#9661 |
Postovi: 8,526
Da, sad koriste situaciju na tržištu i u svijetu, ali budemo pričekali da vidimo finalne cijene, mada za ASUS ništa ne čudi da luduju sa svojim pizdarijama. ![]() ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#9662 |
Lokacija: Zd
Postovi: 4,757
#9664 |
Postovi: 8,526
Mislim da je čak i on komentiral da sad kad imaju LGA, više ništa ne stane ispod, pa su morali gore sa strane rasporediti ove sitne dijelove. ![]() Jedino kaj bude sigurno veselo kad svi živi natrpaju termalnu pastu na IHS, pa ode višak na sve strane. ![]() ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 17.08.2022. u 17:01. |
#9666 |
Datum registracije: Feb 2021
Lokacija: Sveti Petar
Postovi: 306
Bit će veselo kad ljudi naliče Liquid Metal po tome.... |
#9668 |
MadModerator
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Onaj tko bude stavljao tekući metal valjda zna malo više o kompovima pa će paziti. Plus što ne znam tko bi ga stavljao s gornje strane IHS-a umjesto ispod. 99% ljudi ionako nikad ne vadi van hladnjak, tako da nek se termalna pasta razlije koliko hoće, nit se vidi nit smeta.
#9669 |
Postovi: 7,701
Sa pastom MX-4 ili novi MX-5 neće imati štete po smd otpornicima. Koliko puta razlijevalo oko GPU i nije bilo štete. Nepotreban hypie/komentar i pljuvanje. Takav komentar smatram površnim i neiskusnim. Na žalost.
__________________ |
#9670 |
#erase startup-config
Postovi: 3,732
A koliko stvarno različite paste imaju utjecaja kada taj sloj nije ni pola milimetra debeo? Toga tamo treba samo da istisne zrak između proca i coolera, ništa drugo. |
#9671 |
Postovi: 8,526
Heavy Metal Steve bude imal osvrt na to po uzoru na dosadašnje situacije. ![]()
#9672 |
Lokacija: TRPI
Postovi: 456
Dizajn IHS-a AM5 procesora nije problem, netko tko ima iskustvo sa nanosenjem termalne paste, zna otprilike koliko je potrebno da se dobro rasporedi a da opet ne ide van IHS plocice. Laptopi kao i graficke kartice imaju direktni chip na koji se nanosi pasta i tu je slicna situacija, ali opet nije problem ako se stavi precizna kolicina na sredinu chipa. |
#9673 |
Postovi: 306
Postoje konduktivne paste i tekući metal. Ako googlate kako smanjiti temperaturu na procesoru postije stotine površno napravljenih videa o tekućem metalu i termalnim pastama kojima je samo cilj skupiti poglede. Netko neiskusan se lako može nagovoriti da ide radit nešto o čemu nema pojma. Ovaj AMD-ov dizajn daleko olakšava da si netko neiskusan uništi procesor. Pogledajte na engleskim tech support stranicama koliko si ljudi uništi laptop jer se idu petljat tamo gdje ne treba. |
#9674 |
Postovi: 8,526
#9675 |
Postovi: 3,732
Mi smo još u srednjoj koristili onu bijelu silikonsku termalnu mast između tranzistora i alu hladnjaka. Tranzistori su se šarafili za hladnjak i istisnuli bi skoro svu pastu sa strane. U IT-u su se prestale koristiti bijele silikonske termalne paste prije 20ak godina kako su se pojavili hladnjaci s bakrenom bazom jer su “navodno” te paste grizle bakar. Meni se čini da je to bio izgovor da se skuplje prodaju nove termalne paste. Nisam primjetio da mi je ikada išta nagrizlo bakar niti da su novije paste bile išta termalno bolje. Premalo toga ide između da bi imalo ikakav značajan utjecaj. Tko stavlja električki vodljive paste taj traži nevolju. CPU vuče desetke ampera struje. Neka tu negdje nastane kratki spoj…. |
#9677 | ||
Postovi: 7,701
Gotovo praktički krunu preuzeo A.MX-2 koju je bila bolja od Ceramique. Tako A. Silver i Ceramique davno otišle u povjest (u doba AMD mobilnih Bartona) Keramika je znala stvrdnuti i lako počupala CPU iz socketa A i 939 - sve do danas izgledaju jednak socket AM4 Sa ovim LGA socketima (isto kao AM5) nema šanse počupati. |
#9679 |
Prvoklasni Krkan
Postovi: 5,364
@Dottore: Ma pobrkao si, bijele silikonske se nisu stvrdnjavale i sušile (ovo sam doživio samo sa tvorničkim ''žvakama'' tj najgorim smećem) nego su bile nenormalno ljepljive i imale su efekt vakuma i zato je bilo teško odvojit kuler od proca pa si čupao sve van. Dogodilo mi se X puta. Čak bi se i nakon toga trebalo dobro potrudit odvojit proc od kulera. Na svu sreću nikad mi niš nije umrlo od toga. ![]() |
#9680 |
Lokacija: Zd
Postovi: 4,757
#9682 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,331
S obzirom da je napravljen u 2021 dobro i izgleda kolko je taj ruku prosao .
#9684 |
Freelancer
Postovi: 5,331
#9685 |
Lokacija: Zd
Postovi: 4,757
Zadnje izmijenjeno od: Sn4k3. 23.08.2022. u 15:29. |
#9686 | |
Postovi: 7,701
#9687 |
Postovi: 8,526
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 24.08.2022. u 19:36. |
#9688 |
Lokacija: Zd
Postovi: 4,757
#9689 | |
Datum registracije: May 2013
Lokacija: nigdje
Postovi: 599
Sve je to lipo samo koliko kWh energije troši? |
#9690 | ||||
Postovi: 8,526
Troši ugrubo duplo manje od konkurencije. ![]() Citiraj:
