#9421 |
Postovi: 8,512
Veli Lisa su da EYPC Milan-X Zen 3 sa sveukupno 800MB+ L3 cachea ima 50%+ porast u performansama u odnosu na "običan" EPYC Milan Zen 3. ![]()
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX |
#9422 |
Datum registracije: Aug 2020
Postovi: 899
I dionice su porasle oko 8%. |
#9423 |
Postovi: 899
I koliko sam razumio koristili su 6nm za cache? nadam se da će i memorijski kontroler migrirati s 12nm gloflo na 6/7nm TSMC pa da svaki primjerak može raditi na 2000 FCLK što će donjeti dodatan boost pored cachea. |
#9424 | |||
Postovi: 8,512
MCM CDNA 2 GPU na TSMC 6nm procesu sa 128GB HBM2e memorijom, dok je kakvih 2x do 4x brže od nVidia A100 rješenja. ![]() Citiraj:
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 08.11.2021. u 18:50. |
#9425 |
Postovi: 899
TSMC-ov 5nm omogućuje 2x density, 2x power efficiency i 1.28x performance, dobar boost samo od noda, plus promjene u arhitekturi. Zen 4 za desktop bi trebao u najmanju ruku biti ravnopravan sa Raptor Lake, plus naprednija verzija 3d cachea što će se najviše u gamingu osjetiti pa bi tu mogao i dominirati. |
#9426 | |
Postovi: 899
.edit: i btw dionice rastu kao lude haha. |
#9427 |
Postovi: 8,512
Super je kaj su već svi ovi najavljeni proizvodi zapravo već kod klijeneta na korištenju ili testiranju. Sve u svemu nije loše, TSMC 6nm za GPU i 5nm za CPU komponente. ![]()
#9428 |
Datum registracije: Apr 2017
Postovi: 343
AMD Ryzen Desktop CPU Rumors: Zen 2 ‘Renoir X’ To Tackle Intel Core i3, Zen 3 ‘Vermeer X’ To Tackle Alder Lake, Zen 4 ‘Raphael’ To Tackle Raptor Lake, X670 & B650 Motherboards To Feature PCIe Gen 5 Support Link: https://wccftech.com/amd-ryzen-deskt...e-raptor-lake/ |
#9430 | |
Postovi: 343
Nije do yieldova, nego neka čudna strategija AMD-a, s obzirom da nemaju ili ne očigledno ne namjeravaju izbaciti 4-core proc sa ZEN3 jezgrom... idu protiv nadolazećeg AlderLakea i3 sa Renoirom bez IGP.a tj. bez grafike. Da je čudan potez.. je, i to nemalo. Vjerojatno tj. sigurno će bit monolitni čip malih dimenzija i jeftin, a dovoljno nabrijan sa clockom da se može kako-tako nositi sa i3-AL. Da su htjeli mogli su maknuti dvije jezgre i IGP sa R5-5600G, ali ko zna što je pozadina svega.. možda će to ići za OEM only i AIO desktope? |
#9431 |
Postovi: 8,512
Uopće se postavlja pitanje zbog čega Intel u 2021. na pragu 2022. izdaje quad-core Core i3 i dual-core Pentium modele bazirane na Alder Lakeu. Tak da po tom ključu nema razloga da AMD izda ikaj bolje od prepakiranih Zen 2 mobilnih APU-a kojih imaju na bacanje. Osim toga, kad stigne 5nm Zen 4, postojeći 7nm Zen 2 i 3 modeli budu se još jedno dulje vrijeme proizvodili i prodavali. Obzirom na situaciju unatrag skoro dvije godine, prodaje se apsolutno sve, a rijetko tko više i pita za cijenu.
#9432 | |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Stoji, iako je odgovor na neka pitanja jednostavan - postoji segment jeftinih laptopa i desktopa kojima još ne treba ništa više od quada. Na poslu imam Ryzen 3500 mobile quad (znači 4/8 Zen+) i to radi bez greške, još ga nisam uspio preopteretiti u uredskom radu (danas sam enkodirao video dok sam držao prezentaciju u Teamsima plus 10 otvorenih tabova i još jedan program). Tako da to razumijem, manje jezgri=manji die=jeftinija proizvodnja. Ono što ne razumijem je zašto ne ići na Zen 3 jezgre. Pretpostavka je da košta jednako kao i Zen 2 jezgra, a čisto je bolja. Postoje Zen 3 APU isto kao i Zen 2, jednako je kompleksno smanjiti i jednog i drugog iz postojećih proizvoda. |
#9433 |
Postovi: 8,512
Nažalost, jednostavan odgovor na to pitanje je, zato jer mogu, šteta im je iskoristiti Zen 3 za takve izlete, jer ga još uvijek mogu naplatiti više, mada sama proizvodnja košta isto ko Zen 2. Kaj se quad-core rješenja tiče, kod mene je također poslovni laptop upogonjen jednim takvim mobilnim Intel rješenjem i sve radi kak spada, čak se i dvije virtualne mašine istovremeno mogu pokrenuti.
