170FFBCFFB5
11d5970: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 17480178002906D032201E4DA8473220
11d5980: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 1549164B9847FFBD174A311CFFB51048
11d5990: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 00210170FFBD1348FFF7F8FF14490847
11d59a0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 12492063FFB5FFF7F1FFFFBDFFB50848
11d59b0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0178002907D000200E4DA84732200549
11d59c0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 064B9847FFBD00200A4DA847FFBDFFFF
11d59d0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0478034C6F591D45AD591D45251EE844
11d59e0: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 3D2FDE44F2E70000F41600007BE60000
11d59f0: FFFFFFFFFFFFFFFF 2D98EA444D5BEB44
EDIT:Btw. 1000. post
Zadnje izmijenjeno od: piroman007. 30.05.2008. u 22:50. Razlog: zaboravih nešto dodat
Staro 31.05.2008., 00:16   #1001
piroman007
Postovi: 20
Cool ptches
Neki cool patchevi (probano na cid36 red):
Popis i opis datoteka koje se nalaze u download linku
skrvozm_w800_r1bc002.vkp (java fs access)- nisam otkrio za što je
vibra_w800_r1bc002.vkp - kada nekog zovete vibrira kad se taj netko javi
w800_r1bc002_3gptomp4.vkp - video sada ima mp4 extenziju
w800_r1bc002_drv_folder.vkp - cam&display driver prebačeni u /tpa/user/other/drv
w800_r1bc002_faster_scrolling.vkp - brže scrollanje naziva
w800_r1bc002_java_folder.vkp - java folder premješten u /tpa/user/other/ams
w800_r1bc002_light_cambutton.vkp - bljeskalica uključena pritiskom gumba kamere
w800_r1bc002_light_cambutton_adjustbright.vkp - kada je bljeskalica uključena pilagodite jačinu svjetlosti sa + i - (samo kada ste u Walkman izborniku!)
w800_r1bc002_menu.vkp - prebacivanje menija u /tpa/user/other/menu
w800_r1bc002_no_simcard.vkp - uključivanje mobitela bez SIM kartice
w800_r1bc002_photo_date_time.vkp - slike imaju naziv YYYYMMDD_HOUR
w800_r1bc002_photo_while_java.vkp - fotgrafiranje dok je java u pozadini
w800_r1bc002_Playlist.vkp - playlist file na memori stiku
w800_r1bc002_radio.vkp - slušanje radija bez prikopčanih slušalica
w800_r1bc002_silentmode_message.vkp - bez silent mode poruke
w800_r1bc002_volume_warning.vkp - bez"very loud sound" poruke
w800_r1bc002_whitelist.vkp - bijela lista postaje crna, napišite brojeve pozivatelja čiji kpoziv ne želite primiti i oni će čuti ton zauzeća
PATCH DOWNLOAD: http://rapidshare.com/files/118927218/patch.zip.html
Nadam se da je nekome pomoglo.
Zadnje izmijenjeno od: piroman007. 02.06.2008. u 20:34.
Staro 31.05.2008., 12:10   #1002
piroman007
Postovi: 20
Blinkanje IC lampice dok je mobitel spojen na struju/pc
Fora patch, nepotreban al šminka Kada spojite mobitel na punjač ili na komp sa kablom onda će vam počet blinkati IC lampica (slično ko kad vam je baterija prazna).
Patch:
; w800 r1bc002
; Flashing IC charging
; When the battery is charging IC blinks
; © den_po, IronMaster
; (p) HierOS
; the gravest RESPECT to vetaxa-manchyk for clarification of all the nuances and stuff
+44020000
d2a81e: 01A0405C 82488047
d2aa28: DCA94144 01211C44
d2a8b0: 5D48 AF48
1a2100: 4920256420636F6E7465787421212100 1C48405CFFB590B06946194FB8476846
1a2110: 0A534E4443505F4374726C5F48616E64 007800F002F810B0FFBDFFB5134A1178
1a2120: 6C65584964496E642829202D20576172 814207D01070072804D0082802D00020
1a2130: 6E696E673A204372656174696E672053 00F001F8FFBDFFB5012107200F4CA047
1a2140: 41504920256420636F6E746578742121 FA2032300C49084CA047FFBDFFB50021
1a2150: 21000A534E4443505F4374726C5F4861 07200A4CA047054A1278072A03D0082A
1a2160: 6E646C65584964496E642829202D2058 01D0FFF7E8FFFFBD251EE844422B024C
1a2170: 496420636F6C6C6973696F6E20646574 2147714424A8D4444D211C443522E844
Uputstva za izradu vlastitog patcha: KLIK
Zadnje izmijenjeno od: piroman007. 31.05.2008. u 12:32.
Staro 31.05.2008., 19:49   #1003
piroman007
Postovi: 20
Cool Otključavanje Sony Ericsson mobitela
Napomena: sve što radite, ratide na vlastitu odgovornost. Ovim postupkom gubite garanciju na uređaj!
Potrebno:
- SIM-Lock Patch Generator v2.1 (download)
- MAIN firmware kojim ste flashali svoj mobitel
Postupak:
1)Pokrenite SIM-Lock Patch Generator. Pod MAIN firmware stavite svoj main firmware sa kojim ste flashali mobitel. Ostala dva polja će se sama ispuniti. Kliknite Make patch.
2) Nakon što ste kliknuli Make patch, program će napraviti patch koji ćete otključat svoj mobitel za bilo koju karticu.Adresa gdje se patchalo piše u predzadnjem redu. Patch stavljate preko FAR-a ili GSlidea.
FAR tutorial
GSLide tutorial
3) Nakon što ste patchali mobitel restartajte ga i možete staviti bilo koju SIM karticu te bez problema ga pokrenuti.
Staro 01.06.2008., 00:05   #1004
hipi
Lokacija: nin
Postovi: 133
Autor piroman007 Pregled postova
jeli radi ovo i za cid 49
hipi je offline   Reply With Quote
Staro 01.06.2008., 10:54   #1005
piroman007
Postovi: 20
Re:
Da, moj frend ima cid49 i uspio je sredit
Staro 01.06.2008., 11:05   #1006
hipi
Lokacija: nin
Postovi: 133
da ali neki patch ne valja upalim mob i uvik je bilo sve zato sam i pitao nevidis nista nego sve bile boje svitli
Zadnje izmijenjeno od: hipi. 01.06.2008. u 11:29.
Staro 01.06.2008., 16:14   #1007
piroman007
Postovi: 20
Re:
Hmmm, a koji si patch instalirao zadnji? Zna biti problema sa patchom za radio.. Meni svi radi na cid36, na cid49 je taj radio zezao ali nakon brisanja i ponovnog stavljanja sve radi.
Staro 01.06.2008., 16:21   #1008
hipi
Lokacija: nin
Postovi: 133
budem probao bez njega pa javim inace sve sam ih stavio u gslide mislim ove stos i ti stavio kako ih je tvoj frend stavio u mob preko njega ili far menagera radi li ovaj patch
kako aktiviras da radi
Staro 02.06.2008., 19:37   #1009
Reedy
Reedy's Avatar
Postovi: 771
E, da ni meni ovo ne radi...
Reedy je offline   Reply With Quote
Staro 02.06.2008., 19:46   #1010
Reedy
Reedy's Avatar
Postovi: 771
Ja inače ubacujem patcheve sa se2tool
Staro 02.06.2008., 20:33   #1011
piroman007
Postovi: 20
Kako radi
Kako radi podešavanje jačine svjetlosti?
Vrlo jednostavno, moja greška što nisam napisao. Prvo trebate uključiti bljeskalicu preko gumba kamere (znači treba biti prvo instaliran patch w800_r1bc002_light_cambutton.vkp). Zatim treba otiću Walkman, i klikati + za jače, - za slabiju svjetlost. Pjesma ne treba biti pokrenuta.
P.S. meni SEtool nije baš šljakao. FAR sam skužio i baš sam si lijepo sredio mobitel
Staro 02.06.2008., 23:46   #1012
hipi
Lokacija: nin
Postovi: 133
far je super ali mi nece ucita mob odakle si ga ti skinija
Staro 03.06.2008., 17:47   #1013
piroman007
Postovi: 20
Staro 03.06.2008., 19:39   #1014
hipi
Lokacija: nin
Postovi: 133
moze pomoc sve san skuzija samo ovo ne kuzin kako misli NAPOMENA 1: Ako imate cid 49 onda morate sa Farom naći rest_W800_R1BC002.bin pa pritisnuti F5 pa copy i označiti Flash BABE ssw image i pritisnuti flash. Bez rest file-a mob se neće upalit.
kako da to napravim mislim s farom naci rest_...
ako mozete pomoci napisite sto prije hitno je
kako ga pronaci moze pomoc hitno je
Staro 04.06.2008., 20:22   #1015
hipi
Lokacija: nin
Postovi: 133
zna li tko sto o tom
Staro 04.06.2008., 20:34   #1016
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
Autor hipi Pregled postova
ako želiš flešati i modati mob onda probaj s xs-om ako te far zeza
http://rapidshare.com/files/73526795/XS3.1__.rar
MIUI HR Translator
MASVA je offline   Reply With Quote
Staro 04.06.2008., 21:47   #1017
piroman007
Postovi: 20
Ja sam prvo mobitel flashao po uputstvima od Crnog(početna stranica teme) pomoću XS++ (download). Nakon toga sam sve patcheve stavljao peko FAR-a.
Staro 04.06.2008., 22:23   #1018
hipi
Lokacija: nin
Postovi: 133
skuzija san sad far pribacin patcheve na mob ali ga onda ne mogu upalit jer triba nac faron ovo
ali neznan kako moze pomoc sve san skuzija osim tog sad mi ga ucita sve mi je bilo cudno zasto mi ga nece far ucita aja nisam s xs++ -om u mob ubacija neku datoteku i on mi ga nije moga nac mislim mob ako tko zna kako da to napravim neka ja vi sto prije ili jos bolje neka uslika i uploluda taj dio postupka bio bi i pre zahvalan
mob san flesa i moda toliko puta ali uvik s xs++ i sad san proba s faron jer mi na zivce ide uvik koristit gslide i oinda ponovo i xs s faron je sve duplo brze
Staro 05.06.2008., 12:30   #1019
piroman007
Postovi: 20
Jeis uopće flashao mob na w800i firmware?
Ako jesi onda downloadaj rest_W800_R1BC002.bin sa ovog linka: download
Odi u FAR datoteke i ubaci ga pod SEFP>Plugins>Patches i u ubaci rest_W800_R1BC002.bin. Nakon toga pokreni FAR i rtadi sve kao i kad stavljaš patcheve, samo umjesto patcha označiš rest_W800_R1BC002.bin i podigneš na mob.
Staro 05.06.2008., 16:39   #1020
hipi
Lokacija: nin
Postovi: 133
jesan odavno san fleshao mob
znaci oznacim i njega i patcheve koje zelim stavit na mob hvala na pomoci sve radi u redu