#9434 |
Prvoklasni Krkan
Postovi: 5,361
Što se tiče izdavnaja 4-ero jezgrenih procova, treba se upitati i zašto AMD ne nudi neki pandan inetlovim xx400 6-ero jezgrašima? Nešto za kilu kuna. |
#9435 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,007
Valjda računaju da je 2600X i dalje OK |
#9436 |
Postovi: 8,512
Ryzen 5 3600 je svojevremeno koliko-toliko poslužil kao konkurencija za Core i5-10400 modele, ali nažalost R5 3600 današnje cijene nemaju veze sa zdravim razumom.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x4TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750 AMD Ryzen 5 7600 | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x12TB WD Red Plus | Fractal Define 7 Compact | eVGA 650 B5 AMD Ryzen 5 7600 | Scythe Kotetsu SCKTT-1000 | MSI MAG B650 Tomahawk Wi-Fi | 64GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 2x14TB WD Red Pro | Fractal Define 7 Compact | Seasonic SSR-550PX Zadnje izmijenjeno od: The Exiled. 02.12.2021. u 16:25. |
#9437 | |
Prvoklasni Krkan
Postovi: 5,361
Nemoj zaboravit da je to najgori bin i da su im all core taktovi dosta niski (u prosjeku većina je na 3,8-3,9 kad ih se malo upregne), zanemari rivjuere koji dobivaju cherrypickane primjerke. ![]() |
#9438 |
Postovi: 8,512
Ma krivo sam napisal, a linkal sam Core i5-10400 recenziju vezano za ovo kaj segregator priča, jer tak jasno da Zen 2 modeli nemaju šanse sa Core i5-12400. Tu jedino ulazi R5 5600X, ako ikad spuste cijenu.
#9439 |
Postovi: 14,589
Nema se tu što reći, sad AMD mora reagirati. Ili izbaciti nešto bolje po trenutnim cijenama ili drastično skinuti cijenu postojećim Što se tiče quadova, još uvijek ima koristi od istih u office mašinama. Na htpc uz tv imam 2c4t tj. i5 4570T uz klasičan hdd. Koristim za netflix i browser i za to još gura, ali to postaje neki limit upotrebe, quad mora ostati minimum, poželjno sa SMT/HT. Vidi se da se malo kilavi, ne ne znam dali je sve do cpu-a, nešto je vjerojatno i do hdd-a |
#9440 |
Postovi: 8,512
Da fora bude bolja, AMD već ima Zen 3 quad-core u vidu 5300G, ali su rezervirani za OEM ekipu. Samo jebiga, zahvaljujući situaciji koja eto ulazi u svoju drugu godinu, nema tog očekivanog spuštanja cijena. Tak jasno da je običan R5 5600 za ~1.000 kn i više nego super, isto ko i quad-core verzija istog čipa samo da mu srežu dvije jezgre i lupe cijenu od 750 kn, ali jedno su želje, dok ovo ludilo ne posustaje. Eto ga, Core i3-12100 se uspoređuje s dvije godine starim Zen 2 quad-core R3 3300X modelima, dok nVidia izdaje prepakiranu RTX 2060 12GB koja neće stići na tržište, a već bude nestala u kritpo rudnicima. I to je nažalost realnost. Izađe Alder Lake i kaj se desilo, ama baš ništa, jer AMD službeno nije dirnul cijene, a ove BF i CM akcije za kraj godine su tragikomične.
#9441 | |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,165
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#9442 | ||
Postovi: 8,512
Dakle službeno je, Intel CEO sere kvake kao nitko prije njega, a bilo je bisera samo takvih. Jao, frajer umjesto da šuti, on na dnevnoj bazi daje izjave koje su sve hit do hita. ![]() ![]() Pričanje u prvom licu, dok ga se pita za Intel kao firmu bolje da i ne spominjem. Na kraju budu postali fabless, a u međuvremenu još uspiju i TSMC suradnju sjebati. Onda bude nismo znali, ipak smo mi najveći i najbolji, rekordne zarade dok otkupljujemo vlastite dionice i tome slične pizdarije. Citiraj:
#9443 |
Postovi: 343
AMD CES 2022 Event to Highlight Ryzen 3D V-Cache, Radeon Updates Link: https://www.tomshardware.com/news/am...radeon-keynote |
#9444 | |
Postovi: 8,512
AMD to briefly talk about Zen 4 at CES 2022 ![]() Citiraj:
#9445 | |
Postovi: 899
#9446 |
Postovi: 8,512
Da, ali mogli bi komotno 3D cache složiti za cijelu Zen 4 ponudu odjednom i to je to. Ionak su rekli da je 3D cache orginalno planiran za Zen 2, pa nije prošlo, a sad ide s ovim Zen 3 modelima. Onda nek bude sastavni dio svih Zen 4 modela i voljno. Pogotovo, ako slože i RDNA 2 iGPU za sve modele.
#9447 |
Postovi: 343
AMD Ryzen 9 6900HX ‘Rembrandt’ APU Specs Leak Out: 8 Enhanced 6nm Zen 3 Cores, 20 MB Cache, 4.6 GHz Boost & Radeon 680M ‘RDNA 2’ Integrated Graphics Link: https://wccftech.com/amd-ryzen-9-690...ated-graphics/ AMD Next-Gen Ryzen 7000 Raphael ‘Zen 4’ CPU Rumors: Computex Announcement, X670 Flagship Chipset With DDR5 & PCIe 5 Support, RDNA 2 iGPU Link: https://wccftech.com/amd-next-gen-ry...t-rdna-2-igpu/ |
#9448 |
Prvoklasni Krkan
Postovi: 5,361
Uf, ako se pokaže istinitim to da će od sada i svaki AMD proc imat igpu, to će biti fantastično. Pa kakva god da je ta RDNA2 igpu, bit će bolja od ničeg u ovo debilno vrijeme kada grafe koštaju ko mali auto. |
#9449 |
Postovi: 8,512
RDNA 2 iGPU bi se po pitanju performansi mogla smjestiti iznad desktop verzije GTX 1050 Ti modela. ![]()
#9450 |
Prvoklasni Krkan
Postovi: 5,361
